Now Oil Filters, was Re: 93 PT-40 for sale in Nashville
04-23-2008, 03:06
Using the "I don't believe it until I see it" logic, then there is no
way Kurt got a 1 mpg increase after changing to the synthetic tranny
fluid, repardless of wht his VMSpec says.
In that same vein then, Alvie can't possibly have clean oil in a
diesel after 3,000 miles. Sorry, but synthetic users know that you
need very good oil filters to keep it clean or you are just wasting
money. Oil carries dirt, filters keep the oil clean.
To read *facts*, go to:
http://www.mobiloil.com/usa-english/moto...d_per\
formance_oil_filters.aspx
and read their FAQs
or the Donaldson filter site, they make filters, not oil:
http://www.donaldson.com/en/engine/lube/lube.html
http://www.donaldson.com/en/engine/exten...index.html
or even to the Amsoil filter site:
https://www.amsoil.com/filtration/index.aspx#
When you visit those three sites and look around, you will have
visited the 3 best oil filter providers IMO. By the way, the 6V&8V92
oil filter takes a Donaldson Endurance ELF7670 or a regular P551670.
Choose wisely.
Yes, you can keep the oil clean for 3000 miles like Alvie claims, but
not with pleated paper filters.
1991 WB40 "Texas Minivan"
> I'm having a hard time believing your story of clear oil in the 8V92
> after 3000 miles. The nature of the beast is to generate soot and
> that is what turns the oil black. Show me some laboratory oil
> analysis reports and I might believe you.
> We all tend to get the results we want.
> R.E. (Ron) Marabito, Dallas, TX 92WB40
> --- In WanderlodgeForum@yahoogroups.com, "whynotam" wrote:
> > Mike and all,
> > I apologize for starting this hugeSmile controversy but quite frankly I
> > think you are 100% correct in stating that oil technology has
> > improved to the point where Detroit Diesels suggestions are way
> > behind the times. I can only speak from personal experience as I
> > don't have the oil industry back ground that Mike does but due to the
> > fact that I have used synthetic lubricants for many years and have
> > had very good success is the reason that I went with Amsoil's
> > recommendation to use the 15W40 in our 1993 8V92. The engine oil
> > consumption
> > dropped from 1 quart every 200 miles to around 1 quart per 600 miles.
> > With straight 40W Shell Rotella the oil was thin and black within the
> > first 500 miles but with the Amsoil it was still clear after 3000
> > miles same as in my Duramax Chevy after 7500 miles. Exhaust smoke was
> > also considerably reduced on the 8V92. Use what you like but be
> > assured there are definite advantages to the newer synthetic
> > formulations. My genes also seem to still be working fineSmile
> > Best to all,
> > Alvie Miller
> > 1993 WLWB on Amsoil 15W40
> > Arthur IL
> > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@>
> > wrote:
> > > Hey Alvie Miller - I rest my case!
> > > Pete, aren't you the same person that once said *ALL* DD engines
> > > require straight 40W? I also remember you later said jokingly
> > > something like "you are an old guy and all real DDs are 2-cycle" to
> > you.
> > > I guess I'm pressing my luck by not having any lubrication related
> > > failures,... you know, having used Amsoil since 1979 in general and
> > in
> > > my Birds since early 1997. Lots of other members are also using
> > Amsoil
> > > and other synthetics in their Birds.
> > > I know DD updated their 93K124 document on "ENGINE REQUIREMENTS —
> > > LUBRICATING OIL, FUEL AND FILTERS" in 2005, but that update was
> > mainly
> > > to update to reflect the newest API CI-4 rating. That document is
> > > almost entirely about the new series engines now and only mentions
> > the
> > > older 2-cycles by re-printing what has always been there. In their
> > > defense, I can't imagine why DD would spend $$$$$$$$ certifying the
> > > new breed of oils for an obsolete engine, but isn't it odd that they
> > > certify and recommend multi-weight synthetics and dino-based oils
> > for
> > > the newer engines?
> > > Just for the record, all my DD manuals I have ever had always said
> > you
> > > can use 15W-40 in colder climates, but recommend to change back to
> > > straight weight when temps rise to 'normal' again (above 40-50F? I
> > > think it was). Lubricating oils have come a long way from when DD
> > > started building the 2-cycles and was actively certifying oils for
> > > them. Multi-weight dino-based oils, circa 60s and 70s, did in fact
> > > break down incredibly fast when DD was actively building the 2-
> > cycles
> > > and actively certifying oils for them. Testing proved that the
> > > straight weight petroleum oils were much better back then for shear
> > > strength and thermal stability.
> > > Times change. The API standards have also evolved. The synthetics
> > > outperform petroleum based oils by a wide margin today. The way I
> > > understand it, the current generation of 15W-40 synthetics pass all
> > > requirements for the old straight weight petroleum 40. (Note: Even
> > > Mobil's Delvac 1 5W-40 is certified for the Series 60. And anything
> > > with 5W in it makes me shudder.)
> > > I compare the specs listed by DD against the actual specs of the
> > oil I
> > > use. Since we are talking Amsoil here, they used to make a
> > straight
> > > 40-weight diesel oil. Demand dropped to nothing, API standards
> > > changed, and now it is the 15W-40. I called and talked with their
> > > engineers before I went to that. (As the old 2-cycles get retired,
> > and
> > > the market for the old straight weight oils shrinks further, fewer
> > and
> > > fewer companies will even supply a straight-weight 40.)
> > > If you look at thermal stability and high shear strength, critical
> > > measurements for oil protection, the DD literature says: "In 15W-40
> > > grade oils, a HT/HS viscosity below 3.7 centipoise (cP) indicates
> > that
> > > the oil will not perform as a 40 grade oil at engine operating
> > > conditions." Amsoil's 15W-40 is measured at 4.4cP, well above DD
> > > minimum requirements. Checking DD Table 3.2 from their oil spec for
> > > 40W oil, the Amsoil 15W40 that Alvie mentioned meets all the
> > Kinematic
> > > Viscosity and the Viscosity Index requirements.
> > > Further, with the clean air acts and the decreases in sulfur
> > > requirements it is becoming a lot harder for the petroleum based
> > > fluids to meet the TBN (Total Base Number) requirements of the old
> > > 2-cycles - which is listed at a range of 7-10 TBN from the DD 40W
> > > chart. Now TBN is really a case where bigger is better. Amsoil's
> > TBN
> > > is 12.1 for their 15W-40. Total Base Number measures an oil's
> > > alkalinity and ability to neutralize acid using lab testing (ASTM D
> > > 2896 or D 4739) - acid production is generally considered bad for
> > your
> > > basic internal combustion engine.
> > > Finally, from the Amsoil web site:
> > > AMSOIL Synthetic Heavy Duty Diesel & Marine Motor Oil is recommended
> > > for use in diesel engines and other applications requiring any of
> > the
> > > listed worldwide specifications and gasoline engines requiring API
> > SL,
> > > SJ, SH or ACEA A3.
> > > * API CI-4+, CF, CF-2, SL
> > > * ACEA A3/B3, E2, E3, E5, E7
> > > * Global DHD-1
> > > * JASO DH-1
> > > * Mack EO-N Premium Plus '03
> > > * DDC Power Guard 93K214
> > > * Caterpillar ECF-1A, ECF-2
> > > Now I suppose they could be lying in print, but they probably have
> > > lawyers to prevent them from doing that unless they actually can
> > prove
> > > that they can meet those specs.
> > > Anyway, didn't mean to bludgeon the subject. I just wanted to set
> > the
> > > record straight. Newer doesn't mean bad. Otherwise the API, SAE
> > and
> > > ASTM testing wouldn't keep evolving. In the old days, if we got
> > 100k
> > > miles out of a car engine without a re-build it was fantastic. Now
> > > (with something at least resembling proper maintenance) people
> > > regularly get upwards of 250k. I've never had a Suburban with under
> > > 300k when I got rid of it, and they were all running good. Lots of
> > > that is due strictly to lubrication advances.
> > > FWIW,
> > > Mike Bulriss - gene pool still functioning fine thank you
> > > 1991 WB40 "Texas Minivan"- 8V92 running that nasty old Amsoil
> > > San Antonio, TX
> > > --- In WanderlodgeForum@yahoogroups.com, PM7088@ wrote:
> > > > The gene pool of home mechanics is purified by folks who: Use
> > > Amsoil in 2 cycle diesels, install K&N air filters and/or propane
> > > injectors and or sill "Chips" that increase their horsepower to the
> > > point that pistons melt.
> > > > Pete
> > > > -------------- Original message --------------
> > > > From: brad barton <bbartonwx@>
> > > > I always heard never to use anything but single-weight oil on my
> > > 8V92..never multigrade unless in a pinch.
> > > > FWIW
> > > > Brad Barton 00LXiDFW bbartonwx@
> > > > To: WanderlodgeForum@yahoogroups.com
> > > > From: aamiller@
> > > > Date: Mon, 21 Apr 2008 12:41:17 +0000
> > > > Subject: [WanderlodgeForum] Re: 93 PT-40 for sale in Nashville
> > > > Mike,
> > > > Do you like Amsoil also? I use the 15w40 heavy duty Marine in the
> > > > generator as well as the 8v92 and it is doing a great job. I
> > would
> > > > like to also switch the transmission fluid but haven't got it
> > done
> > > > yet. I also use Amsoil in the boys two BMW's, the wife's van, my
> > 05
> > > > Duramax pickup and in the tractor and mowers as well.
> > > > Alvie Miller
> > > > 93 WLWB
> > > > Arthur IL
> > > > wrote:
> > > > > Kurt,
> > > > > Thanks for the update. I'm going to change mine over to the
> > Amsoil
> > > > > equivalent of the Transynd, since I can get that cheaper. 1MPG
> > > > > increase is 20%!
> > > > > Mike Bulriss
> > > > > 1991 WB40 "Texas Minvan"
> > > > > San Antonio, TX
> > > > > --- In WanderlodgeForum@yahoogroups.com, "bumpersbird"
> > > > > wrote:
> > > > > > Mike,
> > > > > > I call Prevost and they told me it is Transynd by Castrol.
> > > > > > http://www.allisontransmission.com/service/transynd.jsp
> > > > > > I also had a level 3 service which replaces all filters. In
> > the
> > > > > > Allison 6 speed I think there are 3 internal filters and of
> > > > course
> > > > > > all oil, fuel and air filters. They greased everything that
> > could
> > > > be
> > > > > > grease and it also helped in the braking. I used to get a
> > noise
> > > > from
> > > > > > the front brake that was called normal but it has now quit.
> > > > > > I was told when I bought my coach that all the fluid &
> > filters
> > > > had
> > > > > > been changed but I really don't know for sure. But it did not
> > > > perform
> > > > > > like it does now.
> > > > > > What I do know is that I'm up to 5.5 to 6 MPG from 4.5 to 4.8
> > > > > > according to the SilverLeaf VMSpc.
> > > > > > Call it what you like, it's working for me.
> > > > > > Here's something to chew on. I don't know anything about H2O
> > > > helping
> > > > > > your fuel mileage but I know Propane injection works. On a
> > trip
> > > > last
> > > > > > summer I was at a Flying J in S.W. KY. At the RV island.
> > > > > > A trucker in a red and white Peterbuilt pulled in behind me.
> > I
> > > > > > thought that to strange in itself, so I went back to his
> > truck to
> > > > > > tell him I was going to be there a while for fuel and
> > propane.
> > > > > > He told me he was after propane. I asked why and he said he
> > had a
> > > > > > truck with propane injection and the outfit he drove for was
> > > > testing
> > > > > > the system on 20 or so trucks. I asked if it was working and
> > he
> > > > > > professed almost 2.5 MPG up on average.
> > > > > > I don't know about that, but I do know the guy whom works on
> > my
> > > > Ford
> > > > > > Powerstroke has a propane fire diesel pick up that with rip
> > and
> > > > > > snort, and he's getting better MPG than my truck gets
> > > > > > Kurt Horvath
> > > > > > 95 PT-42 WLWB
> > > > > > > wrote:
> > > > > > > > filters and the high grade transmission fluid really made
> > a
> > > > > > > > difference, about a mile per gallon and super smooth
> > > > shifting.
> > > > > > > HELLO! 1MPG from tranny fluid change!? Hey Kurt, feel free
> > to
> > > > > > > expound on the tranny fluid change. Synthetic I assume? I
> > > > have
> > > > > > been
> > > > > > > putting that change off for a while since the dino tranny
> > fluid
> > > > was
> > > > > > > fresh, but for 1MPG.....
> > > > > > > Thanks,
> > > > > > > Mike Bulriss
> > > > > > > 1991 WB40 "Texas Minivan" - in need of a quick cheap 1MPG
> > > > upgrade
> > > > > > > San Antonio, TX
> > > > > > > wrote:
> > > > > > > > Well you can tell I've been off the web for a while. My
> > > > computers
> > > > > > > > were infected by a Trojan virus late in Jan. It took a
> > while
> > > > and
> > > > > > a
> > > > > > > > new laptop to fix the problems. I lost a lot of files and
> > had
> > > > to
> > > > > > get
> > > > > > > > new credit cards. S.O.B.'s, "and I don't mean, Some Other
> > > > Bus" So
> > > > > > if
> > > > > > > > I repeat any request or post, or stuff you guys have
> > already
> > > > > > beaten
> > > > > > > > to death, forgive me.
> > > > > > > > Mike your right; I do recall seeing that coach listed for
> > a
> > > > while
> > > > > > > > now. If it's truly a good deal it won't stick around for
> > > > long.
> > > > > > I'll
> > > > > > > > go by Staley's if I have time just to look at her.
> > > > > > > > Paul, The Indulgence is safe at home and ready for this
> > > > weekend's
> > > > > > > > trip. I'm taking my daughter and 9 of her friends to
> > > > Nashville
> > > > > > for
> > > > > > > > their Senior Prom. Should be Hoot!
> > > > > > > > Bye the way my coach is not for sale, I like all Birds,
> > but
> > > > the
> > > > > > PT-
> > > > > > > > 42's are my favorite flavor, maybe a 43 would due but I
> > would
> > > > not
> > > > > > go
> > > > > > > > to a 40 footer of any mfg. Yes you're right I'm spoiled!
> > All
> > > > I
> > > > > > need
> > > > > > > > now is a Stacker Trailer that doesn't cost as much as my
> > > > coach,
> > > > > > so I
> > > > > > > > can load it up full of toys and its party time!
> > > > > > > > I had a full servicing done at Prevost Nashville a few
> > months
> > > > ago
> > > > > > and
> > > > > > > > it was well worth the money. All new filters & fluids,
> > the
> > > > new
> > > > > > tranny
> > a
> > > > shifting.
> > > > > > The
> > > > > > > > Jake is even smoother and not as radical, the jerking
> > upon
> > > > > > activation
> > > > > > > > has gone away. I'm a very happy camper. The brakes were
> > > > checked
> > > > > > for
> > > > > > > > wear and a full chassis lube, headlights adjusted and new
> > > > wiper
> > > > > > > > blades. She is ready to roll.
> > > > > > > > Kurt Horvath
> > > > > > > > 95 PT-42 WLWB
> > > > > > > > Damn the price of fuel! Full speed ahead!
> > > > <mbulriss@>
> > > > > > > > wrote:
> > > > > > > > > Being rather partial to green coaches, I tend to watch
> > for
> > > > > > them.
> > > > > > > > That
> > > > > > > > > one looks really good in the pictures, but it has been
> > on
> > > > > > > > consignment
> > > > > > > > > on Staley's lot for a *long* time. I distinctly
> > remember
> > > > the
> > > > > > > > > (HEADLINER IN FRONT LOUNGE HAS DAMAGE AND NEEDS TO BE
> > > > REPAIRED)
> > > > > > > > > comment. Odd there are no pictures of the damage. As I
> > > > recall,
> > > > > > > > > someone went to see it and had posted a rather negative
> > > > > > review. I
> > > > > > > > > searched for that post but can't find it right now.
> > > > > > > > > If someone remembers that post or went to see the
> > coach,
> > > > please
> > > > > > > > update
> > > > > > > > > us again.
> > > > > > > > > Mike Bulriss
> > > > > > > > > 1991 WB40 "Texas Minivan" (lot's of greeeeen, baby)
> > > > > > > > > San Antonio, TX
> > > > > > > > > wrote:
> > > > > > > > > > I ran across this coach will surfing this morning.
> > > > > > > > > > I like it but I don't know anything about it's
> > history.
> > > > > > > > > > The link is listed below
> > > > > > > > > > http://www.staleycoach.com/48350.htm
> > > > > > > > > > Kurt Horvath
> > > > > > > > > > 95 PT-42 WLWB
> > > > Use video conversation to talk face-to-face with Windows Live
> > > Messenger. Get started!
04-23-2008, 03:17
As a long-time VMSpc user, I do not doubt that the 1 mpg increase was seen. The
problem is in ascribing a particular cause to the phenomenon, sort of like "I
have cancer, and I know it was because that crop-duster flew too close to my
house when I was 10 years old."
I routinely see 1 mpg or more difference in trip segments. Most commonly
West-to-East is better than East-to-West, because of prevailing winds, but also
due to wind anomalies and of course gradient direction. A good head wind can
knock a full mpg off, as a tail wind can add an mpg, for a difference of 2.
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA
Hoping to head up the Oregon Coast tomorrow, and the forecast says I will have a
small tail wind Smile
04-23-2008, 03:38
Don,
I don't have that fancy VMSpc stuff. I have to do it the old fashion
way on each fill up, dividing miles by gallons with pencil or
calculator...... From what I read, I believe that you, Leroy and
others really like it, and it seems fairly accurate based on the posts
I have read.
Just out of curiosity, what has been your experience double-checking
the VMSpc box on mileage? I know my Jeep GC read-out on mpg isn't
even close. It's always waaaay optimistic by 3+mpg.
Thanks,
was seen. The problem is in ascribing a particular cause to the
phenomenon, sort of like "I have cancer, and I know it was because
that crop-duster flew too close to my house when I was 10 years old."
commonly West-to-East is better than East-to-West, because of
prevailing winds, but also due to wind anomalies and of course
gradient direction. A good head wind can knock a full mpg off, as a
> Don Bradner
> Eureka, CA
will have a small tail wind Smile
04-23-2008, 03:48
Over the course of the 7K miles I've put on Blue Thunder so far, VMSpc runs
about 5.1 vs 5.3 measured by calculation. So, I always take a bit less fuel than
the "Tank Minder" on VMSpc says I will need, which is a good thing!
On 4/23/2008 at 3:38 PM mbulriss wrote:
>Don,
>I have read.
>Thanks,
>Mike Bulriss
>San Antonio, TX
>> Don Bradner
>> Eureka, CA
>Yahoo! Groups Links
04-23-2008, 04:15
I do not use mine on a regular basis. I use it on long trips and I used it to verify the accuracy of my coach gauges. I have found that my coach gauges are extremely accurate so I typically rely on them and do not bother plugging up the computer to the DDL. One less things the kids fingers can mess with. They can use the PSP.
My coach runs better fuel economy on average than does Don's. My most recent short trips were in the 5.8 range. Of course most of that is on flat land. Wind, mountains, your gross weight, the cruise speed you decide to use, and other factors cause mileage to vary, including generator usage which the VMSpc cannot measure.
So the mileage is what it is and probably will remain so. I am to the point that I do not get fired up about it any longer because I know I ain't gonna get 6.5. lol
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Roale Conversion
Don Bradner
Over the course of the 7K miles I've put on Blue Thunder so far, VMSpc runs about 5.1 vs 5.3 measured by calculation. So, I always take a bit less fuel than the "Tank Minder" on VMSpc says I will need, which is a good thing!
>Don,
>I have read.
>Thanks,
>Mike Bulriss
>San Antonio, TX
>--- In "WanderlodgeForum%40yahoogroups.com", "Don Bradner"
Most
>> Don Bradner
>> Eureka, CA
>Yahoo! Groups Links
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. [url=http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR...o8Wcj9tAcJ ] Try it now.[/url]
04-23-2008, 07:15
Oh great Mike thanks for keeping me in the loop on this one.
All I can tell you is I spent $1,800.00 bucks to service my coach
with everything you can do to a 95 PT-42 with a series 60 and an
Allison 6 speed.
I haven't done the math by hand to determine mileage, but I always do
when I fill her up. The results to date on theVMSpc are very
accurate.
What is accurate is the coach is running better than ever, my
daughter even mentioned it to me on our way home last Sunday.
What isn't accurate are my coach gauges. I spent lots of time and $'S
trying to get them to function correctly and I finally gave up on
them. That's why I installed the Silverleaf VMSpc. Now I would not
drive without it. I'll go out on a limb here and say I would trust
the Detroit DDEC sooner than I would trust the old steam gauges.
An example the odometer on the coach, the odometer on the VMSpc and
the trip meter, have never reconciled with the same milage. The VMSpc
hour meter and the engine hour meter don't match. The only gauges I'm
sure are correct are the Speedo, Tach, and Volts. They read the same.
Oh, by the way, I'm busy fantasizing over better things than fuel
mileage
Kurt Horvath
95PT-42 WLWB
no
english/motoroil/other_products/mobil_1_extended_performance_oil_filte
rs.aspx
> and read their FAQs
> and
6V&8V92
P551670.
> Choose wisely.
but
> Mike Bulriss
> San Antonio, TX
8V92
> > > Mike and all,
frankly I
I
to the
have
oil
> > > consumption
miles.
within the
3000
smoke was
> > > Best to all,
> > > Alvie Miller
> > > Arthur IL
engines
cycle" to
> > > you.
related
general and
> > > in
using
> > > Amsoil
REQUIREMENTS —
was
> > > mainly
document is
mentions
> > > the
their
certifying the
that they
oils
> > > for
> > > > the newer engines?
said
> > > you
back to
50F? I
when DD
oils for
fact
2-
> > > cycles
shear
synthetics
way I
pass all
(Note: Even
anything
> > > oil I
> > > straight
standards
their
retired,
> > > and
fewer
> > > and
critical
15W-40
indicates
> > > that
above DD
spec for
> > > Kinematic
based
the old
DD 40W
Amsoil's
> > > TBN
(ASTM D
for
> > > your
recommended
any of
> > > the
requiring API
> > > SL,
> > > > SJ, SH or ACEA A3.
> > > > * Global DHD-1
> > > > * JASO DH-1
have
can
> > > prove
to set
> > > the
SAE
> > > and
got
> > > 100k
fantastic. Now
with under
Lots of
> > > > FWIW,
> > > > San Antonio, TX
Use
propane
to the
> > > > > Pete
on my
> > > > > FWIW
> > > > > From: aamiller@
Nashville
> > > > > Mike,
in the
I
> > > would
it
> > > done
van, my
> > > 05
> > > > > Alvie Miller
> > > > > 93 WLWB
> > > > > Arthur IL
<mbulriss@>
> > > > > wrote:
> > > > > > Kurt,
> > > Amsoil
1MPG
> > > > > > increase is 20%!
> > > > > > Mike Bulriss
> > > > > > San Antonio, TX
> > > > > > wrote:
> > > > > > > Mike,
Castrol.
filters. In
> > > the
and of
> > > > > course
that
> > > could
> > > > > be
a
> > > noise
> > > > > from
quit.
> > > filters
> > > > > had
did not
> > > > > perform
> > > > > > > like it does now.
to 4.8
about H2O
> > > > > helping
On a
> > > trip
> > > > > last
island.
behind me.
> > > I
his
> > > truck to
> > > propane.
said he
> > > had a
for was
> > > > > testing
working and
> > > he
works on
> > > my
> > > > > Ford
rip
> > > and
> > > > > > > Kurt Horvath
> > > > > > > 95 PT-42 WLWB
<mbulriss@>
really made
> > > a
smooth
> > > > > shifting.
free
> > > to
assume? I
> > > > > have
> > > > > > > been
tranny
> > > fluid
> > > > > was
> > > > > > > > Thanks,
> > > > > > > > Mike Bulriss
1MPG
> > > > > upgrade
> > > > > > > > San Antonio, TX
while. My
> > > > > computers
took a
> > > while
> > > > > and
> > > > > > > a
files and
> > > had
> > > > > to
> > > > > > > get
Other
> > > > > Bus" So
> > > > > > > if
have
> > > already
> > > > > > > beaten
listed for
> > > a
> > > > > while
around for
> > > > > long.
> > > > > > > I'll
this
> > > > > weekend's
to
> > > > > Nashville
> > > > > > > for
Birds,
> > > but
> > > > > the
> > > > > > > PT-
but I
> > > would
> > > > > not
> > > > > > > go
spoiled!
> > > All
> > > > > I
> > > > > > > need
as my
> > > > > coach,
> > > > > > > so I
few
> > > months
> > > > > ago
> > > > > > > and
fluids,
> > > the
> > > > > new
> > > > > > > tranny
really made
> > > a
smooth
> > > > > shifting.
> > > > > > > The
jerking
> > > upon
> > > > > > > activation
were
> > > > > checked
> > > > > > > for
and new
> > > > > wiper
> > > > > > > > > Kurt Horvath
> > > > > > > > > 95 PT-42 WLWB
> > > > > <mbulriss@>
watch
> > > for
> > > > > > > them.
> > > > > > > > > That
been
> > > on
> > > > > > > > > consignment
> > > remember
> > > > > the
TO BE
> > > > > REPAIRED)
As I
> > > > > recall,
negative
> > > > > > > review. I
now.
> > > coach,
> > > > > please
> > > > > > > > > update
> > > > > > > > > > us again.
> > > > > > > > > > Mike Bulriss
baby)
> > > > > > > > > > San Antonio, TX
> > > > > > > > > > --- In
morning.
> > > history.
> > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > 95 PT-42 WLWB
Live
04-23-2008, 07:32
A couple of ideas on your gauges. Mine work great and are very accurate as per my VMSpc.
Go to ww2.tflx.com and you may find the answer. Senders/sensors cannot be installed with pipe dope because it causes false readings. Make certain you have the correct sender because if a PO installed the wrong one for the gauge it will not register correctly. Find the main ground for the gauges probably in the lower load center and check the integrity.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Allison 6 speed.
accurate.
on the VMSpc and
mileage
Kurt Horvath
95PT-42 WLWB
--- In "WanderlodgeForum%40yahoogroups.com", "mbulriss" <mbulriss@..<wbr>.>
no
wasting
rs.aspx
> and read their FAQs
> and
> http://www.donaldson.com/en/engine/extendedservice/index.html
will have
6V&8V92
P551670.
> Choose wisely.
but
> Mike Bulriss
> San Antonio, TX
> --- In "WanderlodgeForum%40yahoogroups.com", "ronmarabito2002"
8V92
> > We all tend to
> > --- In "WanderlodgeForum%40yahoogroups.com", "whynotam"
> > > Mike and all,
frankly I
I
to the
have
oil
> > > consumption
miles.
within the
3000
smoke was
> > > Best to all,
> > > Alvie Miller
> > > Arthur IL
> > > --- In "WanderlodgeForum%40yahoogroups.com", "mbulriss" <mbulriss@>
engines
cycle" to
> > > you.
related
general and
> > > in
using
> > > Amsoil
Birds.
REQUIREMENTS —
was
> > > mainly
document is
mentions
> > > the
their
certifying the
that they
oils
> > > for
> > > > the newer engines?
> > > > Just for the
said
> > > you
back to
50F? I
when DD
oils for
fact
2-
> > > cycles
shear
> > > > Times
synthetics
way I
pass all
(Note: Even
anything
> > > oil I
> > > straight
standards
their
retired,
> > > and
fewer
> > > and
critical
15W-40
indicates
> > > that
above DD
spec for
meets all the
> > > Kinematic
based
the old
DD 40W
Amsoil's
> > > TBN
(ASTM D
for
> > > your
engine.
recommended
any of
> > > the
requiring API
> > > SL,
> > > > SJ, SH… or ACEA A3.
> > > > * Global DHD-1
> > > > * JASO DH-1
have
can
> > > prove
to set
> > > the
SAE
> > > and
got
> > > 100k
fantastic. Now
with under
Lots of
> > > > FWIW,
> > > > San Antonio, TX
Use
propane
to the
Pete
on my
> > > > > FWIW
> > > > > To: "WanderlodgeForum%40yahoogroups.com"
> > > > > From: aamiller@
Nashville
> > > > > Mike,
in the
I
> > > would
it
> > > done
van, my
> > > 05
> > > > > Alvie Miller
> > > > > 93 WLWB
> > > > > Arthur IL
<mbulriss@>
> > > > > wrote:
> > > > > > Kurt,
> > > Amsoil
1MPG
> > > > > > increase is 20%!
> > > > > > Mike Bulriss
> > > > > > San Antonio, TX
> > > > > > --- In "WanderlodgeForum%40yahoogroups.com", "bumpersbird"
> > > > > > > wrote:
> > > > > Mike,
Castrol.
filters. In
> > > the
and of
> > > > > course
that
> > > could
> > > > > be
a
> > > noise
> from
quit.
> > > filters
> > > > > had
did not
> > > > > perform
> > > > > > > like it does now.
to 4.8
anything
about H2O
> > > > > helping
On a
> > > trip
> > > > > last
island.
behind me.
> > > I
his
> > > truck to
> > > propane.
said he
> > > had a
> > > > > > > truck with propane
for was
> > > > > testing
working and
> > > he
works on
> > > my
> > > > > Ford
rip
> > > and
> > > > > > > Kurt Horvath
> > > > > > > 95 PT-42 WLWB
<mbulriss@>
really made
> > > a
smooth
> > > > > shifting.
free
> > > to
assume? I
> > > > > have
> > > > > > > been
tranny
> > > fluid
> > > > > was
> > > > > > > > Thanks,
> > > > > > > > Mike Bulriss
1MPG
> > > > > upgrade
> > > > > > > > San Antonio, TX
while. My
> > > > > computers
took a
> > > while
> > > > > and
> > > > > > > a
files and
> > > had
to
> > > > > > > get
Other
> > > > > Bus" So
> > > > > > > if
have
> > > already
> > > > > > > beaten
listed for
> > > a
> > > > > while
around for
> > > > > long.
> > > > > > > I'll
this
> > > > > weekend's
to
> > > > > Nashville
> > > > > > > for
Birds,
> > > but
> > > > > the
> > > > > > > PT-
but I
> > > would
> > > > > not
> > > > > > > go
spoiled!
> > > All
> > > > > I
> > > > > > > need
as my
> > > > > coach,
> > > > > > > so I
few
> > > months
> > > > > ago
> > > > > > > and
fluids,
> > > the
> > > > > new
> > > > > > > tranny
really made
> > > a
smooth
> > > > > shifting.
> > > > > > > The
jerking
> > > upon
> > > > > > > activation
were
> > > > > checked
> > > > > > > for
and new
> > > > > wiper
> > > > > > > > Kurt Horvath
> > > > > > > > > 95 PT-42 WLWB
> > > > > <mbulriss@>
watch
> > > for
> > > > > them.
> > > > > > > > > That
been
> > > on
> > > > > > > > > consignment
> > > remember
> > > > > the
TO BE
> > > > > REPAIRED)
As I
> > > > > recall,
negative
> > > > > > > review. I
> > > > > > > > > > searched for
now.
> > > coach,
> > > > > please
> > > > > > > > > update
> > > > > > > > > > us again.
> > > > > > > > > > Mike Bulriss
baby)
> > > > > > > > > > San Antonio, TX
> > > > > > > > > > --- In
morning.
> > > history.
> > > > > > > > > > > Kurt Horvath
> > > > 95 PT-42 WLWB
Live
04-23-2008, 08:20
That was all done still malfunctioning.New gauges & senders/sensors
from BB second time bought from telflex direct third time from some
guy in Calif.
Kurt Horvath 95 Pt-42 WLWB
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> bumpersbird wrote: Oh
> Allison 6 speed.
do
> accurate.
$'S
VMSpc
I'm
same.
> mileage
> Kurt Horvath
> 95PT-42 WLWB
is
> no
tranny
you
wasting
> rs.aspx
> > and read their FAQs
> > and
> 6V&8V92
> P551670.
> > Choose wisely.
claims,
> but
> > Mike Bulriss
> > San Antonio, TX
> 8V92
> > > > Mike and all,
> frankly I
has
way
as
> I
due
> to the
> have
Amsoil's
> oil
> > > > consumption
600
> miles.
> within the
> 3000
> smoke was
be
> > > > Best to all,
> > > > Alvie Miller
> > > > Arthur IL
<mbulriss@>
> engines
jokingly
> cycle" to
> > > > you.
> related
> general and
> > > > in
> using
> > > > Amsoil
> REQUIREMENTS —
update
> was
> > > > mainly
> document is
> mentions
> > > > the
In
> their
> certifying the
> that they
based
> oils
> > > > for
> > > > > the newer engines?
always
> said
> > > > you
> back to
40-
> 50F? I
> when DD
> oils for
in
> fact
> 2-
> > > > cycles
that
> the
for
> shear
> synthetics
The
> way I
> pass all
> (Note: Even
And
> anything
of
> the
> > > > oil I
a
> > > > straight
> standards
with
> their
> retired,
> > > > and
further,
> fewer
> > > > and
> critical
says: "In
> 15W-40
> indicates
> > > > that
operating
> above DD
oil
> spec for
> > > > Kinematic
sulfur
> based
> the old
> DD 40W
> Amsoil's
> > > > TBN
oil's
testing
> (ASTM D
bad
> for
> > > > your
> recommended
> any of
> > > > the
> requiring API
> > > > SL,
> > > > > SJ, SH or ACEA A3.
> > > > > * Global DHD-1
> > > > > * JASO DH-1
probably
> have
actually
> can
> > > > prove
wanted
> to set
> > > > the
API,
> SAE
> > > > and
we
> got
> > > > 100k
> fantastic. Now
people
> with under
good.
> Lots of
> > > > > FWIW,
Amsoil
> > > > > San Antonio, TX
who:
> Use
> propane
horsepower
> to the
> > > > > > Pete
oil
> on my
> > > > > > FWIW
> > > > > > From: aamiller@
> Nashville
> > > > > > Mike,
Marine
> in the
job.
> I
> > > > would
got
> it
> > > > done
> van, my
> > > > 05
> > > > > > Alvie Miller
> > > > > > 93 WLWB
> > > > > > Arthur IL
> <mbulriss@>
> > > > > > wrote:
> > > > > > > Kurt,
to
> the
> > > > Amsoil
cheaper.
> 1MPG
> > > > > > > increase is 20%!
> > > > > > > Mike Bulriss
> > > > > > > San Antonio, TX
> > > > > > > wrote:
> > > > > > > > Mike,
> Castrol.
> filters. In
> > > > the
> and of
> > > > > > course
everything
> that
> > > > could
> > > > > > be
get
> a
> > > > noise
> > > > > > from
now
> quit.
> > > > filters
> > > > > > had
it
> did not
> > > > > > perform
> > > > > > > > like it does now.
4.5
> to 4.8
> about H2O
> > > > > > helping
works.
> On a
> > > > trip
> > > > > > last
> island.
> behind me.
> > > > I
> his
> > > > truck to
> > > > propane.
> said he
> > > > had a
> for was
> > > > > > testing
> working and
> > > > he
> works on
> > > > my
> > > > > > Ford
with
> rip
> > > > and
> > > > > > > > Kurt Horvath
> > > > > > > > 95 PT-42 WLWB
> <mbulriss@>
> > > > wrote:
> > > > > > > > > --- In
> really made
> > > > a
> smooth
> > > > > > shifting.
feel
> free
> > > > to
> assume? I
> > > > > > have
> > > > > > > > been
> tranny
> > > > fluid
> > > > > > was
> > > > > > > > > Thanks,
> > > > > > > > > Mike Bulriss
cheap
> 1MPG
> > > > > > upgrade
> > > > > > > > > San Antonio, TX
> > > > > > > > > --- In
> while. My
> > > > > > computers
> took a
> > > > while
> > > > > > and
> > > > > > > > a
> files and
> > > > had
> > > > > > to
> > > > > > > > get
Some
> Other
> > > > > > Bus" So
> > > > > > > > if
> have
> > > > already
> > > > > > > > beaten
> listed for
> > > > a
> > > > > > while
> around for
> > > > > > long.
> > > > > > > > I'll
her.
for
> this
> > > > > > weekend's
friends
> to
> > > > > > Nashville
> > > > > > > > for
> Birds,
> > > > but
> > > > > > the
> > > > > > > > PT-
due
> but I
> > > > would
> > > > > > not
> > > > > > > > go
> spoiled!
> > > > All
> > > > > > I
> > > > > > > > need
much
> as my
> > > > > > coach,
> > > > > > > > so I
a
> few
> > > > months
> > > > > > ago
> > > > > > > > and
> fluids,
> > > > the
> > > > > > new
> > > > > > > > tranny
> really made
> > > > a
> smooth
> > > > > > shifting.
> > > > > > > > The
> jerking
> > > > upon
> > > > > > > > activation
brakes
> were
> > > > > > checked
> > > > > > > > for
adjusted
> and new
> > > > > > wiper
> > > > > > > > > > Kurt Horvath
> > > > > > > > > > 95 PT-42 WLWB
> > > > > > > > > > --- In
> > > > > > <mbulriss@>
to
> watch
> > > > for
> > > > > > > > them.
> > > > > > > > > > That
has
> been
> > > > on
> > > > > > > > > > consignment
distinctly
> > > > remember
> > > > > > the
NEEDS
> TO BE
> > > > > > REPAIRED)
damage.
> As I
> > > > > > recall,
> negative
> > > > > > > > review. I
> now.
> > > > coach,
> > > > > > please
> > > > > > > > > > update
> > > > > > > > > > > us again.
> > > > > > > > > > > Mike Bulriss
> baby)
> > > > > > > > > > > San Antonio, TX
> > > > > > > > > > > --- In
> morning.
it's
> > > > history.
> > > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > > 95 PT-42 WLWB
> Live
Try it now.
04-23-2008, 08:53
Damn, that sucks! BB disease I guess.
Leroy Eckert
Dahlonega, GA
Royale Conversion
guy in Calif.
--- In "WanderlodgeForum%40yahoogroups.com", Leroy Eckert
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> bumpersbird ...> wrote: Oh
> Allison 6 speed.
> I
do
> accurate.
$'S
VMSpc
I'm
same.
> mileage
> Kurt Horvath
> 95PT-42 WLWB
is
> no
tranny
you
wasting
> rs.aspx
> > and read their FAQs
> > and
> 6V&8V92
> P551670.
> > Choose wisely.
claims,
> but
> > Mike Bulriss
> > San Antonio, TX
> > > wrote:
> > > I'm
> 8V92
> > > > Mike and all,
> frankly I
has
way
as
> I
due
> to the
> have
Amsoil's
> oil
> > > > consumption
600
> miles.
> within the
> 3000
> smoke was
be
> > > > Best to all,
> > > > Alvie Miller
> > > > Arthur IL
<mbulriss@>
> engines
jokingly
> cycle" to
> > > > you.
> related
> general and
> > > > in
> using
> > > > Amsoil
> REQUIREMENTS —
update
> was
> > > mainly
> document is
> mentions
> > > > the
In
> their
> certifying the
> that they
based
> oils
> > > > for
> > > > > the newer engines?
always
> said
> > > > you
> back to
40-
> 50F? I
> when DD
> oils for
in
> fact
> 2-
> > > > cycles
that
> the
for
> shear
> synthetics
The
> way I
> pass all
> (Note: Even
And
> anything
of
> the
> > > > oil I
a
> > > > straight
> standards
with
> their
> retired,
> > > > and
further,
> fewer
> > > > and
> critical
says: "In
> 15W-40
> indicates
> > > > that
grade oil at engine
operating
> above DD
oil
> spec for
> > > > Kinematic
sulfur
> based
> the old
> DD 40W
> Amsoil's
> > > > TBN
oil's
testing
> (ASTM D
bad
> for
> > > > your
> recommended
> any of
> > > > the
> requiring API
> > > > SL,
> > > > > SJ, SH… or ACEA A3.
> > > > > * Global DHD-1
> > > > > * JASO DH-1
probably
> have
actually
> can
> > > > prove
wanted
> to set
> > > > the
API,
> SAE
> > > > and
we
> got
> > > > 100k
> fantastic. Now
people
> with under
good.
> Lots of
> > > > > FWIW,
thank you
Amsoil
> > > > > San Antonio, TX
who:
> Use
> propane
horsepower
> to the
> > > > > > Pete
oil
> on my
> > > > > > FWIW
> > > > > > From: aamiller@
> Nashville
> > > > > > Mike,
Marine
> in the
job.
> I
> > > > would
got
> it
> > > > done
> van, my
> > > > 05
> > > > > > Alvie Miller
> > > > > > 93 WLWB
> > Arthur IL
> <mbulriss@>
> > > > > > wrote:
> > > > > > > Kurt,
to
> the
> > > > Amsoil
cheaper.
> 1MPG
> > > > > > > increase is 20%!
> > > > > > > Mike Bulriss
> > > > > > > San Antonio, TX
> > > > > > > > wrote:
> > > > > > > > Mike,
> Castrol.
> filters. In
> > > > the
> > > > > > > > Allison 6 speed I
> and of
> > > > > > course
everything
> that
> > > > could
> > > > > > be
get
> a
> > > > noise
> > > > > > from
now
> quit.
> > > > filters
> > > > > > had
it
> did not
> perform
> > > > > > > > like it does now.
4.5
> to 4.8
> about H2O
> > > > > > helping
works.
> On a
> > > > trip
> > > > > > last
> island.
> behind me.
> > > > I
> his
> > > > truck to
> > > > propane.
> said he
> > > > had a
> for was
> > > > > > testing
> working and
> > > > he
> works on
> > > > my
> > > > > > Ford
with
> rip
> > > > and
> > > > > > > > Kurt Horvath
> > > > > > > > 95 PT-42 WLWB
> <mbulriss@>
> > > > wrote:
> > > > > > > > > --- In
> really made
> > > > a
> smooth
> > > > > > shifting.
feel
> free
> > > > to
> assume? I
> > > > > > have
> > > > > > > > been
> tranny
> > > > fluid
> > > > > > was
> > > > > > > > > Thanks,
> > > > > > > > > Mike Bulriss
cheap
> 1MPG
> > > > > > upgrade
> > > > > > > > > San Antonio, TX
> > > > > > > > > --- In
> while. My
> > > > > > computers
> took a
> > > > while
> > > and
> > > > > > > > a
> files and
> > > > had
> > > > > > to
> > > > > > > > get
Some
> Other
> > > > > > Bus" So
> > > > > > > > if
> have
> > > > already
> > > > > > > > beaten
> listed for
> > > > a
> > > > > > while
> around for
> > > > > > long.
> > > > > > > > I'll
her.
for
> this
> > > > > > weekend's
friends
> to
> > > > > > Nashville
> > > > > > > > for
> Birds,
> > > > but
> > > > > > the
> > > > > > > > PT-
due
> but I
> > > > would
> > > > > > not
> > > > > > > > go
> spoiled!
> > > > All
> > > > > > I
> > > > > > > > need
much
> as my
> > > > > > coach,
> > > > > > > > so I
a
> few
> > > > months
> > > > > > ago
> > > > > > > > and
> fluids,
> > > > the
> > > > > > new
> > > > > > > > tranny
> really made
> > > > a
> smooth
> > > > > > shifting.
> > > > > The
> jerking
> > > > upon
> > > > > > > > activation
brakes
> were
> > > > > > checked
> > > > > > > > for
adjusted
> and new
> > > > > > wiper
> > > > > > > > > > Kurt Horvath
> > > > > > > > > > 95 PT-42 WLWB
> > > > > > > > > > --- In
> > > > > > <mbulriss@>
to
> watch
> > > > for
> > > > > > > > them.
That
has
> been
> > > > on
> > > > > > > > > > consignment
distinctly
> > > > remember
> > > > > > the
NEEDS
> TO BE
> > > > > > REPAIRED)
damage.
> As I
> > > > > > recall,
> negative
> > > > > > > > review. I
> now.
> > > > coach,
> > > > > > please
> > > > > > > > > > update
> > > > > > > > > > > us again.
> > > > > > > > > > > Mike Bulriss
> baby)
> > > > > > > > > > > San Antonio, TX
> --- In
> morning.
it's
> > > > history.
> > > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > > 95 PT-42 WLWB
> Live
Try it now.
04-23-2008, 11:42
Hey it's all good Leroy. If I could keep the traditional BB dash and
make it all glass I would. One of the future projects I'm
fantasizing over.
Kurt Horvath
95 PT-42
Fayettville TN
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
some
> guy in Calif.
readings.
> > Leroy Eckert
> > Dahlonega, GA
> > Royale Conversion
coach
an
> > Allison 6 speed.
always
> do
> > accurate.
> $'S
on
not
trust
gauges.
> and
> VMSpc
gauges
> I'm
> same.
fuel
> > mileage
> > Kurt Horvath
> > 95PT-42 WLWB
there
> is
> > no
> tranny
in a
that
> you
> wasting
> > rs.aspx
> > > and read their FAQs
> > > and
have
> > 6V&8V92
> > P551670.
> > > Choose wisely.
> claims,
> > but
> > > Mike Bulriss
> > > San Antonio, TX
> the
> > 8V92
soot
> and
oil
> > wrote:
> > > > > Mike and all,
quite
> > frankly I
> has
are
> way
experience
> as
> > I
but
> due
> > to the
> and
> > have
> Amsoil's
engine
> > oil
> > > > > consumption
per
> 600
> > miles.
black
> > within the
after
> > 3000
Exhaust
> > smoke was
but
> be
synthetic
fineSmile
> > > > > Best to all,
> > > > > Alvie Miller
> > > > > Arthur IL
> <mbulriss@>
DD
> > engines
> jokingly
2-
> > cycle" to
> > > > > you.
lubrication
> > related
> > general and
> > > > > in
also
> > using
> > > > > Amsoil
> > REQUIREMENTS â€"
> update
> > was
> > > > > mainly
> > document is
only
> > mentions
> > > > > the
there.
> In
> > their
> > certifying the
odd
> > that they
> based
> > oils
> > > > > for
> > > > > > the newer engines?
> always
> > said
> > > > > you
change
> > back to
(above
> 40-
> > 50F? I
from
> > when DD
certifying
> > oils for
did
> in
> > fact
building
> the
> > 2-
> > > > > cycles
> that
> > the
then
> for
> > shear
The
> > synthetics
today.
> The
> > way I
synthetics
> > pass all
> > (Note: Even
> And
> > anything
specs
> of
> > the
> > > > > oil I
make
> a
> > > > > straight
> > standards
> with
> > their
get
> > retired,
> > > > > and
> further,
> > fewer
> > > > > and
strength,
> > critical
> says: "In
> > 15W-40
> > indicates
> > > > > that
> operating
well
> > above DD
> oil
> > spec for
all
> the
> > > > > Kinematic
> sulfur
petroleum
> > based
of
> > the old
> the
> > DD 40W
better.
> > Amsoil's
> > > > > TBN
an
> oil's
> testing
> > (ASTM D
considered
> bad
> > for
> > > > > your
is
> > recommended
requiring
> > any of
> > > > > the
> > requiring API
> > > > > SL,
> > > > > > SJ, SH… or ACEA A3.
> > > > > > * Global DHD-1
> > > > > > * JASO DH-1
> probably
> > have
> actually
> > can
> > > > > prove
> wanted
> > to set
> > > > > the
> API,
> > SAE
> > > > > and
if
> we
> > got
> > > > > 100k
> > fantastic. Now
> people
Suburban
> > with under
> good.
> > Lots of
> > > > > > FWIW,
you
> Amsoil
> > > > > > San Antonio, TX
> who:
> > Use
and/or
> > propane
> horsepower
> > to the
> > > > > > > Pete
weight
> oil
> > on my
> > > > > > > FWIW
> > > > > > > From: aamiller@
> > Nashville
> > > > > > > Mike,
> Marine
> > in the
> job.
> > I
> > > > > would
haven't
> got
> > it
> > > > > done
wife's
> > van, my
> > > > > 05
> > > > > > > Alvie Miller
> > > > > > > 93 WLWB
> > > > > > > Arthur IL
> > <mbulriss@>
> > > > > > > wrote:
> > > > > > > > Kurt,
over
> to
> > the
> > > > > Amsoil
> cheaper.
> > 1MPG
> > > > > > > > increase is 20%!
> > > > > > > > Mike Bulriss
> > > > > > > > San Antonio, TX
> > > > > > > > --- In
> > > > > > > > wrote:
> > > > > > > > > Mike,
> > Castrol.
> > filters. In
> > > > > the
filters
> > and of
> > > > > > > course
> everything
> > that
> > > > > could
> > > > > > > be
to
> get
> > a
> > > > > noise
> > > > > > > from
> now
> > quit.
fluid
> > > > > filters
> > > > > > > had
But
> it
> > did not
> > > > > > > perform
> > > > > > > > > like it does now.
from
> 4.5
> > to 4.8
anything
> > about H2O
> > > > > > > helping
> works.
> > On a
> > > > > trip
> > > > > > > last
> > island.
> > behind me.
> > > > > I
to
> > his
> > > > > truck to
> and
> > > > > propane.
he
> > said he
> > > > > had a
drove
> > for was
> > > > > > > testing
> > working and
> > > > > he
whom
> > works on
> > > > > my
> > > > > > > Ford
that
> with
> > rip
> > > > > and
gets
> > > > > > > > > Kurt Horvath
> > > > > > > > > 95 PT-42 WLWB
> > <mbulriss@>
> > > > > wrote:
> > > > > > > > > > --- In
> > really made
> > > > > a
> > smooth
> > > > > > > shifting.
Kurt,
> feel
> > free
> > > > > to
> > assume? I
> > > > > > > have
> > > > > > > > > been
dino
> > tranny
> > > > > fluid
> > > > > > > was
> > > > > > > > > > Thanks,
> > > > > > > > > > Mike Bulriss
> cheap
> > 1MPG
> > > > > > > upgrade
> > > > > > > > > > San Antonio, TX
> > > > > > > > > > --- In
> > while. My
> > > > > > > computers
It
> > took a
> > > > > while
> > > > > > > and
> > > > > > > > > a
of
> > files and
> > > > > had
> > > > > > > to
> > > > > > > > > get
mean,
> Some
> > Other
> > > > > > > Bus" So
> > > > > > > > > if
guys
> > have
> > > > > already
> > > > > > > > > beaten
coach
> > listed for
> > > > > a
> > > > > > > while
> > around for
> > > > > > > long.
> > > > > > > > > I'll
> her.
ready
> for
> > this
> > > > > > > weekend's
> friends
> > to
> > > > > > > Nashville
> > > > > > > > > for
all
> > Birds,
> > > > > but
> > > > > > > the
> > > > > > > > > PT-
> due
> > but I
> > > > > would
> > > > > > > not
> > > > > > > > > go
I'm
> > spoiled!
> > > > > All
> > > > > > > I
> > > > > > > > > need
> much
> > as my
> > > > > > > coach,
> > > > > > > > > so I
time!
Nashville
> a
> > few
> > > > > months
> > > > > > > ago
> > > > > > > > > and
> > fluids,
> > > > > the
> > > > > > > new
> > > > > > > > > tranny
> > really made
> > > > > a
> > smooth
> > > > > > > shifting.
> > > > > > > > > The
> > jerking
> > > > > upon
> > > > > > > > > activation
> brakes
> > were
> > > > > > > checked
> > > > > > > > > for
> adjusted
> > and new
> > > > > > > wiper
> > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > 95 PT-42 WLWB
> > > > > > > > > > > --- In
> > > > > > > <mbulriss@>
tend
> to
> > watch
> > > > > for
> > > > > > > > > them.
> > > > > > > > > > > That
it
> has
> > been
> > > > > on
> > > > > > > > > > > consignment
> distinctly
> > > > > remember
> > > > > > > the
> NEEDS
> > TO BE
> > > > > > > REPAIRED)
> damage.
> > As I
> > > > > > > recall,
rather
> > negative
> > > > > > > > > review. I
right
> > now.
see
> the
> > > > > coach,
> > > > > > > please
> > > > > > > > > > > update
> > > > > > > > > > > > us again.
> > > > > > > > > > > > Mike Bulriss
greeeeen,
> > baby)
> > > > > > > > > > > > San Antonio, TX
> > > > > > > > > > > > --- In
> > morning.
> it's
> > > > > history.
> > > > > > > > > > > > > Kurt Horvath
> > > > > > > > > > > > > 95 PT-42 WLWB
Windows
> > Live
Mobile.
> Try it now.
Try it now.
