					Was:HELP - 8V92 will not start NOW It runs!
					06-23-2008, 11:22
				 Post: #1 | |||
| Was:HELP - 8V92 will not start NOW It runs! Larry, that is great news. I am thankful that you shared your results with us.
 Ernie Ekberg 83PT40 Livingston, Montana wishing I had a 8v-- or series 60 Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. | |||
					06-23-2008, 13:48
				 Post: #2 | |||
					OK Thanks for all the help to everyone that made suggestions. Today I talked to the old series 92 guru at Detroit Diesel about what could cause one bank to not fire. He said it could be several things, a clogged fuel hose, a clogged restricter valve or a blown injector fuse. I checked the hose for that side by running a long screwdriver though it. Then found the two inline fuses attached to the center battery. I followed the wires to the center DEC plug. That plug has two green wires that go to the battery ground lug. Four orange wires that merge into two wires that go to the inline fuses. One fuse is the curb side bank injectors power and the other is the street side bank injectors power. I wire brushed all the connectors and checked the DEC plug wires for 12 volts. I found that someone had cut a wire off the engine that looked like a ground, so I added a ground wire from the engine to the ground bar just for good measure. After purging the air, the old 8V92 fired up and I pushed the high idle switch for that great purrrrr. This difficult situation was a real learning experience. I feel so much more comfortable now with the engine. While I have worked on a lot of engines in the past, the 92 was a mystery that worried me a lot. I now know what I would do if the beast quits on the road some time. I somehow gained a real understanding of the fuel and DEC system. Just knowing that if the check engine goes out after the 10 second start-up, the DEC is likely OK is a great help. I was so worried that I had cooked the DEC. I really appreciate knowing that all you guys are here to make suggestions and send diagrams when we need them. Thanks again and I am ready to help with some suggestions now on the fuel and injectors system. Larry Kehler 94 PT-40 WBDA "BAM" St Louis | |||
					06-23-2008, 14:11
				 Post: #3 | |||
					06-23-2008, 14:26
				 Post: #4 | |||
					Glad it is solved and you are running. R.E. (Ron) Marabito, Dallas, TX 92WB40 Currently in Tolland, CT --- In WanderlodgeForum@yahoogroups.com, "Larry Kehler" wrote: > > OK Thanks for all the help to everyone that made suggestions. > > Today I talked to the old series 92 guru at Detroit Diesel about what > could cause one bank to not fire. He said it could be several things, > a clogged fuel hose, a clogged restricter valve or a blown injector fuse. > > I checked the hose for that side by running a long screwdriver though > it. Then found the two inline fuses attached to the center battery. > I followed the wires to the center DEC plug. That plug has two green > wires that go to the battery ground lug. Four orange wires that merge > into two wires that go to the inline fuses. One fuse is the curb side > bank injectors power and the other is the street side bank injectors > power. I wire brushed all the connectors and checked the DEC plug > wires for 12 volts. > > I found that someone had cut a wire off the engine that looked like a > ground, so I added a ground wire from the engine to the ground bar > just for good measure. > > After purging the air, the old 8V92 fired up and I pushed the high > idle switch for that great purrrrr. > > This difficult situation was a real learning experience. I feel so > much more comfortable now with the engine. While I have worked on a > lot of engines in the past, the 92 was a mystery that worried me a > lot. I now know what I would do if the beast quits on the road some > time. I somehow gained a real understanding of the fuel and DEC > system. Just knowing that if the check engine goes out after the 10 > second start-up, the DEC is likely OK is a great help. I was so > worried that I had cooked the DEC. > > I really appreciate knowing that all you guys are here to make > suggestions and send diagrams when we need them. Thanks again and I > am ready to help with some suggestions now on the fuel and injectors > system. > > Larry Kehler > 94 PT-40 WBDA "BAM" > St Louis > | |||
					06-23-2008, 14:38
				 Post: #5 | |||
					Leroy I don't know for sure but I think it was the cleaning of the orange power wires and fuses. The DD guru said that when a power fuse is blown a bank does not fire but if is a ground short, either even or odd injectors will not fire. Since mine was a bank short, it must have been the power shortage. I added the ground wire hoping to correct my speedometer that says I am going 20 miles per hour when I am sitting at a stop light. Larry Kehler 94 PT-40 WBDA "BAM" St Louis --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert wrote: > > Ok, if I understand it correctly, it was a ground problem; or was it corrosion on the fuse wires? Or both? Glad you got her going. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion | |||
					06-25-2008, 15:41
				 Post: #6 | |||
					Larry, glad you got the bus going. The only reason it even matters what the problem was is to keep it from happening again. If you found the problem to be the fuse that is good but if you fixed the issue by mistake, you don't know if you corrected the result or repaired the cause. Not to "beat a running bus" but I cant see 20 seconds of a diesel running at 600rpm with only 50% or the injectors working???? and if they all 8 did work for the 20 seconds and removal of 12v shut off one bank which shut down the engine, both exhaust manifolds would be identical heat???? I put the fuse on my list of obvious fixes. What is interesting is Paul&Jo Carver (Cool couple) had problems starting their 93pt several years ago and it turned out that one of the starter bateries was bad. Wonder if it was the one linked to the fuses?? Last month or so MrCarver posted that he had simular issues and found one other problem. wonder if it was related to the battery and wonder if your center battery is screwed also?????? Could be that you moved battery cables out of contact then back into contact while poking around all week and it is an issue waiting to happen again. If a guru is someone who tells you twenty things to try and one works, Im a RockBreaker guru. I beat on a Boulder atop a cliff in Palmsprings 2,000 times today and it broke. GregoryO'Connor RockBreaker Guru --- In WanderlodgeForum@yahoogroups.com, "Larry Kehler" > > OK Thanks for all the help to everyone that made suggestions. > > Today I talked to the old series 92 guru at Detroit Diesel about what > could cause one bank to not fire. He said it could be several things, > a clogged fuel hose, a clogged restricter valve or a blown injector fuse. > > I checked the hose for that side by running a long screwdriver though > it. Then found the two inline fuses attached to the center battery. > I followed the wires to the center DEC plug. That plug has two green > wires that go to the battery ground lug. Four orange wires that merge > into two wires that go to the inline fuses. One fuse is the curb side > bank injectors power and the other is the street side bank injectors > power. I wire brushed all the connectors and checked the DEC plug > wires for 12 volts. > > I found that someone had cut a wire off the engine that looked like a > ground, so I added a ground wire from the engine to the ground bar > just for good measure. > > After purging the air, the old 8V92 fired up and I pushed the high > idle switch for that great purrrrr. > > This difficult situation was a real learning experience. I feel so > much more comfortable now with the engine. While I have worked on a > lot of engines in the past, the 92 was a mystery that worried me a > lot. I now know what I would do if the beast quits on the road some > time. I somehow gained a real understanding of the fuel and DEC > system. Just knowing that if the check engine goes out after the 10 > second start-up, the DEC is likely OK is a great help. I was so > worried that I had cooked the DEC. > > I really appreciate knowing that all you guys are here to make > suggestions and send diagrams when we need them. Thanks again and I > am ready to help with some suggestions now on the fuel and injectors > system. > > Larry Kehler > 94 PT-40 WBDA "BAM" > St Louis > | |||
 Member Funded
Member Funded Link Directory
Link Directory Wanderlodge Trader
Wanderlodge Trader Document Library
Document Library User Locations
User Locations Gallery
Gallery Calendar
