Generator Fan Motor
06-22-2008, 07:21
Generator Fan Motor
Hi there,
I am new to Bluebirds (Yesterday) and i have a generator problem and i am hoping that someone can share some experiences. The fan that cools the generator radiator is not turning. I did turn the fan by hand and it keep turning and worked. I stopped the generator and restarted and it did the same thing again. I did this a third time and no matter how fast i spin the fan by hand it will not run by itself. I find what i believe to be a capacitor in a box right before the motor and confirmed that i do have 220 going to the motor. Does anyone know, does that typicaly go bad or the motor itself or both. Now assuming the motor has gone bad, are there any secrets for removing the fan assembly from the coach and from the squirrel cage. Thanks again for your help and being new to bluebird, i am sure i will have some more questions. Thanks Paul 1987 PT38 |
06-22-2008, 08:13
Generator Fan Motor
06-22-2008, 13:32
Generator Fan Motor
It could simply be your start capacitor, which is mounted on the side
of the fan or in a J-box. You can remove it and take it to a generator shop to check. Just be carefull that it doesn't unload on you. Keep fingers away from the connections. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "ppotter14950" wrote: > > Hi there, > > I am new to Bluebirds (Yesterday) and i have a generator problem and i > am hoping that someone can share some experiences. > > The fan that cools the generator radiator is not turning. I did turn > the fan by hand and it keep turning and worked. I stopped the > generator and restarted and it did the same thing again. I did this a > third time and no matter how fast i spin the fan by hand it will not > run by itself. > > I find what i believe to be a capacitor in a box right before the motor > and confirmed that i do have 220 going to the motor. > > Does anyone know, does that typicaly go bad or the motor itself or both. > > Now assuming the motor has gone bad, are there any secrets for removing > the fan assembly from the coach and from the squirrel cage. > > Thanks again for your help and being new to bluebird, i am sure i will > have some more questions. > > Thanks > > Paul > > 1987 PT38 > |
06-23-2008, 01:02
Generator Fan Motor
Paul:
Before you remove it, do you show voltage on your meters? If no voltage, then you have to start looking a different way. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, June 22, 2008 6:32:40 PM Subject: [WanderlodgeForum] Re: Generator Fan Motor It could simply be your start capacitor, which is mounted on the side of the fan or in a J-box. You can remove it and take it to a generator shop to check. Just be carefull that it doesn't unload on you. Keep fingers away from the connections. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In "WanderlodgeForum%40yahoogroups.com", "ppotter14950" wrote: > > Hi there, > > I am new to Bluebirds (Yesterday) and i have a generator problem and i > am hoping that someone can share some experiences. > > The fan that cools the generator radiator is not turning. I did turn > the fan by hand and it keep turning and worked. I stopped the > generator and restarted and it did the same thing again. I did this a > third time and no matter how fast i spin the fan by hand it will not > run by itself. > > I find what i believe to be a capacitor in a box right before the motor > and confirmed that i do have 220 going to the motor. > > Does anyone know, does that typicaly go bad or the motor itself or both. > > Now assuming the motor has gone bad, are there any secrets for removing > the fan assembly from the coach and from the squirrel cage. > > Thanks again for your help and being new to bluebird, i am sure i will > have some more questions. > > Thanks > > Paul > > 1987 PT38 > Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail |
06-23-2008, 01:34
Generator Fan Motor
Paul
On my coach and the previous coach there was a circuit breaker or reset button and on off switch on the control box which houses the main circuit breaker and voltage regulator.
As I recallthe switch controls the fan motor.
Fred & Jeanne Hulse
Morristown,Arizona 1997 Wanderlodge WB41 |
06-23-2008, 15:22
Generator Fan Motor
Update on generator fan I checked voltage and had voltage on both I had a 50/50 chance that I would be that Paul 1987 PT38 Hesperia, ca From: It could simply be your start capacitor, which is mounted on the side of the fan or in a J-box. You can remove it and take it to a generator shop to check. Just be carefull that it doesn't unload on you. Keep fingers away from the connections. R.E. (Ron) Marabito, --- In "WanderlodgeForum%40yahoogroups.com", "ppotter14950" wrote: > > Hi there, > > I am new to Bluebirds (Yesterday) and i have a generator problem and i > am hoping that someone can share some experiences. > > The fan that cools the generator radiator is not turning. I did turn > the fan by hand and it keep turning and worked. I stopped the > generator and restarted and it did the same thing again. I did this a > third time and no matter how fast i spin the fan by hand it will not > run by itself. > > I find what i believe to be a capacitor in a box right before the motor > and confirmed that i do have 220 going to the motor. > > Does anyone know, does that typicaly go bad or the motor itself or both. > > Now assuming the motor has gone bad, are there any secrets for removing > the fan assembly from the coach and from the squirrel cage. > > Thanks again for your help and being new to bluebird, i am sure i will > have some more questions. > > Thanks > > Paul > > 1987 PT38 > |
06-23-2008, 15:34
Generator Fan Motor
Paul:
If your windings on your motor were no good, I would doubt that the capacitor would keep it running that long. Since I am not near my coach, I think that the motor is 240 volts. Why not check it from house supply? Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: P & D To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 23, 2008 8:22:01 PM Subject: RE: [WanderlodgeForum] Re: Generator Fan Motor Update on generator fan
I
. Now with a new friend-happy design! Try the new Yahoo! Canada Messenger |
06-23-2008, 15:51
Generator Fan Motor
When I checked it while it was installed Has anyone replaced and where did they Thanks again for all the help Paul 1987 PT38 Hesperia CA From: WanderlodgeForum@yahoogroups.com Paul: Bill 84 FC 35 SB "$quanderlodge" ----- Original Message Update on generator fan I checked voltage and had voltage on both sides of cap and going to I had a 50/50 chance that I would be that lucky. I pulled Paul 1987 PT38 Hesperia, ca . Now with a new friend-happy design! Try the new Yahoo! |
06-23-2008, 17:00
Generator Fan Motor
The invoice shows the following for our '87 PT38: Gen fan motor 1/3HP - A.O. Smith - D1036/X003 $69.12. . Capacitor - 5-370V $3.75. Wheel (fan) - D10-10x1/2 $32.54 Clean, paint, assembly $45.00.
I took the gen housing/motor, fan, etc. assembly to an Electric Motor Sales & Service shop. One that rebuilds home furnace housing/motor/fan units. They are the same as what's in our homes. On Mon, Jun 23, 2008 at 8:51 PM, P & D <"audvid1@gte.net"> wrote:
06-23-2008, 22:58
Generator Fan Motor
Paul,
If you look closely there may be a label that states, "Oil every 3 months", I think this is pretty funny. The Grainger parts that I used on an Onan, I believe are the same, So check out these Grainger numbers. It is a 208 Volt three speed motor, then hard wire the highest speed. motor 208V 4M099 Starting Capacitor 2GE76 Squirrel Cage Blower 4C592 I replaced the Wheel and blower because it was old, out of balance and I damaged it trying to remove the motor. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "P & D" > > When I checked it while it was installed there was 220 volts getting to the > motor. > > > > Has anyone replaced and where did they find the motor. Mine has a part > number of 5KCP39KG3186S and on grainger there is one that is close, but does > not have the same mounting. > > > > Thanks again for all the help > > > > Paul > > 1987 PT38 > > Hesperia CA > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Wilhelmus Schreurs > Sent: Monday, June 23, 2008 8:34 PM > To: WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] Re: Generator Fan Motor > > > > Paul: > If your windings on your motor were no good, I would doubt that the > capacitor would keep it running that long. > Since I am not near my coach, I think that the motor is 240 volts. Why not > check it from house supply? > > > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > > ----- Original Message ---- > From: P & D > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, June 23, 2008 8:22:01 PM > Subject: RE: [WanderlodgeForum] Re: Generator Fan Motor > > Update on generator fan > > > > I checked voltage and had voltage on both sides of cap and going to the > motor. I replaced the run capacitor and it did not start. I gave it a > small push start and it started turning and ran for 5-10 minutes then came > to a stop. > > > > I had a 50/50 chance that I would be that lucky. I pulled squireel cage > assembly out and put it on the workbench. From the time that I had run the > generator to the time I got unit to my work bench was an 1.5 hours, and the > motor case was still very hot, so it makes me think there is something wrong > with the windings in the motor, so I will be out looking for a new motor. > > > > Paul > > 1987 PT38 > > Hesperia, ca > > > > _____ > > > > . > > > > > > _____ > > Now with a new friend-happy design! Try the new > <http://ca.beta.messenger.yahoo.com/> Yahoo! Canada Messenger > |
