Radio Antenna
06-07-2008, 05:34
Radio Antenna
Does any one know where you can get a radio antenna for the roof. The old one is a Larsen ?
Don Spithaler 89SP 36' Butler, PA |
06-07-2008, 06:55
Radio Antenna
Larsen is now Radiall/Larsen. You can buy antennas or any part of
the antenna you have. For example, if you only need the stainless steel rod you can buy that rather than buy the whole antenna. Here is the first hit I had on Google as a source. http://www.wb0w.com/larsen/larsen.htm I know nothing about the dealer. Larsen is probably the top of the line in UHF/VHF and CB antennas. I have been using them since the late 60s in ham radio applications. Marv - KG7V 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "Donald Spithaler" > > Does any one know where you can get a radio antenna for the roof. The old > one is a Larsen ? > Don Spithaler > 89SP 36' > Butler, PA > |
06-07-2008, 15:37
Radio Antenna
Thanks Marv I'll check that out. My base is gone on the antenna up front. The bottom rusted out.
Don Spithaler 89 SP 36' Butler, PA On Sat, Jun 7, 2008 at 2:55 PM, Marv & Jean <"marvwheeler@nwlink.com"> wrote:
