Refrigerator fans
05-18-2008, 15:13
Refrigerator fans
Folks,
Last year we had a chat about refrigerator fans, specifically putting one behind the fridge to blow over the coils. Several members tied theirs into the "refrigerator fan" switch in the coach. I'd like to do the same, as my switch doesn't seem to do anything - no fans come on that I can find. I'm thinking someone removed mine at one point in time - I know the fridge itself has been replaced. So my question is, do I need to fish a wire back up to the switch, or does the wiring already go somewhere - and if so, where might I find it? -Ryan '86 PT-40 8V92 |
05-18-2008, 16:35
Refrigerator fans
> > So my question is, do I need to fish a wire back up to the switch, or > does the wiring already go somewhere - and if so, where might I find > it? > > -Ryan > '86 PT-40 8V92 > Ryan, On mine, the inside switch runs to a fan mounted behind the refrig. You can access it by removing the outside refrigerator panel. However, there was not enough room to remove/replace the fan through this opening. I replaced my refrigerator with a new one and fixed the fan while I was at it. I would assume you still have the wire somewhere behind the refrigerator. Regards, Glenn 1986 PT-40 Marietta, GA |
05-19-2008, 00:01
Refrigerator fans
I did this, and was able to find the wiring for the fan switch behind
the fridge in the outside access panel. If your fan is gone like mine was, there should be some random wires not hooked to anything. Bought a 6-inch computer-type fan at Radio Shack and put it in there blowing straight up across the coils. It's good for 10 degrees on a hot day. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Folks, > > Last year we had a chat about refrigerator fans, specifically putting > one behind the fridge to blow over the coils. Several members tied > theirs into the "refrigerator fan" switch in the coach. I'd like to do > the same, as my switch doesn't seem to do anything - no fans come on > that I can find. I'm thinking someone removed mine at one point in > time - I know the fridge itself has been replaced. > > So my question is, do I need to fish a wire back up to the switch, or > does the wiring already go somewhere - and if so, where might I find > it? > > -Ryan > '86 PT-40 8V92 > |
05-19-2008, 03:23
Refrigerator fans
Great RV rv-refer site listed below. has a tutorial on how it makes
cold out of a flame. My thinking on the fan is not so much a need to blow air over the coil but to move air out of the stack/vent. when the outsie temp is as hot as the air behind the refer, there is no (hot air rises) convection. may be all that is needed is a fan in the vent pointing out. keep in mind that there is no benifit to cooling off the boiler. I noticed little help when I just added a fan untill I mounted it in a box and shrouded the boiler. I now have no issues even at 115. my fan http://www.pbase.com/gregoryoc/wanderlod...cts&page=3 RV refer site http://www.rvmobile.com/ GregoryO'Connor --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Folks, > > Last year we had a chat about refrigerator fans, specifically putting > one behind the fridge to blow over the coils. Several members tied > theirs into the "refrigerator fan" switch in the coach. I'd like to do > the same, as my switch doesn't seem to do anything - no fans come on > that I can find. I'm thinking someone removed mine at one point in > time - I know the fridge itself has been replaced. > > So my question is, do I need to fish a wire back up to the switch, or > does the wiring already go somewhere - and if so, where might I find > it? > > -Ryan > '86 PT-40 8V92 > |
05-19-2008, 05:46
Refrigerator fans
Ryan,
Since we both have 86 PT40's lets assume they we are set up the same.
Get a mirrow and light and look up on the inside of the outer wall of the refrigerator access opening. See if you see one of the small quarter size pancake thermostats.The wire from the refrigerator on/off switch runs to this thermostat and then to the fan. If you turn the refrigerator fan switchon the fan will not come on until thethermostatcalls for it.I bought my replacement fan from BB in 2006. Hope this helps.
Howard Truitt
Camilla, Ga.
86 8V92 PT40
05-19-2008, 12:40
Refrigerator fans
Ryan,
Cooling the refrigerator compartment. A quick description, after looking at others solutions and reading all available info which unfortunately the reference files I had saved for this project were lost to a computer virus. I added the address for the photos at each step I hope they come up for you, if you paste them in the address line they may or may not come up. If not they are in my album , (bumpersbird) bottom of page two and top of page three. The goal is to move air past the cooling coil mounted on the rear of the fridge, in my case a Dometic RM 7030. I have an angled setup with an enormous space behind the refer. It is recommended that there be no more than 1" a space behind the fridge to facilitate convection for cooling the coils. Well I'm not one to reinvent the wheel so I wasn't going to pull out the fridge to build a baffle system, the recommended fix. Ryan, this won't be so much of a problem for you if your fridge is 1" or less from the wall behind it. The origonal fan and snap thermostat set up should work good if it's all there and working. To move a sufficient amount of air past the coils. You have two choices you can suck or blow. Blowing is not recommended, but it works. Greg's system is set up this way and after a little tweeking it works fine. So how do you suck enough air volume past the coils to make a difference? I not an engineer so I went for POWER! You know the old saying. Put enough thrust behind anything and it will fly. I mounted 5 - 130 CFM computer fans inside the flue vent on the roof. http://autos.ph.groups.yahoo.com/group/W...tos/view/7 006?b=29 I got a marine style switch with a four switch/breaker combo. I chose waterproof because I mounted it on the cabinet near the sink in the bathroom and because its high quality and most of all because it looks cool. http://autos.ph.groups.yahoo.com/group/W...tos/view/7 006?b=32 I tagged into the 12V power leading into the fridge. http://autos.ph.groups.yahoo.com/group/W...tos/view/7 006?b=30 Not a big draw for the fans and the fridge doesn't draw anywhere near the 20 amps supplied to it. I used 2 of the 4 switches leaving 2 for future use. I wired the switches, #1 runs 2 fans, #2 runs 3 fans so I have the capability to run 2 fans @ 260 cfm, 3 fans@ 390 cfm or 5 fans@ 650 cfm. Yes if you're standing near the access hatch you know its working. On a calm day it will suck in cigar smoke in from 12" to 14" away. I also mounted 4 fans in the fridge that blow air across the cooling fins inside the fridge and of course they circulate the internal air. http://autos.ph.groups.yahoo.com/group/W...tos/view/7 006?b=33 They are powered from the internal light assembly and mounted in pairs they are quite nice. I got them from a guy on e-bay. Once you see these little jewels you'll want them to. I check e-bay for this guy and he's not making any fans at this time The only problem I had was getting the wiring up to the fans. I used a piece of pvc pipe I don't remember the size I just grabbed some pipe that was laying around the barn and some mounting clamps, inserting the require wires into the conduit before mounting the conduit to the wood walls. http://autos.ph.groups.yahoo.com/group/W...tos/view/7 006?b=31 I poked a hole up through the protective screen in the flue vent, keeping it smaller than the diameter of the pipe so it has a good grip on it. I had to drill one hole through the wall to run the wires into the bathroom. A glob of silicon sealed the hole and holds things firmly to prevent chaffing. I also used wire loom where possible. Problem solved. So far so good, this summer will tell if its working as well as I think it will. I have already had to set the thermostat up to keep everything on the lower shelves from freezing. Is it noisy? Yes Is it bothersome? Somewhat Choice between noise and cold beer? Only you can answer that. The fans are the big computer fans 4.7" @130cfm. There are fans of this size that have a lower cfm and are much quieter to operate. I have used these same fans to replace the blowers on some of my heaters and they are quiet compared to the fridge set up. The only thing I can think of is the fridge cabinet is hollow it may amplify the noise. This post is a little long and may not help a lot in your application, but if you have a big space behind the fridge this will work. Kurt Horvath 95 PT-42 WLWB |
05-19-2008, 16:28
Refrigerator fans
Ah ha! Appreciate everyone's replies - Howard's was the key. I found
that thermostat exactly where you said it would be and traced the wires. They went into a wiring loom, but came right down and were hiding amongst some others, disconnected and taped up. I put a big DC fan in there blowing air out the access panel, and now my fan switch in the coach works just like it's supposed to. Huge thank you to all! This was much, much easier than trying to trace the wires from the fan switch back through the coach, which is what I'd have had to do without this list. You folks are one of the big reasons I bought a Wanderlodge. So glad to have this community support. -Ryan '86 PT-40 8V92 (with a refrigerator that should work in hot weather, now - we'll find out tomorrow!) On Mon, May 19, 2008 at 10:46 AM, Howard O. Truitt > Ryan, > Since we both have 86 PT40's lets assume they we are set up the same. > Get a mirrow and light and look up on the inside of the outer wall of the > refrigerator access opening. See if you see one of the small quarter size > pancake thermostats. The wire from the refrigerator on/off switch runs to > this thermostat and then to the fan. If you turn the refrigerator fan > switch on the fan will not come on until the thermostat calls for it. I > bought my replacement fan from BB in 2006. Hope this helps. > Howard Truitt > Camilla, Ga. > 86 8V92 PT40 > |
05-19-2008, 16:41
Refrigerator fans
Kurt,
Hey. very interesting. Thank you for taking the time to write this up. The pictures came up fine and I like the idea of the roof mount fans even better. Actually, it's probably quieter than what I put in, given that the fans are further away. I may get up on my roof tomorrow evening and move my fan up there, and add a couple more while I'm at it. As for the choice between cold beer and noise, I'll turn the music up to compensate and take both. ;-) -Ryan On Mon, May 19, 2008 at 5:40 PM, bumpersbird > Ryan, > > Cooling the refrigerator compartment. |
05-19-2008, 16:48
Refrigerator fans
"As for the choice between cold beer and noise, I'll turn the music up
to compensate and take both. ;-)" AHAHAHAHAH! Good Man! Betty brought home a 12 pak of Bud Lite Lime...anyone want the other eleven? On Mon, May 19, 2008 at 9:41 PM, Ryan Wright <"ryanpwright@gmail.com"> wrote:
05-20-2008, 01:24
Refrigerator fans
'Out the access panel' is reverse the design convection path.
sucking air out of the compartment as you do with the fan blowing out seems safer as it wont +pressurize the compartment and blow air thru leaks that may put hot air and propane into the bus interior. I dont know if a big airmovement is the key. my fan blows low cfm . I think the down fall is stale air. If you look at the model on how the amonia system works, I think gradual cooling is part of einsteins process. the amonia must process up the coil because the fridge cooling is later in the cycle. You may note that access pannels seem to open below the floor of the propane appliance. I just wonder if that is by design to keep leaking heavy gas from being trapped in the compartment. modifications may want to maintain the open container design. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Ah ha! Appreciate everyone's replies - Howard's was the key. I found > that thermostat exactly where you said it would be and traced the > wires. They went into a wiring loom, but came right down and were > hiding amongst some others, disconnected and taped up. I put a big DC > fan in there blowing air out the access panel, and now my fan switch > in the coach works just like it's supposed to. > > Huge thank you to all! This was much, much easier than trying to trace > the wires from the fan switch back through the coach, which is what > I'd have had to do without this list. You folks are one of the big > reasons I bought a Wanderlodge. So glad to have this community > support. > > -Ryan > '86 PT-40 8V92 (with a refrigerator that should work in hot weather, > now - we'll find out tomorrow!) > > On Mon, May 19, 2008 at 10:46 AM, Howard O. Truitt > > > Ryan, > > Since we both have 86 PT40's lets assume they we are set up the same. > > Get a mirrow and light and look up on the inside of the outer wall of the > > refrigerator access opening. See if you see one of the small quarter size > > pancake thermostats. The wire from the refrigerator on/off switch runs to > > this thermostat and then to the fan. If you turn the refrigerator fan > > switch on the fan will not come on until the thermostat calls for it. I > > bought my replacement fan from BB in 2006. Hope this helps. > > Howard Truitt > > Camilla, Ga. > > 86 8V92 PT40 > > > |
