DC amp meter on dash
03-21-2008, 06:55
Thanks to everyone for their input. I have replaced both alternators
with new ones. When I start the bus, I get about 14.2 on the dc volt
meter on the dash. I initially get about 100 amps on the ampmeter on
the dash but drops off slowly to almost 0 in 3 to 4 seconds. Any
ideas? All information is greatly appreciated.
Gus 89PT40 8V92T
Houston, Tx
03-21-2008, 08:22
Gus. That can be normal with good batteries that are fully charged. Try turning the heaters on to put a load on the system. That should put a load on the batteries and cause the alternators toincrease output.
Paul Downey
Versailles Ky
83 PT 35
Our Rollin Home for sale
Create a Home Theater Like the Pros. Watch the video on AOL Home.
03-23-2008, 05:02
Just this Morning at Amicalola Falls, GA in the mountains with temps at 29 degrees my amp gauge registered a draw of 150 amps on cold start, and dropped back to 50 amps where it runs normally in about 5 minutes. That sounds normal to me.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
ampmeter on
Gus 89PT40 8V92T
Houston, Tx
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. [url=http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR...o8Wcj9tAcJ ] Try it now.[/url]
03-23-2008, 17:25
Thanks for all the input. I put a load on the system as Paul
suggested by turning on the heaters,all the lights, and the dash AC.
The meter showed a little over 50 amps.
It's on to my next fix.
Gus 89pt40 8v92t
Houston, Tx
> Leroy Eckert
> Dahlonega, GA
volt
on
> Gus 89PT40 8V92T
> Houston, Tx
Try it now.
