Crack in fresh water tank
05-26-2008, 03:20
Hello to all!
We have a crack in our street side fresh water tank, it is about a inch
or so long about half way up the side of the tank. What do I use or how
do I fix this, it is a plastic tank. I will try and see if I can lift
it out some to get at the crack, will something like Permatex work?
Thankyou for your help!
Michelle and Jeff August
1980FC35RB
Plymouth Wi.
05-26-2008, 04:19
Check to see if there is a plastic welder nearby. I would be concerned with
contamination of the fresh water supply using any kind of glue.
Gary
To:
Sent: Monday, May 26, 2008 11:20 AM
Subject: [WanderlodgeForum] Crack in fresh water tank
Hello to all!
1980FC35RB
Plymouth Wi.
E-mail message checked by Spyware Doctor (5.5.0.178)
Database version: 5.09900
http://www.pctools.com/spyware-doctor/
05-26-2008, 08:33
Ditto; I agree use a plastic welder. I would venture to say any
adhesive would come unglued in a period of time. A plastic welder
should make it like new.
John 88FC35 Louisville, KY/Jeffersonville, IN
05-26-2008, 09:59
Plastic has a grain, if you find a potable glue , drill a hole at
all ends of the crack. the crack may not continue past the hole
but may continue past the repaired end of a crack. remember the
crack is a result of somthing else that needs attention. what caused
the crack may be the first thing to solve. if it is age brittle
plastic you may need to resupport the tank and treat the plastic as
if it is simply a liner?????
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Jeff August"
> Hello to all!
inch
or how
lift
> 1980FC35RB
> Plymouth Wi.
