Temps
06-18-2008, 00:06
Temps
Glen,
You have correctly identified the different radiators in your coach.
Pete has a dfferent type of engine and more radiators.
Your fan runs constantly with an faster speed controlled by a switch
on the dash that says "fan". If your water temp gets high you can turn
the switch on and "hopefully" pull the temps down. On mine(8V92), I
had to replace the radiator(another story).
Also, my engine only holds 6 1/2 gallons. Yours will probably hold
less. Use 40wt. oil ONLY in your engine.
On changing the trans fluid, do you know when the last time it was
changed? Smell it, does it smell burned? If so, change it. Remember,
we have a retarter in it, so it needs servicing more often.
Another item to check, the rear end fluid. I told the story of my
"simple" rear end fluid change that turned out different. You may not
have the miles I do, but you also don't know what the previous owner
(s) did as far as service.
90WBWL40 Jus Chillin
06-18-2008, 01:31
Temps
Thanks everyone for the responses. Pete you were right about the
retarder. I guess my old age and senility set in and helped me to
get my two coaches mixed up. I had not verified what the second
small radiator(it does have two electric fans mounted on it) did.
I'm going over to the bus this afternoon and will look. I have not
ever removed the outer grill that covers the radiator. If memory
seves me correctly the only fastener that I see on the outside of the
grill is a pop rivet at the top. What is the procedure for removing
the grill to clean the radiator? Thanks again, MIke Mcmahan 96 42'
Wanderlodge
> Pete Masterson, Author of
> Book Design and Production: A Guide for Authors and Publishers
> Aeonix1@...
> Aeonix Publishing Group http://www.aeonix.com
> On Jun 17, 2008, at 10:46 PM, Glenn Allen wrote:
> > Pete,
> > Good Summary. Can you or someone elaborate on the following
> > questions I have about the areas of your post noted below relative
> > to a 1986 PT-40 6V92.
> > Thanks,
> > Glenn....(see questions noted below your comments):
> >> The transmission cooler is in the bottom of the
> >> water radiator. The other radiator you see is not the
> >> transmission cooler. (I don't think it even has a fan.) The air
> >> flow through the transmission cooler is from the main radiator
> >> fan.
> > 1a) There is a small radiator attached on the outside bottom left
of
> > the main radiator that has hoses running to the power stearing
fluid
> > cannister. I assume this small radiator is cooling the fluid for
> > power stearing and the hydraulic fan. There is also a round
> > cannister down low that is between the driver's side of the engine
> > and the main radiator with large diameter (3"+) hoses from the
> > radiator and engine. There are also lines from the transmission.
> > I'm assuming this is the transmission heat exchanger. I would
> > assume water is flowing from the bottom of the radiator to the
> > transmission cooler and then to the engine. Is this correct?
> I'd have to go out to the coach and take a look. I don't recall
> "canister" you mention (it might be there, but I don't recall it).
> The bottom (1/4 or so?) of the water radiator is a radiator for
> transmission fluid. When my radiator core was removed, there was a
> 'stub' radiator for the transmission fluid. The new core attached
> above it. I no longer recall if water moved through some of the
tubes
> and transmission fluid moved through the other tubes or exactly
what
> the physical arrangement was.
> The second small radiator is for cooling the power steering (and
may
> cool the hydraulic fan fluid as well). The power steering
reservoir
> is a large canister on the curb side visible through both the rear
> and side doors. Do not overfill it. If you do, it will coat
> everything nearby with oil. (And I'm not going back to that place
for
> service again.)
> The fan pulls air through a 'stack' of radiators. You can remove
> grill on the street side and you'll see (I'm going by memory here,
so
> bear with me) the AC condenser, and the Air Charge cooler. Behind
> air charge cooler is the regular water radiator with the
transmission
> radiator in the bottom portion of it. You can't see the water/
> transmission radiator since it's fully covered by the Air Charge
cooler.
> Looking from the inside, you mostly see the fan and the metal
shroud
> that makes the fan more efficient.
> > 1b)I notice on this transmission cooler there are plugs on each
> > end. Do these plugs drain the water or transmission fluid from
> > heat exchanger (or maybe both)?
> Afraid I don't know. I have a 400+ page DD Series 60 manual (as a
> PDF). Perhaps I can make a copy available to you if you'd like. (I
> bought a CD with it on eBay.) I don't know if this manual
discusses
> the radiator set up in the coach (bus) as it's mostly focused on
> heavy truck installations. More likely this is covered in Allison
> documentation -- I don't have any of that stuff beyond the owner's
> manual.
> > 1c)Should this transmission cooler be cleaned or serviced?
> The transmission fluid filters should be changed every 36 or 48
> months depending on the size of filters you have. (I have to check
> this.) These are located in the transmission 'pan'. When the
filters
> are changed the transmission fluid is also changed. Use a
synthetic
> transmission fluid (I have Transynd). I don't think there's any
> specific service required for the cooler itself. You change the
> transmission fluid on the same interval as the filters. With an RV
> you're going to probably "time out" rather than exceed the
suggested
> miles.
> Change the engine oil (and filters) every year or 15,000 miles,
> whichever comes first. A full oil change will take nearly 40
quarts
> (10 gallons) of oil. You can use a synthetic, if you wish, but the
> change interval is the same. I have Rotella or Delo for heavy duty
> diesel engines.
> There is a canister on the curb side that holds about 3 gallons of
> oil and there's an automatic oil add system (requires air pressure
to
> operate), if needed.
> >> I think it comes on at 190 or so ... or whenever you turn on
> >> the "fan override" switch
> >> or turn on the dash AC.
> > 2a) I believe my fan is "always on". When the engine temp is
cool,
> > the AC is off, and the fan override is off, should the fan be
> > turning at idle speed or stationary?
> The fan should be not turning or turning very slowly at idle speed
if
> the engine isn't fully warm. They fan will run at full speed if
> _either_ the "fan override" or AC switch (the little button on the
> automotive heat control panel) are on.
> > 2b) Is the speed of the fan proportional to the engine RPM?
> Not that I'm aware of. I think it has two or three speeds.
Frankly,
> I've never paid much attention to the fan when it was operating.
I've
> verified that it works and I've seen the clouds of dust it kicks
up
> when it's on, though.
> > 3b) Where is the relay that the fan override switch controls?
> Front load center, SK 68 is the fuse. Relay K39 says "Chassis A/C
> Eng. Fan Enable" -- I don't see any other relay related to the Fan.
I
> suppose that the fan override switch tickles the same relay as the
AC
> switch.
> There area two other main Load Centers. One is behind the cabinets
> above the dashboard (on the right). The cabinets have a false back
> that pulls out, revealing the TV aerial wires and a load center.
> There's also a load center in the rear closet on the street side
> behind a felt-covered door.
06-18-2008, 01:40
Temps
Mike if your radiator grill is like mine you will have two screws latches at the top which are turned with an Allen Key. Sometimes the paint is thick in the screw heads so look closely and you should see the octangal shaped holes. You loosen these counterclockwise and lift the grill cover UP and OFF. It hooks on at the bottom while the two screw latches at the top keep it in place
2008/6/18 Mike McMahan <"mmcmahan@hot.rr.com">:
Wanderlodge
--- In "WanderlodgeForum%40yahoogroups.com", Pete Masterson
> Aeonix1@...
> > Pete,
> > Thanks,
> >> fan.
of
fluid
tubes
what
may
reservoir
for
> service again.)
so
transmission
cooler.
shroud
discusses
> manual.
filters
synthetic
suggested
> miles.
quarts
> diesel engines.
to
cool,
if
Frankly,
I've
up
I
AC
> switch.
Rob, Sue & Merlin Robinson
94 WLWB
06-18-2008, 01:41
Temps
This is related to a 1990 WB-40.
If your coach has an electric fan override yours should be similar but not necessarily identical. I have read that certain early models operate the fan with an air valve as opposed to electric.
The small radiator that sits on the bottom of the main radiator is a Hayden and cools the power steering and hydraulic fan oil. There are three filters in the oil reservoir and one Parker canister in line filter on the roadside.
If you follow the water hoses they should go to heat exchangers for the tranny and engine oil possibly from a manifold on the road side. Radiator water cools the engine and tranny oil.
Fan operation if yours is Alarmstat electric control.
The fan operates in idle(approx. 300-500rpm)except as follows:
Alarmstat turns on the fan to high mode at 195 degrees and cycles it to low
mode at about 188 degrees. You should be able to see this happen on the water temp gauge while driving. If the temp is not reduced to 188 degrees the fan remains in high mode until temps reach the lower value of the Alarmstat. The Alarmstat is located at or near the water pump in the water jacket. It is a bulb looking instrument with two wires. This unit is designed to default to fan high mode in the event of failure. Your fan operating in high mode at all times could be due to a failed Alarmstat(likely) or the Alarmstat has been removed by a PO. or a problem with a a/c/fan relay(unlikely) While stationary at idle have someone operate the fan override and/or chassis a/c and see if the fan speed changes. There is a very noticeable difference.
With the chassis a/c or fan override on the fan runs in high mode until either or both are switched off. Switching either one on takes the Alarmstat out of the system and runs the fan on high.
My
understanding is that engine idle speed provides more than adequate fluid volume to operate the fan on full high mode.
My fan enable relay is in the lower load center on an ignition circuit.
You need to find someone with 1986 prints for your records. I bet someone out there has a set. I have a fan circuit diagram for my coach if you want a copy. It may not be identical to your coach.
Leroy Eckert
1990 WB-40 Royale
Dahlonega, GA
Smoke N Mirrors
--- On Wed, 6/18/08, putneyflash@... wrote:
From: putneyflash@... Subject: Re: [WanderlodgeForum] Re: Temps
Date: Wednesday, June 18, 2008, 7:34 AM
Not to butt in, But the Fan/steering pump is either a gear or vane pump and both depend on Rpm's to move oil, so there comes a point where you must have high rpm's to get the maxium flow to turn the hydraulic motor at its maxium, speed.
RE
-------------- Original message from "Glenn Allen" : --------------
Pete,
Thanks,
> fan.
1a) There is a small radiator attached on the outside bottom left of
the main radiator that has hoses running to the power stearing fluid
radiator and
end. Do these plugs drain the water or transmission fluid from the
2a) I believe my fan is "always on". When the engine temp is cool,
Thanks for your
insight.
Glenn Allen
1986 PT-40
Mar
ietta, GA
06-18-2008, 02:12
Temps
Thanks Leroy. I guess I can't type either. 96 42' Wanderlodge
-- In WanderlodgeForum@yahoogroups.com, Leroy Eckert
it to low mode at about 188 degrees. You should be able to see this
> My understanding is that engine idle speed provides more than
circuit.
> Leroy Eckert
> 1990 WB-40 Royale
> Dahlonega, GA
> Smoke N Mirrors
> From: putneyflash@... > Subject: Re: [WanderlodgeForum] Re: Temps
> RE
> Pete,
> Thanks,
> > fan.
of
fluid
> Thanks for your insight.
> Glenn Allen
> 1986 PT-40
> Mar
> ietta, GA
06-18-2008, 02:16
Temps
Thanks Rob. MIke McMahan 96 42' Wanderlodge
latches at
thick in
shaped
UP and
top keep
> it in place
> 2008/6/18 Mike McMahan <mmcmahan@...>:
removing
> > Wanderlodge
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > Pete Masterson
> > > Aeonix1@
> > > > Pete,
relative
> > > > Thanks,
air
radiator
> > > >> fan.
left
> > of
> > fluid
for
engine
transmission.
> > the
it).
> > the
was a
attached
> > tubes
> > what
> > may
> > reservoir
rear
place
> > for
> > > service again.)
> > the
here,
> > so
Behind
> > the
> > transmission
> > cooler.
> > shroud
each
> > the
a
(I
> > discusses
Allison
owner's
> > > manual.
check
> > filters
> > synthetic
RV
> > suggested
> > > miles.
> > quarts
duty
> > > diesel engines.
of
pressure
> > to
> > cool,
speed
> > if
> > Frankly,
> > I've
> > up
A/C
Fan.
> > I
> > AC
> > > switch.
cabinets
back
> 94 WLWB
06-18-2008, 03:05
Temps
Hi Mike. I was trying to help Glenn on his '86. I do not know much about the later models except some have a system with aux fans and the Alarmstat is called something else.
However, my fan relay and fuse circuit is exactly the same as Pete's including the id numbers.
Sometimes these days my reading comprehension is suspect.
Leroy Eckert
1990 WB-40 Royale
Danlonega, GA
Smoke N Mirrors
--- On Wed, 6/18/08, Mike McMahan <mmcmahan@...> wrote:
Subject: [WanderlodgeForum] Re: Temps
Date: Wednesday, June 18, 2008, 10:12 AM
-- In "WanderlodgeForum%40yahoogroups.com", Leroy Eckert
circuit.
> Leroy Eckert
> 1990 WB-40 Royale
> Dahlonega, GA
> Smoke N Mirrors
> --- On Wed, 6/18/08, putneyflash@ ... wrote:
> From: putneyflash@ ...
> RE
> ------------ -- Original message from "Glenn Allen" : --
> Pete,
> Thanks,
> > fan.
of
fluid
> Glenn Allen
> 1986 PT-40
> Mar
> ietta, GA
06-18-2008, 04:14
Temps
My apologies -- I got Glen's message crossed up (in my mind) with another fellow who recently purchased a '96 PT-42 with the DD Series 60... so, most of what I said has nothing to do with a PT-40 with an 8V92.
Sorry...
El Sobrante CA
"aeonix1@mac.com"
On Jun 18, 2008, at 5:06 AM, patticake592000 wrote:
  Glen,
06-18-2008, 04:19
Temps
The radiator grill has 3 special fasteners. The OEM version uses an allen wrench to turn. They're a little strange as they turn a metal tab, but are also spring loaded, so it takes several turns to turn the tap 1/4 of the diameter. (This is easier to do than to explain.)
On my coach, I replaced the three fasteners with stainless steel ones with a slot. (A quarter works perfectly to turn them.) The grill is a little 'fussy' to re-position as a metal tab at the bottom that holds it in place is a little tight.
The fasteners are held in place by two pop rivets each.
El Sobrante CA
"aeonix1@mac.com"
Wanderlodge
06-18-2008, 08:21
Temps
--- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" <mmcmahan@...>
> I'm fixing to take my first hot weather trip(to Denver) in our 96 42'
> Wanderlodge series 60 six speed towing my 28' race car trailer.
Howdy, Mike.
Jack and I are in Buena Vista, CO for the summer. If you get down this
way, we are staying at Valley Mobile RV Park on Highway 24.
We hope that you have a good trip. Travel safe.
Regards,
Jack and Liz Pearce
1993 WLWB
Buena Vista, CO
