Weak generator battery
05-06-2008, 20:05
Tom Sorrentino ('87 PT38) and I finally solved the loss of voltage
across the diode on our generator batteries with the installation of a Battery Link ACR from Blue Sea Systems. For anyone with a mid-80's coach that has a generator without its own alternator, Blue Bird installed a diode to permit the on-board battery chargers to also charge the genset battery, but keep it isolated from the house batteries when necessary. As many of you have experienced, this arrangement never quite allowed the genny battery to get topped off because of the voltage loss across the diode. We installed these units this past weekend and so far they work beautifully. I'm now seeing 14.4 volts at the genny battery and 14.4 volts at the engine batteries in my PT when the charger is on and the ACR is in "combine" mode. Once the charger is off and the voltage drops off to around 13.2 volts, the two banks disconnect and remain apart until the house voltage rises above 13.4 volts again (or I rock the Aux battery switch to "on"). The Blue Sea unit was around $90 and is an easy "drop-in" replacement for the diode- although we used heavier 6-ga. cable to allow more power across the ACR. It is also a good idea to install an 80-amp resettable breaker in line with the ACR in case there is ever a short in the genny battery circuit. Shane Fedeli 85PT40 Hershey, PA |
05-07-2008, 00:57
Shane, sounds like a good device for my three bank system. Is the
blueSea able to pass 79 amps? Or return pass the request amps of a failed start using aux "combined"??? the mfg calls it a charging link. recharging a genset battery should draw no more than 20 amps. with a good starter the momentary "combined" to start should not be needed. I would think 79 amps would cook the BlueSea and the only time there would be a big cross would be using aux to make a start of gen or the detroit with compramised starters. I now use mini alligator clips and 14 ga wire to charge my add on genset battery and have no issue unless I drain the battery when boondocking by not unclipping a clip. I think charging and starter issues begin with overuse of momentary aux "combined"???? a link to Shanes find: http://www.nulime.com/Blue-Sea-7600-CL-S...CR/p237402 or http://tinyurl.com/5aeaer GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Tom Sorrentino ('87 PT38) and I finally solved the loss of voltage > across the diode on our generator batteries with the installation of a > Battery Link ACR from Blue Sea Systems. For anyone with a mid-80's > coach that has a generator without its own alternator, Blue Bird > installed a diode to permit the on-board battery chargers to also > charge the genset battery, but keep it isolated from the house > batteries when necessary. As many of you have experienced, this > arrangement never quite allowed the genny battery to get topped off > because of the voltage loss across the diode. We installed these units > this past weekend and so far they work beautifully. I'm now seeing > 14.4 volts at the genny battery and 14.4 volts at the engine batteries > in my PT when the charger is on and the ACR is in "combine" mode. Once > the charger is off and the voltage drops off to around 13.2 volts, the > two banks disconnect and remain apart until the house voltage rises > above 13.4 volts again (or I rock the Aux battery switch to "on"). The > Blue Sea unit was around $90 and is an easy "drop-in" replacement for > the diode- although we used heavier 6-ga. cable to allow more power > across the ACR. It is also a good idea to install an 80-amp resettable > breaker in line with the ACR in case there is ever a short in the > genny battery circuit. > > Shane Fedeli > 85PT40 > Hershey, PA > |
05-07-2008, 02:57
Hi Greg,
I put an 80 amp resettable marine grade circuit breaker in the charging compartment with the ACR (Automatic Charging Relay)to prevent it from ever getting cooked. Although it has an internal self-limiting protective element, the only way that I could forsee that happening would be if the batteries were all linked and you hit the genny start switch or main engine start while you had extremely low voltage in one bank. The only time that the two banks become linked on my coach is when there is a charge over 13.4 volts- but that can be adjusted up to 14 volts. Since it is designed for marine use on an alternator-charged system- the presence of plug-in shore power (as opposed to genset or alternator power) presents a new dynamic that should/can be addressed with the resettable breaker. Since we never fried the old diode (which only had 10 ga. wires in my coach), I'm guessing that there are very few situations where the call for power across the ACR would exceed 80 amps. Also, in response to your question about a 3-bank system, the unit is designed to work on only two banks, so I would connect it to your house and genset banks only. The main engine bank can easily get a charge directly from the on-board inverter/charger. Most of them already have an extra connection for a second bank of batteries. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Shane, sounds like a good device for my three bank system. Is the > blueSea able to pass 79 amps? Or return pass the request amps of a > failed start using aux "combined"??? the mfg calls it a charging > link. recharging a genset battery should draw no more than 20 amps. > with a good starter the momentary "combined" to start should not be > needed. I would think 79 amps would cook the BlueSea and the only > time there would be a big cross would be using aux to make a start > of gen or the detroit with compramised starters. I now use mini > alligator clips and 14 ga wire to charge my add on genset battery > and have no issue unless I drain the battery when boondocking by not > unclipping a clip. I think charging and starter issues begin with > overuse of momentary aux "combined"???? > > a link to Shanes find: > > http://www.nulime.com/Blue-Sea-7600-CL-S...CR/p237402 > > or > > http://tinyurl.com/5aeaer > > > GregoryO'Connor > 94ptRomolandCa > |
