Generator Fan Motor
06-23-2008, 23:48
Generator Fan Motor
When I reworked my complete generator bay 4 years ago I purchase the whole thing, motor and squirrel cage assembly from BB. As I recall about $200 new. That was then, who knows now.
Leroy Eckert
1990 WB-40 SmokeN Mirrors
Dahlonega, GA
Royale Conversion
--- On Mon, 6/23/08, P & D wrote:
Subject: RE: [WanderlodgeForum] Re: Generator Fan Motor
Date: Monday, June 23, 2008, 11:51 PM
When I checked it while it was installed
there was 220 volts getting to the motor.
Has anyone replaced and where did they
find the motor. Mine has a part number of 5KCP39KG3186S and on grainger
there is one that is close, but does not have the same mounting.
Thanks again for all the help
Paul
1987 PT38
Hesperia CA
[mailto:Wanderlodge Forum@yahoogroup s.com] On
Behalf Of
Wilhelmus Schreurs
Sent: Monday, June 23, 2008 8:34
PM
To:
WanderlodgeForum@ yahoogroups. com
Subject: Re: [WanderlodgeForum]
Paul:
If your windings on your motor were no good, I would doubt that the capacitor
would keep it running that long.
Since I am not near my coach, I think that the motor is 240 volts. Why
not check it from house supply?
Bill 84 FC 35 SB "$quanderlodge"
Terrace, B.C. Canada
----- Original Message
Sent: Monday, June 23, 2008 8:22:01 PM
Update on generator fan
I checked voltage and had voltage on both sides of cap and going to
the motor. I replaced the run capacitor and it did not start. I
gave it a small push start and it started turning and ran for 5-10 minutes then
came to a stop.
I had a 50/50 chance that I would be that lucky. I pulled
squireel cage assembly out and put it on the workbench. From the time
that I had run the generator to the time I got unit to my work bench was an 1.5
hours, and the motor case was still very hot, so it makes me think there is
something wrong with the windings in the motor, so I will be out looking for a
new motor.
Paul
1987 PT38
Hesperia, ca
Now with a new friend-happy design! Try the new Yahoo!
Canada Messenger
06-24-2008, 00:12
Generator Fan Motor
Have you considered having the motor reworked?
RE
-------------- Original message from Wilhelmus Schreurs : --------------
Paul:
If your windings on your motor were no good, I would doubt that the capacitor would keep it running that long.
Since I am not near my coach, I think that the motor is 240 volts. Why not check it from house supply?
----- Original Message ----
I checked voltage and had voltage on both sides of cap and going to the motor. I replaced the run capacitor and it did not start. I gave it a small push start and it started turning and ran for 5-10 minutes then came to a stop.
I had a 50/50 chance that I would be that lucky. I pulled squireel cage assembly out and put it on the workbench. From the time that I had run the generator to the time I got unit to my work bench was an 1.5 hours, and the motor case was still very hot, so it makes me think there is something wrong with the windings in the motor, so I will be out looking for a new motor.
Paul
1987 PT38
Hesperia, ca
Now with a new friend-happy design! Try the new Yahoo! Canada Messenger
06-24-2008, 05:15
Generator Fan Motor
I have a previous-owner invoice for motor replacement in August of '03:
Huston Electric, Lafayette, IN
Replace Blower Fan motor on Generator
Labor $238
1 motor 1/3 HP 1075 RPM MARA X003 .33HP 48Y Open 1ph $57.30
Cap 5MFD 370V OV-5-370 (no charge listed)
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA
On 6/23/2008 at 10:00 PM Curt Sprenger wrote:
>The invoice shows the following for our '87 PT38: Gen fan motor 1/3HP -
>A.O.
>Smith - D1036/X003 $69.12. . Capacitor - 5-370V $3.75. Wheel (fan) -
>D10-10x1/2 $32.54 Clean, paint, assembly $45.00.
>I took the gen housing/motor, fan, etc. assembly to an Electric Motor Sales
>& Service shop. One that rebuilds home furnace housing/motor/fan units.
>They
>are the same as what's in our homes.
06-24-2008, 05:39
Generator Fan Motor
I got a replacement at an electric motor specialty house (located in Oakland, CA). I can probably find the receipt with the name, if you want, but there's closer (and probably cheaper) alternatives. Perhaps Tom McCarthy will check in as he got a replacement fan in Southern California.
Just check your yellow pages under "electric motors" and you'll probably find a place that can get you a near-exact match. There's been a lot of changes in the electric motor business with companies being bought and sold, merging, etc. So it's sometimes a little tricky finding the exact duplicates -- but they're out there.
El Sobrante CA
"aeonix1@mac.com"
On Jun 23, 2008, at 8:51 PM, P & D wrote:
When I checked it while it was installed there was 220 volts getting to the motor.
Has anyone replaced and where did they find the motor.  Mine has a part number of 5KCP39KG3186S and on grainger there is one that is close, but does not have the same mounting.
06-24-2008, 14:22
Generator Fan Motor
Thank you for all the info, I ordered it
from Grainger today and will be able to pick up tomorrow, so I will
Know more soon.
Thanks again, awesome information
Paul
WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Curt Sprenger
Sent: Monday, June 23, 2008 10:01
PM
To:
fan motor 1/3HP - A.O. Smith - D1036/X003 $69.12. . Capacitor - 5-370V $3.75.
Wheel (fan) - D10-10x1/2 $32.54 Clean, paint, assembly $45.00.
units. They are the same as what's in our homes.
mounting.
help
Paul
1987 PT38
Hesperia CA
[mailto:"WanderlodgeForum@yahoogroups.com"]
On Behalf Of Wilhelmus Schreurs
PM
Paul:
Paul
1987 PT38
Hesperia, ca
Curt Sprenger
Anaheim Hills, CA
07-03-2008, 11:55
Generator Fan Motor
I replaced mine last year, best deal was an aircondition supply house, motor cost about 65.00
Ron Robert
95pt40
In a message dated 6/23/2008 11:51:57 P.M. Eastern Daylight Time, audvid1@... writes:
Paul
1987 PT38
Hesperia CA
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Wilhelmus Schreurs
Sent: Monday, June 23, 2008 8:34 PM
Subject: Re: [WanderlodgeForum] Re: Generator Fan Motor
Paul:
Paul
1987 PT38
Hesperia, ca
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
