recall
04-16-2008, 02:15
recall
Has anyone out there had their recall work done with the generator
moved from the front to the rear bay? Jerry Smith 2005 450 LXI Sarasota, Fl. |
04-16-2008, 03:23
recall
I was at Ft. Valley just prior to Maxton. They were in the middle of one genset move to the left rear bay, in front of the drive axle.
Alan Barbee said that the genset would only be moved if the unit was overweight after all other remedies were tried first.
The old genset compartment would be available to open storage of items up to a max of 150#. This would not be an enclosed space.
Mike
'97 BMC 40'
Michael Brody
P.O. Box 281 Dresher, Pennsylvania 19025 (V) 215-572-0663
(F) 215-572-6992 |
04-16-2008, 04:06
recall
04-16-2008, 15:29
recall
I guess this begs the question, what does moving the generator do to the rear axle weight, especially on the side that the genny is mounted? I sure wish that 450 owners would be more vocal in what changes are being made to their coaches to satisfy the front axle recall, or any other recall. This info is of great interest to those of us considering purchasing a 450. Thanks, David Brady '02 LXi, NC JERRY SMITH wrote:
04-17-2008, 07:48
recall
04-17-2008, 08:16
recall
04-17-2008, 08:49
recall
04-17-2008, 08:58
recall
Hi Jerry, Thanks for your input. I don't mean to single you out regarding the lack of info, and I very much appreciate whatever light you can shed on the modifications. Is it possible to post the pictures somewhere for us to see? Thanks, David Brady, (who's growing family may require more slides) '02 LXi, NC JERRY SMITH wrote:
04-17-2008, 11:53
recall
Thanks Jerry, Looks like a professional job, nicely mounted in a sound box. It appears that the generator is in the 3rd bay from the front on the driver's side. Is this true? That would put the weight right at the center of the wheelbase distributing the generator's weight evenly between the steer and drive axles. David '02 LXi, NC JERRY SMITH wrote:
04-18-2008, 01:33
recall
