WEIGHT PULLED BY 3208NA POWERED FC35 'BIRD
05-21-2005, 03:41
What is the heaviest weight vehicle, tandem axle trailer or,
trailer/vehicle combination that you have pulled successfully with a 3208NA powered 35 foot FC model 'Bird. I want just actual experiences, not estimates. In what type of terrain have you pulled this combination? I know that it will be slow crawling up the steep grades and I'm not concerned with that. My main concern is what extra weight the power train on my FC35RB 'Bird, that weighs 31560# by itself when loaded, can handle. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA |
05-21-2005, 04:05
I pulled about 7,000lbs of car on open trailer behind my '77 with
5.29:1 gears. I had changed injector pump/timing/nozzles for a little more power also. The combination probably weighed only a little more than your '82 FC35, and it was a lot of work to keep up with granny even in rolling terrain. It pulled okay on the flat, but climbing and accelerating was painfully slow. Also without a retarder, I had to descend grades VERY slowly as the engine braking in higher gears wouldn't hold the coach's speed, usually 2nd gear. An added US Gear exhaust brake was little help, about as much braking as the Jacobs electric retarder set to "1", possibly less. I didn't have a transmission temp gauge, so I don't know how that was, but engine temp seemed to maintain 200-210 okay on long climbs. The '82 is the lowest power/weight ratio FC. It will pull most anything but it is slow. At least re-line your brakes if you're going to consider this. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "John" wrote: > What is the heaviest weight vehicle, tandem axle trailer or, > trailer/vehicle combination that you have pulled successfully with a > 3208NA powered 35 foot FC model 'Bird. I want just actual > experiences, not estimates. > > In what type of terrain have you pulled this combination? I know that > it will be slow crawling up the steep grades and I'm not concerned > with that. > > My main concern is what extra weight the power train on my > FC35RB 'Bird, that weighs 31560# by itself when loaded, can handle. > > > "REMEMBER SEPTEMBER 11, 2001" > John Finn > '82 35FCRB > BLUEBIRD WANDERLODGE > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > GO TO; > http://www.pbase.com/image/24977457 > '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" > SEE THE OLD COACH AT: > http://www.pbase.com/image/26052733 > HOPKINS, SOUTH CAROLINA |
