Repair Service
04-29-2008, 04:22
Repair Service
Hi all, we wanted to let you know of a great repair shop we found in
Waco, TX. We were traveling to the Lone Star Rally, in Boerne, when our engine kept going into a fault and wanted to shut down. We have had this intermittent problem for over a year, but could not be diagnosed properly. Found this shop on line and called them. Daniel Moravec, their Service Manager, gave us directions and said to come on in immediately. When we arrived he, Daniel, and another mechanic, Aaron, promptly diagnosed and repaired our problem. We were in and out in an hour and a half. Friendly and efficient, we would go back to them for any kind of service we needed. I should mention that they are a Detroit, Allison and Perkins shop. Diesel Power Supply Co., Waco, TX, 254 753-1587 Paul & Jo Carver 1993 WLWB Seven Points, TX |
04-29-2008, 04:23
Repair Service
What was the problem and how was it corrected?
In a message dated 4/29/2008 11:25:20 A.M. Central Daylight Time, jocarver@... writes:
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. |
04-30-2008, 03:32
Repair Service
It seems that the temperature sensor, at the expansion tank, went
bad. We had run low on coolant. However, after adding coolant the sensor would malfunction, wanting to shut down the engine. After replacing the sensor and, driving 800 miles, we have had no further problems. The original diagnosis was low voltage. We replaced all three starting batteries. Still had intermittent fault. Then was advised to replace the coach batteries. So, we replaced all 8 of those. Now, after a little over $2000.00 the coach is running great. Paul & Jo Carver 1993 WLWB Seven Points, TX --- In WanderlodgeForum@yahoogroups.com, ciao70@... wrote: > > What was the problem and how was it corrected? > > > In a message dated 4/29/2008 11:25:20 A.M. Central Daylight Time, > jocarver@... writes: > > > > > Hi all, we wanted to let you know of a great repair shop we found in > Waco, TX. We were traveling to the Lone Star Rally, in Boerne, when > our engine kept going into a fault and wanted to shut down. We have had > this intermittent problem for over a year, but could not be diagnosed > properly. Found this shop on line and called them. Daniel Moravec, > their Service Manager, gave us directions and said to come on in > immediately. When we arrived he, Daniel, and another mechanic, Aaron, > promptly diagnosed and repaired our problem. We were in and out in an > hour and a half. Friendly and efficient, we would go back to them for > any kind of service we needed. I should mention that they are a > Detroit, Allison and Perkins shop. > > Diesel Power Supply Co., Waco, TX, 254 753-1587 > > Paul & Jo Carver > 1993 WLWB > Seven Points, TX > > > > > > > > **************Need a new ride? Check out the largest site for U.S. used car > listings at AOL Autos. > (http://autos.aol.com/used?NCID=aolcmp00300000002851) > |
04-30-2008, 03:33
Repair Service
Right, just add money!
BradBarton00LXiDFW bbartonwx@...
Spell a grand slam in this game where word skill meets World Series. Get in the game. |
