Kohler generator overheating
08-14-2008, 12:40
Greg,
Others may chime in, but I am not convinced that the fan "sucking"
instead of "blowing" is your problem. 80's FC's (including my
old '82 FC) had basically the same radiator/fan set-up and the fan
sucked in so as to not be blowing hot air out on the "porch" area.
As long as the fan is moving air across the radiator, it should not
matter which direction it is moving.
You may want to look for plugged hoses on a radiator stuck closed.
Scott
--- In WanderlodgeForum@yahoogroups.com, Greg Young
> Hi Bryan & Scott and everybody
> Follow up to our generator issues. I had the radiator serviced and
it was only 20% blocked, so the guess is that was not the problem.
However, I was wrong about the fan. Ours appeared to be sucking air
in rather than blowing out. There is a junction box leading to the
fan motor, which was wired normally - Hot (black) to black, neutral
(white) to white. I reversed these and the motor continues to suck
in. So how does one reverse the wiring and actually make it change
direction?
> I'm also a little baffled about oil levels and think we may have a
plug somewhere - the dipstick showed oil level above max, yet when I
opened the plug, with the filter off and the oil filler cap off, no
oil came out. Putting in more resulted in oil spilling out the
breather hose.
> Sorry, I'm not a gearhead like so many of you, but I can follow
instructions if they're detailed enough...
> Thanks!
> Greg Young
> 1986 PT40
> Escondido, CA
> (760) 807-1727
> ----- Original Message ----
> From: Greg Young
> Sent: Thursday, August 7, 2008 7:17:51 PM
> Subject: Re: [WanderlodgeForum] Re: Kohler generator overheating
> Hi Scott - Thanks for the info. We have the standard vertical, so
I think the fan's OK. Time to flush, and if that doesn't improve it,
I'll probably take it in for "professional" (i.e. expensive)
assessment.
> Greg Young
> 1986 PT40
> Escondido CA
> From: Scott Forman <scottforman75@...>
> Sent: Thursday, August 7, 2008 5:54:06 PM
> Subject: [WanderlodgeForum] Re: Kohler generator overheating
> Greg,
> If you bus has the stock vertical radiator with traditional fan, it
> should blow out...or at least that is what mine does.
> Later models...and some retro-fitted earlier ones...have a
horizontal
> radiator with squirrel's cage fan blowing down and out.
> I ran my Yanmar this past weekend at heavy load in 104 degree heat
> and it never went above 180.
> Scott Forman
> 86 PT38
> Memphis
> --- In WanderlodgeForum@ yahoogroups. com, Greg Young
> > Hi Bryan - Thanks for the idea. Which way is it supposed to turn -
> exhausting air through the radiator, or pulling it in? I would
think
> out, which is what ours is doing.
> > -Greg
> > 86 PT40
> > From: Bryan Altier
> > To: WanderlodgeForum@ yahoogroups. com
> > Sent: Thursday, August 7, 2008 3:45:08 PM
> > Subject: Re: [WanderlodgeForum] Kohler generator overheating
> > Greg, We had some problems with ours overheating
> > just at times, (hot weather) and I discovered that the cooling
fan
> on the
> > radiator was turning backwards. Reversed two wires and problem
> > solved.
> > Bryan Altier
> > 88WLWB 40
> > Greenville, SC
> > ----- Original Message -----
> > From: Greg Young
> > To: Wanderlodge Forum
> > Sent: Thursday, August 07, 2008 4:09 PM
> > Subject: [WanderlodgeForum] Kohler generator overheating
> > Hi -
> > Our Kohler generator is overheating under load. So far I've
> replaced the thermostat, and so I guess that flushing the system is
> the next step.
> > Details:
> > 86 PT-40
> > Kohler 12.5CCO67-RV
> > Yanmar 4-cyl engine
> > with no load ran cool. Started adding load at around 180 degrees
> > Added load up to 20A leg one, 30A leg two - all three cruise-air
> AC's running plus some other appliances. Maintained about 115V all
> the time.
> > Temp slowly climbed up to about 215 before I took the load off.
In
> the past it actually tripped the high temp switch, but I didn't see
> any point in doing that again.
> > After I took the load off it slowly dropped to around 200.
Stopped
> it then.
> > We've got two weeks before we head to the desert and 100+ heat.
> Any thoughts would be appreciated.
> > Thanks!
> > Greg Young
> > 1986 PT40
> > Escondido, CA
> > (760) 807-1727
08-14-2008, 12:46
Greg in a DC (direct current) motor like the 12v water pump,
reversing the + and - from the battery will reverse the rotation of
the spinn. quite often the DC - lead from the battey is refered to
as a "ground" we call it ground because that is the path used to run
the direct current directly back at (not to) the battery. but it is
not universal with "AC Ground"
The 120V juice to run the fan (if it is not 220)is not DC it is AC
or alternating current. there is no direction. To reverse an AC
motor you change the "starting wingings" with the "running
windings". usuly there is a face plate that labels the colors. You
would want to rewire the black to black and white to white to
maintain ground protection with the genset power.
One other point to make about wires with motors is that if there are
compacitors holding stored juice, they can give a hell of a shock
to the touch. ANd 120V is 120V be it from a wall socket in the house
or a little 3 horse honda inverter. test for voltage first with a
meter then with a screwdriver prior to touching it with your hands
Maybe that is the way the fan is required to run? I guess it depends
on how the squirl cage fins are set up????? Bird engineers may have
made several changes to try and prevent dust at the fan and the lack
of air with the air streeming past at 60 mph???????
OIL****************
the drain plug for the engine is on the engine??? maybe you are
pulling a dry plug of the generator head???
if it truly was the oil plug,,,
pull the filler cap off; remove oil drain plug; keep the filter on
and ;blow some air down the filler cap ( aprox 15-25 psi) you should
get oil out of the drain plug, or air .
and it was only 20% blocked, so the guess is that was not the
problem. However, I was wrong about the fan. Ours appeared to be
sucking air in rather than blowing out. There is a junction box
leading to the fan motor, which was wired normally - Hot (black) to
black, neutral (white) to white. I reversed these and the motor
continues to suck in. So how does one reverse the wiring and
actually make it change direction?
breather hose.
> Thanks!
> Greg Young
> 1986 PT40
> Escondido, CA
> (760) 807-1727
> From: Greg Young
it, I'll probably take it in for "professional" (i.e. expensive)
assessment.
> Greg Young
> 1986 PT40
> Escondido CA
> Greg,
it
horizontal
> Scott Forman
> 86 PT38
> Memphis
turn -
think
> > -Greg
> > 86 PT40
> > From: Bryan Altier
fan
> on the
> > solved.
> > Bryan Altier
> > 88WLWB 40
> > Greenville, SC
> > From: Greg Young
> > Hi -
is
> the next step.
> > Details:
> > 86 PT-40
> > Kohler 12.5CCO67-RV
> > Yanmar 4-cyl engine
> the time.
In
see
Stopped
> it then.
> > Thanks!
> > Greg Young
> > 1986 PT40
> > Escondido, CA
> > (760) 807-1727
08-14-2008, 12:55
I bet Scott is right. 20% blockage is 50 to 60 % efficiency lost. If
flow and air was not the issue prior, it may well be now that you
have drained the block and still have air in the system. I would
loosen some hoses to remove air that is traped and cavitating the
pump????? may be RobR can explain how he got the air out.
I know you are in a pinch to get off to BM so give me a call and I
can try and fine some one to look at it in Temecula. I made a phone
call . ON the road it is good to remember that many euipment rental
yards have inhouse mechanics that are well versed in genset repair
and usuly a wizz on equipment with varity of facets.
GregO'Connor
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman"
<scottforman75@...> wrote:
> Greg,
area.
not
> Scott
problem.
air
neutral
suck
change
> direction?
a
I
no
> breather hose.
> > Thanks!
> > Greg Young
> > 1986 PT40
> > Escondido, CA
> > (760) 807-1727
> > From: Greg Young
so
it,
> assessment.
> > Greg Young
> > 1986 PT40
> > Escondido CA
> > From: Scott Forman <scottforman75@>
> > Greg,
it
> horizontal
heat
> > Scott Forman
> > 86 PT38
> > Memphis
turn -
> think
> > > -Greg
> > > 86 PT40
> > > From: Bryan Altier
> fan
> > on the
problem
> > > solved.
> > > Bryan Altier
> > > 88WLWB 40
> > > Greenville, SC
> > > From: Greg Young
> > > Hi -
is
> > the next step.
> > > Details:
> > > 86 PT-40
> > > Kohler 12.5CCO67-RV
> > > Yanmar 4-cyl engine
degrees
air
all
> > the time.
off.
> In
see
> Stopped
> > it then.
heat.
> > > Thanks!
> > > Greg Young
> > > 1986 PT40
> > > Escondido, CA
> > > (760) 807-1727
08-14-2008, 13:05
Greg,
Looking at the motor at the end of the fan, mine had two wires coming out of the winding and wrapped up before going back into the winding. I removed the wrapping and found that there were two connectors that I swapped causing the motor to run in the proper direction. Look and see if there is a sticker on the end of the fan housing with an arrow "direction". Since I got mine blowing out the bottom of the fan my overheating problems are apparently gone.
Bryan Altier
88 WLWB 40
Greenville, SC
Sent: Thursday, August 14, 2008 7:36 PM
Follow up to our generator issues. I had the radiator serviced and it was only 20% blocked, so the guess is that was not the problem. However, I was wrong about the fan. Ours appeared to be sucking air in rather than blowing out. There is a junction box leading to the fan motor, which was wired normally - Hot (black) to black, neutral (white) to white. I reversed these and the motor continues to suck in. So how does one reverse the wiring and actually make it change direction?
I'm also a little baffled about oil levels and think we may have a plug somewhere - the dipstick showed oil level above max, yet when I opened the plug, with the filter off and the oil filler cap off, no oil came out. Putting in more resulted in oil spilling out the breather hose.
Sorry, I'm not a gearhead like so many of you, but I can follow instructions if they're detailed enough...
Thanks!
Greg Young
1986 PT40
Escondido, CA
(760) 807-1727
Hi Scott - Thanks for the info. We have the standard vertical, so I think the fan's OK. Time to flush, and if that doesn't improve it, I'll probably take it in for "professional" (i.e. expensive) assessment.
Greg Young
1986 PT40
Escondido CA
Greg,
Later models...and some retro-fitted earlier ones...have a horizontal
Scott Forman
86 PT38
Memphis
--- In "WanderlodgeForum%40yahoogroups.com", Greg Young
exhausting air through the radiator, or pulling it in? I would think
> -Greg
> 86 PT40
> From: Bryan Altier
> just at times, (hot weather) and I discovered that the cooling fan
on the
> solved.
> Bryan Altier
> 88WLWB 40
> Greenville, SC
> From: Greg Young
> Hi -
the next step.
> Details:
> 86 PT-40
> Kohler 12.5CCO67-RV
> Yanmar 4-cyl engine
the time.
> Temp slowly climbed up to about 215 before I took the load off. In
> After I took the load off it slowly dropped to around 200. Stopped
it then.
> Thanks!
> Greg Young
> 1986 PT40
> Escondido, CA
> (760) 807-1727
08-14-2008, 13:16
I bled the air out using boththe petcock upbeside the thermostat and the one down on the radiator tank. The radiator on mine has two petcocks. One on the top side of the tank and one under which acts as the low drain point. I bled air out using the radiator tank top side petcock.
2008/8/14 Gregory OConnor <"Gregoryoc@aol.com">
GregO'Connor
--- In "WanderlodgeForum%40yahoogroups.com", "Scott Forman"
> Greg,
area.
not
> Scott
problem.
air
neutral
suck
change
> direction?
a
I
no
> breather hose.
> > Thanks!
> > Greg Young
> > 1986 PT40
> > Escondido, CA
> > (760) 807-1727
> > From: Greg Young
so
it,
> assessment.
> > Greg Young
> > 1986 PT40
> > Escondido CA
> > Greg,
it
> horizontal
heat
> > Scott Forman
> > 86 PT38
> > Memphis
turn -
> think
> > > -Greg
> > > 86 PT40
> > > From: Bryan Altier
> fan
> > on the
problem
> > > solved.
> > > Bryan Altier
> > > 88WLWB 40
> > > Greenville, SC
> > > From: Greg Young
> > > Hi -
is
> > the next step.
> > > Details:
> > > 86 PT-40
> > > Kohler 12.5CCO67-RV
> > > Yanmar 4-cyl engine
degrees
air
all
> > the time.
off.
> In
see
> Stopped
> > it then.
heat.
> > > Thanks!
> > > Greg Young
> > > 1986 PT40
> > > Escondido, CA
> > > (760) 807-1727
Rob, Sue & Merlin Robinson
94 WLWB
08-14-2008, 14:21
If you look closely, there is an arrow on the squirrel cage housing showing direction. At least there is on mine. The motor on mine is 208v. I have a typical wiring diagram from the box to the fan motor if anyone needs it.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
Date: Thursday, August 14, 2008, 9:05 PM
Greg,
Bryan Altier
88 WLWB 40
Greenville, SC
Thanks!
Greg Young
1986 PT40
Escondido, CA
(760) 807-1727
Greg Young
1986 PT40
Escondido CA
Greg,
Scott Forman
86 PT38
Memphis
> -Greg
> 86 PT40
> From: Bryan Altier
on the
> solved.
> Bryan Altier
> 88WLWB 40
> Greenville, SC
> From: Greg Young
> Hi -
the next step.
> Details:
> 86 PT-40
> Kohler 12.5CCO67-RV
> Yanmar 4-cyl engine
the time.
it then.
> Thanks!
> Greg Young
> 1986 PT40
> Escondido, CA
> (760) 807-1727
08-14-2008, 14:27
Scott,
I had just replaced my fan motor, and left
the wires on motor as purchased, and it sucked air in. It would run in 100
degree weather for 30 minutes or so before it would overheat. On the end of
the motor were 4 wires, 2 sets of 2 wires tied together. On the side of the
motor it said to change directions, switch which wires are connected to each
other.
Switched the wire and made the fan blow
out of compartment, and instantly water temperature went down and will run all
day in 100 degree weather.
Paul
Potter
1987 PT38
Hesperia CA
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman
5:40 PM
Greg,
Scott
Greg Young
direction?
breather hose.
> Thanks!
> Greg Young
> 1986 PT40
> Escondido, CA
> (760) 807-1727
> From: Greg Young
assessment.
> Greg Young
> 1986 PT40
> Escondido CA
> From: Scott Forman <scottforman75@<wbr>...>
> Greg,
horizontal
> Scott Forman
> 86 PT38
> Memphis
> > Hi Bryan
think
> > -Greg
> > 86 PT40
> > From: Bryan Altier
fan
> on the
> > solved.
> > Bryan
Altier
> > 88WLWB 40
> > Greenville, SC
> > From: Greg Young
> > Hi -
> the next step.
> > Details:
> > 86 PT-40
> > Kohler 12.5CCO67-RV
> > Yanmar 4-cyl engine
> the time.
In
Stopped
> it then.
> > Thanks!
> > Greg Young
> > 1986 PT40
> > Escondido, CA
> > (760) 807-1727
08-14-2008, 14:39
This is not a squirrel cage. The pre-87 units are old-fashioned fan
units.
Scott
if anyone needs it.
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: Bryan Altier
> Greg,
back into
fan
the bottom
> Bryan Altier
> 88 WLWB 40
> Greenville, SC
> From:
> Greg Young
> PM
so the
out.
normally -
and the
showed oil level
the oil filler
spilling out
> the breather hose.
> Thanks!
> Greg
> Young
> 1986 PT40
> Escondido, CA
> (760) 807-1727
> From: Greg Young
> To:
> 7:17:51 PM
> overheating
so I
it, I'll
> assessment.
> Greg Young
> 1986 PT40
> Escondido CA
> From: Scott Forman
> <scottforman75@ gmail.com>
> To:
> 5:54:06 PM
> overheating
> Greg,
> fan, it
horizontal
> I ran my
> and it never
> went above 180.
> Scott Forman
> 86 PT38
> Memphis
think
> > -Greg
> > 86 PT40
> > From: Bryan
> Altier
> yahoogroups. com
> > just at
> on the
> solved.
> > Bryan Altier
> > 88WLWB 40
> > Greenville,
> SC
> > From: Greg Young
> > To:
> Wanderlodge Forum
> > Hi
> the next step.
> > Details:
> > 86 PT-40
> > Kohler
> 12.5CCO67-RV
> > Yanmar 4-cyl engine
> the time.
> > Temp slowly
> the past it
> any point in doing
> that again.
> Stopped
> it then.
> > Thanks!
> > Greg Young
> > 1986 PT40
> > Escondido,
> CA
> > (760)
> 807-1727
08-14-2008, 14:42
Is yours squirrel's cage over horizontal rad or traditional fan over
vertical rad? I thought the 87's switched to the squirrel's cage.
A squirrel's cage fan doesn't work worth a damn trying to suck in.
Scott
--- In WanderlodgeForum@yahoogroups.com, "P & D" wrote:
> Scott,
> I had just replaced my fan motor, and left the wires on motor as
purchased,
> and it sucked air in. It would run in 100 degree weather for 30
minutes or
> so before it would overheat. On the end of the motor were 4 wires,
2 sets
> of 2 wires tied together. On the side of the motor it said to
change
> directions, switch which wires are connected to each other.
> Switched the wire and made the fan blow out of compartment, and
instantly
> water temperature went down and will run all day in 100 degree
weather.
> Paul Potter
> 1987 PT38
> Hesperia CA
> _____
> Sent: Thursday, August 14, 2008 5:40 PM
> Greg,
> Scott
> direction?
a
I
> breather hose.
> > Thanks!
> > Greg Young
> > 1986 PT40
> > Escondido, CA
> > (760) 807-1727
> > From: Greg Young
> yahoogroups.com
it,
> assessment.
> > Greg Young
> > 1986 PT40
> > Escondido CA
> yahoogroups.com
> > Greg,
it
> horizontal
heat
> > Scott Forman
> > 86 PT38
> > Memphis
turn -
> think
> > > -Greg
> > > 86 PT40
> > > From: Bryan Altier
> fan
> > on the
> > > solved.
> > > Bryan Altier
> > > 88WLWB 40
> > > Greenville, SC
> > > From: Greg Young
> > > Hi -
is
> > the next step.
> > > Details:
> > > 86 PT-40
> > > Kohler 12.5CCO67-RV
> > > Yanmar 4-cyl engine
air
all
> > the time.
> In
see
> Stopped
> > it then.
> > > Thanks!
> > > Greg Young
> > > 1986 PT40
> > > Escondido, CA
> > > (760) 807-1727
08-14-2008, 15:03
Date: Thursday, August 14, 2008, 10:39 PM
units.
Scott
--- In "WanderlodgeForum%40yahoogroups.com", Leroy Eckert
if anyone needs it.
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: Bryan Altier
> Greg,
back into
fan
the bottom
> Bryan Altier
> 88 WLWB 40
> Greenville, SC
> From:
> Greg Young
> PM
so the
out.
normally -
and the
showed oil level
the oil filler
spilling out
> the breather hose.
> Thanks!
> Greg
> Young
> 1986 PT40
> Escondido, CA
> (760) 807-1727
> From: Greg Young
> To:
> 7:17:51 PM
> overheating
so I
it, I'll
> assessment.
> Greg Young
> 1986 PT40
> Escondido CA
> From: Scott Forman
> To:
> 5:54:06 PM
> overheating
> Greg,
> fan, it
horizontal
> I ran my
> and it never
> went above 180.
> Scott Forman
> 86 PT38
> Memphis
think
> > -Greg
> > 86 PT40
> > From: Bryan
> Altier
> yahoogroups. com
> > just at
> on the
> solved.
> > Bryan Altier
> > 88WLWB 40
> > Greenville,
> SC
> > From: Greg Young
> > To:
> Wanderlodge Forum
> > Hi
> the next step.
> > Details:
> > 86 PT-40
> > Kohler
> 12.5CCO67-RV
> > Yanmar 4-cyl engine
> the time.
> > Temp slowly
> the past it
> any point in doing
> that again.
> Stopped
> it then.
> > Thanks!
> > Greg Young
> > 1986 PT40
> > Escondido,
> CA
> > (760)
> 807-1727
