Camera cables
05-19-2008, 11:34
Camera cables
My quest to upgrade the rear view camera continues...
Today, I managed to get the old camera and old monitor out of the bus. This, of course, has raised a new question for me. In my old FC, I changed out the old camera with a modern one. I kept the old monitor, which worked fine. I was able (using some connection adapters from Radio Shack) to plug the new camera right into the original coax camera cable. Presto! New camera worked great. With that in mind, my hope was that I would be able to change out the camera and the monitor on my PT and just plug each of them into the original cable, thereby saving me the headache of running a new cable. The problem? The original monitor doesn't have a coax plugged into the back like I expected...just a pin connector with several small wires on it. So my question...does anyone know where the single cable that comes out of the camera terminates? And, am I just being foolish to believe I can use that old cable with a new camera and LCD monitor anyway? Scott Forman 86 PT38 Memphis |
05-19-2008, 13:09
Camera cables
wrote: > > My quest to upgrade the rear view camera continues... > > Today, I managed to get the old camera and old monitor out of the > bus. This, of course, has raised a new question for me. > > In my old FC, I changed out the old camera with a modern one. I kept > the old monitor, which worked fine. I was able (using some > connection adapters from Radio Shack) to plug the new camera right > into the original coax camera cable. Presto! New camera worked > great. > > With that in mind, my hope was that I would be able to change out the > camera and the monitor on my PT and just plug each of them into the > original cable, thereby saving me the headache of running a new > cable. The problem? The original monitor doesn't have a coax > plugged into the back like I expected...just a pin connector with > several small wires on it. > > So my question...does anyone know where the single cable that comes > out of the camera terminates? And, am I just being foolish to > believe I can use that old cable with a new camera and LCD monitor > anyway? > > Scott Forman > 86 PT38 > Memphis > Hi Scott, Im in the middle of redoing my rear view too, have a camera and a small LCD monitor that I picked up, going to install them RSN... The CRT monitor has a edge card connector on the back, if you look you'll see where the coax is soldered to it. The other connections are for the brightness, contrast and power. I soldered the coax to a RCA plug and the power to a connector that fits the LCD monitor and that seems to work OK. The contrast and brightness wires I capped off with insulated crimp ons. If you need I can look at the old connector and get you the pins ---if I havent tossed it. I still have to mount the LCD in the console and the camera at the rear of the coach... HTH, Joe '87 PT40 San Francisco |
05-19-2008, 15:14
Camera cables
Scott,
The old cable worked for me using two of the old monitor 10 pin connector wires. I used the orange wire for the camera signal to the new LCD, the white wire for ground. On Mon, May 19, 2008 at 4:34 PM, Scott Forman <"sforman@renasant.com"> wrote:
05-19-2008, 15:20
Camera cables
Scott,
I replaced my rear view camera and monitor about 2 or 3 years ago. I to considered using my old cable but changed my mind when I couldn't immediately find the appropriate cable adapter. That and I was told that a 20 year old cable isn't as good as a new one. Might work fine but not as good. I didn't find it a particular problem running the new cable. The only place that was a little difficult was in the bedroom. Ours has a center queen with valances instead of cabinets on both sides. I used a tool made by Greenlee that made the job possible without removing the valance. The tool, made of fibreglass,is available at Home Depot and has 3 sections that can be screwed together as needed. I had to remove some of the upper cabinet work to get to an opening at the rear of the valance. I aimed for that opening and with a little "practice" I got the wire through. I left the old wire in just in case I might need it some day.
Good luck.
05-24-2008, 17:06
Camera cables
Finished the new camera / monitor install and it came out pretty
good... Used parts from ebay and found one that would fit in the opening of the fiberglass cover that holds the plastic lens that the old camera looked through. That lens was so clouded that it looked like some one had sanded it! The new LCD monitor fits where the old CRT monitor did, but I attached it to the front of the panel so I could get to the controls. I'll post some photos later this week. /Joe --- In WanderlodgeForum@yahoogroups.com, "joepat50" > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > My quest to upgrade the rear view camera continues... > > > > Today, I managed to get the old camera and old monitor out of the > > bus. This, of course, has raised a new question for me. > > > > In my old FC, I changed out the old camera with a modern one. I kept > > the old monitor, which worked fine. I was able (using some > > connection adapters from Radio Shack) to plug the new camera right > > into the original coax camera cable. Presto! New camera worked > > great. > > > > With that in mind, my hope was that I would be able to change out the > > camera and the monitor on my PT and just plug each of them into the > > original cable, thereby saving me the headache of running a new > > cable. The problem? The original monitor doesn't have a coax > > plugged into the back like I expected...just a pin connector with > > several small wires on it. > > > > So my question...does anyone know where the single cable that comes > > out of the camera terminates? And, am I just being foolish to > > believe I can use that old cable with a new camera and LCD monitor > > anyway? > > > > Scott Forman > > 86 PT38 > > Memphis > > > > Hi Scott, > > Im in the middle of redoing my rear view too, have a camera and a > small LCD monitor that I picked up, going to install them RSN... > > The CRT monitor has a edge card connector on the back, if you look > you'll see where the coax is soldered to it. The other connections > are for the brightness, contrast and power. > I soldered the coax to a RCA plug and the power to a connector that > fits the LCD monitor and that seems to work OK. The contrast and > brightness wires I capped off with insulated crimp ons. > If you need I can look at the old connector and get you the pins > ---if I havent tossed it. > > I still have to mount the LCD in the console and the camera at the > rear of the coach... > > HTH, Joe > > '87 PT40 > San Francisco > |
05-25-2008, 04:33
Camera cables
Must be the weekend for backup cameras. I finished mine as well.
Only difficult part for me was fishing the wire from the camera to the monitor but even that was not all that difficult. Mounting the camera I thought might challenge me a little because I wanted to get bolts and nuts rather then self tapping screws. I used double sided tape and stuck the nuts on my finger, reached thru the one inch hole the wire went thru (where I removed a marker light) and was able to get the lock nut started. The camera provides a nice clear color picture of what is behind me so I feel mission accomplished. I closed the hole this way. I bought a rubber stopper at Lowe's and shaped it as close as I could using a bench grinder. I cut a notch around the circumference of the stopper so that it would snap into place and then another cut just large enough to let the wire to go thru. Once I had that fitting pretty closely I applied some clear silicone and sealed everything up. I used the center of three marker lights as my location as was suggested by one of the other owners so that no new holes had to be cut. I only had to drill three small holes for the #10 bolts. I mounted the monitor on the upper left corner of the upper dash so that it hangs at the upper corner of the windshield and ran the wires down the window frame. One ground wire and one to DC current and off she went. I did wire in a toggle switch to turn everything off. John Heckman central Pa 1973 FC > > Finished the new camera / monitor install and it came out pretty > good... Used parts from ebay and found one that would fit in the > opening of the fiberglass cover that holds the plastic lens that the > old camera looked through. > > That lens was so clouded that it looked like some one had sanded it! > > The new LCD monitor fits where the old CRT monitor did, but I attached > it to the front of the panel so I could get to the controls. > > I'll post some photos later this week. > > /Joe > > > > > --- In WanderlodgeForum@yahoogroups.com, "joepat50" wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > > wrote: > > > > > > My quest to upgrade the rear view camera continues... > > > > > > Today, I managed to get the old camera and old monitor out of the > > > bus. This, of course, has raised a new question for me. > > > > > > In my old FC, I changed out the old camera with a modern one. I kept > > > the old monitor, which worked fine. I was able (using some > > > connection adapters from Radio Shack) to plug the new camera right > > > into the original coax camera cable. Presto! New camera worked > > > great. > > > > > > With that in mind, my hope was that I would be able to change out the > > > camera and the monitor on my PT and just plug each of them into the > > > original cable, thereby saving me the headache of running a new > > > cable. The problem? The original monitor doesn't have a coax > > > plugged into the back like I expected...just a pin connector with > > > several small wires on it. > > > > > > So my question...does anyone know where the single cable that comes > > > out of the camera terminates? And, am I just being foolish to > > > believe I can use that old cable with a new camera and LCD monitor > > > anyway? > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > > Hi Scott, > > > > Im in the middle of redoing my rear view too, have a camera and a > > small LCD monitor that I picked up, going to install them RSN... > > > > The CRT monitor has a edge card connector on the back, if you look > > you'll see where the coax is soldered to it. The other connections > > are for the brightness, contrast and power. > > I soldered the coax to a RCA plug and the power to a connector that > > fits the LCD monitor and that seems to work OK. The contrast and > > brightness wires I capped off with insulated crimp ons. > > If you need I can look at the old connector and get you the pins > > ---if I havent tossed it. > > > > I still have to mount the LCD in the console and the camera at the > > rear of the coach... > > > > HTH, Joe > > > > '87 PT40 > > San Francisco > > > |
05-27-2008, 14:08
Camera cables
Some photos of the rear camera and LCD monitor are uploaded to the
Photos section, http://autos.ph.groups.yahoo.com/group/W...rowse/12cf Or look for Joe Garner... /Joe '87 PT40 San Francisco --- In WanderlodgeForum@yahoogroups.com, "joepat50" > > Finished the new camera / monitor install and it came out pretty > good... Used parts from ebay and found one that would fit in the > opening of the fiberglass cover that holds the plastic lens that the > old camera looked through. > > That lens was so clouded that it looked like some one had sanded it! > > The new LCD monitor fits where the old CRT monitor did, but I attached > it to the front of the panel so I could get to the controls. > > I'll post some photos later this week. > > /Joe > > |
