air from up front
04-24-2008, 10:06
air from up front
I HAVE A 1990 WB40 IN THE FRONT END COMPARTMENT I TOOK THE LONG DOOR
OFF
ONE OF THE AIR VALVES I GUESS IS HISSING IS THIS NORMAL???
IT HAS YELLOW PLASTIC CAPS ON THE ENDS OF IT
IF NOT ARE THEY REPAIRABLE??
04-24-2008, 12:24
air from up front
you may want to go to a truck shop and have a complete go over on
your air brakes . The inspection is called a DOT check up. cost about
$75.00 in California. The questions you ask are good but the questions
you may not be asking can cause some damage. They can teach you a bit
if you study one of the many air brake diagrams of previous posts and
familiarize yourself with the appliances and functions prior to a
scheduled DOT visit.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "gasparillaglass"
> OFF
