Generator Fan Relay
05-23-2005, 04:03
Generator Fan Relay
I have a 12.5 Kohler Gen with the perkins, I replaced the electric
cooling fan on the radiator, the fan does not come on at all when the temp rises and the overheating protection trips the reset button on the control box. Can anyone tell me where the thermostat relay is for this motor? Thanks Derk Allaben 79 FC 35 |
05-23-2005, 04:39
Generator Fan Relay
The Kohler 12.5 doesn't (originally) have a thermoswitch for the
cooling fan, it operates directly from the 220v output of the generator. As soon as genset puts out 220v the fan should be running. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "derkallaben" wrote: > I have a 12.5 Kohler Gen with the perkins, I replaced the electric > cooling fan on the radiator, the fan does not come on at all when the > temp rises and the overheating protection trips the reset button on the > control box. Can anyone tell me where the thermostat relay is for this > motor? > Thanks > Derk Allaben > 79 FC 35 |
05-23-2005, 04:53
Generator Fan Relay
My 12.5 has a Kysor thermoswitch in the neck set at 195. The switch is
normally closed so when the temp rises it opens, relay transfers and the fan starts. Oene Pomper 85 PT40 >>> dallaben@... 05/23/05 12:03 PM >>> I have a 12.5 Kohler Gen with the perkins, I replaced the electric cooling fan on the radiator, the fan does not come on at all when the temp rises and the overheating protection trips the reset button on the control box. Can anyone tell me where the thermostat relay is for this motor? Thanks Derk Allaben 79 FC 35 Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
