Hot water heater
05-23-2005, 20:07
Hot water heater
doesn't Stephen Birtles sell these heaters, also? ernie
[Non-text portions of this message have been removed] |
05-23-2005, 21:43
Hot water heater
Where is the best place to purchase a new hot water heater?
Elmer in Sebring FL 86 PT 38 |
05-24-2005, 00:00
Hot water heater
west marine..randydupree93wb
----- Original Message ----- From: ejohna2000 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 24, 2005 5:43 AM Subject: [WanderlodgeForum] Hot water heater Where is the best place to purchase a new hot water heater? Elmer in Sebring FL 86 PT 38 ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-24-2005, 00:22
Hot water heater
Yes I do
Raritan 6 Gallon with heat exchanger 510.00 plus shpping Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > doesn't Stephen Birtles sell these heaters, also? ernie > > > [Non-text portions of this message have been removed] |
05-24-2005, 00:36
Hot water heater
yes,i forgot about that! randydupree93wb
----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 24, 2005 8:07 AM Subject: Re: [WanderlodgeForum] Hot water heater doesn't Stephen Birtles sell these heaters, also? ernie [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-24-2005, 01:23
Hot water heater
Hi Elmer,
I replaced my faulty water heater a few years ago with a near direct replacement from Seaward Products, _http://www.seawardproducts.com/waterhtr.htm_ (http://www.seawardproducts.com/waterhtr.htm) . I believe it was a 11 gallon unit, and it too had the motor aid feature. Replacement was pretty easy, but took me a day or so. It was my first "big" project with my then "new to me" BB, and I learned a lot about the quality and workmanship of BB's. The plumbing almost hooked up like the unit I took out, but the slight mismatch was taken care of by using those neat and flexible stainless steel braided hoses available at all Home Depot or Lowes plumbing depts. I believe the unit cost me a little over $300, and I picked it up at the factory in nearby Whittier. They do ship, and they do sell direct. Knock on wood, but the water heater is still working, even after my install !! Good luck.. Kevin McKeown Yorba Linda, CA 1986 38' PT (same as yours) [Non-text portions of this message have been removed] |
05-24-2005, 02:05
Hot water heater
Elmer I just bought one the other day from a marine supply.
Original Message: ----------------- From: ejohna2000 ejohna@... Date: Tue, 24 May 2005 09:43:11 -0000 To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Hot water heater Where is the best place to purchase a new hot water heater? Elmer in Sebring FL 86 PT 38 <!-- |**|begin egp html banner|**| --> Yahoo! Groups Links
<!-- |**|end egp html banner|**| --> -------------------------------------------------------------------- mail2web - Check your email from the web at http://mail2web.com/ . |
09-08-2005, 14:09
Hot water heater
I would like to thank everyone who offered help. i have gas going now
the hot water heateris a mystry and it shouldn't be. i shut the breaker off checked continuity at the jubction box. i had continuity from the black wire to the white wire which tells men the circuit is complete. how long does it take to heat the 10 gal. of water? thanks again re |
09-08-2005, 22:16
Hot water heater
It should take less than 30 minutes. When I'm out dry camping, and the
girls need that once-a-day shower, I run the gen set for 30 minutes, and that seems sufficient to give 'em plenty of hot water (the water is already pretty warm from the day before). Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] |
09-09-2005, 22:38
Hot water heater
Thanks, i think i am going to run me a hot wire directly to the
element when i get the cover off and have time-- - In WanderlodgeForum@yahoogroups.com, krminyl@a... wrote: > It should take less than 30 minutes. When I'm out dry camping, and the > girls need that once-a-day shower, I run the gen set for 30 minutes, and that > seems sufficient to give 'em plenty of hot water (the water is already pretty > warm from the day before). > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] |
