Extended coolant for PT36
03-22-2008, 14:57
Hi group,
I plan on replacing my coolant with the green extended coolant sold by truck dealers. This doesn't require a 50/50 mix so was wondering about having to check with test strips since not a mixture with water. Just fill it to the brim and go? Bob Lawrence 84 P36 Presently in Boulder City Nv till 1st of month then heading east on 40. |
03-22-2008, 15:15
Only if it is pre-charged with SCA's. That's what you are testing for.
R.E. Marabito, Dallas, TX, 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi group, > > I plan on replacing my coolant with the green extended coolant sold by > truck dealers. > This doesn't require a 50/50 mix so was wondering about having to check > with test strips since not a mixture with water. > Just fill it to the brim and go? > > Bob Lawrence > 84 P36 > Presently in Boulder City Nv till 1st of month then heading east on 40. > |
03-22-2008, 15:16
Extended coolant that doesn't require mixing with water means it already IS
mixed with water, normally 50/50. Doesn't matter whether it is Red or Green, concentrated (you mix with water), or pre-mix, it's functionally the same as long as it meets the ratings. You want to see TMC RP329, generaly, for a Detroit. I use Zerex Extended Life, bought in concentrate and then mixed with distilled water. I wouldn't mind if it was Ready-to-use (which Zerex makes), but my local source doesn't carry it that way. On 3/23/2008 at 1:57 AM Bob Lawrence wrote: >Hi group, > >I plan on replacing my coolant with the green extended coolant sold by >truck dealers. >This doesn't require a 50/50 mix so was wondering about having to check >with test strips since not a mixture with water. >Just fill it to the brim and go? > >Bob Lawrence >84 P36 >Presently in Boulder City Nv till 1st of month then heading east on 40. > > > >------------------------------------ > >Yahoo! Groups Links > > > |
03-23-2008, 10:35
Thanks for the replies. We be getting the premix. Should work ok.
Bob --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Extended coolant that doesn't require mixing with water means it already IS mixed with water, normally 50/50. > > Doesn't matter whether it is Red or Green, concentrated (you mix with water), or pre-mix, it's functionally the same as long as it meets the ratings. You want to see TMC RP329, generaly, for a Detroit. > > I use Zerex Extended Life, bought in concentrate and then mixed with distilled water. I wouldn't mind if it was Ready-to-use (which Zerex makes), but my local source doesn't carry it that way. > > On 3/23/2008 at 1:57 AM Bob Lawrence wrote: > > >Hi group, > > > >I plan on replacing my coolant with the green extended coolant sold by > >truck dealers. > >This doesn't require a 50/50 mix so was wondering about having to check > >with test strips since not a mixture with water. > >Just fill it to the brim and go? > > > >Bob Lawrence > >84 P36 > >Presently in Boulder City Nv till 1st of month then heading east on 40. > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > > > > > |
