COACH BATTERIES
08-11-2008, 06:11
Post: #31
COACH BATTERIES
Very interesting Thread. Being an Electro-Mechanical Technician for
Motorola for 25 years has taught me several things, as well as owning
bus conversions for over 20 years.
1) The definition of a Technician - an Engineer's only link to
reality.
2) KISS - Keep It Simple Stupid.
3) The nice things about "standards" is there are so many to choose
from. :-)
I'm no battery expert but do know a thing or two about keeping
equipment running for long periods of time. Some designs have built
in weaknesses (series circuits), and some have built in redundancy
(parallel circuits). So 12v parallel systems are superior if you
view them from a "survival" stance. Sure you can throw more money
and more batteries into a 6v battery system, but then there's my
point.
Some batteries do have memory, some don't. Some can be damaged just
by charging with your engine's alternator, some don't. The more
expensive and high tech the battery, the more expensive and high tech
the maintenance and charging system. Thin plates on starting
batteries, thick on deep cycle, etc I do say stick to one or the
other; hybrids do both fair but is not specialized as the starting
and deep cycle.
I'm not a fan of putting thousands of dollars in battery banks, huge
inverters, and special chargers just to avoid running a generator to
use my AC's down the road. That's what generators were designed to
do. What our Engineer friend was trying to say is that ANY
connection is not as good as a straight wire. And if the straight
wire is not the correct gauge even it can be an issue.
Running 20 amps on an inverter is at least 200+ amps on the DC side.
I'm not going into details about efficiencies, etc.. but it is
probably more like 220+ amps. At those currents even a small bit of
corrosion, dirt, wrong wire size, or any other contaminant that might
cause resistance is devastating. Do you realize it would only take a
resistance of .005 ohms to loose an entire volt! It's very easy to
have that kind of resistance and not be able to find it, especially
with the added connections of a 6v system.
Running multiple batteries in a series/parallel config is superior to
running the 12v counter parts in parallel... IF..IF.. you only look
at performance! If you do believe it is the BEST choice then you too
are living in an ideal Engineers' world! There are Mean Time Between
Failure (MTBF) numbers that needs to be looked at. Even if the 6v
golf battery is superior to a cheap 12v deep cycle it does make
itself vulnerable simply by design. A bad 6v battery will bring you
down. A bad 12v battery simply needs to be removed and you can go on.
If you compare EVERY THING, the cost, size, weight, and design
limitations it doesn't make 6v batteries very appealing in my book
for the small spaces available on the older coaches. Plus, unless
you have special needs (long dry camping or running an AC) then your
bank will only be a few batteries.
Using cheap Walmart MAXX-29 batteries for $76 a piece allows you to
have 3 batteries in parallel for a rating of 375 ah. The cost is
low, the space and weight are low. The area the battery consumes is
636 cu in each. The 6v equivalent (2 batteries) has an area at
closer to 4003 cu in, over 6 times more area and how much more
weight? How much more cost? I know you can try to justify cost over
time, but with the prorating on batteries these days, we're just
renting them anyway so that has little meaning now.
Bottom line is for most people who will not take the time to do the
proper maintenance, invest big dollars in expensive
monitoring/charging systems, or have special needs, then 12v parallel
systems ARE superior to their 6v counter parts.
Hope I didn't put too much fuel on the fire?
Michael & Tami
63FC35 - "Freedom Bus"
78FC35 - "Putz'n Around"
82FC35 - parts
82 GMC RTS
Mesa, Az
--- In WanderlodgeForum@yahoogroups.com, Ron Thompson
> I can't help but comment on this one.
> Old and new batteries mixed would most likely have eddy currents
flowing between the batteries due to deterioration of th internal
currents and would definitely have reducing effect on the AH and
therefore the cranking amps too.
> There are good points on both sides of this discussion. No need to
beat each other up.
> Oh by the way my qualifications are over 30 years experience
electronics with an engineering background. Not a graduate engineer
but definitely schooled in several good engineering schools. In
summary I was a practical applications electronic tech.
> Just my two cents.
> Ron Thompson
> 1995 WLWB 42'
> hippieforever3 wrote: > I
am not an engineer ( nor did I play one on TV) but what you are
> > suggesting goes against avery article I have ever read. Some
were
> > written by battery mfr. engineers.
> Show me one.
> > You are never supposed to mix old
> > and new battreies in a battery bank!
> Why??? Please use science, physics or electronics or references.
> > 6 volt golf cart batteries will
> > give you longer life than any common wet cell deep cycle 12
volt.
> They
> > are sturdy and made to handle frequent discharge.
> It is very likely that the manufacturers design almost all 6 volt
> batteries to withstand more abuse like 100% discharge, temperature
> extremes and vibration. However if you get a 12 volt battery from
> same manufacturer, built to the same design spec and use it in the
> same application, the 12 volt system will last longer and
outperform
> the 6 volt with less maintenance.
> Regards,
> GPSGary
> Ron Thompson -Waller, Tx.
> 1995 WLWB 42'Blue Bird
> (cockyfox@...)
08-11-2008, 07:58
Post: #32
COACH BATTERIES
Motorola the last 25 years has taught me several things. (as well as
owning 4 busses)
reality.
2) KISS - Keep is simple stupid.
from. :-)
point, it's basically not as robust.
by charging with your engines alternator, some don't. The more
the maintenance and charging system must be. Thin plates on starting
and deep cycle batteries.
resistance of .005 ohms to loose an entire volt! Much less
resistance if we discuss starting currents! It's very easy to have
that kind of resistance and not be able to find it, especially with
are living in an ideal Engineer's world. There are Mean Time Between
renting them anyway!
systems ARE superior to their 6v counter parts. So if you're looking
for "bang per buck", 12v lead acid is the way to go.. in MY opinion!
Michael & Tami
82FC35 - parts
82 GMC RTS
Mesa, Az
beat each other up.
> Just my two cents.
> Ron Thompson
> 1995 WLWB 42'
were
> Show me one.
volt.
> They
outperform
> Regards,
> GPSGary
> (cockyfox@...)
08-11-2008, 08:40
Post: #33
COACH BATTERIES
Nope, but once again you brought a lot of theory to a situation where practical
often doesn't have to compete with theoretical best.
We have people here at the oldest end with single batteries, where 6-volt is not
an option without engineering significant changes. So 12-volt is the best not
for any of the reasons supplied in terms of redundancy, connections, etc.
We have people here at the newest end who have 8Ds, or perhaps even 12Ds. 6-volt
is not an option there, either, again for none of the theoretical reasons, but
simply for supplier availability.
Then we have all of us in the middle, with 4 or more conventional batteries,
always an even number. That tends to make a lot of the theoretical reasons
against 6-volt moot.
My case is typical. The battery tray was designed for 6 Group 24 batteries, all
in parallel. That is a lot of connections, no matter how you do it - figure at
least a dozen cables. Depending on brand, a Group 24 is 75-80AH and can be had
in anything from deep-cycle to high CCA starting batteries.
Now assume you want more capacity. I do, and it is not for running air
conditioners going down the road. I boondock one 1+ month continuous every year,
plus additional shorter periods. I run a *lot* of electronics. I want to run the
generator as little as possible, with a high charge rate, into those batteries.
In the space I have, I challenge anyone to find an off-the-shelf solution that
will exceed the capacity of 6 6-volt batteries. At 210-220AH each depending on
brand, giving 630-660AH in the same footprint as the above 450-480AH.
Now guess what? This is accomplished with FEWER cables and connections! Don't
believe me? work it out. Three less cables, 6 less connections.
Finally, while our engineer says that a manufacturer can produce the same
deep-cycle characteristics in 12-volts that they (all) do in 6-volts, I just
don't see anything like that actually being manufactured. Perhaps it is true in
a 4D or larger, but there isn't space for plates that thick in any "standard"
size below a 4D.
Don Bradner
90 PT40 "Blue Thunder"
08-11-2008, 08:48
Post: #34
COACH BATTERIES
>weight?
Math error, I think. A standard 6-volt GC is ~823 cu in each. Not sure how/where
you got that 4003 for two.
08-11-2008, 09:29
Post: #35
COACH BATTERIES
Correct Don, I mistakenly used 8D diminsions in my calculations. So
we're looking at 1646 Cu In for two T-105's vs the 636 of the group-
29. And I'd call boony docking for a month a "special need". Mind
you, I'm not knocking the power/performance of the series/parallel 6v
battery system. Just the need for us "common" folk with "typical"
power needs. And being able to use what ever quanity battery bank you
need is also a benefit, 12v systems can be of any quantity. I'm
assuming people are adding up their requirements so they are matching
the need to the bank size.
Regards, Michael
> >weight?
sure how/where you got that 4003 for two.
08-11-2008, 09:50
Post: #36
COACH BATTERIES
After 25 years as an elctro whizbang, u learned KISS and then
proceeded to take five paragraphs to say 12 volt bat's were mo betta.
Reagardless, after my 67 yrs on earth, I/m sticking to my TROJAN T-
105 six volts for my "house," LOL
Regards,
Hank
90SP36 still in hot Vegas
--- In WanderlodgeForum@yahoogroups.com, "Michael" <mike.putz@...>
for
owning
> reality.
> from. :-)
built
> point.
just
tech
> and deep cycle.
huge
to
side.
of
might
a
to
too
Between
you
on.
your
is
over
parallel
> Michael & Tami
> 82FC35 - parts
> 82 GMC RTS
> Mesa, Az
to
> beat each other up.
engineer
> > Just my two cents.
> > Ron Thompson
> > 1995 WLWB 42'
> were
> > Show me one.
> volt.
> > They
volt
temperature
from
> the
> outperform
> > Regards,
> > GPSGary
> > (cockyfox@)
08-11-2008, 10:34
Post: #37
COACH BATTERIES
Now Hank.. I used that many words so you'd know I did NOT say 12v is
better than 6v. I said 12v batteries would be more appealing to
older coaches with less room for batteries. They are easier to deal
with in terms of weight, maintenance, etc.. Unless you have a big
nice tray that slides out to inspect your batteries...
Michael
78FC35
(hotter in Phx) hee hee hee
--- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan"
betta.
> Regards,
> Hank
> --- In WanderlodgeForum@yahoogroups.com, "Michael" <mike.putz@>
> for
> owning
> > reality.
choose
> > from. :-)
> built
redundancy
money
> > point.
> just
> tech
starting
> > and deep cycle.
> huge
> to
to
straight
> side.
> of
> might
take
> a
to
especially
superior
> to
look
> too
> Between
6v
> you
go
> on.
book
unless
> your
to
> is
> over
> parallel
> > Michael & Tami
> > 82FC35 - parts
> > 82 GMC RTS
> > Mesa, Az
currents
need
> to
> > beat each other up.
> engineer
> > > Just my two cents.
> > > Ron Thompson
> > > 1995 WLWB 42'
> > were
> > > Show me one.
references.
> > volt.
> > > They
> volt
> temperature
> from
> > the
> the
> > outperform
> > > Regards,
> > > GPSGary
> > > (cockyfox@)
08-11-2008, 12:01
Post: #38
COACH BATTERIES
Hey Michael!
You are right.........it is Hotter in Phoenix.
What we need is new battery technology to help with this energy
crisis.
In the meantime, when those four 12 volt house batteries in your FC
crap out....just replace them with TWO six volt TROJANS T105's....you
will be very happy! LOL
I bet you like that FC...I really liked my 80FC31!!! They are
bulletproof!
Take care.
Hank
90SP36
is
deal
> Michael
> 78FC35
> betta.
T-
> > Regards,
> > Hank
Technician
> > for
> > owning
> > > reality.
> choose
> > > from. :-)
> > built
> redundancy
you
> money
my
> > > point.
> > just
more
high
> > tech
> starting
> > > and deep cycle.
> > huge
generator
> > to
designed
> to
> straight
> > side.
bit
> > of
> > might
> take
> > a
easy
> to
> especially
> superior
> > to
> look
you
> > too
> > Between
> 6v
bring
> > you
> go
> > on.
> book
> unless
> > your
you
> to
is
consumes
> > is
cost
> > over
just
> the
> > parallel
> > > Michael & Tami
> > > 82FC35 - parts
> > > 82 GMC RTS
> > > Mesa, Az
> currents
internal
> need
> > to
> > > beat each other up.
> > engineer
In
> > > > Just my two cents.
> > > > Ron Thompson
> > > > 1995 WLWB 42'
I
Some
> > > were
> > > > Show me one.
> references.
12
> > > volt.
> > > > They
> > volt
> > temperature
> > from
> > > the
in
> > the
> > > outperform
> > > > Regards,
> > > > GPSGary
> > > > (cockyfox@)
08-11-2008, 12:16
Post: #39
COACH BATTERIES
Hey Hank.. I think comparing the temp in Phx vs Vegas is like
comparing 6v vs 12v, it's just too similar to compare! hee hee hee.
Yes, I do love my 78FC35. I'm very demanding on my vehicles and take
them off road camping a lot. I'm not one to pull into a KOA very
often and almost always pull a trailer. I can tolerate the hill
climbing as long as that MPG stays so high! hee hee hee
Currently the previous owner put 4-12v batteries in my coach so I'll
just compliment the house with one more I think. Having 2 12v in
parallel here in Arizona is pleanty of start power and the 3 in
parallel will work well for my boony docking needs.
I did have the pleasure of driving my friends 90SP36 from Texas to
Phx not long ago when he bought it in Florida. It was very nice, too
nice to take off road. I think you guys should insulate those
batteries on those as they were exposed to a lot of engine heat.
That or relocate them? And I was especially careful not to spill any
oil on the batteries. They were right under the fill tube!
Say, you're on this side of the world. Gonna make it to the
Southwest Bluebirds & Friends ralley in Quartzsite this January? I
just learned of it and have signed up.
Regards,
Michael & Tami
78FC35 "Putz'n Around"
Mesa, Az
> Hey Michael!
> crisis.
T105's....you
> bulletproof!
> Take care.
> Hank
> 90SP36
> is
> deal
big
> > Michael
> > 78FC35
> > betta.
TROJAN
> T-
> > > Regards,
> > > Hank
> Technician
> > > for
as
> > > owning
to
> > > > reality.
> > choose
> > > > from. :-)
keeping
have
> > > built
> > redundancy
> you
> > money
> my
> > > > point.
damaged
> > > just
> more
> high
> > > tech
> the
> > starting
> > > > and deep cycle.
banks,
> > > huge
> generator
> > > to
> designed
> > to
> > straight
DC
> > > side.
is
> bit
> > > of
that
> > > might
> > take
> > > a
> easy
> > to
> > especially
> > superior
> > > to
only
> > look
> you
> > > too
> > > Between
> > 6v
make
> bring
> > > you
can
> > go
> > > on.
design
> > book
> > unless
then
> > > your
> you
> > to
cost
> is
> consumes
> > > is
at
more
> cost
> > > over
> just
do
> > the
> > > parallel
> > > > Michael & Tami
> > > > 82FC35 - parts
> > > > 82 GMC RTS
> > > > Mesa, Az
> > currents
> internal
> and
> > need
> > > to
> > > > beat each other up.
experience
> > > engineer
> In
> > > > > Just my two cents.
> > > > > Ron Thompson
> > > > > 1995 WLWB 42'
> I
are
> Some
> > > > were
> > > > > Show me one.
> > references.
> 12
> > > > volt.
> > > > > They
6
> > > volt
> > > temperature
battery
> > > from
> > > > the
it
> in
> > > the
> > > > outperform
> > > > > Regards,
> > > > > GPSGary
> > > > > (cockyfox@)
