Portable Freezers???
06-14-2008, 08:26
Anyboby have one of these Portable Freezers?
I would like to get one but there are several choices. They have two or three types of systems for cooling. Sizes, practicallity, do you really use them and reliability. I have found out that the two common types of compressors the swing compressor which can operate up to 30 degrees off level and the sealed Danfoss compressors which are very good but not a robust as the swing type. Can they really keep stuff frozen? I would like to hear from the group about any experiance with these freezers. Kurt Horvath 95 PT-42 WLWB 10ac |
06-14-2008, 10:48
I have a Norcold 640 series dual voltage unit. It was purchased by
the previous owner of the coach in 1985 and it does a super job. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "bumpersbird" > > Anyboby have one of these Portable Freezers? > I would like to get one but there are several choices. > They have two or three types of systems for cooling. Sizes, > practicallity, do you really use them and reliability. > I have found out that the two common types of compressors the swing > compressor which can operate up to 30 degrees off level and the sealed > Danfoss compressors which are very good but not a robust as the swing > type. > Can they really keep stuff frozen? > I would like to hear from the group about any experiance with these > freezers. > Kurt Horvath > 95 PT-42 WLWB > 10ac > |
06-14-2008, 11:55
--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002"
I also have the same one it is a 100# works very well. Bob Loomas 1985 PT 36 Harahan La > > I have a Norcold 640 series dual voltage unit. It was purchased by > the previous owner of the coach in 1985 and it does a super job. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > --- In WanderlodgeForum@yahoogroups.com, "bumpersbird" > > > > > Anyboby have one of these Portable Freezers? > > I would like to get one but there are several choices. > > They have two or three types of systems for cooling. Sizes, > > practicallity, do you really use them and reliability. > > I have found out that the two common types of compressors the swing > > compressor which can operate up to 30 degrees off level and the sealed > > Danfoss compressors which are very good but not a robust as the swing > > type. > > Can they really keep stuff frozen? > > I would like to hear from the group about any experiance with these > > freezers. > > Kurt Horvath > > 95 PT-42 WLWB > > 10ac > > > |
