93 PT-40 for sale in Nashville
04-24-2008, 02:56
Post: #41
Maury,
It is ok to mix the two fuels. You can buy B5 or B20 in most
states now. What I do is start out B100 and only buy enough fuel to
get me home with a safe margin of error. If I am travelling into a
cold climate, I top off at the end of the day so I start changing my
percentages which will lower my gel point. I only do this because my
aquahot system will not pass fuel till after lunch on cold mornings (
less than 50 degrees ) and I like taking hot showers. If it were not
for this, I could safely go down in the upper 30's without worry. I
live in the deep south so most of my travel does not require this. I
am also not retired so many times I am taking 3 or 4 day trips
centered around the weekend. I wanted to attend this weeks rally
with the lonestar group but they only met during the week so I will
try to make the next one.
Al Johnson
'96 BMC B100
Mandeville, Louisiana
--- In WanderlodgeForum@yahoogroups.com, "M.L. Perkinson"
<mp222116@...> wrote:
> Al, I have wondered since your first mention of this fuel if you
take a long trip- where do you supplement it or can you use regular
fuel as needed also? Maury 80 FC 31'
> From: Al
> Sent: Wednesday, April 23, 2008 10:40 PM
> Subject: [WanderlodgeForum] Re: 93 PT-40 for sale in Nashville
> I am using a Biopro 380 now so the system is very compact. It
uses
> an acid / base process and utilizes a water wash / dry process.
The
> system is totally automated and requires about 30 min a day of my
> time now. I am trying to put together a commercial biodiesel
plant
> now doing all the studies and will be looking for investors soon
to
> get it rolling by end of the year. Government incentives thru
2015
> so the numbers look good. I am ready to take my hobby to the next
> level if I can get all the stars to line up.
> As far as glycerin, I am stock piling it now. It can be used to
> produce soap, make compost, engine cleaner, burned in incinator
> weed killer. Research is being done now and they hope to develop
a
> process to utilize for making ethanol. I am really excited about
> that. Currently the market has so much of it that it is priced
very
> low. As a hobbist, I don't produce enough that a commercial buyer
> would want.
> Al Johnson
> '96 BMC B100
> --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert
> > Recently, I have been reading about how to manufacture it, and
I
> have read your previous posts. Unfortunately, I do not have an
area
> to produce the product at this moment. What do you do with the by
> product, glycerin, I think? And do you water wash the product
before
> you use it?
> > Leroy Eckert
> > 1990 WB-40 Smoke N Mirrors
> > Dahlonega, GA
> > Royale Conversion
> > Al wrote: Leroy,
> > You can make your own biodiesel for about $1 a gallon. My
> average
> > cost per gallon since '05 is about 0.69.
> > Al Johnson
> > '96 BMC B100
> > wrote:
> > > Ok Mike you have set forth your history of use without
problems.
> I
> > think I will try it. Lets call them and see if they can mass
> produce
> > synthetic diesel at about $2 per gallon. Whatayou think?
> > > Leroy Eckert
> > > Dahlonega, GA
> > > Royale Conversion
> > > mbulriss <mbulriss@> wrote: Oh my
> > Alvie,
> > > I fear your testimonial will start the great oil debate (once
> > AGAIN)
> > > on DD not certifying anything except straight 40W for the 2-
> cycle
> > > engines. Maybe we should add multi-weight oil and synthetic
> oil to
> > > the list of forbidden topics along with politics and
religion!
> > > I feel sure someone will be along shortly to explain to you
how
> you
> > > are going to destroy your engine.
> > > As for me, as I said in post 33039, I grew up in the oil
> > distributing
> > > business from a long time ago. Been running Amsoil since
1979.
> Run
> > it
> > > in all my street vehicles, Harleys, John Deere tractors, lawn
> > > equipment, Birds and my race cars since then. So yeah, I
guess
> I
> > like
> > > it also......
> > > LOL!
> > > Mike Bulriss
> > > 1991 WB40 "Texas Minivan"-running on Amsoil like Stagecoach
> before
> > her
> > > San Antonio, TX
> > > --- In WanderlodgeForum@yahoogroups.com, "whynotam"
> > wrote:
> > > > Mike,
> > > > Do you like Amsoil also? I use the 15w40 heavy duty Marine
in
> > the
> > > > generator as well as the 8v92 and it is doing a great job.
I
> > would
> > > > like to also switch the transmission fluid but haven't got
it
> > done
> > > > yet. I also use Amsoil in the boys two BMW's, the wife's
van,
> my
> > 05
> > > > Duramax pickup and in the tractor and mowers as well.
> > > > Alvie Miller
> > > > 93 WLWB
> > > > Arthur IL
> > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss"
> <mbulriss@>
> > > > wrote:
> > > > > Kurt,
> > > > > Thanks for the update. I'm going to change mine over to
> the
> > Amsoil
> > > > > equivalent of the Transynd, since I can get that cheaper.
> 1MPG
> > > > > increase is 20%!
> > > > > Mike Bulriss
> > > > > 1991 WB40 "Texas Minvan"
> > > > > San Antonio, TX
> > > > > --- In WanderlodgeForum@yahoogroups.com, "bumpersbird"
> > > > > wrote:
> > > > > > Mike,
> > > > > > I call Prevost and they told me it is Transynd by
> Castrol.
> > > > > > http://www.allisontransmission.com/service/transynd.jsp
> > > > > > I also had a level 3 service which replaces all
filters.
> In
> > the
> > > > > > Allison 6 speed I think there are 3 internal filters
> of
> > > > course
> > > > > > all oil, fuel and air filters. They greased everything
> that
> > could
> > > > be
> > > > > > grease and it also helped in the braking. I used to get
a
> > noise
> > > > from
> > > > > > the front brake that was called normal but it has now
> quit.
> > > > > > I was told when I bought my coach that all the fluid &
> > filters
> > > > had
> > > > > > been changed but I really don't know for sure. But it
did
> > not
> > > > perform
> > > > > > like it does now.
> > > > > > What I do know is that I'm up to 5.5 to 6 MPG from 4.5
to
> > 4.8
> > > > > > according to the SilverLeaf VMSpc.
> > > > > > Call it what you like, it's working for me.
> > > > > > Here's something to chew on. I don't know anything
about
> H2O
> > > > helping
> > > > > > your fuel mileage but I know Propane injection works.
On
> a
> > trip
> > > > last
> > > > > > summer I was at a Flying J in S.W. KY. At the RV
island.
> > > > > > A trucker in a red and white Peterbuilt pulled in
behind
> me.
> > I
> > > > > > thought that to strange in itself, so I went back to
his
> > truck to
> > > > > > tell him I was going to be there a while for fuel and
> > propane.
> > > > > > He told me he was after propane. I asked why and he
said
> he
> > had a
> > > > > > truck with propane injection and the outfit he drove
for
> was
> > > > testing
> > > > > > the system on 20 or so trucks. I asked if it was
working
> and
> > he
> > > > > > professed almost 2.5 MPG up on average.
> > > > > > I don't know about that, but I do know the guy whom
works
> on
> > my
> > > > Ford
> > > > > > Powerstroke has a propane fire diesel pick up that with
> rip
> > and
> > > > > > snort, and he's getting better MPG than my truck gets
> > > > > > Kurt Horvath
> > > > > > 95 PT-42 WLWB
> <mbulriss@>
> > > > > > > wrote:
> > > > > > > > filters and the high grade transmission fluid
really
> > made a
> > > > > > > > difference, about a mile per gallon and super
smooth
> > > > shifting.
> > > > > > > HELLO! 1MPG from tranny fluid change!? Hey Kurt,
> feel
> > free to
> > > > > > > expound on the tranny fluid change. Synthetic I
> assume?
> > I
> > > > have
> > > > > > been
> > > > > > > putting that change off for a while since the dino
> tranny
> > fluid
> > > > was
> > > > > > > fresh, but for 1MPG.....
> > > > > > > Thanks,
> > > > > > > Mike Bulriss
> > > > > > > 1991 WB40 "Texas Minivan" - in need of a quick cheap
> 1MPG
> > > > upgrade
> > > > > > > San Antonio, TX
> > > > > > > wrote:
> > > > > > > > Well you can tell I've been off the web for a
while.
> My
> > > > computers
> > > > > > > > were infected by a Trojan virus late in Jan. It
took
> a
> > while
> > > > and
> > > > > > a
> > > > > > > > new laptop to fix the problems. I lost a lot of
files
> > and had
> > > > to
> > > > > > get
> > > > > > > > new credit cards. S.O.B.'s, "and I don't mean, Some
> > Other
> > > > Bus" So
> > > > > > if
> > > > > > > > I repeat any request or post, or stuff you guys
have
> > already
> > > > > > beaten
> > > > > > > > to death, forgive me.
> > > > > > > > Mike your right; I do recall seeing that coach
listed
> > for a
> > > > while
> > > > > > > > now. If it's truly a good deal it won't stick
around
> for
> > > > long.
> > > > > > I'll
> > > > > > > > go by Staley's if I have time just to look at her.
> > > > > > > > Paul, The Indulgence is safe at home and ready for
> this
> > > > weekend's
> > > > > > > > trip. I'm taking my daughter and 9 of her friends
to
> > > > Nashville
> > > > > > for
> > > > > > > > their Senior Prom. Should be Hoot!
> > > > > > > > Bye the way my coach is not for sale, I like all
> Birds,
> > but
> > > > the
> > > > > > PT-
> > > > > > > > 42's are my favorite flavor, maybe a 43 would due
but
> I
> > would
> > > > not
> > > > > > go
> > > > > > > > to a 40 footer of any mfg. Yes you're right I'm
> spoiled!
> > All
> > > > I
> > > > > > need
> > > > > > > > now is a Stacker Trailer that doesn't cost as much
as
> my
> > > > coach,
> > > > > > so I
> > > > > > > > can load it up full of toys and its party time!
> > > > > > > > I had a full servicing done at Prevost Nashville a
> few
> > months
> > > > ago
> > > > > > and
> > > > > > > > it was well worth the money. All new filters &
> fluids,
> > the
> > > > new
> > > > > > tranny
really
> > made a
smooth
> > > > shifting.
> > > > > > The
> > > > > > > > Jake is even smoother and not as radical, the
jerking
> > upon
> > > > > > activation
> > > > > > > > has gone away. I'm a very happy camper. The brakes
> were
> > > > checked
> > > > > > for
> > > > > > > > wear and a full chassis lube, headlights adjusted
> > new
> > > > wiper
> > > > > > > > blades. She is ready to roll.
> > > > > > > > Kurt Horvath
> > > > > > > > 95 PT-42 WLWB
> > > > > > > > Damn the price of fuel! Full speed ahead!
> > > > <mbulriss@>
> > > > > > > > wrote:
> > > > > > > > > Being rather partial to green coaches, I tend to
> watch
> > for
> > > > > > them.
> > > > > > > > That
> > > > > > > > > one looks really good in the pictures, but it has
> been
> > on
> > > > > > > > consignment
> > > > > > > > > on Staley's lot for a *long* time. I distinctly
> > remember
> > > > the
> > > > > > > > > (HEADLINER IN FRONT LOUNGE HAS DAMAGE AND NEEDS
TO
> BE
> > > > REPAIRED)
> > > > > > > > > comment. Odd there are no pictures of the damage.
> As
> > I
> > > > recall,
> > > > > > > > > someone went to see it and had posted a rather
> > negative
> > > > > > review. I
> > > > > > > > > searched for that post but can't find it right
now.
> > > > > > > > > If someone remembers that post or went to see the
> > coach,
> > > > please
> > > > > > > > update
> > > > > > > > > us again.
> > > > > > > > > Mike Bulriss
> > > > > > > > > 1991 WB40 "Texas Minivan" (lot's of greeeeen,
> baby)
> > > > > > > > > San Antonio, TX
> > > > > > > > > --- In
> > > > > > > > > wrote:
> > > > > > > > > > I ran across this coach will surfing this
morning.
> > > > > > > > > > I like it but I don't know anything about it's
> > history.
> > > > > > > > > > The link is listed below
> > > > > > > > > > http://www.staleycoach.com/48350.htm
> > > > > > > > > > Kurt Horvath
> > > > > > > > > > 95 PT-42 WLWB
> > > Be a better friend, newshound, and know-it-all with Yahoo!
> Mobile.
> > Try it now.
Mobile.
> Try it now.
> No virus found in this incoming message.
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 269.23.3/1393 - Release Date:
4/23/2008 8:12 AM
04-24-2008, 04:20
Post: #42
Al,
You have the Lone Star Birds confused with the factory sponsored
Family of Friends.
The Lone Star Birds are meeting this *weekend* in Boerne, Tx, just NW
of San Antonio. A couple of Birds are already here (Gureasko and
Marabito), but most will arrive on Friday. LSB does weekend rallies only.
The Family of Friends also happened to be meeting during this week in
Kerreville, TX, further NW of San Antonio by 50 miles.
You still have time to make the Lone Star Birds Rally! Come on over.
--- In WanderlodgeForum@yahoogroups.com, "Al" wrote:
> Maury,
> Al Johnson
> '96 BMC B100
> > From: Al
> uses
> The
> plant
> to
> 2015
> and
> a
> very
> > would want.
> > Al Johnson
> > '96 BMC B100
> I
> area
> before
> > you use it?
> > > Leroy Eckert
> > > Dahlonega, GA
> > > Royale Conversion
> > > Al wrote: Leroy,
> > average
> > > Al Johnson
> > > '96 BMC B100
> problems.
> > I
> > produce
> > > > Leroy Eckert
> > > > Dahlonega, GA
> > > > Royale Conversion
> > > Alvie,
> > > AGAIN)
> > cycle
> > oil to
> religion!
> how
> > you
> > > distributing
> 1979.
> > Run
> > > it
> guess
> > I
> > > like
> > > > it also......
> > > > LOL!
> > > > Mike Bulriss
> > before
> > > her
> > > > San Antonio, TX
> > > wrote:
> > > > > Mike,
> in
> > > the
> I
> > > would
> it
> > > done
> van,
> > my
> > > 05
> > > > > Alvie Miller
> > > > > 93 WLWB
> > > > > Arthur IL
> > <mbulriss@>
> > > > > wrote:
> > > > > > Kurt,
> > the
> > > Amsoil
> > 1MPG
> > > > > > increase is 20%!
> > > > > > Mike Bulriss
> > > > > > San Antonio, TX
> > > > > > wrote:
> > > > > > > Mike,
> > Castrol.
> filters.
> > In
> > > the
> and
> > of
> > > > > course
> > that
> > > could
> > > > > be
> a
> > > noise
> > > > > from
> > quit.
> > > filters
> > > > > had
> did
> > > not
> > > > > perform
> > > > > > > like it does now.
> to
> > > 4.8
> about
> > H2O
> > > > > helping
> On
> > a
> > > trip
> > > > > last
> island.
> behind
> > me.
> > > I
> his
> > > truck to
> > > propane.
> said
> > he
> > > had a
> for
> > was
> > > > > testing
> working
> > and
> > > he
> works
> > on
> > > my
> > > > > Ford
> > rip
> > > and
> > > > > > > Kurt Horvath
> > > > > > > 95 PT-42 WLWB
> > <mbulriss@>
> really
> > > made a
> smooth
> > > > > shifting.
> > feel
> > > free to
> > assume?
> > > I
> > > > > have
> > > > > > > been
> > tranny
> > > fluid
> > > > > was
> > > > > > > > Thanks,
> > > > > > > > Mike Bulriss
> > 1MPG
> > > > > upgrade
> > > > > > > > San Antonio, TX
> while.
> > My
> > > > > computers
> took
> > a
> > > while
> > > > > and
> > > > > > > a
> files
> > > and had
> > > > > to
> > > > > > > get
> > > Other
> > > > > Bus" So
> > > > > > > if
> have
> > > already
> > > > > > > beaten
> listed
> > > for a
> > > > > while
> around
> > for
> > > > > long.
> > > > > > > I'll
> > this
> > > > > weekend's
> to
> > > > > Nashville
> > > > > > > for
> > Birds,
> > > but
> > > > > the
> > > > > > > PT-
> but
> > I
> > > would
> > > > > not
> > > > > > > go
> > spoiled!
> > > All
> > > > > I
> > > > > > > need
> as
> > my
> > > > > coach,
> > > > > > > so I
> > few
> > > months
> > > > > ago
> > > > > > > and
> > fluids,
> > > the
> > > > > new
> > > > > > > tranny
> really
> > > made a
> smooth
> > > > > shifting.
> > > > > > > The
> jerking
> > > upon
> > > > > > > activation
> > were
> > > > > checked
> > > > > > > for
> and
> > > new
> > > > > wiper
> > > > > > > > > Kurt Horvath
> > > > > > > > > 95 PT-42 WLWB
> > > > > <mbulriss@>
> > watch
> > > for
> > > > > > > them.
> > > > > > > > > That
> > been
> > > on
> > > > > > > > > consignment
> > > remember
> > > > > the
> TO
> > BE
> > > > > REPAIRED)
> > As
> > > I
> > > > > recall,
> > > negative
> > > > > > > review. I
> now.
> > > coach,
> > > > > please
> > > > > > > > > update
> > > > > > > > > > us again.
> > > > > > > > > > Mike Bulriss
> > baby)
> > > > > > > > > > San Antonio, TX
> > > > > > > > > > --- In
> morning.
> > > history.
> > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > 95 PT-42 WLWB
> > Mobile.
> > > Try it now.
> Mobile.
> > Try it now.
> > Checked by AVG.
> 4/23/2008 8:12 AM
04-24-2008, 05:25
Post: #43
Mike,
Yes I am .. Was in China till Tuesday.. Wife looked at the wrong
one.. If I can get packed up, I am on my way.. Can you send me
address and is their space available?
Al Johnson
'96 BMC B100
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...>
will
> Al,
> Family of Friends.
NW
rallies only.
in
over.
> Mike Bulriss
> San Antonio, TX
> > Maury,
to
a
my
because my
mornings (
not
worry. I
this. I
will
> > Al Johnson
> > '96 BMC B100
you
regular
> > > From: Al
> > uses
process.
> > The
of my
> > plant
soon
> > to
> > 2015
next
to
incinator
> > and
develop
> > a
about
priced
> > very
buyer
> > > would want.
> > > Al Johnson
> > > '96 BMC B100
> > I
an
> > area
the by
> > before
> > > you use it?
> > > > Leroy Eckert
> > > > Dahlonega, GA
> > > > Royale Conversion
> > > > Al wrote: Leroy,
> > > average
> > > > Al Johnson
> > > > '96 BMC B100
> > problems.
> > > I
mass
> > > produce
> > > > > Leroy Eckert
> > > > > Dahlonega, GA
> > > > > Royale Conversion
> > > > Alvie,
(once
> > > > AGAIN)
2-
> > > cycle
synthetic
> > > oil to
> > religion!
you
> > how
> > > you
> > > > distributing
> > 1979.
> > > Run
> > > > it
lawn
> > guess
> > > I
> > > > like
> > > > > it also......
> > > > > LOL!
> > > > > Mike Bulriss
Stagecoach
> > > before
> > > > her
> > > > > San Antonio, TX
> > > > wrote:
> > > > > > Mike,
Marine
> > in
> > > > the
job.
> > I
> > > > would
got
> > it
> > > > done
wife's
> > van,
> > > my
> > > > 05
> > > > > > Alvie Miller
> > > > > > 93 WLWB
> > > > > > Arthur IL
> > > <mbulriss@>
> > > > > > wrote:
> > > > > > > Kurt,
to
> > > the
> > > > Amsoil
cheaper.
> > > 1MPG
> > > > > > > increase is 20%!
> > > > > > > Mike Bulriss
> > > > > > > San Antonio, TX
> > > > > > > wrote:
> > > > > > > > Mike,
> > > Castrol.
> > filters.
> > > In
> > > > the
filters
> > and
> > > of
> > > > > > course
everything
> > > that
> > > > could
> > > > > > be
get
> > a
> > > > noise
> > > > > > from
now
> > > quit.
fluid &
> > > > filters
> > > > > > had
it
> > did
> > > > not
> > > > > > perform
> > > > > > > > like it does now.
4.5
> > to
> > > > 4.8
> > about
> > > H2O
> > > > > > helping
works.
> > On
> > > a
> > > > trip
> > > > > > last
> > island.
> > behind
> > > me.
> > > > I
to
> > his
> > > > truck to
> > > > propane.
> > said
> > > he
> > > > had a
drove
> > for
> > > was
> > > > > > testing
> > working
> > > and
> > > > he
> > works
> > > on
> > > > my
> > > > > > Ford
with
> > > rip
> > > > and
gets
> > > > > > > > Kurt Horvath
> > > > > > > > 95 PT-42 WLWB
> > > <mbulriss@>
> > > > wrote:
> > > > > > > > > --- In
> > really
> > > > made a
> > smooth
> > > > > > shifting.
> > > feel
> > > > free to
> > > assume?
> > > > I
> > > > > > have
> > > > > > > > been
dino
> > > tranny
> > > > fluid
> > > > > > was
> > > > > > > > > Thanks,
> > > > > > > > > Mike Bulriss
cheap
> > > 1MPG
> > > > > > upgrade
> > > > > > > > > San Antonio, TX
> > > > > > > > > --- In
> > while.
> > > My
> > > > > > computers
> > took
> > > a
> > > > while
> > > > > > and
> > > > > > > > a
> > files
> > > > and had
> > > > > > to
> > > > > > > > get
Some
> > > > Other
> > > > > > Bus" So
> > > > > > > > if
> > have
> > > > already
> > > > > > > > beaten
> > listed
> > > > for a
> > > > > > while
> > around
> > > for
> > > > > > long.
> > > > > > > > I'll
her.
for
> > > this
> > > > > > weekend's
friends
> > to
> > > > > > Nashville
> > > > > > > > for
all
> > > Birds,
> > > > but
> > > > > > the
> > > > > > > > PT-
due
> > but
> > > I
> > > > would
> > > > > > not
> > > > > > > > go
> > > spoiled!
> > > > All
> > > > > > I
> > > > > > > > need
much
> > as
> > > my
> > > > > > coach,
> > > > > > > > so I
Nashville a
> > > few
> > > > months
> > > > > > ago
> > > > > > > > and
> > > fluids,
> > > > the
> > > > > > new
> > > > > > > > tranny
> > really
> > > > made a
> > smooth
> > > > > > shifting.
> > > > > > > > The
> > jerking
> > > > upon
> > > > > > > > activation
brakes
> > > were
> > > > > > checked
> > > > > > > > for
adjusted
> > and
> > > > new
> > > > > > wiper
> > > > > > > > > > Kurt Horvath
> > > > > > > > > > 95 PT-42 WLWB
> > > > > > > > > > --- In
> > > > > > <mbulriss@>
to
> > > watch
> > > > for
> > > > > > > > them.
> > > > > > > > > > That
has
> > > been
> > > > on
> > > > > > > > > > consignment
distinctly
> > > > remember
> > > > > > the
NEEDS
> > TO
> > > BE
> > > > > > REPAIRED)
damage.
> > > As
> > > > I
> > > > > > recall,
rather
> > > > negative
> > > > > > > > review. I
right
> > now.
> > > > coach,
> > > > > > please
> > > > > > > > > > update
> > > > > > > > > > > us again.
> > > > > > > > > > > Mike Bulriss
> > > baby)
> > > > > > > > > > > San Antonio, TX
> > > > > > > > > > > --- In
> > morning.
it's
> > > > history.
> > > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > > 95 PT-42 WLWB
Yahoo!
> > > Mobile.
> > > > Try it now.
> > Mobile.
> > > Try it now.
> > > Checked by AVG.
Date:
> > 4/23/2008 8:12 AM
04-24-2008, 06:05
Post: #44
What we need is an importer of Chinese goods and an exporter of
American money and jobs to convince us to go green. When it became
acceptable to admit or justify doing business with the lot, it was
the beginning of this end. The Bio Diesel movement and its advantage
with the new cost savings will help American thinkers develop better
ways with alternative fuels. It looks like the marketing
opertunist living in our country will send the Bio and green
movements advances and profits there too
GregoryO'Connor
94ptRomolandCa
> Mike,
wrong
> Al Johnson
> '96 BMC B100
> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@>
> will
> > Al,
> > Family of Friends.
just
> NW
> rallies only.
week
> in
> over.
> > Mike Bulriss
> > San Antonio, TX
> > > Maury,
most
fuel
> to
into
> a
changing
> my
> because my
> mornings (
were
> not
> worry. I
> this. I
rally
> will
> > > Al Johnson
> > > '96 BMC B100
if
> you
> regular
> > > > From: Al
Nashville
It
> > > uses
> process.
> > > The
day
> of my
biodiesel
> > > plant
investors
> soon
> > > to
thru
> > > 2015
> next
used
> to
> incinator
> > > and
> develop
> > > a
> about
> priced
> > > very
commercial
> buyer
> > > > would want.
> > > > Al Johnson
> > > > '96 BMC B100
it,
> and
> > > I
have
> an
> > > area
> the by
product
> > > before
> > > > you use it?
> > > > > Leroy Eckert
> > > > > Dahlonega, GA
> > > > > Royale Conversion
> > > > > Al wrote: Leroy,
My
> > > > average
> > > > > Al Johnson
> > > > > '96 BMC B100
> > > problems.
> > > > I
> mass
> > > > produce
> > > > > > Leroy Eckert
> > > > > > Dahlonega, GA
> > > > > > Royale Conversion
> > > > > Alvie,
debate
> (once
> > > > > AGAIN)
> 2-
> > > > cycle
> synthetic
> > > > oil to
> > > religion!
to
> you
> > > how
> > > > you
oil
> > > > > distributing
since
> > > 1979.
> > > > Run
> > > > > it
tractors,
> lawn
I
> > > guess
> > > > I
> > > > > like
> > > > > > it also......
> > > > > > LOL!
> > > > > > Mike Bulriss
> Stagecoach
> > > > before
> > > > > her
> > > > > > San Antonio, TX
> > > > > wrote:
> > > > > > > Mike,
> Marine
> > > in
> > > > > the
great
> job.
> > > I
> > > > > would
haven't
> got
> > > it
> > > > > done
> wife's
> > > van,
> > > > my
> > > > > 05
> > > > > > > Alvie Miller
> > > > > > > 93 WLWB
> > > > > > > Arthur IL
> > > > <mbulriss@>
> > > > > > > wrote:
> > > > > > > > Kurt,
over
> to
> > > > the
> > > > > Amsoil
> cheaper.
> > > > 1MPG
> > > > > > > > increase is 20%!
> > > > > > > > Mike Bulriss
> > > > > > > > San Antonio, TX
> > > > > > > > --- In
> > > > > > > > wrote:
> > > > > > > > > Mike,
by
> > > > Castrol.
> > > filters.
> > > > In
> > > > > the
> filters
> > > and
> > > > of
> > > > > > > course
> everything
> > > > that
> > > > > could
> > > > > > > be
to
> get
> > > a
> > > > > noise
> > > > > > > from
has
> now
> > > > quit.
> fluid &
> > > > > filters
> > > > > > > had
But
> it
> > > did
> > > > > not
> > > > > > > perform
> > > > > > > > > like it does now.
from
> 4.5
> > > to
> > > > > 4.8
anything
> > > about
> > > > H2O
> > > > > > > helping
> works.
> > > On
> > > > a
> > > > > trip
> > > > > > > last
> > > island.
in
> > > behind
> > > > me.
> > > > > I
back
> to
> > > his
> > > > > truck to
fuel
> and
> > > > > propane.
he
> > > said
> > > > he
> > > > > had a
> drove
> > > for
> > > > was
> > > > > > > testing
> > > working
> > > > and
> > > > > he
whom
> > > works
> > > > on
> > > > > my
> > > > > > > Ford
that
> with
> > > > rip
> > > > > and
> gets
> > > > > > > > > Kurt Horvath
> > > > > > > > > 95 PT-42 WLWB
> > > > <mbulriss@>
> > > > > wrote:
> > > > > > > > > > --- In
fluid
> > > really
> > > > > made a
super
> > > smooth
> > > > > > > shifting.
Kurt,
> > > > feel
> > > > > free to
I
> > > > assume?
> > > > > I
> > > > > > > have
> > > > > > > > > been
> dino
> > > > tranny
> > > > > fluid
> > > > > > > was
> > > > > > > > > > Thanks,
> > > > > > > > > > Mike Bulriss
> cheap
> > > > 1MPG
> > > > > > > upgrade
> > > > > > > > > > San Antonio, TX
> > > > > > > > > > --- In
a
> > > while.
> > > > My
> > > > > > > computers
It
> > > took
> > > > a
> > > > > while
> > > > > > > and
> > > > > > > > > a
of
> > > files
> > > > > and had
> > > > > > > to
> > > > > > > > > get
mean,
> Some
> > > > > Other
> > > > > > > Bus" So
> > > > > > > > > if
guys
> > > have
> > > > > already
> > > > > > > > > beaten
coach
> > > listed
> > > > > for a
> > > > > > > while
stick
> > > around
> > > > for
> > > > > > > long.
> > > > > > > > > I'll
at
> her.
ready
> for
> > > > this
> > > > > > > weekend's
> friends
> > > to
> > > > > > > Nashville
> > > > > > > > > for
> all
> > > > Birds,
> > > > > but
> > > > > > > the
> > > > > > > > > PT-
would
> due
> > > but
> > > > I
> > > > > would
> > > > > > > not
> > > > > > > > > go
I'm
> > > > spoiled!
> > > > > All
> > > > > > > I
> > > > > > > > > need
as
> much
> > > as
> > > > my
> > > > > > > coach,
> > > > > > > > > so I
time!
> Nashville a
> > > > few
> > > > > months
> > > > > > > ago
> > > > > > > > > and
> > > > fluids,
> > > > > the
> > > > > > > new
> > > > > > > > > tranny
fluid
> > > really
> > > > > made a
super
> > > smooth
> > > > > > > shifting.
> > > > > > > > > The
> > > jerking
> > > > > upon
> > > > > > > > > activation
> brakes
> > > > were
> > > > > > > checked
> > > > > > > > > for
> adjusted
> > > and
> > > > > new
> > > > > > > wiper
> > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > 95 PT-42 WLWB
> > > > > > > > > > > --- In
> > > > > > > <mbulriss@>
tend
> to
> > > > watch
> > > > > for
> > > > > > > > > them.
> > > > > > > > > > > That
it
> has
> > > > been
> > > > > on
> > > > > > > > > > > consignment
> distinctly
> > > > > remember
> > > > > > > the
> NEEDS
> > > TO
> > > > BE
> > > > > > > REPAIRED)
> damage.
> > > > As
> > > > > I
> > > > > > > recall,
> rather
> > > > > negative
> > > > > > > > > review. I
> right
> > > now.
see
> the
> > > > > coach,
> > > > > > > please
> > > > > > > > > > > update
> > > > > > > > > > > > us again.
> > > > > > > > > > > > Mike Bulriss
greeeeen,
> > > > baby)
> > > > > > > > > > > > San Antonio, TX
> > > > > > > > > > > > --- In
this
> > > morning.
about
> it's
> > > > > history.
> > > > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > > > 95 PT-42 WLWB
> Yahoo!
> > > > Mobile.
> > > > > Try it now.
Yahoo!
> > > Mobile.
> > > > Try it now.
> > > > Checked by AVG.
> Date:
> > > 4/23/2008 8:12 AM
04-24-2008, 15:52
Post: #45
Why are you always so negative?
I have freely helped anyone that asked for help or information. To
date, no money has been collected for my time and information. If
you are fine feeding the pump, then so be it. And I do believe that
I am making a difference in the environmment that I live although it
might be a small one. I know how to make my own fuel and have showed
many other persons how to do the same. If it does not work for you
then don't discredit someone else that it does work for.
If you want to stop importers from exporting American money and jobs,
then stop buying all the imported goods and the importer will go
away. After all, I only import items that consumers want and if I
did not do it, someone else would. And if you look in your house, in
your bus, your tennis shoes, your clothes, you will quickly find out
that most goods are no longer made in the US. Ever go to Walmart,
Kmart or any other big box. I bet if you were to look you will
quickly realize that about 90 - 95 of their goods they sale are
imported.
Al Johnson
'96 BMC B100
advantage
better
> GregoryO'Connor
> 94ptRomolandCa
> > Mike,
> wrong
> > Al Johnson
> > '96 BMC B100
I
> > will
> > > Al,
> > > Family of Friends.
> just
> > NW
> and
> > rallies only.
> week
> > in
> > over.
> > > Mike Bulriss
> > > San Antonio, TX
> > > > Maury,
> most
> fuel
> > to
> into
> > a
> changing
> > my
> > because my
> > mornings (
> were
> > not
> > worry. I
> > this. I
trips
> rally
I
> > will
> > > > Al Johnson
> > > > '96 BMC B100
> if
> > you
> > regular
> > > > > From: Al
> Nashville
compact.
> It
> > > > uses
> > process.
> > > > The
> day
> > of my
> biodiesel
> > > > plant
> investors
> > soon
> > > > to
> thru
> > > > 2015
> the
> > next
> used
> > to
> > incinator
> > > > and
> > develop
> > > > a
excited
> > about
> > priced
> > > > very
> commercial
> > buyer
> > > > > would want.
> > > > > Al Johnson
> > > > > '96 BMC B100
> it,
> > and
> > > > I
> have
> > an
> > > > area
with
> > the by
> product
> > > > before
> > > > > you use it?
> > > > > > Leroy Eckert
> > > > > > Dahlonega, GA
> > > > > > Royale Conversion
> > > > > > Al wrote: Leroy,
> My
> > > > > average
> > > > > > Al Johnson
> > > > > > '96 BMC B100
without
> > > > problems.
> > > > > I
> > mass
> > > > > produce
> > > > > > > Leroy Eckert
> > > > > > > Dahlonega, GA
> > > > > > > Royale Conversion
> > > > > > Alvie,
> debate
> > (once
> > > > > > AGAIN)
> the
> > 2-
> > > > > cycle
> > synthetic
> > > > > oil to
> > > > religion!
> to
> > you
> > > > how
> > > > > you
> oil
> > > > > > distributing
> since
> > > > 1979.
> > > > > Run
> > > > > > it
> tractors,
> > lawn
yeah,
> I
> > > > guess
> > > > > I
> > > > > > like
> > > > > > > it also......
> > > > > > > LOL!
> > > > > > > Mike Bulriss
> > Stagecoach
> > > > > before
> > > > > > her
> > > > > > > San Antonio, TX
> > > > > > wrote:
> > > > > > > > Mike,
> > Marine
> > > > in
> > > > > > the
> great
> > job.
> > > > I
> > > > > > would
> haven't
> > got
> > > > it
> > > > > > done
> > wife's
> > > > van,
> > > > > my
> > > > > > 05
well.
> > > > > > > > Alvie Miller
> > > > > > > > 93 WLWB
> > > > > > > > Arthur IL
> > > > > <mbulriss@>
> > > > > > > > wrote:
> > > > > > > > > Kurt,
> over
> > to
> > > > > the
> > > > > > Amsoil
> > cheaper.
> > > > > 1MPG
> > > > > > > > > increase is 20%!
> > > > > > > > > Mike Bulriss
> > > > > > > > > San Antonio, TX
> > > > > > > > > --- In
> > > > > > > > > wrote:
> > > > > > > > > > Mike,
> by
> > > > > Castrol.
> > > > filters.
> > > > > In
> > > > > > the
> > filters
> > > > and
> > > > > of
> > > > > > > > course
> > everything
> > > > > that
> > > > > > could
> > > > > > > > be
used
> to
> > get
> > > > a
> > > > > > noise
> > > > > > > > from
> has
> > now
> > > > > quit.
> > fluid &
> > > > > > filters
> > > > > > > > had
> But
> > it
> > > > did
> > > > > > not
> > > > > > > > perform
> > > > > > > > > > like it does now.
> from
> > 4.5
> > > > to
> > > > > > 4.8
> anything
> > > > about
> > > > > H2O
> > > > > > > > helping
> > works.
> > > > On
> > > > > a
> > > > > > trip
> > > > > > > > last
RV
> > > > island.
> in
> > > > behind
> > > > > me.
> > > > > > I
> back
> > to
> > > > his
> > > > > > truck to
> fuel
> > and
> > > > > > propane.
> he
> > > > said
> > > > > he
> > > > > > had a
> > drove
> > > > for
> > > > > was
> > > > > > > > testing
was
> > > > working
> > > > > and
> > > > > > he
> whom
> > > > works
> > > > > on
> > > > > > my
> > > > > > > > Ford
> that
> > with
> > > > > rip
> > > > > > and
truck
> > gets
> > > > > > > > > > Kurt Horvath
> > > > > > > > > > 95 PT-42 WLWB
> > > > > <mbulriss@>
> > > > > > wrote:
> > > > > > > > > > > --- In
> fluid
> > > > really
> > > > > > made a
> super
> > > > smooth
> > > > > > > > shifting.
> Kurt,
> > > > > feel
> > > > > > free to
> I
> > > > > assume?
> > > > > > I
> > > > > > > > have
> > > > > > > > > > been
> > dino
> > > > > tranny
> > > > > > fluid
> > > > > > > > was
> > > > > > > > > > > Thanks,
> > > > > > > > > > > Mike Bulriss
quick
> > cheap
> > > > > 1MPG
> > > > > > > > upgrade
> > > > > > > > > > > San Antonio, TX
> > > > > > > > > > > --- In
> a
> > > > while.
> > > > > My
> > > > > > > > computers
Jan.
> It
> > > > took
> > > > > a
> > > > > > while
> > > > > > > > and
> > > > > > > > > > a
lot
> of
> > > > files
> > > > > > and had
> > > > > > > > to
> > > > > > > > > > get
> mean,
> > Some
> > > > > > Other
> > > > > > > > Bus" So
> > > > > > > > > > if
> guys
> > > > have
> > > > > > already
> > > > > > > > > > beaten
> coach
> > > > listed
> > > > > > for a
> > > > > > > > while
> stick
> > > > around
> > > > > for
> > > > > > > > long.
> > > > > > > > > > I'll
> at
> > her.
> ready
> > for
> > > > > this
> > > > > > > > weekend's
> > friends
> > > > to
> > > > > > > > Nashville
> > > > > > > > > > for
like
> > all
> > > > > Birds,
> > > > > > but
> > > > > > > > the
> > > > > > > > > > PT-
> would
> > due
> > > > but
> > > > > I
> > > > > > would
> > > > > > > > not
> > > > > > > > > > go
> I'm
> > > > > spoiled!
> > > > > > All
> > > > > > > > I
> > > > > > > > > > need
> as
> > much
> > > > as
> > > > > my
> > > > > > > > coach,
> > > > > > > > > > so I
> time!
> > Nashville a
> > > > > few
> > > > > > months
> > > > > > > > ago
> > > > > > > > > > and
filters
> > > > > fluids,
> > > > > > the
> > > > > > > > new
> > > > > > > > > > tranny
> fluid
> > > > really
> > > > > > made a
> super
> > > > smooth
> > > > > > > > shifting.
> > > > > > > > > > The
> the
> > > > jerking
> > > > > > upon
> > > > > > > > > > activation
> > brakes
> > > > > were
> > > > > > > > checked
> > > > > > > > > > for
> > adjusted
> > > > and
> > > > > > new
> > > > > > > > wiper
> > > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > > 95 PT-42 WLWB
> > > > > > > > > > > > --- In
> > > > > > > > <mbulriss@>
> tend
> > to
> > > > > watch
> > > > > > for
> > > > > > > > > > them.
> > > > > > > > > > > > That
but
> it
> > has
> > > > > been
> > > > > > on
> > > > > > > > > > > > consignment
> > distinctly
> > > > > > remember
> > > > > > > > the
> > NEEDS
> > > > TO
> > > > > BE
> > > > > > > > REPAIRED)
> > damage.
> > > > > As
> > > > > > I
> > > > > > > > recall,
> > rather
> > > > > > negative
> > > > > > > > > > review. I
> > right
> > > > now.
> see
> > the
> > > > > > coach,
> > > > > > > > please
> > > > > > > > > > > > update
> > > > > > > > > > > > > us again.
> > > > > > > > > > > > > Mike Bulriss
> greeeeen,
> > > > > baby)
> > > > > > > > > > > > > San Antonio, TX
> > > > > > > > > > > > > --- In
> this
> > > > morning.
> about
> > it's
> > > > > > history.
> > > > > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > > > > 95 PT-42 WLWB
> > Yahoo!
> > > > > Mobile.
> > > > > > Try it now.
> Yahoo!
> > > > Mobile.
> > > > > Try it now.
> > > > > Checked by AVG.
Release
> > Date:
> > > > 4/23/2008 8:12 AM
04-25-2008, 00:52
Post: #46
surprised you think my observation is negative, seems like you
justified your dealings well. To date,(Hank whats a latin phrase
for that disclaimer?),When I buy chinese, I try to find a restraunt
who's owner needs a pool dug.
GregoryO'Connor
94ptRomolandCa
To
that
it
showed
you
jobs,
in
out
> imported.
> Al Johnson
> '96 BMC B100
became
was
> advantage
> better
> > GregoryO'Connor
> > 94ptRomolandCa
> > > Mike,
> > wrong
> > > Al Johnson
> > > '96 BMC B100
<mbulriss@>
so
> I
> > > will
> > > > Al,
sponsored
> > > > Family of Friends.
Tx,
> > just
> > > NW
(Gureasko
> > and
> > > rallies only.
this
> > week
> > > in
on
> > > over.
> > > > Mike Bulriss
> > > > San Antonio, TX
> > > > > Maury,
in
> > most
enough
> > fuel
> > > to
travelling
> > into
> > > a
> > changing
> > > my
> > > because my
> > > mornings (
it
> > were
> > > not
> > > worry. I
require
> > > this. I
> trips
weeks
> > rally
so
> I
> > > will
> > > > > Al Johnson
> > > > > '96 BMC B100
fuel
> > if
> > > you
use
> > > regular
> > > > > > From: Al
> > Nashville
> compact.
> > It
> > > > > uses
> > > process.
> > > > > The
a
> > day
> > > of my
> > biodiesel
> > > > > plant
> > investors
> > > soon
> > > > > to
incentives
> > thru
> > > > > 2015
to
> > the
> > > next
be
> > used
> > > to
> > > incinator
> > > > > and
to
> > > develop
> > > > > a
> excited
> > > about
is
> > > priced
> > > > > very
> > commercial
> > > buyer
> > > > > > would want.
> > > > > > Al Johnson
> > > > > > '96 BMC B100
manufacture
> > it,
> > > and
> > > > > I
> > have
> > > an
> > > > > area
> with
> > > the by
> > product
> > > > > before
> > > > > > you use it?
> > > > > > > Leroy Eckert
> > > > > > > Dahlonega, GA
> > > > > > > Royale Conversion
> > > > > > > Al wrote: Leroy,
gallon.
> > My
> > > > > > average
> > > > > > > Al Johnson
> > > > > > > '96 BMC B100
Eckert
> without
> > > > > problems.
> > > > > > I
can
> > > mass
> > > > > > produce
think?
> > > > > > > > Leroy Eckert
> > > > > > > > Dahlonega, GA
> > > > > > > > Royale Conversion
> > > > > > > Alvie,
> > debate
> > > (once
> > > > > > > AGAIN)
for
> > the
> > > 2-
> > > > > > cycle
> > > synthetic
> > > > > > oil to
> > > > > religion!
explain
> > to
> > > you
> > > > > how
> > > > > > you
> > oil
> > > > > > > distributing
> > since
> > > > > 1979.
> > > > > > Run
> > > > > > > it
> > tractors,
> > > lawn
> yeah,
> > I
> > > > > guess
> > > > > > I
> > > > > > > like
> > > > > > > > it also......
> > > > > > > > LOL!
> > > > > > > > Mike Bulriss
> > > Stagecoach
> > > > > > before
> > > > > > > her
> > > > > > > > San Antonio, TX
> > > > > > > > --- In
> > > > > > > wrote:
> > > > > > > > > Mike,
duty
> > > Marine
> > > > > in
> > > > > > > the
> > great
> > > job.
> > > > > I
> > > > > > > would
> > haven't
> > > got
> > > > > it
> > > > > > > done
> > > wife's
> > > > > van,
> > > > > > my
> > > > > > > 05
> well.
> > > > > > > > > Alvie Miller
> > > > > > > > > 93 WLWB
> > > > > > > > > Arthur IL
> > > > > > > > > --- In
> > > > > > <mbulriss@>
> > > > > > > > > wrote:
> > > > > > > > > > Kurt,
mine
> > over
> > > to
> > > > > > the
> > > > > > > Amsoil
that
> > > cheaper.
> > > > > > 1MPG
> > > > > > > > > > increase is 20%!
> > > > > > > > > > Mike Bulriss
> > > > > > > > > > San Antonio, TX
> > > > > > > > > > --- In
> > > > > > > > > > wrote:
> > > > > > > > > > > Mike,
Transynd
> > by
> > > > > > Castrol.
all
> > > > > filters.
> > > > > > In
> > > > > > > the
> > > filters
> > > > > and
> > > > > > of
> > > > > > > > > course
> > > everything
> > > > > > that
> > > > > > > could
> > > > > > > > > be
> used
> > to
> > > get
> > > > > a
> > > > > > > noise
> > > > > > > > > from
it
> > has
> > > now
> > > > > > quit.
> > > fluid &
> > > > > > > filters
> > > > > > > > > had
sure.
> > But
> > > it
> > > > > did
> > > > > > > not
> > > > > > > > > perform
> > > > > > > > > > > like it does now.
MPG
> > from
> > > 4.5
> > > > > to
> > > > > > > 4.8
> > anything
> > > > > about
> > > > > > H2O
> > > > > > > > > helping
injection
> > > works.
> > > > > On
> > > > > > a
> > > > > > > trip
> > > > > > > > > last
> RV
> > > > > island.
pulled
> > in
> > > > > behind
> > > > > > me.
> > > > > > > I
> > back
> > > to
> > > > > his
> > > > > > > truck to
> > fuel
> > > and
> > > > > > > propane.
> and
> > he
> > > > > said
> > > > > > he
> > > > > > > had a
he
> > > drove
> > > > > for
> > > > > > was
> > > > > > > > > testing
> was
> > > > > working
> > > > > > and
> > > > > > > he
guy
> > whom
> > > > > works
> > > > > > on
> > > > > > > my
> > > > > > > > > Ford
up
> > that
> > > with
> > > > > > rip
> > > > > > > and
> truck
> > > gets
> > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > 95 PT-42 WLWB
> > > > > > > > > > > In
> > > > > > <mbulriss@>
> > > > > > > wrote:
> > > > > > > > > > > > --- In
> > fluid
> > > > > really
> > > > > > > made a
> > super
> > > > > smooth
> > > > > > > > > shifting.
> > Kurt,
> > > > > > feel
> > > > > > > free to
Synthetic
> > I
> > > > > > assume?
> > > > > > > I
> > > > > > > > > have
> > > > > > > > > > > been
> > > dino
> > > > > > tranny
> > > > > > > fluid
> > > > > > > > > was
> > > > > > > > > > > > Thanks,
> > > > > > > > > > > > Mike Bulriss
> quick
> > > cheap
> > > > > > 1MPG
> > > > > > > > > upgrade
> > > > > > > > > > > > San Antonio, TX
> > > > > > > > > > > > --- In
for
> > a
> > > > > while.
> > > > > > My
> > > > > > > > > computers
> Jan.
> > It
> > > > > took
> > > > > > a
> > > > > > > while
> > > > > > > > > and
> > > > > > > > > > > a
> lot
> > of
> > > > > files
> > > > > > > and had
> > > > > > > > > to
> > > > > > > > > > > get
> > mean,
> > > Some
> > > > > > > Other
> > > > > > > > > Bus" So
> > > > > > > > > > > if
you
> > guys
> > > > > have
> > > > > > > already
> > > > > > > > > > > beaten
> > coach
> > > > > listed
> > > > > > > for a
> > > > > > > > > while
> > stick
> > > > > around
> > > > > > for
> > > > > > > > > long.
> > > > > > > > > > > I'll
look
> > at
> > > her.
> > ready
> > > for
> > > > > > this
> > > > > > > > > weekend's
her
> > > friends
> > > > > to
> > > > > > > > > Nashville
> > > > > > > > > > > for
> like
> > > all
> > > > > > Birds,
> > > > > > > but
> > > > > > > > > the
> > > > > > > > > > > PT-
> > would
> > > due
> > > > > but
> > > > > > I
> > > > > > > would
> > > > > > > > > not
> > > > > > > > > > > go
right
> > I'm
> > > > > > spoiled!
> > > > > > > All
> > > > > > > > > I
> > > > > > > > > > > need
cost
> > as
> > > much
> > > > > as
> > > > > > my
> > > > > > > > > coach,
> > > > > > > > > > > so I
party
> > time!
> > > Nashville a
> > > > > > few
> > > > > > > months
> > > > > > > > > ago
> > > > > > > > > > > and
> filters
> > > > > > fluids,
> > > > > > > the
> > > > > > > > > new
> > > > > > > > > > > tranny
> > fluid
> > > > > really
> > > > > > > made a
> > super
> > > > > smooth
> > > > > > > > > shifting.
> > > > > > > > > > > The
radical,
> > the
> > > > > jerking
> > > > > > > upon
> > > > > > > > > > > activation
The
> > > brakes
> > > > > > were
> > > > > > > > > checked
> > > > > > > > > > > for
> > > adjusted
> > > > > and
> > > > > > > new
> > > > > > > > > wiper
> > > > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > > > 95 PT-42 WLWB
> > > > > > > > > > > > > --- In
> > > > > > > > > <mbulriss@>
I
> > tend
> > > to
> > > > > > watch
> > > > > > > for
> > > > > > > > > > > them.
> > > > > > > > > > > > > That
> but
> > it
> > > has
> > > > > > been
> > > > > > > on
> > > > > > > > > > > > > consignment
> > > distinctly
> > > > > > > remember
> > > > > > > > > the
AND
> > > NEEDS
> > > > > TO
> > > > > > BE
> > > > > > > > > REPAIRED)
> > > damage.
> > > > > > As
> > > > > > > I
> > > > > > > > > recall,
a
> > > rather
> > > > > > > negative
> > > > > > > > > > > review. I
it
> > > right
> > > > > now.
to
> > see
> > > the
> > > > > > > coach,
> > > > > > > > > please
> > > > > > > > > > > > > update
> > > > > > > > > > > > > > us again.
> > > > > > > > > > > > > > Mike Bulriss
> > greeeeen,
> > > > > > baby)
> > > > > > > > > > > > > > San Antonio, TX
> > > > > > > > > > > > > > --- In
> > this
> > > > > morning.
> > about
> > > it's
> > > > > > > history.
> > > > > > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > > > > > 95 PT-42 WLWB
with
> > > Yahoo!
> > > > > > Mobile.
> > > > > > > Try it now.
> > Yahoo!
> > > > > Mobile.
> > > > > > Try it now.
> > > > > > Checked by AVG.
> Release
> > > Date:
> > > > > 4/23/2008 8:12 AM
