Dash AC / Sight glass
05-25-2005, 09:08
Does anyone know if there is a sight glass on the dash ac system
anywhere that can be gotten to easily? Also the capacity of the ac system on a 90SP? Thanks Tom 90 SP36 Alpharetta GA |
05-25-2005, 13:24
Hi Tom,
I just converted my old system over to 134-A. I pulled a vaccuum on the system and it held for 8 hours. When I filled it, she took about 5 lbs of refrigerant and oil. Your SP36 should take between 4 and 5 pounds if you evacuate it. I could not find a sight glass anywhere in my a/c lines. Seems to be maintaining around 40 degrees out of the vents. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" wrote: > Does anyone know if there is a sight glass on the dash ac system > anywhere that > can be gotten to easily? Also the capacity of the ac system on a 90SP? > Thanks Tom 90 SP36 Alpharetta GA |
05-25-2005, 14:03
some sight glass's are on top of the dryer.sometimes there is a small cardboard
plug,protecting the glass.randydupree93wb ----- Original Message ----- From: sfedeli3 To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 25, 2005 9:24 PM Subject: [WanderlodgeForum] Re: Dash AC / Sight glass Hi Tom, I just converted my old system over to 134-A. I pulled a vaccuum on the system and it held for 8 hours. When I filled it, she took about 5 lbs of refrigerant and oil. Your SP36 should take between 4 and 5 pounds if you evacuate it. I could not find a sight glass anywhere in my a/c lines. Seems to be maintaining around 40 degrees out of the vents. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" wrote: > Does anyone know if there is a sight glass on the dash ac system > anywhere that > can be gotten to easily? Also the capacity of the ac system on a 90SP? > Thanks Tom 90 SP36 Alpharetta GA ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-25-2005, 14:17
Shane,
When I switched the dash a/c over to 134, only "hardware" update was a new expansion valve. Pulled a vacuum on it for a while, then filled system with 38oz of R134. Works like a champ! 5 pounds is a lot more than what I used. Did you repace the roof top condenser with something larger? Jay Darst 85PT40 SpringfieldIL --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@c...> wrote: > Hi Tom, > > I just converted my old system over to 134-A. I pulled a vaccuum on > the system and it held for 8 hours. When I filled it, she took about 5 > lbs of refrigerant and oil. Your SP36 should take between 4 and 5 > pounds if you evacuate it. I could not find a sight glass anywhere in > my a/c lines. Seems to be maintaining around 40 degrees out of the > vents. > > Shane Fedeli > 85PT40 > Hershey, PA > > > --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" > wrote: > > Does anyone know if there is a sight glass on the dash ac system > > anywhere that > > can be gotten to easily? Also the capacity of the ac system on a > 90SP? > > Thanks Tom 90 SP36 Alpharetta GA |
05-25-2005, 14:22
sight glass would be on top of drier in a R-12 system but it dont work
with a r134 system or one that has been converted Stepehen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" > Does anyone know if there is a sight glass on the dash ac system > anywhere that > can be gotten to easily? Also the capacity of the ac system on a 90SP? > Thanks Tom 90 SP36 Alpharetta GA |
05-25-2005, 14:49
Thanks for your help guys but it looks like I need more than just a
chrage of the system. looks like my compressor is bad. leaking around the front. Anybody have an idea what kind of compressor it is on a 90 SP. the guy helping me was asking me about the sytem and asked me if i could get a drawing of the system and how it was layed out.Anybody no were i could get one? or is it set up the same as a car system? anything special he should know..Thanks Tom 90 SP36 Alpharetta GA --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > some sight glass's are on top of the dryer.sometimes there is a small cardboard plug,protecting the glass.randydupree93wb > ----- Original Message ----- > From: sfedeli3 > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, May 25, 2005 9:24 PM > Subject: [WanderlodgeForum] Re: Dash AC / Sight glass > > > Hi Tom, > > I just converted my old system over to 134-A. I pulled a vaccuum on > the system and it held for 8 hours. When I filled it, she took about 5 > lbs of refrigerant and oil. Your SP36 should take between 4 and 5 > pounds if you evacuate it. I could not find a sight glass anywhere in > my a/c lines. Seems to be maintaining around 40 degrees out of the > vents. > > Shane Fedeli > 85PT40 > Hershey, PA > > > --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" > wrote: > > Does anyone know if there is a sight glass on the dash ac system > > anywhere that > > can be gotten to easily? Also the capacity of the ac system on a > 90SP? > > Thanks Tom 90 SP36 Alpharetta GA > > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
05-25-2005, 15:05
if its the york style compressor we have them
Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" > Thanks for your help guys but it looks like I need more than just a > chrage of the system. looks like my compressor is bad. leaking > around the front. > Anybody have an idea what kind of compressor it is on a 90 SP. > the guy helping me was asking me about the sytem and asked me if > i could get a drawing of the system and how it was layed out.Anybody > no were i could get one? or is it set up the same as a car system? > anything special he should know..Thanks Tom 90 SP36 Alpharetta GA > > > --- In WanderlodgeForum@yahoogroups.com, randydupree > wrote: > > some sight glass's are on top of the dryer.sometimes there is a > small cardboard plug,protecting the glass.randydupree93wb > > ----- Original Message ----- > > From: sfedeli3 > > To: WanderlodgeForum@yahoogroups.com > > Sent: Wednesday, May 25, 2005 9:24 PM > > Subject: [WanderlodgeForum] Re: Dash AC / Sight glass > > > > > > Hi Tom, > > > > I just converted my old system over to 134-A. I pulled a > vaccuum on > > the system and it held for 8 hours. When I filled it, she took > about 5 > > lbs of refrigerant and oil. Your SP36 should take between 4 and > 5 > > pounds if you evacuate it. I could not find a sight glass > anywhere in > > my a/c lines. Seems to be maintaining around 40 degrees out of > the > > vents. > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" > > > wrote: > > > Does anyone know if there is a sight glass on the dash ac > system > > > anywhere that > > > can be gotten to easily? Also the capacity of the ac system on > a > > 90SP? > > > Thanks Tom 90 SP36 Alpharetta GA > > > > > > > > > > ------------------------------------------------------------------- > ----------- > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > > > [Non-text portions of this message have been removed] |
05-25-2005, 15:22
Stephen, york style??Iguess I dont know what that is. Hopefully I
will be able to pull it off tomorrow and get some info off it. Tom 90 SP36 --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > if its the york style compressor we have them > Stephen 77fc35 > > > --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" > > Thanks for your help guys but it looks like I need more than just a > > chrage of the system. looks like my compressor is bad. leaking > > around the front. > > Anybody have an idea what kind of compressor it is on a 90 SP. > > the guy helping me was asking me about the sytem and asked me if > > i could get a drawing of the system and how it was layed out.Anybody > > no were i could get one? or is it set up the same as a car system? > > anything special he should know..Thanks Tom 90 SP36 Alpharetta GA > > > > > > --- In WanderlodgeForum@yahoogroups.com, randydupree > > wrote: > > > some sight glass's are on top of the dryer.sometimes there is a > > small cardboard plug,protecting the glass.randydupree93wb > > > ----- Original Message ----- > > > From: sfedeli3 > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Wednesday, May 25, 2005 9:24 PM > > > Subject: [WanderlodgeForum] Re: Dash AC / Sight glass > > > > > > > > > Hi Tom, > > > > > > I just converted my old system over to 134-A. I pulled a > > vaccuum on > > > the system and it held for 8 hours. When I filled it, she took > > about 5 > > > lbs of refrigerant and oil. Your SP36 should take between 4 and > > 5 > > > pounds if you evacuate it. I could not find a sight glass > > anywhere in > > > my a/c lines. Seems to be maintaining around 40 degrees out of > > the > > > vents. > > > > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" > > > > > wrote: > > > > Does anyone know if there is a sight glass on the dash ac > > system > > > > anywhere that > > > > can be gotten to easily? Also the capacity of the ac system on > > a > > > 90SP? > > > > Thanks Tom 90 SP36 Alpharetta GA > > > > > > > > > > > > > > > --------------------------------------------------------------- ---- > > ----------- > > > Yahoo! Groups Links > > > > > > a.. To visit your group on the web, go to: > > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > > of Service. > > > > > > > > > > > > [Non-text portions of this message have been removed] |
05-25-2005, 15:53
Shane,
How much 134-a and how much oil? Curt Sprenger â87PT38, Anaheim, Calif. sfedeli3 wrote: > Hi Tom, > > I just converted my old system over to 134-A. I pulled a vaccuum on > the system and it held for 8 hours. When I filled it, she took about 5 > lbs of refrigerant and oil. Your SP36 should take between 4 and 5 > pounds if you evacuate it. I could not find a sight glass anywhere in > my a/c lines. Seems to be maintaining around 40 degrees out of the > vents. > > Shane Fedeli > 85PT40 > Hershey, PA |
05-25-2005, 16:09
Tom,
If the compressor is a "stand-up" vs. "laying down round cylinder" it is most likely a York. The York has the two High/Suction lines or ports on the flat top of the compressor. Remove the compressor and take it to maybe NAPA in your area, or to an Automotive Air conditioning supply house. You may need a new clutch too. I just paid $200 for my York compressor and $100 for the clutch. Get a new dryer, take the old one with you. Curt Sprenger â87PT38, Anaheim, Calif. Tom Seitz wrote: > Thanks for your help guys but it looks like I need more than just a > chrage of the system. looks like my compressor is bad. leaking > around the front. > Anybody have an idea what kind of compressor it is on a 90 SP. > the guy helping me was asking me about the sytem and asked me if > i could get a drawing of the system and how it was layed out.Anybody > no were i could get one? or is it set up the same as a car system? > anything special he should know..Thanks Tom 90 SP36 Alpharetta GA > > > --- In WanderlodgeForum@yahoogroups.com, randydupree > wrote: > > some sight glass's are on top of the dryer.sometimes there is a > small cardboard plug,protecting the glass.randydupree93wb > > ----- Original Message ----- > > From: sfedeli3 > > To: WanderlodgeForum@yahoogroups.com > > Sent: Wednesday, May 25, 2005 9:24 PM > > Subject: [WanderlodgeForum] Re: Dash AC / Sight glass > > > > > > Hi Tom, > > > > I just converted my old system over to 134-A. I pulled a > vaccuum on > > the system and it held for 8 hours. When I filled it, she took > about 5 > > lbs of refrigerant and oil. Your SP36 should take between 4 and > 5 > > pounds if you evacuate it. I could not find a sight glass > anywhere in > > my a/c lines. Seems to be maintaining around 40 degrees out of > the > > vents. > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Tom Seitz" > > > wrote: > > > Does anyone know if there is a sight glass on the dash ac > system > > > anywhere that > > > can be gotten to easily? Also the capacity of the ac system on > a > > 90SP? > > > Thanks Tom 90 SP36 Alpharetta GA > > > > > > > > > > ------------------------------------------------------------------- > ----------- > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------------------------------------------ > *Yahoo! Groups Links* > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > -- |
