Fresh Water Tanks
06-21-2008, 16:30
Fresh Water Tanks
Hello All.. just picked up a 78FC35 and found the fresh water tank bad
and water heater shot. I'm thinking about replacing the small water
heater under the bed with an electric tankless type, has anyone tried
this? If this would work I could replace the original fresh water tank
with a larger one as I haven't found a stock replacement anywhere.
Michael
06-21-2008, 16:47
Fresh Water Tanks
Michael,
Welcome the 'Bird Owners Club. Where are you located? When you have time please setup an auto signature so we know about you and your coach.
Your tankless water heater question should generate a few responses. There are a few folks on this site that can help you. And do not forget to keep us in the loop about your project.
Michael
Curt Sprenger
Anaheim Hills, CA
06-22-2008, 00:57
Fresh Water Tanks
we have replacement hot water tanks
stephen http://www.dupreeproducts.com
> Michael
06-22-2008, 03:54
Fresh Water Tanks
The only problem with an electric tankless water heater is that the current draw exceeds the current available from most campgrounds and your generator. It has often been discussed, but none with the capacity to actually provide the hot water you expect will work with the electrical limits involved.
Better you simply replace the existing water heater with an RV-type LP gas model.
Note. The AquaHot system in later 'birds is a tankless water heater. It has a 2000 watt heating element that gives you a 'shot' of hot water while the burner kicks on. The electrically heated water only lasts a short time and it can't adequately heat a significant flow of water.
As for replacing the fresh tank with a larger one, be careful to calculate the impact on the weight of the vehicle. It's not that hard to overload the coach and water adds about 7# per gallon.
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
06-22-2008, 04:21
Fresh Water Tanks
I mounted a propane Precision Temp tankless hot water heater in the
side of our coach. Its use of propane equates to 12,000btu per hour.
Since there are 92,000btus in a gallon on propane, we only fill our 5
(4)gallon external propane tank about every 6 weeks.
This gives us unlimited hot water. Limited only by your holding tanks.
My 15 minute showers (continuous)are great!!
It fits in the size of the 10 gallon Atwood tank.
I cut out the side of the bus and mounted it. See pics under photos.
This is our second one. The previous one was mounted in our 26ft GMC.
We now only use the electric as a backup. Haven't used it in 5 years,
tho.
Bob Lawrence
84 PT36
Workcamping in Branson, Mo.
with
type
> LP gas model.
heater.
only
of
> water.
hard
> Pete Masterson
> El Sobrante CA
> aeonix1@...
tank bad
water
tried
tank
06-22-2008, 05:04
Fresh Water Tanks
Bob:
You got pics of it installed. In your coach is it located in one of the bins?
Terrace, B.C. Canada
----- Original Message ----
Sent: Sunday, June 22, 2008 9:21:50 AM
Subject: [WanderlodgeForum] Re: Fresh Water Tanks
My 15 minute showers (continuous) are great!!
tho.
Bob Lawrence
84 PT36
with the
with
type
> LP gas model.
heater.
only
of
> water.
hard
> Pete Masterson
> El Sobrante CA
> aeonix1@...
tank bad
water
tried
tank
Now with a new friend-happy design! Try the new Yahoo! Canada Messenger
06-22-2008, 08:17
Fresh Water Tanks
Thanx Curt. Where do I setup the auto signature? I'll manually add
one to this post. I did order a replacement Hot Water Heater through
Dupree. Although I do like the tankless systems (use them at home) I
thought a small single faucet heater would be ok here, but still the
requirements are 23a @ 230v so I'll drop that for now. I'm not ready
to go gas on that yet, although that is an attactive solution.
Now I just need to replace the water tank. On the Wanderlodge page
it states the 78FC35 has a 98 gal fresh water tank, but it does not.
By my measurements it cannot be over 65 gal due to its dimensions
alone? So now I'm thinking about turning the tank 90 degrees and
loosing the under bed storage drawer to try and get a larger tank in
there. I'm assuming the black (42gal) & gray (60gal) numbers are
correct? If so I'd like to get closer to 100 gallons.
The current tank measures about 29"w x 38"l x 14"h. If I turn 90
degrees I could go with 32" x 48" x 16 if I move the heater vent or
14 if I leave it there. At any rate that would give me 106 gals or
93 gals and will leave more room for plumbing than exists now.
Michael Putz
1963 FC35 Bluebird "Freedom Bus"
1978 FC35 Wanderlodge "Putz'n Around"
1982 FC35 School Bus "Parts"
1982 GMC 40' RTS
Mesa, Az
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> Michael,
time
responses. There
to keep us
tank bad
water
tried
tank
> > Michael
> Curt Sprenger
> Anaheim Hills, CA
06-23-2008, 08:14
Fresh Water Tanks
Mike,
If you can't find the a tank to fit, you might consider two tanks with
overflow from tank 1 to tank 2 for filling and both feeding into the
water system. That is what is under the bed in our 82 PT40. Don't
know if it is original or a creative replacement.
Dan Carr
82PT40 6V
Columbiana, OH
Waiting on parts to fix my sporlan fill valve and dump valves.
Luckily one stop shopping compliments of Dupree Products.
> Michael
06-24-2008, 05:47
Fresh Water Tanks
--- In WanderlodgeForum@yahoogroups.com, "Dan Carr"
The archives detail the marine types of direct replacement water
heaters on the market. We have found that the engine heated feature
takes care of ALL hot water needs when traveling and the electric
function is equally good when parked. Replacement water containers
can be located by Googeling the subject.
We have found that less trouble will be encountered by using the on
board water tank and water pump system exclusively and using city
water sources to fill the tank. Greatly reduces the stress
on 'vintage' plumbing. Once you take a good look at the 'as designed'
water system, it's hard to improve on. On the other hand, there is
much that can be done to improve the DC electrical service. Adding
battery capacity and a inverter charger are top of the list
improvements.
MH
> Mike,
with
> Dan Carr
> 82PT40 6V
> Columbiana, OH
> --- In WanderlodgeForum@yahoogroups.com, "Michael" <mike.putz@>
tank bad
water
tried
water tank
anywhere.
> > Michael
06-24-2008, 06:12
Fresh Water Tanks
I did end up getting a replacement water heater from Dupree Products
that very much resembles the original one. And I found a tank from
Plastic-Mart that will fit in the original location without
modifications for a very decent price. Ocean Link had tanks for over
$400 while this one was only $121, both are spun tanks. I dropped
the modification idea due to time (trip coming up)and not really
gaining a lot using the existing tanks found. This one is 55 gal so
it is just a few gallons smaller. However, it does have a cut-out
that will allow for better room while plumbing. The original was so
tight I had problems getting it apart much less putting it back to
gether.
Michael
--- In WanderlodgeForum@yahoogroups.com, "michaelhohnstein"
feature
designed'
> improvements.
> MH
> > Mike,
> with
> the
Don't
> > Dan Carr
> > 82PT40 6V
> > Columbiana, OH
> tank bad
> water
> tried
> water tank
> anywhere.
> > > Michael
