Temps
06-18-2008, 13:59
Post: #21
Temps
Thanks to everyone for their responses. I just spent the last three
hours cleaning the radiators on the bus. It only has 88000 miles on
it so I did not expect to find much but I was wrong. I took the
grill off and cleaned everything I could get to with greased
lightning, Then low pressure water. After about two cleanings really
nasty water running on the ground I thouoght it was pretty clean.
After looking a little closer I removed the ac cooler and behind it
on the ari cooler it was really nasty. After cleaning this I put it
all back together and started the engine. There is a noticeable
difference in the amount of air being pulled thru the radiator.
There were no real symptoms of any of this being clogged up, bus ran
fine and at proper temps. I knew that going to Denver the high
altitude air is enough thinner that it can reduce your cooling
efficency. Thanks again, Mike Mcmahan 96 42' Wanderlodge
> Hi Mike. I was trying to help Glenn on his '86. I do not know much
about the later models except some have a system with aux fans and
the Alarmstat is called something else.
> However, my fan relay and fuse circuit is exactly the same as
Pete's including the id numbers.
> Sometimes these days my reading comprehension is suspect.
> Leroy Eckert
> 1990 WB-40 Royale
> Danlonega, GA
> Smoke N Mirrors
> --- On Wed, 6/18/08, Mike McMahan <mmcmahan@...> wrote:
> From: Mike McMahan <mmcmahan@...>
> Subject: [WanderlodgeForum] Re: Temps
> Date: Wednesday, June 18, 2008, 10:12 AM
> Thanks Leroy. I guess I can't type either. 96 42'
Wanderlodge
> -- In WanderlodgeForum@ yahoogroups. com, Leroy Eckert
> Wanderlodge< jwasnewski@ ...> wrote:
> > This is related to a 1990 WB-40.
> > If your coach has an electric fan override yours should be
similar
> but not necessarily identical. I have read that certain early
models
> operate the fan with an air valve as opposed to electric.
> > The small radiator that sits on the bottom of the main radiator
is
> a Hayden and cools the power steering and hydraulic fan oil. There
> are three filters in the oil reservoir and one Parker canister in
> line filter on the roadside.
> > If you follow the water hoses they should go to heat exchangers
for
> the tranny and engine oil possibly from a manifold on the road
side.
> Radiator water cools the engine and tranny oil.
> > Fan operation if yours is Alarmstat electric control.
> > The fan operates in idle(approx. 300-500rpm)except as follows:
> > Alarmstat turns on the fan to high mode at 195 degrees and cycles
> it to low mode at about 188 degrees. You should be able to see this
> happen on the water temp gauge while driving. If the temp is not
> reduced to 188 degrees the fan remains in high mode until temps
reach
> the lower value of the Alarmstat. The Alarmstat is located at or
near
> the water pump in the water jacket. It is a bulb looking instrument
> with two wires. This unit is designed to default to fan high mode
in
> the event of failure. Your fan operating in high mode at all times
> could be due to a failed Alarmstat(likely) or the Alarmstat has
been
> removed by a PO. or a problem with a a/c/fan relay(unlikely) While
> stationary at idle have someone operate the fan override and/or
> chassis a/c and see if the fan speed changes. There is a very
> noticeable difference.
> > With the chassis a/c or fan override on the fan runs in high mode
> until either or both are switched off. Switching either one on
takes
> the Alarmstat out of the system and runs the fan on high.
> > My understanding is that engine idle speed provides more than
> adequate fluid volume to operate the fan on full high mode.
> > My fan enable relay is in the lower load center on an ignition
> circuit.
> > You need to find someone with 1986 prints for your records. I bet
> someone out there has a set. I have a fan circuit diagram for my
> coach if you want a copy. It may not be identical to your coach.
> > Leroy Eckert
> > 1990 WB-40 Royale
> > Dahlonega, GA
> > Smoke N Mirrors
> > --- On Wed, 6/18/08, putneyflash@ ... wrote:
> > From: putneyflash@ ... >
> > Subject: Re: [WanderlodgeForum] Re: Temps
> > To: WanderlodgeForum@ yahoogroups. com
> > Date: Wednesday, June 18, 2008, 7:34 AM
> > Not to butt in, But the Fan/steering pump is either a gear or
vane
> pump and both depend on Rpm's to move oil, so there comes a point
> where you must have high rpm's to get the maxium flow to turn the
> hydraulic motor at its maxium, speed.
> > RE
> > ------------ -- Original message from "Glenn Allen" : -
> > Pete,
> > Good Summary. Can you or someone elaborate on the following
> > questions I have about the areas of your post noted below
relative
> > to a 1986 PT-40 6V92.
> > Thanks,
> > Glenn....(see questions noted below your comments):
> > > The transmission cooler is in the bottom of the
> > > water radiator. The other radiator you see is not the
> > > transmission cooler. (I don't think it even has a fan.) The air
> > > flow through the transmission cooler is from the main radiator
> > > fan.
> > 1a) There is a small radiator attached on the outside bottom left
> of
> > the main radiator that has hoses running to the power stearing
> fluid
> > cannister. I assume this small radiator is cooling the fluid for
> > power stearing and the hydraulic fan. There is also a round
> > cannister down low that is between the driver's side of the
engine
> > and the main radiator with large diameter (3"+) hoses from the
> > radiator and engine. There are also lines
> > from the transmission.
> > I'm assuming this is the transmission heat exchanger. I would
> > assume water is flowing from the bottom of the radiator to the
> > transmission cooler and then to the engine. Is this correct?
> > 1b)I notice on this transmission cooler there are plugs on each
> > end. Do these plugs drain the water or transmission fluid from
> > heat exchanger (or maybe both)?
> > 1c)Should this transmission cooler be cleaned or serviced?
> > > I think it comes on at 190 or so ... or whenever you turn on
> > > the "fan override" switch
> > > or turn on the dash AC.
> > 2a) I believe my fan is "always on". When the engine temp is
cool,
> > the AC is off, and the fan override is off, should the fan be
> > turning at idle speed or stationary?
> > 2b) Is the speed of the fan proportional to the engine RPM?
> > 3b) Where is the relay that the fan override switch controls?
> > Thanks for your insight.
> > Glenn Allen
> > 1986 PT-40
> > Mar
> > ietta, GA
06-18-2008, 14:14
Post: #22
Temps
I'm sure you did the right thing. On my maiden trip (home to CA from near Dallas via Denver) I ran into serious heat problems while climbing some long grades in eastern Nevada. Had a very very long day where I was pulling off to cool down, then heating right up again when I started up a grade.
When I got to the Donner pass, during the morning hours, I had no particular heating trouble. But once I got home, I found a heavy duty radiator service and had the radiator pulled -- that's when I discovered that only the area swept by the fan was clear and everything else was fully clogged.
Since the cost of pulling the radiator was considerable, I decided to go ahead and replace the core (with a new, more modern design that's supposed to be more efficient).
Water temp hasn't been over 190 or so ever since. On that first trip, I spent half the time staring at the water temp gauge as it 'hung' at around 205 or so...
I get in every year or so and give it a good washing out with simple green and a garden hose. A fair amount of nasty stuff comes out each time.
There are solutions (that help) where you re-route the "slobber tube" (crankcase vent) that runs down the street side of the DD Series 60. Oily fumes will be pulled under the coach and back through the radiator by the fan. Add a little dust, and you have a recipe for oily concrete. One solution is to attach some plumbing to it to carry the fumes out the curb side. A more thorough (and expensive) solution is to get a filter system that catches the oil residue/mist before it leaves the tube.
El Sobrante CA
"aeonix1@mac.com"
--- In "WanderlodgeForum@yahoogroups.com", Leroy Eckert
Leroy Eckert
1990 WB-40 Royale
Danlonega, GA
Smoke N Mirrors
Wanderlodge
similar
models
is
for
side.
reach
near
in
been
takes
circuit.
Leroy Eckert
1990 WB-40 Royale
Dahlonega, GA
Smoke N Mirrors
vane
RE
Pete,
relative
Thanks,
fan.
of
fluid
engine
cool,
Glenn Allen
1986 PT-40
Mar
ietta, GA
Yahoo! Groups Links
<*> Your email settings:
    (Yahoo! ID required)
06-18-2008, 14:20
Post: #23
Temps
Glenn,
If you have already added fluid to the rear end, then you probably
don't need servicing. On mine, you could smell the fluid(when being
drained), from 5-10 feet away. It was really burned!!
When checking the speed of the fan, you will know if it's on low
speed, because you can almost count the blades(something like 300
to 500 rpms). Call Leroy, he's close and is good at diagnosing these
problems, plus he likes doing these things.
90WBWL40 Jus Chillin
06-18-2008, 14:39
Post: #24
Temps
Radiators are something we all take for granted because our daily vehicles have them in front. If you think about it, look at the side of the bus after a rainstorm. Dirt starts behind the front wheel and climbs the bus to the roof at the rear. The fan is sucking all that crud into the radiator in the process. A good cleaning once a year saves a $26,000 engine. We all should be happy that the cooling fan is not on the back of the bus. 8 wheels and all that &#%$ in the vacumn being sucked into it. Yuk.
I am happy I do not own a Revolution.
Leroy Eckert
1990 WB-40 Royale
Dahlonega, GA
Smoke N Mirrors
<mmcmahan@...>
Date: Wednesday, June 18, 2008, 9:59 PM
--- In "WanderlodgeForum%40yahoogroups.com", Leroy Eckert
> Leroy Eckert
> 1990 WB-40 Royale
> Danlonega, GA
> Smoke N Mirrors
> --- On Wed, 6/18/08, Mike McMahan <mmcmahan@.. .> wrote:
> From: Mike McMahan <mmcmahan@.. .>
Wanderlodge
similar
models
is
for
side.
reach
near
in
been
takes
> circuit.
> > Leroy Eckert
> > 1990 WB-40 Royale
> > Dahlonega, GA
> > Smoke N Mirrors
vane
> > RE
> > Pete,
relative
> > Thanks,
> > > fan.
> of
> fluid
engine
cool,
> > Glenn Allen
> > 1986 PT-40
> > Mar
> > ietta, GA
06-18-2008, 14:40
Post: #25
Temps
Does the 02 have the DD Series 60 or did they move to the Cummins?
Of course, it's possible that my thermostat is 5 degrees off, or so -- or my interpretation is off, since there's no mark at 190 or 195 -- as I recall, the mark is at 180 and 200...
The radiator guy told me what the thermostats were (OEM standard by the engine owners manual) but I don't recall exactly what they are.
El Sobrante CA
"aeonix1@mac.com"
On Jun 18, 2008, at 8:22 PM, David Brady wrote:
Pete, what thermostat are you running. My coach likes to run at
195 deg F. It could be that the newer coaches run with a hotter
thermostat.
David Brady
'02 LXi, NC
06-18-2008, 15:22
Post: #26
Temps
Pete,
thermostat.
David Brady
'02 LXi, NC
06-18-2008, 15:28
Post: #27
Temps
After the trouble CCW had getting the interface to talk with their computer, I'm sure I won't be getting VMSpc. (Besides, I'm an all-Mac kind of guy and I really don't want to get a Windows computer.)
CCW eventually had to dig out an old Windows 98 laptop to hook up to my connector. They just couldn't get anything newer to talk to the old hardware. At least they had one around to use ... and, of course this added another day to my sojourn there.
Hint: Take a toad with you if you ever plan to stay with your coach at CCW in Riverside! I opted not to, and I regretted it (I was there for 10 days -- I'd planned on 3. The long stay was not all their fault as there were some problems getting parts quickly and a last minute discovery of a failed front shock mount didn't help).
El Sobrante CA
"aeonix1@mac.com"
On Jun 18, 2008, at 8:54 PM, David Brady wrote:
Series 60. I thought maybe you were getting your temps from
VMSpc, or the like. I know my dash gauge reads 6 deg F high.
David Brady
'02 LXi, NC, (I bought the engine, the bus came with it)
El Sobrante CA
"aeonix1@mac.com"
thermostat.
David Brady
'02 LXi, NC
Checked by AVG. Version: 7.5.524 / Virus Database: 270.4.0/1506 - Release Date: 6/17/2008 4:30 PM
06-18-2008, 15:54
Post: #28
Temps
David Brady
so -- or myinterpretationis off, since there's no mark at 190 or
El Sobrante CA
"aeonix1@mac.com"
thermostat.
David Brady
'02 LXi, NC
06-18-2008, 16:37
Post: #29
Temps
Ouch, another failed front shock mount??? Is this the one that
Hendrickson's
welded for you? I guess you are stuck with Windows if you want VMSpc,
or for mega-bucks you can buy one of their stand-alone units, or you
could
pioneer a linux/wine installation. Ten days w/o a toad, I feel your
pain.
David Brady
'02 LXi, NC
course this added another day to mysojournthere.
El Sobrante CA
"aeonix1@mac.com"
your temps from
David Brady
Cummins?
off, or so -- or myinterpretationis off, since there's no mark
they are.
El Sobrante CA
"aeonix1@mac.com"
thermostat.
David Brady
'02 LXi, NC
06-18-2008, 19:23
Post: #30
Temps
Thanks Steve. I talked with Leroy tonight. He and Ralph have given me a few good
ideas
to investigate.
Glenn
1986 PT40
--- In WanderlodgeForum@yahoogroups.com, "patticake592000" <sgureasko@...>
> Glenn,
> Steve Gureasko
> Ponchatoula, La.
