Install a wireless rear-view camera....
08-09-2008, 08:20
Seems to work fine so far. Got it on eBay cheap. Kit contains a 7"
LCD screen, color IR camera w/ transmitter, and wireless receiver. My bus has a piece of smoked plastic that covered the screen of the original CRT that was mounted behind the bulkhead. With the CRT unit removed (it is big and heavy), the new LCD panel lays perfectly against the back of the smoked plastic window. One adhesive strip in each corner and it is mounted, and it looks factory. The wiring is very easy to hook up,and I was able to use the original wiring so that the unit still turns on and off with the stock camera switch on the bulkhead. The wireless receiver is in the compartment above the driver's seat. For the camera, I removed the original camera and wired the new camera to the original power and ground wires. Then I took off the panel with the little window in it that the original camera looks through (comes off from outside). I then removed the plexiglass window and used a Dremel to enlarge the hole just slightly (the panel is made of fiberglass) so that the new camera would fit in the hole. Doing this eliminates the problem of the IR reflecting off the little window at night. After a little experimentation to find the view I liked from the camera, I secured it to the fiberglass panel with some epoxy and sealed up around the edges to make it water-tight. System works great so far. I will admit that I am worried about how long it might last since this is eBay stuff fom China rather than a name brand unit from a store. But, since those go for two and three times what I paid for this set-up, I figure it is worth a shot. I can buy a lot of cheap replacement cameras before I get to the price of a "good" system. I put an eBay camera in my old FC, and it never gave me any trouble. So, anyway, if you are considering upgrading your camera system, think about this option. It beats the hell out of running wire all the way up from the back. Scott Forman 86 PT38 Memphis |
07-17-2009, 01:49
Digging up old messages here. Scott, do you have any specifics on the
model of camera and monitor you installed? Is it still working fine? I'm guessing if it works ok, then you did not have to do anything to boost signal from the camera. Just worried about the 35 foot distance from camera to monitor. Thanks for the help! Dru and Debora Penland Corpus Christi, TX 83fc35rb --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <scottforman75@...> wrote: > > Seems to work fine so far. Got it on eBay cheap. Kit contains a 7" > LCD screen, color IR camera w/ transmitter, and wireless receiver. > > My bus has a piece of smoked plastic that covered the screen of the > original CRT that was mounted behind the bulkhead. With the CRT unit > removed (it is big and heavy), the new LCD panel lays perfectly > against the back of the smoked plastic window. One adhesive strip in > each corner and it is mounted, and it looks factory. > > The wiring is very easy to hook up,and I was able to use the original > wiring so that the unit still turns on and off with the stock camera > switch on the bulkhead. The wireless receiver is in the compartment > above the driver's seat. > > For the camera, I removed the original camera and wired the new > camera to the original power and ground wires. Then I took off the > panel with the little window in it that the original camera looks > through (comes off from outside). I then removed the plexiglass > window and used a Dremel to enlarge the hole just slightly (the panel > is made of fiberglass) so that the new camera would fit in the hole. > Doing this eliminates the problem of the IR reflecting off the little > window at night. After a little experimentation to find the view I > liked from the camera, I secured it to the fiberglass panel with some > epoxy and sealed up around the edges to make it water-tight. > > System works great so far. I will admit that I am worried about how > long it might last since this is eBay stuff fom China rather than a > name brand unit from a store. But, since those go for two and three > times what I paid for this set-up, I figure it is worth a shot. I > can buy a lot of cheap replacement cameras before I get to the price > of a "good" system. I put an eBay camera in my old FC, and it never > gave me any trouble. > > So, anyway, if you are considering upgrading your camera system, > think about this option. It beats the hell out of running wire all > the way up from the back. > > Scott Forman > 86 PT38 > Memphis > |
