Battery "drain" issue ?? maybe?
05-25-2005, 05:07
Hi Guys!
We have a 95 4203 and being newbies I am not sure whether or not we have a battery "drain" issue. I had the 3 engine batteries load tested, 1 was bad so I replaced it. I did not have the 6 "house" side load tested because they appear to be all new. However when the coach sits for a week, she fires right up, no problems but 1 of the "inverters" seems to start at about 130 amps, then slowly goes down to 10-15 in about 4-5 hours of the generator running to charge them up. Then other inverter starts at 10 amps and usually stays there. The master switch in the coach is alwys off and I have turned off every "device" I can find. Any ideas ?? Also does anyone know how these 2 changers/inverters are "loaded" or how the aux battery switch on the dash ought to work - it has 3 postions?? Thanks much! Pete and Donna Chin 1995 4203 newbies |
05-25-2005, 09:19
Hi Pete,
Answers are interspersed below: pgchd wrote: > Hi Guys! > We have a 95 4203 and being newbies I am not sure whether or not we > have a battery "drain" issue. I had the 3 engine batteries load > tested, 1 was bad so I replaced it. Make certain that you have at least 1000 amps CCA in group 31 batteries. Someone had changed mine to the interstate Group 24 with only 400 CCA each. It is best if all batteries are the same age, preferably from the same batch. I did not have the 6 "house" side > load tested because they appear to be all new. However when the coach > sits for a week, she fires right up, no problems but 1 of the > "inverters" seems to start at about 130 amps, then slowly goes down > to 10-15 in about 4-5 hours of the generator running to charge them > up. Then other inverter starts at 10 amps and usually stays there. The > master switch in the coach is alwys off and I have turned off every > "device" I can find. Several thoughts: 1st; my coach is an all electric 4203 so there may be some differences. If you are storing without power available, there are two switches that I have been told must be turned off. One is the A/T switch and the other is the electronics master in the overhead compartment, center front. I have been told that the small current flow for keep memory on the various electronics will deplete the batteries. Personally, we keep ours plugged in when not in use. Also we have an Amana refrigerator that draws a lot of power. You may have a manual master switch. My coach did not come with one. Supposedly, if you have such a switch, turning it to the off position disconnects all the batteries... If so, and you are still getting depletion of the batteries, check each cell of the house batteries. I suggest a hydrometer (about $25 for a good one). A load tester can be had from Harbor Freight for about $10 -20. I carry both. A dead or shorted cell in any one of your house batteries can drain all the rest in a short period of time. It can also overheat the battery and possibly explode. Any ideas ?? Also does anyone know how these 2 > changers/inverters are "loaded" or how the aux battery switch on the > dash ought to work - it has 3 postions?? Thanks much! On the inverters, one will assume the primary position, usually the same one every time, and the other seems to just loaf during the charging cycle. Sometimes, if you turn off the one with the larger load, the other will take over. As to the Aux. battery switch; this powers the relay to connect the engine and house batteries together. I normally leave it in the center (off) position unless needed. Mine seems to connect the batteries automatically when the key is turned on. If I need to charge the engine batteries, I will turn on the aux. battery or crossover switch until the engine batteries are up. I seldom find a need for this. The other position of the switch is a momentary on position meant to give a boost when starting. Hope this helps you out. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD > > Pete and Donna Chin > 1995 4203 newbies > > > > > > > Yahoo! Groups Links > > > > > > > > > |
