300 Amp delco remy alternator
04-13-2008, 04:20
Fred,
Really good stuff! Do you have information on the part numbers for
the seal kit?
I took the liberty of adding your post as a File for future reference,
in case you get follow-up inquiries.
Thanks,
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote:
> Morning David
> To remove the belt,there is a idler pulley in the center of the
engine with an adjustment bolt (about 8 inches long) above at an
angle.Loosen this bolt about two inches allowing the pulley to move
away from the belt and you can remove the belt.
> The alternator pulley is removed with a 33mm socket.(1 3/8 may be
close) A 1/2 air gun with 100 psi will get it off, but don't "rattle
on it" for much longer than 10 seconds at a time.
> Once the nut is off the pulley will slip off easily as it is a
splined armature shaft.You will now see the seal plate held on with 6
bolts,remove the bolts and the seal plate will come off revealing the
front bearing. Now remove the seal collar still on the shaft and an o
ring.Scrape the seal plate gasket off the alternator housing.Change
the seal on the plate being careful to press the seal in properly,if
the seal surface is dry apply a thin coat of grease an the
lip.Reassemble the oring ,seal collar and seal plate and pulley,
washer and nut,then the belt and re-adjust with the idler pulley with
the long adjusting bolt and you have now saved a lot of time and money.
> Also I have a seal, gasket and o-ring kit available if you need it.
> Fred & Jeanne Hulse
> Morristown,Arizona
> 1997 Wanderlodge WB41
04-13-2008, 06:33
Thanks Fred,
That's great info; you saved me a bunch of bucks. Thanks for the offer
on the seal kit, but I'm going to get a few more parts from Elreg;
besides,
you may want to keep that kit as a backup.
Mike, Elreg has parts. It appears that the seal is part number 402-1407
at: http://www.elreg.com/category/83.aspx
David Brady
'02 LXi, NC
Fred Hulse wrote:
Morning David
pulley in the center of the engine with an adjustment bolt (about 8
inches long) aboveat an angle.Loosen this bolt about two inches
allowing the pulley to move away from the belt and you can remove the
belt.
with a 33mm socket.(1 3/8 may be close) A 1/2 air gun with 100 psi will
get it off, but don't "rattle on it" for much longer than 10 seconds at
a time.
slip off easily as it is a splined armature shaft.You will now see the
seal plate held on with 6 bolts,remove the bolts and the seal plate
will come off revealing the front bearing. Now remove the sealcollar
still on the shaft and an o ring.Scrape the seal plate gasket off the
alternator housing.Change the seal on the plate being careful to press
the seal in properly,if the seal surface is dry apply a thin coat of
grease an the lip.Reassemble the oring ,seal collar and seal plate and
pulley, washer andnut,then the belt and re-adjust with theidler
pulley with the long adjusting bolt and you have now saved a lot of
time and money.
Fred & Jeanne Hulse
Morristown,Arizona
Checked by AVG. Version: 7.5.519 / Virus Database: 269.22.13/1375 - Release Date: 4/12/2008 11:32 AM
04-13-2008, 06:41
Actually part no: 402-1410 has all the parts that Fred describes.
David Brady
'02 LXi, NC
David Brady wrote:
Thanks Fred,
besides,
David Brady
'02 LXi, NC
Fred Hulse wrote:
Morning David
idler
belt.
a time.
will
time and money.
Fred & Jeanne Hulse
Morristown,Arizona
04-13-2008, 10:12
Hi Mike
I have Delco Remy part numbers at the house,but we are out in the coach for a few days,but I will get the numbers when I get home thursday.
I got my pieces from a rebuilder in Phoenix through the local NAPA store,but he used Delco numbers.
Thanks for adding the post to the files.
Fred & Jeanne Hulse
Morristown,Arizona
