PT36 suspension problems.
04-04-2008, 03:46
My '85 PT36 rides 4 to 6 inches higher in the rear than it should.
This is on both sides. That would seem to eliminate the levelers,
unless they both have the same problem.
The suspension takes about a day to bleed down. The suspension dump
works normally.
Any idea of what could be the problem?
Art Weatherly
Riverside Ca.
'85 PT36
04-04-2008, 04:35
--- In WanderlodgeForum@yahoogroups.com, "amweath"
So Art when you measure the rear end it is 22 in hight instead of
17 in.How hi is the front it should be 17in also.
Bob Loomas 1985 PT 36
> works normally.
> Art Weatherly
> Riverside Ca.
> '85 PT36
04-04-2008, 09:53
The reason I say its high is because of the large clearence between
the tire top and the top of the wheel opening or wheel well, 5 or 6
inches. The front is normal.
Art Weatherly
Riverside Ca
'85 PT36
--- In WanderlodgeForum@yahoogroups.com, "robert nloomas"
dump
> > works normally.
> > Art Weatherly
> > Riverside Ca.
> > '85 PT36
04-04-2008, 13:59
Art,
That sounds normal to me with the tag aired up. As I recall, the
early 80s all had a little bit of a rake to them (the rear is higher
than the front) with suspension fully aired up. You need to look in
your Blue Box for the ride height specs on your year/model and where
to measure it at.
1991 WB40 "Texas Minivan"
> Art Weatherly
> Riverside Ca
> '85 PT36
> dump
> > > works normally.
> > > Art Weatherly
> > > Riverside Ca.
> > > '85 PT36
04-04-2008, 20:28
My 83 has the "rake" also. Rides great, though.
83PT40
Livingston, Montana
currently in Weatherford, Tx
Planning your summer road trip? Check out AOL Travel Guides.
