faulty transmission temp. reading
05-21-2005, 03:13
Last year while on a trip my transmission temp suddenly went to 300
degrees. I immediatley stopped and checked it out and determined that the temp was in the normal range around 170. The gage stayed at 300 degrees the rest of the trip. I ordered a new gage from BB and installed it. After that the temp would go to 250 degrees and stay in that area. Again I assured myself that the temp was in fact normal 170.Thinking that it could be a bad sending unit in the transmission, I changed it this week when I had the pan off. I started the coach up and the transmission temp. went to 230-260 in about 5 minutes. again I assured myself that temp was in fact normal about 95 degrees just idling. I rigged up my old gage under the coach at the sending unit using different wire from sending unit, new ground wire and a hot wire from the battery. It seemed to give a normal reading at this point. What do you suspect the problem to be? bad ground at the dash? bad wire from the sending unit? Any suggestions would be welcome. Thanks Bob 93pt Illinois |
05-21-2005, 03:43
Bob this would be a good example of where an IR Thermometer would come in
handy. Original Message: ----------------- From: Bob & Carol Howald` rhowald@... Date: Sat, 21 May 2005 15:13:27 -0000 To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] faulty transmission temp. reading  Last year while on a trip my transmission temp suddenly went to 300 degrees. I immediatley stopped and checked it out and determined that the temp was in the normal range around 170. The gage stayed at 300 degrees the rest of the trip. I ordered a new gage from BB and installed it. After that the temp would go to 250 degrees and stay in that area. Again I assured myself that the temp was in fact normal 170.Thinking that it could be a bad sending unit in the transmission, I changed it this week when I had the pan off. I started the coach up and the transmission temp. went to 230-260 in about 5 minutes. again I assured myself that temp was in fact normal about 95 degrees just idling. I rigged up my old gage under the coach at the sending unit using different wire from sending unit, new ground wire and a hot wire from the battery. It seemed to give a normal reading at this point. What do you suspect the problem to be? bad ground at the dash? bad wire from the sending unit? Any suggestions would be welcome. Thanks Bob 93pt Illinois <!-- |**|begin egp html banner|**| --> Yahoo! Groups Links
<!-- |**|end egp html banner|**| --> -------------------------------------------------------------------- mail2web - Check your email from the web at http://mail2web.com/ . |
05-21-2005, 03:52
Bob,
The way I was taught to do a quick check of a temp system was to ground the wire from the gage at the sensor. With it grounded, the gage should read full scale high. With no connection, it should read full scale low. With the indication you have, I would hazard a guess that you have a high resistance short to ground in the wire some place. Might be easier to run a new wire than to try to find the short. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Bob & Carol Howald` wrote: > Last year while on a trip my transmission temp suddenly went to 300 > degrees. I immediatley stopped and checked it out and determined that > the temp was in the normal range around 170. The gage stayed at 300 > degrees the rest of the trip. I ordered a new gage from BB and > installed it. After that the temp would go to 250 degrees and stay in > that area. Again I assured myself that the temp was in fact normal > 170.Thinking that it could be a bad sending unit in the transmission, I > changed it this week when I had the pan off. I started the coach up and > the transmission temp. went to 230-260 in about 5 minutes. again I > assured myself that temp was in fact normal about 95 degrees just > idling. I rigged up my old gage under the coach at the sending unit > using different wire from sending unit, new ground wire and a hot wire > from the battery. It seemed to give a normal reading at this point. > What do you suspect the problem to be? bad ground at the dash? bad wire > from the sending unit? Any suggestions would be welcome. Thanks Bob > 93pt Illinois > > > > > > > Yahoo! Groups Links > > > > > > > > > |
05-21-2005, 04:10
--- In WanderlodgeForum@yahoogroups.com, "rrob@t..."
wrote: > Bob this would be a good example of where an IR Thermometer would come in > handy. > Rob: That's how I was assuring myself that the temp's were OK. Great piece of equiptment. Bob 93pt > Original Message: > ----------------- > From: Bob & Carol Howald` rhowald@b... > Date: Sat, 21 May 2005 15:13:27 -0000 > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] faulty transmission temp. reading > > > > > > > Â Last year while on a trip my transmission temp suddenly went to 300 > degrees. I immediatley stopped and checked it out and determined that > the temp was in the normal range around 170. The gage stayed at 300 > degrees the rest of the trip. I ordered a new gage from BB and > installed it. After that the temp would go to 250 degrees and stay in > that area. Again I assured myself that the temp was in fact normal > 170.Thinking that it could be a bad sending unit in the transmission, I > changed it this week when I had the pan off. I started the coach up and > the transmission temp. went to 230-260 in about 5 minutes. again I > assured myself that temp was in fact normal about 95 degrees just > idling. I rigged up my old gage under the coach at the sending unit > using different wire from sending unit, new ground wire and a hot wire > from the battery. It seemed to give a normal reading at this point. > What do you suspect the problem to be? bad ground at the dash? bad wire > from the sending unit? Any suggestions would be welcome. Thanks Bob > 93pt Illinois > > > > > > > > <!-- |**|begin egp html banner|**| --> > > > > Yahoo! Groups Links >
> > > <!-- |**|end egp html banner|**| --> > > > > > > > -------------------------------------------------------------------- > mail2web - Check your email from the web at > http://mail2web.com/ . |
05-21-2005, 05:07
Hey,Let me try an answer,
We are in our second year of ownership, Maybe we are sophomores?? We have learned a little about our 88 FC. This suggestion may help and contribute for our many silly first year questions. I am not an expert gage person, But we ordered a Teleflex oil temp gage from BlueBird. After replacing the gage the temp read 250/ 300 degrees. In talking to Teleflex, we discovered that the original gage is no longer available. The replacement gage also requires the replacement of the temp sensor probe, to match the latest gage. The original BB gage and the replacement gage carry the same BB part number, but it was not the same gage. After replacing the defective gage and later the sensor all readings are normal. If you want a part number, I can dig it up from the pile of notes and receipts, we have collected. Bill 88 FC Michigan Still learning - In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > Last year while on a trip my transmission temp suddenly went to 300 > degrees. I immediatley stopped and checked it out and determined that > the temp was in the normal range around 170. The gage stayed at 300 > degrees the rest of the trip. I ordered a new gage from BB and > installed it. After that the temp would go to 250 degrees and stay in > that area. Again I assured myself that the temp was in fact normal > 170.Thinking that it could be a bad sending unit in the transmission, I > changed it this week when I had the pan off. I started the coach up and > the transmission temp. went to 230-260 in about 5 minutes. again I > assured myself that temp was in fact normal about 95 degrees just > idling. I rigged up my old gage under the coach at the sending unit > using different wire from sending unit, new ground wire and a hot wire > from the battery. It seemed to give a normal reading at this point. > What do you suspect the problem to be? bad ground at the dash? bad wire > from the sending unit? Any suggestions would be welcome. Thanks Bob > 93pt Illinois |
05-21-2005, 06:34
Bill: That's what I've been thinking. I've called parts and asked
questions about matching the gage with the sending unit. They have assured me that I have the matched pair. The old gage said transmission temp. on it but this new one say's engine oil temp and is calibrated differently on the face. BB say's this is the only temp gage avilable for the tranny. Iam going to do more looking into it the first of next week. Send your part # please.. Thanks for the info.. Bob 93pt Ill. |
05-22-2005, 05:15
Hi Bob,
On our 88FC, we have the ZF transmission. The ZF Trans.temp gage is very different from the engine oil temp gage and the rear axle temp gage. I do not know if these part numbers will solve the problem you are having with your 1993 Transmission gage. I went through this same discussion with the BB parts people.I even purchased a Napa temp sensor for the rear axle, based on the supplier part number, that BB used in 1988. Again we had the very high temp readings of 250 to 300 degrees. So, I contacted Teleflex, They have a great web site at http://www.tflx.com. The gages and sensors are listed. They have a tech trouble-shooting guide that makes it easy to isolate the problem. It is a simple circiut to trace. There is also an issue with the tread size of the sensors, therefore Teleflex lists four different sensors 1/8, 1/4, 3/8, or 1/2 inch diameter. These part numbers are for the Cat, the Onan and rear axle oil temp. BB oil temp gage # 3865334 crosses over to Teleflex # 9153278 The gage supplied by BB is different than the original gage, but carries the same part number. The latest gage has a different scale on the face that requires a sensor change to match the impedance. Teleflex recommended that, I purchase a Stewart-Warner sensor to match the gage. The Stewart-Warner part # is 280EE-F. It comes with three threaded inserts to fit all thread sizes. After installing the Stewart Warner sensor, The BB/Teleflex gages reads normal. It was difficult to find a Teleflex dealer, I purchase gages from BB, the price is reasonable. The Stewart-Warner sensor was purchased from a truck parts store. (e-mail if you need this phone number, they will ship UPS) West Marine and Boaters World carry some Teleflex items. Now, our rear axle temp, oil temps, and oil pressures on both the Cat and the Onan read correctly. We like the scaling of the original old gage to better read the much lower axle temp Hope this helps, Bill 88 FC, Love the upgrade to an FC, 7.4 mpg last 3500 miles with little Onan time. --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > Bill: That's what I've been thinking. I've called parts and asked > questions about matching the gage with the sending unit. They have > assured me that I have the matched pair. The old gage said transmission > temp. on it but this new one say's engine oil temp and is calibrated > differently on the face. BB say's this is the only temp gage avilable > for the tranny. Iam going to do more looking into it the first of next > week. Send your part # please.. Thanks for the info.. Bob 93pt Ill. |
