Need help getting with Onan
05-31-2008, 11:54
Try wiggling that white plastic connector at the back of the Onan box
that houses the circuitry. They are notorious for working loose as the
wiring makes a sharp turn. You should be able to trace the 110 volt
wirning from the genset to find that double breaker box. Mine , like
Bill's , is in the cord compartment.
Bruce
1988 FC35
06-01-2008, 11:54
Thanks for the help. I found the generator AC breaker box. It was
under the queen bed next to the water tank. Not the most obvoius or
convenient place, but all is working now.
Ron Hazlett
1987 FC
Toledo, Ohio
box
like
> Bruce
> 1988 FC35
06-01-2008, 13:28
Great!! Glad you found it.
Dick Gideon
1989FC35
--- In WanderlodgeForum@yahoogroups.com, "Ron Hazlett"
> Ron Hazlett
> 1987 FC
> Toledo, Ohio
> box
as
> the
volt
> like
> > Bruce
> > 1988 FC35
