Speakking of Steering Boxes . . .
08-24-2008, 07:31
Last week I changed the power steering hydraulic oil from "whatever was
in there" to Redline synthetic power steering fluid. The steering had
always balked and squawked in tight low-speed situations like parking.
Well the second that synthetic fluid hit the system I could spin the
wheel stop-to-stop (on gravel) with little or no resistance. Looks
like synthetic is a winner!
I also installed an oil cooler in the steering system. Hopefully the
valve action will improve out on the road and hydraulic noise will be
reduced.
Many thanks to David KerryEdwards and others who have shared their
experiences and suggested the synthetic oil and cooler.
Bob Griesel '84 FC31 WLII - Ross HFB64 box.
08-24-2008, 12:18
Thanks for that post Bob,
I thought that I had all my fluids changed out on my last trip to the
shop. I overlooked the hydraulic steering fluid, like you say who
knows how long that fluid has been in there, I have no records of
that.
I have been working on the coach steering since day one and while
it's greatly improved, it could be better.
A few questions need to be answered.
On a `95 PT-42 is the hydraulic fluid in the steering box a stand
alone system, or is it tied into other systems? Does it have a
cooler, I've never seen anything that looked like a cooler, but two
weeks ago while under the coach I noticed a squirrel cage fan and
motor in the top rear of the generator doghouse, never noticed it
before. If not, does it need one? Are there any internal adjustments
in the steering box ?
Any other inf. would be helpful.
Kurt Horvath
95-PT-42 WLWB
10AC
--- In WanderlodgeForum@yahoogroups.com, "freewill2008"
was
had
parking.
be
> reduced.
08-24-2008, 13:49
on the 94pt steering pump is the fan pump and the fluids are kept in
the fan fluid reservoir. oil cooler is large radiator infront of
engine radiator
GregoryO'Connor
94ptRomolandCa--- In WanderlodgeForum@yahoogroups.com, "Kurt
> that.
two
adjustments
> Kurt Horvath
> 95-PT-42 WLWB
> 10AC
from "whatever
> was
steering
> had
> parking.
> the
Looks
Hopefully
> the
will
> be
> > reduced.
their
08-24-2008, 14:49
In addition to what Greg mentioned, as I recall from memory (now
there's a risk after several glasses of box wine - Hi Ernie!) that
steering reservoir on the PT takes engine oil rather than power
steering fluid. So synthetic engine oil rather than synthetic power
steering fluid in a PT system.
1991 WB40 "Texas Minivan"
> engine radiator
> GregoryO'Connor
> the
> > that.
> two
> adjustments
> > Kurt Horvath
> > 95-PT-42 WLWB
> > 10AC
> from "whatever
> > was
> steering
> > had
> > parking.
> > the
> Looks
> Hopefully
> > the
> will
> > be
> > > reduced.
> their
08-24-2008, 15:08
Gregg,
So if I understand correctly the power steering is hooked up to the
fan hydraulic system. So this is all one system?
The 42 `s radiators are stacked in order: Dash A/C condenser,
Intercooler, Engine Radiator.
On the PT-42 there is another smaller radiator between the main
radiator and the rear wheels on the roadside, These are the
hydraulic fan cooling radiators.
I'm not sure where the reservoir is located.. Is there a reservoir?
Would the Radiator itself be the reservoir? I have no clue at this
point.
Kurt Horvath
95 Pt-42 WLWB
|10AC
in
> engine radiator
> GregoryO'Connor
> the
> > that.
> two
> adjustments
> > Kurt Horvath
> > 95-PT-42 WLWB
> > 10AC
> from "whatever
> > was
> steering
> > had
> > parking.
spin
> > the
> Looks
> Hopefully
> > the
> will
> > be
> > > reduced.
> their
08-24-2008, 16:41
Kurt your 95 has the S60. my 94pt40 has the 8V92 and no intercooler
it has a blower and turbo. the ps/fan resevoir is a big tank near
the fan motor. not sure how your bus is set up??
Greg
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
> Gregg,
reservoir?
> point.
> Kurt Horvath
> 95 Pt-42 WLWB
> |10AC
kept
> in
of
> > engine radiator
> > GregoryO'Connor
to
> > the
who
of
> > > that.
while
stand
but
> > two
it
> > adjustments
> > > Kurt Horvath
> > > 95-PT-42 WLWB
> > > 10AC
> > from "whatever
> > > was
> > steering
> > > had
like
> > > parking.
> spin
> > > the
resistance.
> > Looks
> > Hopefully
> > > the
noise
> > will
> > > be
> > > > reduced.
> > their
08-25-2008, 01:28
Well I feel stupid. The big blue tank in my engine compartment is the
reservoir, I knew that, DUH! I was told this morning that it also has
3 filters in it and they need to be changed every few years. It takes
HD32 oil, As far adjusting the steering box on a 42 there is no real
adjustment available, my BB Guru did suggest a Safety-Plus for the
front end, mostly as a precaution for steer tire blow outs. I'm told
it will keep you on the road in that event, I'll have to check into
that. Does anyone have any thoughts on that idea?
Kurt Horvath
95 PT-42 WLWB
10AC
> Greg
> > Gregg,
> the
> reservoir?
this
> > point.
> > Kurt Horvath
> > 95 Pt-42 WLWB
> > |10AC
> kept
> > in
> of
> > > engine radiator
> > > GregoryO'Connor
trip
> to
> > > the
> who
records
> of
> > > > that.
> while
> stand
a
> but
> > > two
> and
noticed
> it
> > > adjustments
> > > > Kurt Horvath
> > > > 95-PT-42 WLWB
> > > > 10AC
> > > from "whatever
> > > > was
> > > steering
> > > > had
> like
> > > > parking.
> > spin
> > > > the
> resistance.
> > > Looks
> > > Hopefully
> > > > the
> noise
> > > will
> > > > be
> > > > > reduced.
shared
> > > their
08-25-2008, 03:37
Kurt,
Interesting that yours specs a hydraulic fluid. I know my 83 and 91
and Leroy's 90, based on his recent post, spec multi-grade 10-30 motor
oil. I wonder why the difference?
By the way, the Parts Database and the Bluebird Filters & Belts Files
have part numbers for the reservoir filters.
> Kurt Horvath
> 95 PT-42 WLWB
> 10AC
> > Greg
> > wrote:
> > > Gregg,
> > the
> > reservoir?
> this
> > > point.
> > > Kurt Horvath
> > > 95 Pt-42 WLWB
> > > |10AC
> > kept
> > > in
> > of
> > > > engine radiator
> > > > GregoryO'Connor
> trip
> > to
> > > > the
> > who
> records
> > of
> > > > > that.
> > while
> > stand
> a
> > but
> > > > two
> > and
> noticed
> > it
> > > > adjustments
> > > > > Kurt Horvath
> > > > > 95-PT-42 WLWB
> > > > > 10AC
> > > > from "whatever
> > > > > was
> > > > steering
> > > > > had
> > like
> > > > > parking.
> > > spin
> > > > > the
> > resistance.
> > > > Looks
> > > > Hopefully
> > > > > the
> > noise
> > > > will
> > > > > be
> > > > > > reduced.
> shared
> > > > their
08-25-2008, 03:57
For the Ross box in our FC, the book shows a list of approved oils
including one type of 'power steering fluid', a couple of ATF types,
and 2 or 3 motor oils.
While researching available synthetic oils, I found that hydraulic
oil parameters include base viscosity (like 30W), multi-viscosity
additives, and detergent additives (or not).
Because several types of oil are listed for the Ross, my conclusion
is that the recommended oils all have similar specifications for
viscosity and additives.
Bob Griesel '84 FC31 WLII WA
(Who really does know that 'speaking' has ONE 'K' Smile
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...>
> Kurt,
motor
Files
> Mike Bulriss
> San Antonio, TX
has
takes
real
told
into
> > Kurt Horvath
> > 95 PT-42 WLWB
> > 10AC
intercooler
near
> > > Greg
> > > wrote:
> > > > Gregg,
to
> > > the
condenser,
main
> > > reservoir?
> > this
> > > > point.
> > > > Kurt Horvath
> > > > 95 Pt-42 WLWB
> > > > |10AC
are
> > > kept
> > > > in
infront
> > > of
> > > > > engine radiator
> > > > > GregoryO'Connor
> > trip
> > > to
> > > > > the
say
> > > who
> > records
> > > of
> > > > > > that.
> > > while
a
> > > stand
have
> > a
cooler,
> > > but
> > > > > two
fan
> > > and
> > noticed
> > > it
> > > > > adjustments
> > > > > > Kurt Horvath
> > > > > > 95-PT-42 WLWB
> > > > > > 10AC
> > > > > from "whatever
> > > > > > was
The
> > > > > steering
> > > > > > had
situations
> > > like
> > > > > > parking.
could
> > > > spin
> > > > > > the
> > > resistance.
> > > > > Looks
> > > > > Hopefully
> > > > > > the
> > > noise
> > > > > will
> > > > > > be
> > > > > > > reduced.
> > shared
> > > > > their
08-25-2008, 04:11
I have a Blue Ox TruCenter on the front end.
http://www.blueox.us/TruCenter/tru_center.html
Supposed to keep you on the road if a blow out occurs. I really don't
care to find out if it works. It is not a substitute for poor ball
joint connections.
My power steering and hydraulic fan spec's 10w-30 motor oil,
specifically, Texaco but cannot see that makes any difference. I know
that is the same on specific earlier and later models I have seen. I
would not know why yours is different.??? However, I would not call
the reservoir a steering box and I do not know the manufacturer of my
steering box. I doubt it would take a different oil but do not know.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@>
> > Kurt,
> motor
> Files
> > Mike Bulriss
> > San Antonio, TX
> the
> has
> takes
> real
> the
> told
> into
> > > Kurt Horvath
> > > 95 PT-42 WLWB
> > > 10AC
> intercooler
> near
> > > > Greg
> > > > wrote:
> > > > > Gregg,
> to
> > > > the
> condenser,
> main
> > > > reservoir?
> > > this
> > > > > point.
> > > > > Kurt Horvath
> > > > > 95 Pt-42 WLWB
> > > > > |10AC
> are
> > > > kept
> > > > > in
> infront
> > > > of
> > > > > > engine radiator
> > > > > > GregoryO'Connor
> > > trip
> > > > to
> > > > > > the
> say
> > > > who
> > > records
> > > > of
> > > > > > > that.
> and
> > > > while
> a
> > > > stand
> have
> > > a
> cooler,
> > > > but
> > > > > > two
> fan
> > > > and
> > > noticed
> > > > it
> > > > > > adjustments
> > > > > > > Kurt Horvath
> > > > > > > 95-PT-42 WLWB
> > > > > > > 10AC
> > > > > > from "whatever
> > > > > > > was
> The
> > > > > > steering
> > > > > > > had
> situations
> > > > like
> > > > > > > parking.
> could
> > > > > spin
> > > > > > > the
> > > > resistance.
> > > > > > Looks
> > > > > > Hopefully
> > > > > > > the
> > > > noise
> > > > > > will
> > > > > > > be
> > > > > > > > reduced.
> > > shared
> > > > > > their
