Genset regulator
06-04-2008, 01:38
Genset regulator
Regarding my 15KW generator in my 97 WL, Both voltmeters are pegging the gauge and I am assuming from talking to the Power Tech folks that the voltage regulator needs changed. I am quite certain it is inside the circuit breaker box behind the valve cover and air box. Can anyone confirm this? Thanks. Fred & Jeanne Hulse
06-04-2008, 02:39
Genset regulator
Yes it is Fred. Remove the air box and associated piping and don't lose those rubber strips under the air box. They protect against vibration wear.
2008/6/4 Fred Hulse <"fhulse@wildblue.net">:
-- Rob, Sue & Merlin Robinson 94 WLWB |
06-04-2008, 02:50
Genset regulator
Rob,
I was hoping you would reply,Thank you!
I should have paid more attention to your project at Quartzsite when you had that stuff apart back there.
Tell Sue & Merlin hello from this Family.
Fred & Jeanne Hulse
06-04-2008, 03:04
Genset regulator
Fred, powertech are 'R&R thinking'their troubleshooting/repair
technique lack the insight the unit build design has. Not that I know a volt from an amp. I'm still pissed about Robs issue with PT. With the high ambient heat BB spec'ed into the build, I would use the same exact VR to replace. ??? is the pegged voltmeter symptom duplicated when you start the genset unhooked to shore power? could 'transfer switch' have been the cause of the resulting voltage regulator failure???? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Yes it is Fred. Remove the air box and associated piping and don't lose > those rubber strips under the air box. They protect against vibration wear. > > 2008/6/4 Fred Hulse > > > Regarding my 15KW generator in my 97 WL, > > Both voltmeters are pegging the gauge and I am assuming from talking to the > > Power Tech folks that the voltage regulator needs changed. > > I am quite certain it is inside the circuit breaker box behind the valve > > cover and air box. > > Can anyone confirm this? > > Thanks. > > Fred & Jeanne Hulse > > Morristown Arizona > > 1997 Wanderlodge WLWB41 > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > |
06-04-2008, 03:18
Genset regulator
Gregory When the voltage regulator crap out on my 12 KW power tech I am sure it was due to heat.The regulator had a crack in the top that ran from one side to the other. Bob Loomas PT 85 Harahan La. > > Fred, powertech are 'R&R thinking'their troubleshooting/repair > technique lack the insight the unit build design has. Not that I > know a volt from an amp. I'm still pissed about Robs issue with PT. > > With the high ambient heat BB spec'ed into the build, I would use > the same exact VR to replace. > > ??? is the pegged voltmeter symptom duplicated when you start the > genset unhooked to shore power? could 'transfer switch' have been > the cause of the resulting voltage regulator failure???? > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > > > > Yes it is Fred. Remove the air box and associated piping and don't > lose > > those rubber strips under the air box. They protect against > vibration wear. > > > > 2008/6/4 Fred Hulse > > > > > Regarding my 15KW generator in my 97 WL, > > > Both voltmeters are pegging the gauge and I am assuming from > talking to the > > > Power Tech folks that the voltage regulator needs changed. > > > I am quite certain it is inside the circuit breaker box behind > the valve > > > cover and air box. > > > Can anyone confirm this? > > > Thanks. > > > Fred & Jeanne Hulse > > > Morristown Arizona > > > 1997 Wanderlodge WLWB41 > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > |
06-04-2008, 08:46
Genset regulator
Fred,
You are correct, the regulator is inside the box. I had mine replaced by PowerTech at the factory a couple of years ago. The tech changed it with the genny just extended. Not the asiest job, but also not the hardest. Paul 97wb43 Silver Spring, MD --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > Regarding my 15KW generator in my 97 WL, > Both voltmeters are pegging the gauge and I am assuming from talking to the Power Tech folks that the voltage regulator needs changed. > I am quite certain it is inside the circuit breaker box behind the valve cover and air box. > Can anyone confirm this? > Thanks. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > |
06-04-2008, 12:45
Genset regulator
Gregory,
The meters only pegged with the genset running and is ok with shore power.
I experienced a problem at Quartzsite this January and it went away until yesterday, but Ihad ordered a new regulator from PowerTech as soon as we got homefrom the Q rally.
This morning I replaced it and was able to figure out the newwiring processwith help of the paperwork that came with the regulator and it works fine except I need to adjust the voltage before Ican put it back together.
The new regulator is a vast improvement over the OE unit.
Thanks for the help
A Diet Pepsi will be on its way soon.
Fred & Jeanne Hulse
06-04-2008, 12:49
Genset regulator
Paul
Thanks for the response.
It appears that I have successfully accomplished the repair, but yes it was a little difficult to get to and to rewire.
Tylenol for everyone!!
Fred & Jeanne Hulse
06-04-2008, 13:05
Genset regulator
Hi Bob Loomis
Heat ?? Yes
When I pulled out the old regulator the case was cracked and swollen from heat.
The new unit had heat sinks to help cool it.
(I hope)
Fred & Jeanne Hulse
06-04-2008, 13:40
Genset regulator
Fred, can the heat sink part be mounted on some steel that extends
outside of the compartment? if it is mounted on hot metal, it would be a heat wick????? GregoryO'Connor 94ptRomolandca --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote: > > Hi Bob Loomis > Heat ?? Yes > When I pulled out the old regulator the case was cracked and swollen from heat. > The new unit had heat sinks to help cool it. > (I hope) > > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > |
