Fridge won't stay lit on LP
05-26-2005, 03:54
I've got a refridgeraqtor question today.
I have a dometic RM3807. When I switch to GAS, the burner will ignite and stay lit, nice blue flame, for about a minute, then it will shut off and the fridge will go to "Check" status. It works fine on AC. I replaced the circuit board about 4 years ago with one of the improved Dinosaur boards. Anybody have an idea of what might be causing this? I'm off to check rvmobile.com to see if there is anything over there that might explain the problem, but if anyone has any ideas I'd be happy to take them. Thanks, Rick Brink 87FC35 Rochester, MN |
05-26-2005, 04:30
It sounds like the thermocoupler - the copper bulb located next to
the flame of the pilot light has stopped working. The one on my home water heater crapped out the other day and I had to have a cold shower this morning, the repair guy (me) should be able to fix it this weekend. It should be a pretty easy fix if you can get it off and to an appliance parts store to find a match for it. It also should be easy to test, it should read normally open with a multimeter at room temperature and should close when heated with a flame. Good luck, Tim Hannink Winter Park, FL 1981 FC-33SB --- In WanderlodgeForum@yahoogroups.com, "Rick B" > I've got a refridgeraqtor question today. > I have a dometic RM3807. When I switch to GAS, > the burner will ignite and stay lit, nice blue flame, > for about a minute, then it will shut off and the fridge > will go to "Check" status. It works fine on AC. > > I replaced the circuit board about 4 years ago with > one of the improved Dinosaur boards. > > Anybody have an idea of what might be causing this? > > I'm off to check rvmobile.com to see if there is anything > over there that might explain the problem, but if > anyone has any ideas I'd be happy to take them. > > Thanks, > Rick Brink > 87FC35 > Rochester, MN |
05-26-2005, 04:32
check the thermocoulple near the ignitor it would seem that it is not
sensing the flame changed mine around 40 for parts Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Rick B" > I've got a refridgeraqtor question today. > I have a dometic RM3807. When I switch to GAS, > the burner will ignite and stay lit, nice blue flame, > for about a minute, then it will shut off and the fridge > will go to "Check" status. It works fine on AC. > > I replaced the circuit board about 4 years ago with > one of the improved Dinosaur boards. > > Anybody have an idea of what might be causing this? > > I'm off to check rvmobile.com to see if there is anything > over there that might explain the problem, but if > anyone has any ideas I'd be happy to take them. > > Thanks, > Rick Brink > 87FC35 > Rochester, MN |
05-26-2005, 10:19
I was able to test the thermocouple with a lighter, and putting a
voltmeter on the two leads. I was able to get it to 20 mV. I am not sure if this is enough or not. So far what I've found is some generic info on http://www.rvmobile.com that says the thermocouple will usually put out 25-35 mV, so I'm not sure if the 20mV I am getting is enough. When the thermocouple goes bad, does it just not create a high enough voltage, or would it not generate any voltage? The local RV dealer still thought it could be the board that went bad. Any info is still apreciated. Thanks, Rick Brink 87FC35 (with Dometic RM3807, w. P-711 Dinosaur Board) Rochester, MN (currently in Grand Haven, MI) --- In WanderlodgeForum@yahoogroups.com, "Tim Hannink" > It sounds like the thermocoupler - the copper bulb located next to > the flame of the pilot light has stopped working. The one on my home > water heater crapped out the other day and I had to have a cold > shower this morning, the repair guy (me) should be able to fix it > this weekend. > > It should be a pretty easy fix if you can get it off and to an > appliance parts store to find a match for it. It also should be easy > to test, it should read normally open with a multimeter at room > temperature and should close when heated with a flame. > > Good luck, > > Tim Hannink > Winter Park, FL > 1981 FC-33SB > > > --- In WanderlodgeForum@yahoogroups.com, "Rick B" > > I've got a refridgeraqtor question today. > > I have a dometic RM3807. When I switch to GAS, > > the burner will ignite and stay lit, nice blue flame, > > for about a minute, then it will shut off and the fridge > > will go to "Check" status. It works fine on AC. > > > > I replaced the circuit board about 4 years ago with > > one of the improved Dinosaur boards. > > > > Anybody have an idea of what might be causing this? > > > > I'm off to check rvmobile.com to see if there is anything > > over there that might explain the problem, but if > > anyone has any ideas I'd be happy to take them. > > > > Thanks, > > Rick Brink > > 87FC35 > > Rochester, MN |
05-26-2005, 12:21
Fridge service and trouble-shooting docs on line at:
http://bryantrv.com/docs.html might help you out. Dan 94 BMC 37' --- In WanderlodgeForum@yahoogroups.com, "Rick B" > I've got a refridgeraqtor question today. > I have a dometic RM3807. When I switch to GAS, > the burner will ignite and stay lit, nice blue flame, > for about a minute, then it will shut off and the fridge > will go to "Check" status. It works fine on AC. > > I replaced the circuit board about 4 years ago with > one of the improved Dinosaur boards. > > Anybody have an idea of what might be causing this? > > I'm off to check rvmobile.com to see if there is anything > over there that might explain the problem, but if > anyone has any ideas I'd be happy to take them. > > Thanks, > Rick Brink > 87FC35 > Rochester, MN |
05-26-2005, 14:07
Rick seems like what you need is some good troubleshooting information.
Here is the best that I have found on Dometic products. http://tinyurl.com/78cl8 This is at http://www.gasrefrigeration.net but the tiny URL will get you straight to the info you need. good luck Tom 1982 FC35 Vernon Center,NY At 10:19 PM 5/26/2005 +0000, you wrote: >I was able to test the thermocouple with a lighter, and putting a >voltmeter on the two leads. I was able to get it to 20 mV. >I am not sure if this is enough or not. So far what I've found >is some generic info on http://www.rvmobile.com that says the thermocouple >will usually put out 25-35 mV, so I'm not sure if the 20mV I am >getting is enough. When the thermocouple goes bad, does >it just not create a high enough voltage, or would it not generate any >voltage? > >The local RV dealer still thought it could be the board that went bad. >Any info is still apreciated. > >Thanks, >Rick Brink >87FC35 (with Dometic RM3807, w. P-711 Dinosaur Board) >Rochester, MN (currently in Grand Haven, MI) > >--- In WanderlodgeForum@yahoogroups.com, "Tim Hannink" > > > It sounds like the thermocoupler - the copper bulb located next to > > the flame of the pilot light has stopped working. The one on my home > > water heater crapped out the other day and I had to have a cold > > shower this morning, the repair guy (me) should be able to fix it > > this weekend. > > > > It should be a pretty easy fix if you can get it off and to an > > appliance parts store to find a match for it. It also should be easy > > to test, it should read normally open with a multimeter at room > > temperature and should close when heated with a flame. > > > > Good luck, > > > > Tim Hannink > > Winter Park, FL > > 1981 FC-33SB > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Rick B" > > > I've got a refridgeraqtor question today. > > > I have a dometic RM3807. When I switch to GAS, > > > the burner will ignite and stay lit, nice blue flame, > > > for about a minute, then it will shut off and the fridge > > > will go to "Check" status. It works fine on AC. > > > > > > I replaced the circuit board about 4 years ago with > > > one of the improved Dinosaur boards. > > > > > > Anybody have an idea of what might be causing this? > > > > > > I'm off to check rvmobile.com to see if there is anything > > > over there that might explain the problem, but if > > > anyone has any ideas I'd be happy to take them. > > > > > > Thanks, > > > Rick Brink > > > 87FC35 > > > Rochester, MN > > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. |
05-26-2005, 20:14
Also gasrefrigeration.net. You can download most manuals in PDF format.
Bill & Rita in Roanoke, VA 1987 FC-35 [Non-text portions of this message have been removed] |
05-26-2005, 20:25
Bill, thanks for that site, I have included it in the parts section of the
Database. Ernie- 83PT40 in Texas [Non-text portions of this message have been removed] |
