Parking brake knob
05-26-2005, 14:10
Post: #21
Parking brake knob
Probably NAPA also.
- Jeff Miller
> Any truck-part shop should be able to help you, I buy from a fleet
> supplier but a Kenworth store, bus service, etc. You are looking
for a
> parking brake button for the Bendix PP-1 valve.
> - Jeff Miller
> http://www.wanderlodge.net
> --- In WanderlodgeForum@yahoogroups.com, jon lechich
> > Jeff where can I just locate the knob that goes on the shaft that
> opperates the air brake? Right now I just have a shaft and a D ring
> that's it. Can you help me? Jon
05-26-2005, 17:11
Post: #22
Parking brake knob
Thanks a heap! Jon
Jeff Miller wrote:Any truck-part shop should be able to
supplier but a Kenworth store, bus service, etc. You are looking for a
- Jeff Miller
opperates the air brake? Right now I just have a shaft and a D ring and
Yahoo! Groups Links
One of my favorite sayings goes! "You never own anything, everything owns you!"
Yahoo! Mail Mobile
Take Yahoo! Mail with you! Check email on your mobile phone.
05-27-2005, 15:19
Post: #23
Parking brake knob
> It's easiest from below the dash, it is open to the bottom. The
hard
> part is swinging the wrenches, a crow's-foot tubing wrench on a
short
> extension makes it work.
> Opening the front panel doesn't help, you can barely see it from
> front. Similarly, opening the top of the dash gives a good view of
> valve, but the fittings are on the bottom & side. Leave the dash in
IMO.
> - Jeff Miller
Jeff,
I know what a crow's-foot wrench is...by tubing wrench do you mean a
flare nut wrench? Is this a shop fabricated tool, a Snap On goodie or
an off-the-shelf item from Sears, Napa or...?
BTW, our parking brake is now working - 'Bird is going into the shop
next week. Last mechanic who cut a water line to get the parking
brake
to work was fired. Seems he wasn't qualified!? I'm hoping the new guy
can service the air dryer without disconnecting the LP tank :^0
Jim Owens 77 FC33SB (Gas)
Lake of the Ozarks, MO
05-27-2005, 15:30
Post: #24
Parking brake knob
look for rigid tubing wrenches they rachet and only need about a 10
degree arc to work used primarily in hvac work
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Jim Owens"
> hard
> short
> the
> the
> IMO.
> > - Jeff Miller
> Jeff,
> brake
05-27-2005, 22:44
Post: #25
Parking brake knob
> hard
> short
> the
> the
> IMO.
> > - Jeff Miller
> Jeff,
> flare nut wrench?
Jim,
That's exactly what it is. It's a 6 point box-end wrench that's
been cut enough to slip the tubing through so you can get a good grip
on the flare nut, usually brass and soft. The tubing wrench is made a
lot heavier on the end to keep it from opening up under a lot of stress.
I've used the craftsman brand in the past and found them to fit
too loosely to be any good. The Snap-On brand is a tight fit and
works well. Haven't tried any other brands, but when you find the
right one it will fit snugly on the nut.
Uh, yeah. ;o)
George Witt
81 FC 35
Lincoln, Nebraska--Huskers
Host for the August 7 Nebraska Parking Lot Rally
> brake
05-29-2005, 13:06
Post: #26
Parking brake knob
ok,must be something wrong............randy
To:
Sent: Thursday, May 26, 2005 7:53 PM
Subject: Re: [WanderlodgeForum] Parking brake knob
> Randy, I just got this message and it's dated May 24...received a couple
> other messages earlier today from you that were also dated a day or two
> back.
> Curt Sprenger ‘87PT38, Anaheim, Calif.
> randydupree wrote:
>> is it easier if you open the front panel? randydupree93wb
>> From: racin41@...
>> To: WanderlodgeForum@yahoogroups.com
>> Sent: Tuesday, May 24, 2005 3:31 PM
> Yahoo! Groups Links
05-29-2005, 13:06
Post: #27
Parking brake knob
ok! randy
Sent: Thursday, May 26, 2005 7:55 PM
Subject: [WanderlodgeForum] Re: Parking brake knob
It's easiest from below the dash, it is open to the bottom. The hard
part is swinging the wrenches, a crow's-foot tubing wrench on a short
Opening the front panel doesn't help, you can barely see it from the
front. Similarly, opening the top of the dash gives a good view of the
valve, but the fittings are on the bottom & side. Leave the dash in IMO.
- Jeff Miller
Yahoo! Groups Links
a.. To visit your group on the web, go to:
