Brush gobbler
06-01-2008, 17:02
Brush gobbler
What would cause my generator (12.5kw Yanmar powered Kohler) to eat
through brushes at a rapid rate? Some time after buying my coach last year, the generator quit working. I found the rear brush to be worn all the way down and the wire popped off. The front brush looked OK, but I replaced them both anyway, as well as the little holder for them just for kicks. Fast forward to this weekend: With only ~30 hours of operation on the new brushes, the generator stopped and I found the rear brush worn down with it's wire popped off again. Front brush still looks new. Thankfully, I still had the good front brush from before, so I installed it in place of the worn rear brush. This was Saturday morning. Roughly 5 additional hours of runtime later, the generator stopped again. That was this morning and I haven't climbed under there yet but I suspect I'll find that rear brush worn back down. What's the deal here? -Ryan '86 PT-40 8V92 |
06-01-2008, 21:58
Brush gobbler
Ryan,
I am going thru the exact same thing right now(yanmar/kohler). What I discovered is that the rear commutator slip ring has a grove worn into it, but only about a third of the way around. Causing the ring to be more egg shaped. Which I think is whats causing that brush to wear out so rapidily. I have no idea what has caused this irregular wear pattern. I bought new slip rings and rear bearing, but don't have enough guts to attempt the R+R yet! If anybody has been thru this I also would appreciate any tips and advice. Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > What would cause my generator (12.5kw Yanmar powered Kohler) to eat > through brushes at a rapid rate? > > Some time after buying my coach last year, the generator quit working. > I found the rear brush to be worn all the way down and the wire popped > off. The front brush looked OK, but I replaced them both anyway, as > well as the little holder for them just for kicks. Fast forward to > this weekend: With only ~30 hours of operation on the new brushes, the > generator stopped and I found the rear brush worn down with it's wire > popped off again. Front brush still looks new. Thankfully, I still had > the good front brush from before, so I installed it in place of the > worn rear brush. This was Saturday morning. > > Roughly 5 additional hours of runtime later, the generator stopped > again. That was this morning and I haven't climbed under there yet but > I suspect I'll find that rear brush worn back down. > > What's the deal here? > > -Ryan > '86 PT-40 8V92 > |
06-02-2008, 00:01
Brush gobbler
Your commutator ring is worn. I went through this in January. You
have three options: 1) Replace entire genset 2) Find a modern head unit that mates up to your engine 3) Rebuild the head unit I went for option three, as it had the lowest price and fewest potential headaches. Now it is basically a brand new "old technology" generator which should last another 20 years just like the first one did. The commutator ring must be pressed out, so machine tools are required. Good luck Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > What would cause my generator (12.5kw Yanmar powered Kohler) to eat > through brushes at a rapid rate? > > Some time after buying my coach last year, the generator quit working. > I found the rear brush to be worn all the way down and the wire popped > off. The front brush looked OK, but I replaced them both anyway, as > well as the little holder for them just for kicks. Fast forward to > this weekend: With only ~30 hours of operation on the new brushes, the > generator stopped and I found the rear brush worn down with it's wire > popped off again. Front brush still looks new. Thankfully, I still had > the good front brush from before, so I installed it in place of the > worn rear brush. This was Saturday morning. > > Roughly 5 additional hours of runtime later, the generator stopped > again. That was this morning and I haven't climbed under there yet but > I suspect I'll find that rear brush worn back down. > > What's the deal here? > > -Ryan > '86 PT-40 8V92 > |
06-02-2008, 00:19
Brush gobbler
MANY years ago I worked with large A/C.D/C motor generator set. We used to turn the commutator with special tooling while in place. Maybe some one who rebuilds commercial/industrial motors can lead you in the right direction. These units are almost timeless... Pete -------------- Original message ---------------------- From: "Scott Forman" <sforman@...> > Your commutator ring is worn. I went through this in January. You > have three options: > > 1) Replace entire genset > 2) Find a modern head unit that mates up to your engine > 3) Rebuild the head unit > > I went for option three, as it had the lowest price and fewest > potential headaches. Now it is basically a brand new "old > technology" generator which should last another 20 years just like > the first one did. > > The commutator ring must be pressed out, so machine tools are > required. > > Good luck > > Scott Forman > 86 PT38 > Memphis > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > What would cause my generator (12.5kw Yanmar powered Kohler) to eat > > through brushes at a rapid rate? > > > > Some time after buying my coach last year, the generator quit > working. > > I found the rear brush to be worn all the way down and the wire > popped > > off. The front brush looked OK, but I replaced them both anyway, as > > well as the little holder for them just for kicks. Fast forward to > > this weekend: With only ~30 hours of operation on the new brushes, > the > > generator stopped and I found the rear brush worn down with it's > wire > > popped off again. Front brush still looks new. Thankfully, I still > had > > the good front brush from before, so I installed it in place of the > > worn rear brush. This was Saturday morning. > > > > Roughly 5 additional hours of runtime later, the generator stopped > > again. That was this morning and I haven't climbed under there yet > but > > I suspect I'll find that rear brush worn back down. > > > > What's the deal here? > > > > -Ryan > > '86 PT-40 8V92 > > > > > |
Your commutator ring is worn. I went through this in January. You have three options: 1) Replace entire genset 2) Find a modern head unit that mates up to your engine 3) Rebuild the head unit I went for option three, as it had the lowest price and fewest potential headaches. Now it is basically a brand new "old technology" generator which should last another 20 years just like the first one did. The commutator ring must be pressed out, so machine tools are required. Good luck Scott Forman 86 PT38 Memphis --- In "WanderlodgeForum%40yahoogroups.com", "Ryan Wright" > > What would cause my generator (12.5kw Yanmar powered Kohler) to eat > through brushes at a rapid rate? > > Some time after buying my coach last year, the generator quit working. > I found the rear brush to be worn all the way down and the wire popped > off. The front brush looked OK, but I replaced them both anyway, as > well as the little holder for them just for kicks. Fast forward to > this weekend: With only ~30 hours of operation on the new brushes, the > generator stopped and I found the rear brush worn down with it's wire > popped off again. Front brush still looks new. Thankfully, I still had > the good front brush from before, so I installed it in place of the > worn rear brush. This was Saturday morning. > > Roughly 5 additional hours of runtime later, the generator stopped > again. That was this morning and I haven't climbed under there yet but > I suspect I'll find that rear brush worn back down. > > What's the deal here? > > -Ryan > '86 PT-40 8V92 > |
06-02-2008, 00:23
Brush gobbler
I think the shaft is tapered to the engine?? so it then could be the
bearing in the gen or the mounting bolts that hold the gen to the engine?? MikeH pointed out some time ago that it is important to replace critical bolts to get them back to spec torque. I have a coleman light tower that had a crack in the casting that holds the genset bearing. once I welded the crack I then started to run thru brushes . I guess I off centered the bearing seat. when I pulled the genhead off the Kubota I noticed a broken motor mount on the engine side which must have cantilivered stress on the duo and caused the crack. Servicing mounting points may also help with vibration. vibration is more annoying than noise. On the topic of mounting and vibration; BB has some funky exhaust mating systems for genset slides. I notice most vibration come into the coach from the muffler mounting. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > What would cause my generator (12.5kw Yanmar powered Kohler) to eat > through brushes at a rapid rate? > > Some time after buying my coach last year, the generator quit working. > I found the rear brush to be worn all the way down and the wire popped > off. The front brush looked OK, but I replaced them both anyway, as > well as the little holder for them just for kicks. Fast forward to > this weekend: With only ~30 hours of operation on the new brushes, the > generator stopped and I found the rear brush worn down with it's wire > popped off again. Front brush still looks new. Thankfully, I still had > the good front brush from before, so I installed it in place of the > worn rear brush. This was Saturday morning. > > Roughly 5 additional hours of runtime later, the generator stopped > again. That was this morning and I haven't climbed under there yet but > I suspect I'll find that rear brush worn back down. > > What's the deal here? > > -Ryan > '86 PT-40 8V92 > |
06-02-2008, 10:23
Brush gobbler
Scott, did you do this work yourself? If not, would you might sharing
a rough dollar figure as to what I should expect when I start calling generator repair shops? -Ryan On Mon, Jun 2, 2008 at 5:01 AM, Scott Forman <sforman@...> wrote: > > I went for option three, as it had the lowest price and fewest > potential headaches. Now it is basically a brand new "old > technology" generator which should last another 20 years just like > the first one did. > |
06-02-2008, 11:56
Brush gobbler
No, I am pretty handy but this level of work is beyond my capability
right from the beginning...I have no way to get the Genset out of the coach. I am a bad example for costs, because the shop that services my coach is owned by a close friend...he gives me parts at cost and greatly reduced labor rates. That being said, it was 16 hours of labor and $136 (at cost) in parts. You should be able to estimate your cost based on your local hourly shop rates since the parts are insignificant. This is the narrative from my shop invoice: Complaint: Generator not making electricity. Cause: Exciter ring and brushes bad. Correction: Drained coolant and disconnected radiator hoses. Disconnected A/C wires and control box. Removed gen set from coach. Removed engine from cradle. Dissassembled generator. Removed armature from engine. Removed end bearing. Replaced exciter ring. Installed new end bearing. Installed armature on engine. Assembled generator. Put engine in cradle and installed in coach. Connected wires, fuel lines, and rad hoses. Filled cooling system and bled air. Cranked engine, okay. 120v A/C from both lugs at no load. Put load on generator and let run to check out, okay. Hope this helps Scott --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Scott, did you do this work yourself? If not, would you might sharing > a rough dollar figure as to what I should expect when I start calling > generator repair shops? > > -Ryan > > On Mon, Jun 2, 2008 at 5:01 AM, Scott Forman <sforman@...> wrote: > > > > I went for option three, as it had the lowest price and fewest > > potential headaches. Now it is basically a brand new "old > > technology" generator which should last another 20 years just like > > the first one did. > > > |
06-02-2008, 13:06
Brush gobbler
All I would ask is that if anyone does this repair, take lots of
pictures. It sounds like a pretty common problem and nothing is more helpful that pictures along with an explanation. I don't have one of these gen sets (yet), but Ihave friends that do. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > I think the shaft is tapered to the engine?? so it then could be the > bearing in the gen or the mounting bolts that hold the gen to the > engine?? MikeH pointed out some time ago that it is important to > replace critical bolts to get them back to spec torque. > > I have a coleman light tower that had a crack in the casting that > holds the genset bearing. once I welded the crack I then started to > run thru brushes . I guess I off centered the bearing seat. when I > pulled the genhead off the Kubota I noticed a broken motor mount on > the engine side which must have cantilivered stress on the duo and > caused the crack. Servicing mounting points may also help with > vibration. vibration is more annoying than noise. > > On the topic of mounting and vibration; BB has some funky exhaust > mating systems for genset slides. I notice most vibration come into > the coach from the muffler mounting. > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > What would cause my generator (12.5kw Yanmar powered Kohler) to eat > > through brushes at a rapid rate? > > > > Some time after buying my coach last year, the generator quit > working. > > I found the rear brush to be worn all the way down and the wire > popped > > off. The front brush looked OK, but I replaced them both anyway, as > > well as the little holder for them just for kicks. Fast forward to > > this weekend: With only ~30 hours of operation on the new brushes, > the > > generator stopped and I found the rear brush worn down with it's > wire > > popped off again. Front brush still looks new. Thankfully, I still > had > > the good front brush from before, so I installed it in place of the > > worn rear brush. This was Saturday morning. > > > > Roughly 5 additional hours of runtime later, the generator stopped > > again. That was this morning and I haven't climbed under there yet > but > > I suspect I'll find that rear brush worn back down. > > > > What's the deal here? > > > > -Ryan > > '86 PT-40 8V92 > > > |
06-02-2008, 17:19
Brush gobbler
Much appreciated, Scott. Thank you for sharing this.
-Ryan '86 PT-40 8V92 On Mon, Jun 2, 2008 at 4:56 PM, Scott Forman <sforman@...> wrote: > > This is the narrative from my shop invoice: |
06-02-2008, 17:44
Brush gobbler
What is an exciter ring? Between the ExciterRing and the swaybar
threads "porpoising", I'm lost. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > No, I am pretty handy but this level of work is beyond my capability > right from the beginning...I have no way to get the Genset out of the > coach. > > I am a bad example for costs, because the shop that services my coach > is owned by a close friend...he gives me parts at cost and greatly > reduced labor rates. That being said, it was 16 hours of labor and > $136 (at cost) in parts. You should be able to estimate your cost > based on your local hourly shop rates since the parts are insignificant. > > This is the narrative from my shop invoice: > Complaint: Generator not making electricity. Cause: Exciter ring and > brushes bad. Correction: Drained coolant and disconnected radiator > hoses. Disconnected A/C wires and control box. Removed gen set from > coach. Removed engine from cradle. Dissassembled generator. Removed > armature from engine. Removed end bearing. Replaced exciter ring. > Installed new end bearing. Installed armature on engine. Assembled > generator. Put engine in cradle and installed in coach. Connected > wires, fuel lines, and rad hoses. Filled cooling system and bled air. > Cranked engine, okay. 120v A/C from both lugs at no load. Put load on > generator and let run to check out, okay. > > Hope this helps > Scott > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > Scott, did you do this work yourself? If not, would you might sharing > > a rough dollar figure as to what I should expect when I start calling > > generator repair shops? > > > > -Ryan > > > > On Mon, Jun 2, 2008 at 5:01 AM, Scott Forman <sforman@> wrote: > > > > > > I went for option three, as it had the lowest price and fewest > > > potential headaches. Now it is basically a brand new "old > > > technology" generator which should last another 20 years just like > > > the first one did. > > > > > > |
