Installing a new SureFlo water pump...
07-02-2008, 12:17
On my coach it is under the bed.
Leroy Eckert
1990 WB-40 Royale
Dahlonega, GA
Smoke N Mirrors
--- On Wed, 7/2/08, Scott Forman <scottforman75@...> wrote:
Subject: [WanderlodgeForum] Re: Installing a new SureFlo water pump...
Date: Wednesday, July 2, 2008, 7:37 PM
Where is the pressure tank?
Scott Forman
86 PT38
Memphis
--- In "WanderlodgeForum%40yahoogroups.com", "Ryan Wright"
> Thank you for the responses. I ordered the 5.7 from pplmotorhomes, and
> the screen/filter for it. Look forward to installing this. I'm going
> to go through and tighten any hose clamps I can find before
> installation, just to be safe.
> I do think I'll keep the pressure tank. I usually keep the pump off,
> only turning it on when necessary. The pressure tank allows me to wash
> my hands and flush the toilet a couple of times without turning the
> pump on, which is nice, especially in the middle of the night.
> Appreciate the replies!
> -Ryan
> '86 PT-40 8V92
07-02-2008, 12:27
It's actually an "accumulator tank" that accumulates pressure for the water system. It's often located near the main water pump. It will look like a canister of about 6 to 8" in diameter and perhaps 12 to 14" tall. Mine was painted blue. There will be a schrader valve on one end. This allows you to pressurize the diaphragm, if it loses it's 'charge.' Normally you'd fill it with air to about the expected water pressure in the system, that puts the rubber diaphragm at the minimum stretch. As pressure drops, the diaphragm pushes on the water side of the accumulator tank (giving you water pressure). As water pressure is recovered by the pump, it will push the diaphragm back against the trapped air.
Almost all water pump systems (home or RV) have them (sized for the water demand). The usual maintenance issue is that the air pressure has been lost (just put a compressor on it and pump it back up) or the diaphragm has failed (in which case the accumulator tank must be replaced).
El Sobrante CA
"aeonix1@mac.com"
Scott Forman
86 PT38
Memphis
--- In "WanderlodgeForum@yahoogroups.com", "Ryan Wright"
-Ryan
'86 PT-40 8V92
Yahoo! Groups Links
<*> Your email settings:
    (Yahoo! ID required)
07-02-2008, 12:36
Is it marked on the accumulator how much air pressure one is supposed
to put into the unit?
Al Johnson
'96 BMC B100
Mandeville, Louisiana
to
expected
water
pressure
be
> replaced).
> Pete Masterson
> El Sobrante CA
> aeonix1@...
> > Scott Forman
> > 86 PT38
> > Memphis
> > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright"
pplmotorhomes,
> >> and
going
off,
to
> >> wash
> >> -Ryan
> >> '86 PT-40 8V92
> > Yahoo! Groups Links
07-02-2008, 13:46
What's the difference? I've always heard it called a "pressure tank"
... we use them on wells, in water filtration systems, etc. Not that
the name matters. Smile I Google'd both of them and got plenty of results
for the same products.
Scott, mine is under the driver's side bed, toward the front of the coach.
-Ryan
07-02-2008, 13:54
Kevin,
Thanks for the info. I'm looking forward to receiving this new pump.
Mine is the old belt driven style... and I do mean old; my '66 Travco
had the same darn pump and based on the looks of it, I'm guessing
that's what it came with. Pretty sure my Bird came with the same pump
way back in '86.
I always leave my water pump off unless I'm washing dishes or taking a
shower. Beyond that, I only turn it on for a few seconds to recharge
the pressure/accumulator tank when water flow slows down. I do this
for precisely the reason you mentioned... A couple of years ago,
before I bought my coach, I read a post (I think it was on this forum
even) about someone who came back to a flooded coach and a smoking,
almost but not quite on fire water pump that had been running dry for
God knows how long. I'd rather not deal with any of that and it's easy
enough to flip the water on and off as I need it. Smile
-Ryan
'86 PT-40 8V92
On Wed, Jul 2, 2008 at 6:44 PM, wrote:
> Ryan,
> I installed the shurflo a few years ago, after my accumulator tank failed.
> I eliminated the tank, and went with just the pump. Works great. The pump
> speeds up when the demand increases, and it is sure nice using the shower
> with the improved pressure. You use more water just because it comes out
> faster, but according to my girls, it's a lot easier to get the shampoo out
> of their hair so it probably about the same water usage. All the tank does
> is maintain some pressure in the lines so the pump doesn't run for just a
> momentary demand of water. Since the shurflo is a variable speed motor, you
> won't notice a difference in sound from the original (maybe even a little
> quieter)
> Just one note....I had a fitting pop off the pressure side of the pump while
> I was driving, and in a short period of time that ever so efficient pump
> almost drained my fresh water tank into the area where the pump and
> accumulator tank is located. It was a faulty shurflo clamp....(taught me to
> keep the pump switch "Off")
> Kevin McKeown
> Yorba Linda, CA
> 1986 38' PT (For sale)
> ________________________________
> Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
07-02-2008, 14:43
Does this look like your pump? If so it is used in a million boats and
in our Wanderlodge coach. It can run for days without water and not
get hot. I just wanted to defend it so it does not get a bad name.
http://www.wmjmarine.com/itt-369001000.html It has been around for
years, long before computers. Still pumping.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
> Kevin,
> way back in '86.
> -Ryan
> '86 PT-40 8V92
> > Ryan,
failed.
The pump
shower
comes out
shampoo out
tank does
just a
motor, you
little
> > quieter)
pump while
efficient pump
> > Kevin McKeown
> > Yorba Linda, CA
used cars.
07-02-2008, 14:46
No one ever considers that.
Leroy Eckert
1990 WB-40 Royale
Dahlonega, GA
--- On Wed, 7/2/08, erniecarpet@... wrote:
Subject: Re: [WanderlodgeForum] Installing a new SureFlo water pump...
Date: Wednesday, July 2, 2008, 10:05 PM
One thing about the increased gpm, is the extra flow into your gray tank. Might fill up too fast.
83PT40
Livingston, Montana
07-02-2008, 15:53
Ryan,
A call to Shurflo might be worth it regarding its use with the
pressure tank. The installation instructions are pretty clear
in that there shouldn't be any elbows, or other obstructions,
within x distance from the pump outlet. These kinds of
obstructions can reflect the water pressure tricking the pump
into thinking that the water line is pressurized (when it's actually
only the pressure in the pressurized tank). You may end up
with pressure oscillations if you keep the pressure tank. Give
it a try. If you have oscillations, then remove the pressure
tank.
David Brady
'02 LXi, NC
-Ryan
'86 PT-40 8V92
Checked by AVG. Version: 7.5.526 / Virus Database: 270.4.3/1529 - Release Date: 7/1/2008 7:23 PM
07-02-2008, 16:46
One thing about pump ratings is the psi at a given gpm discharge.
shureflow seems to maintain sufficient psi at normal use. I fill the
fresh water tank and use the pump to pressurize the bus often while
camped with full hookups. Not hearing the pump run when all is quiet
indicates no leaks.
My 94 has two ShureFlow pumps I have the option of running both but
can only guess that that is to maintain a steady psi with higher
volumn flow. ( Like Ernie points out that is asking for a quick
depletion) I use one or the other to exersize both pumps
independently(choice is an "A-B-Both switch in the bathroom). One
thing to point out in this thread
XXXXXXXXXXXXXXXXXXXXX
The pumps have a built in backflow / checkvalve. that is; you can
not push water in the discharge side even with the pump off. if the
backflow craps out, pressurizing with city p.o.c. will send water
past the pump and overflow the Potable tank. If you remove a pump
for repair it is best to plug both lines (atleast the discharge) and
not loop them with a pipe splice.
GregoryO'Connor
94ptRomolandCa
07-03-2008, 03:53
No. It is apparently assumed that you'll know what to do. (These are mostly installed by professional plumbers.) The only instructions I found in a brief online search stated: The accumulator tank is precharged at 0.8 bar. If your pump's cut-in pressure is different you may have to customize the tank to best fit your installation. It goes on to explain how to check and adjust the pressure in the tank. See:
I note that this appears to be from a Swedish company and English is not the primary language. I leave it to you to figure out what 0.8 bar is in psi. English instructions are on page 4 of this pdf.
El Sobrante CA
"aeonix1@mac.com"
Al Johnson
'96 BMC B100
--- In "WanderlodgeForum@yahoogroups.com", Pete Masterson
to
expected
water
pressure
be
replaced).
El Sobrante CA
aeonix1@...
Scott Forman
86 PT38
Memphis
pplmotorhomes,
going
off,
to
wash
-Ryan
'86 PT-40 8V92
Yahoo! Groups Links
Yahoo! Groups Links
