no suspension FC35
05-21-2005, 23:17
no suspension FC35
Butch, does your air dryer release air all the time? If so- sounds like your
air governor is out. Easy, cheap fix. Give us some more info and we can narrow your problem further. Ernie, 83PT40 in Texas [Non-text portions of this message have been removed] |
05-22-2005, 02:45
no suspension FC35
I know this has been asked several times. But not having the problem
at the time is blasted by the posting. My suspension won't air up both front and rear. I get the usual 75+ lbs on the front and rear guages. I did notice that the air dryer dosn't release the ocasional air blast. WhenI toggle the susp dump some air does escape but nowhere near as much as if I had suspension. The only comonality I can see between the front and rear, by the scematic, is the filter regulator just behind the street side air tank. I took the regulator apart and didn't see anything significant. When I re-enstalled it I left one of the output connection off. When I aired up there was air escaping from the not connected fitting, but how much? Any help would be apreciated; Butch "Sojourn" 83(82)FC35SB |
05-22-2005, 05:23
no suspension FC35
You might have a blown air bag.
Run the engine with the suspension dumped, you should get to around 125psi on both gauges. Pump the brakes to bring the pressure down as you turn off the dump switch. If switching the dump switch back off prevents the coach from building over 75psi then it is a suspension leak. If it will not build over 75psi with the suspension dumped then you have a leak or problem elsewhere, need to narrow it down. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "bchauvette" <bchauvette@a...> wrote: > I know this has been asked several times. But not having the problem > at the time is blasted by the posting. > > My suspension won't air up both front and rear. I get the usual 75+ > lbs on the front and rear guages. I did notice that the air dryer > dosn't release the ocasional air blast. WhenI toggle the susp dump > some air does escape but nowhere near as much as if I had suspension. > The only comonality I can see between the front and rear, by the > scematic, is the filter regulator just behind the street side air > tank. I took the regulator apart and didn't see anything significant. > When I re-enstalled it I left one of the output connection off. When I > aired up there was air escaping from the not connected fitting, but > how much? > > Any help would be apreciated; > > Butch "Sojourn" 83(82)FC35SB |
