Xantrex RV 3012 M Inverter Installation, Reinventing the wheel!
06-09-2008, 08:44
The two inveters arrived in new sealed boxes. The RV7/GS controlers
arrived in as new condition, but they were in non mfg packaging.
cost to date:
$1370.00 inverters.
$ 305.00 controls.
$ 100.00 Sheet metal and aluminum angle for lining bay.
I decided that I will move the inverters into bay 3, right side in
place of the electric grill, from the hot, dirty, and sometimes wet
inverter box in the engine compartment.
After the renovations I will convert the old inverter box to hold 2
more house batteries.
I have removed the grill and I have lined the area with sheet metal,
and framed the opening with aluminum angle. I also replaced the
small angle iron mounting peices with wider aluminun braces and ran
an angle support under the shelf to help support the 120+ lbs. of
weight, Overkill! When the tool box is under the shelf it does not
move or vibrate. I will post photos shortly.
There is the question of how large the wires have to be that connect
the invertes to the batteries. It will take appox. 115' of cable to
get the job done and if you have bought heavy copper cable of late
it's not cheep! It looks like around $10.00 a foot for 350 MCM
welding cable.
It is 0.970 in diameter So I am having a bit of trouble figuring out
how or where to run these cables. Idealy inside the frame rail would
be my first choice, but after spending a few hours under the coach,
poking around, this will be impossible without getting the coach on a
lift. Anybody know what size cable is used on the coaches that have
factory installed inverters in the bays?
Here is a responce from Xantrex about the cable size. YIKES!!!
Dear Kurt Horvath,
My wire size calculator says 1000 MCM, which I didn't even know
existed until just now. Is there any way you can shorten the run to
12 feet, which would allow you to use 500 MCM?
For all correspondence regarding this issue, please make sure to
leave the ID number [ref:00D3Wjr.500351Yfr:ref] in the subject line
or body of the email.
Allegra Sloman
Customer Service Operations
Xantrex Technology Inc.
Well there goes the farm 1000 MCM cable????
There are 2 large cables running along the top inside of the wheel
well from the engine compartment into the holding tank bay and
forwards from there. This looks like the easy way to run the cables
but it is exposed to a lot road damage and wear and tear, not to
mention a tire coming apart. So it's not really a good choice. Any
ideas on this option?
I am checking into STACKING the inverters. I really don't know much
about how this system works. Or what is required to change from the
two unit system to a STACKED system. I do know that it reduces the
required cable lenght in half. Any ideas here would be helpful.
I also have to run the control wires and 120v wires from the engine
bay to the new invert bay. The control wires are also a small problem
the origonal wires are 6 wire data lines and the new control wires
call for a 4 wire telephone line in place of the old data line. I'm
told that these can be used with a little effort. I haven't gotten
that far into the project yet. I hope that I don't have to re-run the
control lines through the whole coach.
One thing that bothers me is that the inverters are now surrounded by
water pipes and tanks. Water pumps on one side and a small water tank
on the other with plumbing going over the top. i guess I'll just have
to keep an eye out for leaks.
I am considering installing some small fans with snap thermostats to
control venting the compartment. Here again I'm asking for ideas. You
can vent out the back of the bay but it blows against the fuel tank.
That doesn't seem like a good idea. Or I could mount the fans on the
shelf and pipe it down through the bottom of the bay. But here again
hot air rises and this will be trying to draw it downwards. I'm not
even sure if this is needed. But it sounds like a lot of fun.
Kurt Horvath
95 PT-42 WLWB
Fayetteville TN
PS. After the e-mail from Xantrex I am considering putting the new
inveters back in the engine compartment. After all the old inverters
were there for 13 years?!?!?!?!?!?!? HELP!
06-09-2008, 12:32
Kurt,
Would it be less costly and with less issues to re vamp the heart
inverter box area above the batteries to make it waterproof and may
be even taller????
With L-16 I have more room under the inverter box as the top
battery tray was removed.
http://www.pbase.com/gregoryoc/image/86932717
you can also split the inverters up?????????
GregoryO'Connor
--- In WanderlodgeForum@yahoogroups.com, "bumpersbird"
controlers
> cost to date:
> $1370.00 inverters.
> $ 305.00 controls.
wet
2
metal,
ran
connect
to
> welding cable.
out
would
coach,
on a
have
> Dear Kurt Horvath,
to
line
> Allegra Sloman
cables
much
engine
problem
I'm
by
tank
have
to
You
tank.
again
not
> Kurt Horvath
> 95 PT-42 WLWB
> Fayetteville TN
inverters
06-09-2008, 14:48
Gregg,
Your probably right.
I spoke with several people today, Xantrex support, Solar power techs
etc. after I posted my little progress report. It seems as it does
not matter how heavy the cable is after a certain lenght the DC side
decreases efficance for every foot past 7' and after about 12' it may
not function at all. I've learned there are three enemies of an
invertrer: 1- Moisture,2- Heat,3- Dirt
I have been told that it can be done but the majority opinion is it's
better to keep the inverters as close to the batteries as possible,
even if they run hot and are in a dirty enviroment. By the way those
who think it's doable have not elaborated on how to do it.
So I'm going to put the new units in the inverter box in the engine
compartment. It will be a tight fit. Moisture is not really a
problem, perhaps condensation on the rare occasion. I will vent it in
some fashion, probably a couple of 130 cfm computer fans. The fans
that I'm installing to cool the engine compartment should also help a
lot. I'm mounting 2 - 1650 CFM radiator fans on the right side grill.
The inverters are just a 10" or 12" away. I might place some sort of
air filter on the door in an attemp to keep the box interior somewhat
clean.
I have 6 Lifline Batteries, they are only 24 month old and in time
switching to something else could happen, but these will have to die
first, especially at $600.00 each
SSSSHHHHHH_________TTTTTTTT !!!!!! There I go again, trying to
reinvent the wheel. To be honest this was probably one of Bluebirds
bigger engineering screw ups. Then again maybe not the old inverters
were in there for 13 years.
Hey on the bright side the bay with the BBQ is now metal lined, Looks
good and should be easier to clean.
Kurt Horvath
95 PT-42 WLWB
Fayetteville TN
> Kurt,
> be even taller????
> GregoryO'Connor
> controlers
> > cost to date:
> > $1370.00 inverters.
> > $ 305.00 controls.
in
> wet
> 2
> metal,
> ran
not
> connect
> to
late
> > welding cable.
> out
> would
> coach,
> on a
> have
> > Dear Kurt Horvath,
> to
> line
> > Allegra Sloman
wheel
> cables
Any
> much
> the
> engine
> problem
wires
> I'm
gotten
> the
surrounded
> by
> tank
> have
> to
> You
> tank.
> the
> again
> not
> > Kurt Horvath
> > 95 PT-42 WLWB
> > Fayetteville TN
new
> inverters
06-09-2008, 16:22
The only time it is hot is when the engine is running. I learned
with the refer mod that moving air with a fan has little cooling
effect. replacing the air in the compartment with a fan has the most
advantage.
If you look at the inverter box that BB engineeres (BirdBrains)
installed(in my '94), it floats in the battery compartment with air
gap around the entire box. Even the material it is made of looks
like it is a special (maybe, low heat conductive) product???????I
wonder if the box by design cools with passing air as you drive or
is there a better way to move the engine heated air away from the
inverter box? I wonder if a scoop would move more air or hinder the
existing path
The "three enemies of inverters" Xantrex quote may be three enimies
of an Inverter/Charger and not necessarly of just the stand alone
inverter??????? . I wonder why BB speced units with remote
batterychargers??? and why they moved the chargers so far away. Is
it a heat issue with the chargers only??? .
if Chargers-only have the heat issue (prompting the BirdBrain move),
chargers are not worked while driving unless you drive with the
genset running, so while driving heat is of no issue with inverter
only???? It may be that you need to cut 110V input to the inverter/
chargers when the detroit is running (or InverterBox temp is too
hot) to keep the chargers from lighting up if the genset is used.
GregoryO'Connor
94pt in need of new inverter chargers.
> Gregg,
techs
side
may
it's
possible,
those
engine
in
help a
grill.
of
somewhat
> clean.
die
Bluebirds
inverters
Looks
> Kurt Horvath
> 95 PT-42 WLWB
> Fayetteville TN
> > Kurt,
heart
may
> > be even taller????
> > GregoryO'Connor
> > controlers
packaging.
> > > cost to date:
> > > $1370.00 inverters.
> > > $ 305.00 controls.
side
> in
sometimes
> > wet
hold
> > 2
> > metal,
> > ran
of
> not
> > connect
cable
> > to
> late
> > > welding cable.
figuring
> > out
> > would
> > coach,
coach
> > on a
> > have
> > > Dear Kurt Horvath,
know
run
> > to
to
> > line
> > > Allegra Sloman
> wheel
> > cables
to
> Any
> > much
from
> > the
> the
> > engine
> > problem
> wires
line.
> > I'm
> gotten
run
> > the
> surrounded
> > by
water
> > tank
just
> > have
thermostats
> > to
ideas.
> > You
> > tank.
on
> > the
> > again
I'm
> > not
> > > Kurt Horvath
> > > 95 PT-42 WLWB
> > > Fayetteville TN
> new
> > inverters
06-10-2008, 00:12
I'm absolutely planning on running the 3012 I bought while the engine is running, to provide some amount of 120VAC while driving down the road. I'm considering mounting it inside the coach in the cabinet behind the drivers seat, since that would be within two or three feet of the batteries...
Dorn Hetzel
77FC35
Hogansville, GA
On Tue, Jun 10, 2008 at 12:22 AM, Gregory OConnor <"Gregoryoc@aol.com"> wrote:
advantage.
existing path
GregoryO'Connor
--- In "WanderlodgeForum%40yahoogroups.com", "bumpersbird"
> Gregg,
techs
side
may
it's
possible,
those
engine
in
help a
grill.
of
somewhat
> clean.
die
Bluebirds
inverters
Looks
> Kurt Horvath
> 95 PT-42 WLWB
> Fayetteville TN
> --- In "WanderlodgeForum%40yahoogroups.com", "Gregory OConnor"
> > Kurt,
heart
may
> > be even taller????
> > GregoryO'Connor
> > controlers
packaging.
> > > cost to date:
> > > $1370.00 inverters.
> > > $ 305.00 controls.
side
> in
sometimes
> > wet
hold
> > 2
> > metal,
> > ran
of
> not
> > connect
cable
> > to
> late
> > > welding cable.
figuring
> > out
> > would
> > coach,
coach
> > on a
> > have
> > > Dear Kurt Horvath,
know
run
> > to
to
> > line
> > > Allegra Sloman
> wheel
> > cables
to
> Any
> > much
from
> > the
> the
> > engine
> > problem
> wires
line.
> > I'm
> gotten
run
> > the
> surrounded
> > by
water
> > tank
just
> > have
thermostats
> > to
ideas.
> > You
> > tank.
on
> > the
> > again
I'm
> > not
> > > Kurt Horvath
> > > 95 PT-42 WLWB
> > > Fayetteville TN
> new
> > inverters
06-10-2008, 02:33
Dorn,
Yes a cool, dry, clean place for the new unit. Within a few feet of
the batterries. Sounds perfect, speaking of sound. Did you notice the
large cooling fan on the back of the inverter. I wonder how loud that
baby is when she spins up? You could vent that fan out of the cabinet
somehow, maybe like a side wall mounted water heater. I am sure you
will have to vent it somehow. The installation instructions warn
about mounting in an enclosed space.
Kurt Horvath
95 PT-42
10AC
--- In WanderlodgeForum@yahoogroups.com, "Dorn Hetzel"
engine is
road. I'm
drivers
batteries...
> Dorn Hetzel
> 77FC35
> Hogansville, GA
most
> > advantage.
air
> > existing path
enimies
move),
inverter/
> > GregoryO'Connor
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "bumpersbird"
> > wrote:
> > > Gregg,
> > techs
does
> > side
it
> > may
> > it's
> > possible,
> > those
> > engine
it
> > in
fans
> > help a
> > grill.
sort
> > of
> > somewhat
> > > clean.
time
> > die
> > Bluebirds
> > inverters
> > Looks
> > > Kurt Horvath
> > > 95 PT-42 WLWB
> > > Fayetteville TN
> > "Gregory OConnor"
> > > wrote:
> > > > Kurt,
> > heart
> > may
> > > > be even taller????
> > > > GregoryO'Connor
> > "bumpersbird"
> > > > controlers
> > packaging.
> > > > > cost to date:
> > > > > $1370.00 inverters.
> > > > > $ 305.00 controls.
> > side
> > > in
> > sometimes
> > > > wet
> > hold
> > > > 2
sheet
> > > > metal,
> > the
> > and
> > > > ran
lbs.
> > of
does
> > > not
> > > > connect
> > cable
> > > > to
of
> > > late
MCM
> > > > > welding cable.
> > figuring
> > > > out
rail
> > > > would
> > > > coach,
> > coach
> > > > on a
that
> > > > have
YIKES!!!
> > > > > Dear Kurt Horvath,
> > know
> > run
> > > > to
sure
> > to
subject
> > > > line
> > > > > Allegra Sloman
> > > wheel
> > > > cables
not
> > to
choice.
> > > Any
know
> > > > much
> > from
> > > > the
reduces
> > > the
helpful.
> > > > engine
small
> > > > problem
> > > wires
> > line.
> > > > I'm
> > > gotten
re-
> > run
> > > > the
> > > surrounded
> > > > by
> > water
> > > > tank
> > just
> > > > have
> > thermostats
> > > > to
> > ideas.
> > > > You
fuel
> > > > tank.
fans
> > on
> > > > the
here
> > > > again
> > I'm
> > > > not
fun.
> > > > > Kurt Horvath
> > > > > 95 PT-42 WLWB
> > > > > Fayetteville TN
> > > new
> > > > inverters
06-10-2008, 02:41
I'm considering pulling the under-couch propane heater that doesn't work anyway and using it's vent to route the inverter hot air out.
On Tue, Jun 10, 2008 at 10:33 AM, bumpersbird <"bumpersbird@yahoo.com"> wrote:
Dorn,
Kurt Horvath
95 PT-42
10AC
--- In "WanderlodgeForum%40yahoogroups.com", "Dorn Hetzel"
engine is
road. I'm
drivers
batteries...
> Dorn Hetzel
> 77FC35
> Hogansville, GA
most
> > advantage.
air
> > existing path
enimies
move),
inverter/
> > GregoryO'Connor
40yahoogroups.com>,
> > "bumpersbird"
> > wrote:
> > > Gregg,
> > techs
does
> > side
it
> > may
> > it's
> > possible,
> > those
> > engine
it
> > in
fans
> > help a
> > grill.
sort
> > of
> > somewhat
> > > clean.
time
> > die
> > Bluebirds
> > inverters
> > Looks
> > > Kurt Horvath
> > > 95 PT-42 WLWB
> > > Fayetteville TN
40yahoogroups.com>,
> > "Gregory OConnor"
> > > wrote:
> > > > Kurt,
> > heart
> > may
> > > > be even taller????
> > > > GregoryO'Connor
40yahoogroups.com>,
> > "bumpersbird"
> > > > controlers
> > packaging.
> > > > > cost to date:
> > > > > $1370.00 inverters.
> > > > > $ 305.00 controls.
> > side
> > > in
> > sometimes
> > > > wet
> > hold
> > > > 2
sheet
> > > > metal,
> > the
> > and
> > > > ran
lbs.
> > of
does
> > > not
> > > > connect
> > cable
> > > > to
of
> > > late
MCM
> > > > > welding cable.
> > figuring
> > > > out
rail
> > > > would
> > > > coach,
> > coach
> > > > on a
that
> > > > have
YIKES!!!
> > > > > Dear Kurt Horvath,
> > know
> > run
> > > > to
sure
> > to
subject
> > > > line
> > > > > Allegra Sloman
> > > wheel
> > > > cables
not
> > to
choice.
> > > Any
know
> > > > much
> > from
> > > > the
reduces
> > > the
helpful.
> > > > engine
small
> > > > problem
> > > wires
> > line.
> > > > I'm
> > > gotten
re-
> > run
> > > > the
> > > surrounded
> > > > by
> > water
> > > > tank
> > just
> > > > have
> > thermostats
> > > > to
> > ideas.
> > > > You
fuel
> > > > tank.
fans
> > on
> > > > the
here
> > > > again
> > I'm
> > > > not
fun.
> > > > > Kurt Horvath
> > > > > 95 PT-42 WLWB
> > > > > Fayetteville TN
> > > new
> > > > inverters
06-10-2008, 02:58
Well there you go, sounds like a good spot for the inverter.
Did you get a RC7 or RC7/GS control for the inverter?
Kurt Horvath
95 PT-42
10AC
work
> > Dorn,
of
that
cabinet
you
> > Kurt Horvath
> > 95 PT-42
> > 10AC
> > "Dorn Hetzel"
> > engine is
> > road. I'm
> > drivers
> > batteries...
> > > Dorn Hetzel
> > > 77FC35
> > > Hogansville, GA
learned
cooling
> > most
> > > > advantage.
(BirdBrains)
with
> > air
looks
product???????I
drive or
hinder
> > the
> > > > existing path
> > enimies
alone
away. Is
> > move),
inverter
> > inverter/
too
used.
> > > > GregoryO'Connor
> > > > 40yahoogroups.com>,
> > > > "bumpersbird"
> > > > wrote:
> > > > > Gregg,
power
> > > > techs
it
> > does
the DC
> > > > side
12'
> > it
> > > > may
of an
opinion is
> > > > it's
> > > > possible,
way
> > > > those
> > > > engine
a
vent
> > it
> > > > in
The
> > fans
also
> > > > help a
side
> > > > grill.
> > sort
> > > > of
> > > > somewhat
> > > > > clean.
in
> > time
have to
> > > > die
to
> > > > Bluebirds
> > > > inverters
lined,
> > > > Looks
> > > > > Kurt Horvath
> > > > > 95 PT-42 WLWB
> > > > > Fayetteville TN
> > > > 40yahoogroups.com>,
> > > > "Gregory OConnor"
> > > > > wrote:
> > > > > > Kurt,
> > > > heart
waterproof
> > and
> > > > may
> > > > > > be even taller????
top
> > > > > > GregoryO'Connor
> > > > 40yahoogroups.com>,
> > > > "bumpersbird"
> > > > > > controlers
> > > > packaging.
> > > > > > > cost to date:
> > > > > > > $1370.00 inverters.
> > > > > > > $ 305.00 controls.
right
> > > > side
> > > > > in
> > > > sometimes
> > > > > > wet
box to
> > > > hold
> > > > > > 2
> > sheet
> > > > > > metal,
replaced
> > > > the
braces
> > > > and
> > > > > > ran
120+
> > lbs.
> > > > of
it
> > does
> > > > > not
that
> > > > > > connect
of
> > > > cable
> > > > > > to
cable
> > of
> > > > > late
350
> > MCM
> > > > > > > welding cable.
> > > > figuring
> > > > > > out
frame
> > rail
> > > > > > would
under the
> > > > > > coach,
> > > > coach
> > > > > > on a
coaches
> > that
> > > > > > have
> > YIKES!!!
> > > > > > > Dear Kurt Horvath,
even
> > > > know
shorten the
> > > > run
> > > > > > to
> > sure
> > > > to
> > subject
> > > > > > line
> > > > > > > Allegra Sloman
of the
> > > > > wheel
bay
> > and
run the
> > > > > > cables
tear,
> > not
> > > > to
> > choice.
> > > > > Any
don't
> > know
> > > > > > much
change
> > > > from
> > > > > > the
> > reduces
> > > > > the
> > helpful.
from the
> > > > > > engine
> > small
> > > > > > problem
control
> > > > > wires
data
> > > > line.
> > > > > > I'm
haven't
> > > > > gotten
to
> > re-
> > > > run
> > > > > > the
> > > > > surrounded
> > > > > > by
small
> > > > water
> > > > > > tank
I'll
> > > > just
> > > > > > have
> > > > thermostats
> > > > > > to
for
> > > > ideas.
> > > > > > You
> > fuel
> > > > > > tank.
> > fans
> > > > on
> > > > > > the
But
> > here
> > > > > > again
downwards.
> > > > I'm
> > > > > > not
> > fun.
> > > > > > > Kurt Horvath
> > > > > > > 95 PT-42 WLWB
> > > > > > > Fayetteville TN
putting
> > the
> > > > > new
old
> > > > > > inverters
06-10-2008, 03:27
Kurt,
I'm puzzled -- you refer to the inverters as being in the engine compartment, but mine are in a metal box at the top of the house battery compartment, just in front of the engine compartment (curb side). (Two of the house batteries are nearby in the engine compartment, however.) The metal box has some vent holes in it (but no fan) -- and it does gather some dirt, but it's moderately insulated from the engine itself, so it's not quite as hot as if it were actually in the engine compartment proper.
Are your inverters in a different location? (I note that each WL seems to have it's own unique features, even those of the same year...)
El Sobrante CA
"aeonix1@mac.com"
On Jun 9, 2008, at 7:48 PM, bumpersbird wrote:
Gregg,
clean. <snip>
06-10-2008, 04:39
Pete,
My Inverters and Batterries are in the same place as yours, but with
the engine compartment being just inches away from the inverter/batt.
bay and the the tranny being under/to the side of the inverter box
the radiant heat warms everything up pretty good. Plus there is an
opening of about 8" X 24" between the two compartments. Which allows
the hot air to enter the inverter bay. So I have just gotten used to
the idea that they are one in the same. Not completly accurate from a
tech. point of veiw.
I've been working towards getting the temps down in the engine
compartment since last Aug. Hot bedroon syndrome. I'm not trying to
cool the engine. Just everything that surrounds it. That's why I'm
putting in some fans to vent the engine compartment. it's been done
by several other guys and they seem to like the results.
I have also considered exhaust blankets, some love them some hate
them. It's said that the pipes can rust prematurly. I don't know
about that but they seem like a good idea to me.
I guess I'm just stuck on making my coach all that it can be.
In the installation manual it goes into a great detail on
installation enviroment.
This from the Xantrex web site.
Installation
2–2 975-0209-01-01
Choosing a Location
Inverters are sophisticated electronic devices and should be treated
accordingly.
When selecting the operating environment for the inverter, don't
think of it in the
same terms as other equipment that works with it, such as batteries,
diesel
generators, motor generators, washing machines, and so on. It is a
highly complex
microprocessor-controlled device, similar in nature to stereo
equipment,
television sets, or computers. The use of conformal-coated circuit
boards, plated
copper bus bars, powder-coated metal components, and stainless steel
fasteners
improves tolerance to hostile environments. However, in a condensing
environment (one in which humidity and/or temperature change causes
water to
form on components) all the ingredients for electrolysis are present:
water,
electricity and metals. In a condensing environment the life
expectancy of the
inverter is indeterminate and the warranty is voided.
The inverter/charger should only be installed in a location that
meets the
following requirements:
CAUTION
Install the inverter in a dry, protected location away from sources
of high temperature and
moisture. Exposure to salt water is particularly destructive and
potentially hazardous.
Ventilated Do not operate the inverter/charger in a closed-in area or
restrict
ventilation in any way. The inverter/charger requires air circulation
to maintain optimum operating temperature and provide best
performance. If the unit has inadequate ventilation, it may shut down
due to overheating.
The air vented through the openings should also have a path to
circulate away from the inverter/charger.
Dry Do not allow water or other fluids to drip or splash on the
inverter.
Do not expose to rain, snow or water.
Cool Normal air temperature should be between 32 °F and 122 °F
(0 °C and 50 °C)—the cooler the better within this range.
Clearance Allow as much space around the inverter/charger as possible.
Xantrex recommends that other objects and surfaces be at least
3 inches (76 mm) away from the ventilation openings for best
performance.
Safe Locate the inverter/charger away from battery in a separate well
ventilated compartment. Do not install the inverter/charger in any
compartment containing flammable gases or liquids like gasoline.
Close to
battery
compartment
The length and size of your DC cables will affect performance. Use
the DC cables recommended in Table 2-2 on page 2–12. The unit
should not be installed in the battery compartment due to the
possible presence of explosive hydrogen gas from the batteries.
Bla, Bla, Bla, Bla ,
You know the older I get the more I read the instructions. I should
have realized from reading the instructions that the DC cables can't
be 22' long.
But no my two BB Gurus said it could be done. Well I
guess you could re-power a bird with a turbine, and chuck in an
afterburner for those steep hills, but it would plobably be tough on
your toad:}
What I'm really looking forward to is the next off the wall upgrade.
F.L.I.R. Forward Looking Infrared.
I think I will go with the PathFindIR unit small easy to install and
at a low price point about $3700.00 installed down in Houston
FLIR Systems, Inc.
70 Castilian Drive
Goleta, CA 93117
Phone: 1-877-773-FLIR (3547)
http://www.corebyindigo.com
http://www.flir.com
Gregg Conner once posted, " If it took a leaf blower to cool the
fridge I'd use it." I agree. What ever it takes to make it work, make
it better, make more fun. I'd really like to take that small water
tank between bay two
> Kurt,
(but
it
year...)
> Pete Masterson
> El Sobrante CA
> aeonix1@...
> > Gregg,
techs
side
may
it's
possible,
those
engine
it in
help a
grill.
of
somewhat
> > clean. <snip>
