PT Radiator Air Scoop
09-11-2008, 04:40
Post: #21
I hope you guys do the ribbon thing, kinda why I didnt post my
result.
I found that there is no airflow past the grill. the ribbon would
not lift horiz. mounted on aprox 6 inch a piece of plastic, the
ribbon would spin out and back to the rear. when the fan come on the
ribbon got sucked to the grill. I wanted to open the rear gate and
see if that changed air flow. But remember;is you only need the
engine oil to be 230 to 250 and the water 180 to 195 to make the bus
run as engineered. running cooler than that is not cool.
I do think that the hydrolic fan could do a better job of reusing
the radiator passed air to more evenly cool the outside of the
block. If you run the bus at 1500 rpm standing still ;fan on. most
of the air goes out the first 3 feet of the rear door vent and
verry little ever gets pathed to the battery area and manifold over
the passanger side engine block. I wonder if closing off most of the
leading part of the rear door vent would shroud the air to push heat
out of the engine compartment. I would think it would path air thru
the rad for those who have electric fans above the batteies.
shrouding engines for air cooling is an engineered calc. I think
that is where the gas workhorse pushers are having problems.
GregoryO'Connor
94ptRomoladCa
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
> Gregg......
> Do I need to add Air Louvers like on the Eagle, rotate the grill
45
> degrees, Do I have to tie ribbons on the grill and go for a
drive????
> Come on cough it up........
> Kurt Horvath
> 95 PT-42
> 10AC
> --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> > Hey Greg...I'll believe anything ..until I won't... Please fill
us
> in.
> > We are hanging...
> > On Wed, Sep 10, 2008 at 3:26 PM, Scott Forman
> <scottforman75@>wrote:
> > > You can't leave us hanging like that.
> > > Scott Forman
> > > 86 PT38
> > > Memphis
> > > --- In WanderlodgeForum@yahoogroups.com > 40yahoogroups.com>,
> > > "Gregory OConnor"
> > > wrote:
> > > > I tied ribbons in my grill last week and taped a piece of
erect
> > > flat
> > > > plastic pointed outward at drivers window and grill to get a
> clue on
> > > > air flow. wont comment because you guys wont believe it.
> > Curt Sprenger
> > 1987 PT38 8V92 "MacAttack Racing"
> > Anaheim Hills, CA
09-11-2008, 05:32
Post: #22
> result.
bus
heat
> GregoryO'Connor
> 94ptRomoladCa
> > Gregg......
> 45
> drive????
> > Kurt Horvath
> > 95 PT-42
> > 10AC
> us
> > in.
> > > We are hanging...
> > > > Scott Forman
> > > > 86 PT38
> > > > Memphis
> > > > --- In WanderlodgeForum@yahoogroups.com > > 40yahoogroups.com>,
> > > > "Gregory OConnor"
> erect
> > > > flat
a
> > clue on
> > > Curt Sprenger
> > > Anaheim Hills, CA
> >I have followed with great interest the ribbon test string??. I
too have constructed scoops to direct air into and through the
radiator in my '90 SP36. They stick out the sides 4 inches and are
painted to match. Look pretty but were of little help. I did not
use the ribbon test as I have a guage that measures inches of water
in both directions. When I attached a long hose to it and placed it
in various positions in the rear and side grills I found NO
measureable pressure. If anything the rear of the coach seems to be
a calm area with very little air movement/pressure. I have yet to
do the measure thing since the scoops were added.
Another thought worth considering is to install 12 volt cooling fans
on the side grills to suck air into and out through the radiator. As
you can tell I am trying to limit the amount the fan runs. I did
install a 180 deg. diverter (thermostat) in my 3208 but have not
taken it out with that change yet. Here's hoping!
Bob Criss
'90 SP36
Bethel Park, PA
09-11-2008, 07:57
Post: #23
While this discussion has been going on I have been looking for an article I read about rear engine vehicles. Cooling was a concern because there is no way to get any "ram" air effect. The only radiator placement that had any benefit was rear mounted. There is a negative pressure immediately following a vehicle and there can be some passive air flow through a rear mounted radiator. It was not enough to "idle" the fan. I will keep looking, maybe I can find it yet. It did include wind tunnel tests.
- Chuck Wheeler-
FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of crissrace
Sent: Thursday, September 11, 2008 12:33 PM
Subject: [WanderlodgeForum] Re: PT Radiator Air Scoop
--- In "WanderlodgeForum%40yahoogroups.com", "Gregory OConnor"
> result.
bus
heat
> GregoryO'Connor
> 94ptRomoladCa
> --- In "WanderlodgeForum%40yahoogroups.com", "Kurt Horvath"
> > wrote:
> > Gregg......
> 45
> drive????
> > Kurt Horvath
> > 95 PT-42
> > 10AC
> > --- In "WanderlodgeForum%40yahoogroups.com", "Curt Sprenger"
> us
> > in.
> > > We are hanging...
> > > > Scott Forman
> > > > 86 PT38
> > > > Memphis
> > > > --- In "WanderlodgeForum%40yahoogroups.com" > > 40yahoogroups.com>,
> > > > "Gregory OConnor"
> erect
> > > > flat
a
> > clue on
> > > Curt Sprenger
> > > Anaheim Hills, CA
Bob Criss
'90 SP36
Bethel Park, PA
09-11-2008, 11:47
Post: #24
Hey BOB:
Please keep me posted on what changes u make to the radiator
airflow... thanks
Hank
90SP36
--- In WanderlodgeForum@yahoogroups.com, "crissrace"
> > result.
> the
> bus
most
over
> the
> heat
thru
> > GregoryO'Connor
> > 94ptRomoladCa
> > wrote:
> > > Gregg......
grill
> > 45
> > drive????
> > > Kurt Horvath
> > > 95 PT-42
> > > 10AC
fill
> > us
> > > in.
> > > > We are hanging...
> > > > > Scott Forman
> > > > > 86 PT38
> > > > > Memphis
> > > > > --- In WanderlodgeForum@yahoogroups.com > > > 40yahoogroups.com>,
> > > > > "Gregory OConnor"
> > erect
> > > > > flat
get
> a
> > > clue on
> > > > Curt Sprenger
> > > > Anaheim Hills, CA
it
be
fans
As
> Bob Criss
> '90 SP36
> Bethel Park, PA
09-11-2008, 15:43
Post: #25
My main reason for airflow is my interest in adding a Mister. I
think the mister cools the air and not the radiator therefor you
need space and time to do the calorie thing to the air. My last
trip up the grapevine pulling a HummerPU in 105 degree heat and a
freshly rodded radiator proved that the cooling system works proper
the way BBengineeres designed it to.
The mister is just a project to add a safety device for backup as
there is a small variable between 'optimal operating temp' 185
and 'your totaly screwed temp' 205.
I like to run the dash ac but the fan need to be on to blow air over
the ac coil. It is not the added stress of the ac compressor that
engineers prompt the fan to run every time the ac is on, it is the
need for air over the ac coil. The prob with running the ac is I
dont like to run the fan as the bus water stays at 160 and the oil
way cool also.
a 12 volt fan should do the trick for the ac and even be an added
device to cool part of the bus rad. I wonder if some major 12v
airflow over the ac coil and one 12Vfan directing that air to be
exhusted over and out the grill at the driver side ; with closed
off rear vents is the ticket??
I dont think I will ever do it because sill havent taken down the
Christmass lights. gotta do that soon because they dont work and its
a litle over 100 day to go.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan"
> Hey BOB:
> airflow... thanks
> Hank
> 90SP36
> > > result.
would
on
> > the
> and
> > bus
reusing
> most
> over
of
> > the
push
> > heat
> thru
think
> > > GregoryO'Connor
> > > 94ptRomoladCa
> > > wrote:
> > > > Gregg......
> grill
> > > 45
> > > drive????
> > > > Kurt Horvath
> > > > 95 PT-42
> > > > 10AC
> fill
> > > us
> > > > in.
> > > > > We are hanging...
> > > > > > Scott Forman
> > > > > > 86 PT38
> > > > > > Memphis
> > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > 40yahoogroups.com>,
> > > > > > "Gregory OConnor"
of
> > > erect
> > > > > > flat
> get
> > a
> > > > clue on
it.
> > > > > Curt Sprenger
> > > > > Anaheim Hills, CA
string??. I
are
not
water
placed
> it
to
> be
to
> fans
radiator.
> As
did
> > Bob Criss
> > '90 SP36
> > Bethel Park, PA
09-12-2008, 16:13
Post: #26
Gregg,
http://www.acpartsguys.com/ac_supplies
Check this web site, scroll down a little and look for the Hayden
High Performance Rapid Cool Radiator Mist System. $50 bucks. A couple
of these units with a few more nozzles would work. Mount it, wire it,
good to go. If there is no vacuum to pull it in you will need to spay
the water into the Rad some how.
Kurt Horvath
95 PT-42
10AC
over
> way cool also.
its
> GregoryO'Connor
> 94ptRomolandCa
> > Hey BOB:
> > airflow... thanks
> > Hank
> > 90SP36
my
> > > > result.
> would
> the
> on
> > > the
gate
> > and
> the
> the
> > > bus
> reusing
> > most
> and
manifold
> > over
> of
> > > the
> push
> > > heat
air
> > thru
> think
> > > > GregoryO'Connor
> > > > 94ptRomoladCa
> > > > wrote:
> > > > > Gregg......
> > grill
> > > > 45
> > > > drive????
> > > > > Kurt Horvath
> > > > > 95 PT-42
> > > > > 10AC
Please
> > fill
> > > > us
> > > > > in.
> > > > > > We are hanging...
> > > > > > > Scott Forman
> > > > > > > 86 PT38
> > > > > > > Memphis
> > > > > > > --- In
WanderlodgeForum@yahoogroups.com > > > > > 40yahoogroups.com>,
> > > > > > > "Gregory OConnor"
piece
> of
> > > > erect
> > > > > > > flat
to
> > get
> > > a
> > > > > clue on
> it.
> > > > > > Curt Sprenger
> > > > > > Anaheim Hills, CA
> string??. I
> are
> not
> water
> placed
> > it
> to
> > be
yet
> to
> > fans
> radiator.
> > As
> did
not
> > > Bob Criss
> > > '90 SP36
> > > Bethel Park, PA
