Repair Service
04-29-2008, 04:22
Repair Service
Hi all, we wanted to let you know of a great repair shop we found in
Waco, TX. We were traveling to the Lone Star Rally, in Boerne, when
our engine kept going into a fault and wanted to shut down. We have had
this intermittent problem for over a year, but could not be diagnosed
properly. Found this shop on line and called them. Daniel Moravec,
their Service Manager, gave us directions and said to come on in
immediately. When we arrived he, Daniel, and another mechanic, Aaron,
promptly diagnosed and repaired our problem. We were in and out in an
hour and a half. Friendly and efficient, we would go back to them for
any kind of service we needed. I should mention that they are a
Detroit, Allison and Perkins shop.
Diesel Power Supply Co., Waco, TX, 254 753-1587
Paul & Jo Carver
1993 WLWB
Seven Points, TX
04-29-2008, 04:23
Repair Service
What was the problem and how was it corrected?
In a message dated 4/29/2008 11:25:20 A.M. Central Daylight Time, jocarver@... writes:
Paul & Jo Carver
1993 WLWB
Seven Points, TX
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
04-30-2008, 03:32
Repair Service
It seems that the temperature sensor, at the expansion tank, went
bad. We had run low on coolant. However, after adding coolant the
sensor would malfunction, wanting to shut down the engine. After
replacing the sensor and, driving 800 miles, we have had no further
problems. The original diagnosis was low voltage. We replaced all
three starting batteries. Still had intermittent fault. Then was
advised to replace the coach batteries. So, we replaced all 8 of
those.
Now, after a little over $2000.00 the coach is running great.
Paul & Jo Carver
1993 WLWB
Seven Points, TX
in
when
had
diagnosed
Aaron,
an
for
> Paul & Jo Carver
> 1993 WLWB
> Seven Points, TX
> **************Need a new ride? Check out the largest site for U.S.
used car
> (http://autos.aol.com/used?NCID=aolcmp00300000002851)
04-30-2008, 03:33
Repair Service
Right, just add money!
Date: Wed, 30 Apr 2008 15:32:33 +0000
Subject: [WanderlodgeForum] Re: Repair Service
those.
Paul & Jo Carver
1993 WLWB
Seven Points, TX
in
when
had
diagnosed
Aaron,
an
for
> Paul & Jo Carver
> 1993 WLWB
> Seven Points, TX
used car
Spell a grand slam in this game where word skill meets World Series. Get in the game.
