Headlight switch 89 SP 36'
04-09-2008, 01:42
Hi Guys
I got a problem with my headlight switch. It is a split toggle switch. The headlights work but the dash lights parking lights & the tail lights do not work.The fuse is good for them. Is there a relay for them & where is it. The switch has power & the grounds are good. I have break lights & turn signals. The taillights & dash lights do not come on when you turn the headlights. Don Spithaler 89 SP 36' Butler, PA Just got home from another good trip to FL. |
04-09-2008, 06:20
The headlight switch you describe sounds just like the one I have. They are notoriously "weak". You probably just need a new switch.
As a temporary work around, I hooked a toggle switch to ground the relays for the non-working lights and that solved the problem until I could install a new headlight switch. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Apr 9, 2008, at 6:42 AM, Donald Spithaler wrote:
04-09-2008, 09:04
Thanks Pete
I opened up my dash & it is a Delco Remy. Do you remember if is that is what you have Don Spithaler 89 SP 36' Butler, PA On Wed, Apr 9, 2008 at 2:20 PM, Pete Masterson > > > > > > > The headlight switch you describe sounds just like the one I have. They are > notoriously "weak". You probably just need a new switch. > > As a temporary work around, I hooked a toggle switch to ground the relays > for the non-working lights and that solved the problem until I could install > a new headlight switch. > > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > > On Apr 9, 2008, at 6:42 AM, Donald Spithaler wrote: > > Hi Guys > > I got a problem with my headlight switch. It is a split toggle > switch. The headlights work but the dash lights parking lights & the > tail lights do not work.The fuse is good for them. Is there a relay > for them & where is it. The switch has power & the grounds are good. I > have break lights & turn signals. The taillights & dash lights do not > come on when you turn the > headlights. > Don Spithaler > 89 SP 36' > > |
04-09-2008, 09:59
Not sure.... BB Parts has 'em, I think.
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Apr 9, 2008, at 2:04 PM, Donald Spithaler wrote:
04-09-2008, 10:11
Give parts a call in the AM I will look into it. 951 836 6520 thanks. Chris
Sent from my Verizon Wireless BlackBerry -----Original Message----- From: Pete Masterson Date: Wed, 9 Apr 2008 14:59:29 To:WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Headlight switch 89 SP 36' Not sure.... BB Parts has 'em, I think. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@mac. On Apr 9, 2008, at 2:04 PM, Donald Spithaler wrote: Thanks Pete   I opened up my dash & it is a Delco Remy. Do you remember if is that is what you have Don Spithaler 89 SP 36' Butler, PA On Wed, Apr 9, 2008 at 2:20 PM, Pete Masterson  The headlight switch you describe sounds just like the one I have. They are notoriously "weak". You probably just need a new switch. |
