Suspension dump
08-26-2008, 01:42
Suspension dump
I have a 1982 33 fc and I dumped the suspension last night. This
morning it wont come back up. All of the other air systems seem to be
working correctly. I just purchased this BB and I am not sure if I have
done something wrong or if its broke.
08-26-2008, 05:49
Suspension dump
Try the switch a couple times.
Assuming the switch is 12V...If trying the switch a couple times doesn't work, remove the switch and test for 12V. If no 12V, check for a burned out fuse. Keep us posted.
Per forum rules, please sign your posts with your name, location, coach year and model. Thanks.
Curt Sprenger
Anaheim Hills, CA
08-26-2008, 07:22
Suspension dump
I may have found out the problem. It very well may be operator error. Will know for sure when I get home from work.
Joe Jarles
Prospect KY
'82 33'FC
----- Original Message ----
Sent: Tuesday, August 26, 2008 1:49:46 PM
Subject: Re: [WanderlodgeForum] Suspension dump
Curt Sprenger
Anaheim Hills, CA
08-26-2008, 07:50
Suspension dump
Sometimes you need to run at fast idle to
supply enough air to close the valve.
Dan
88pt38
Jackson, MS
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of joejarles
8:43 AM
Subject: [WanderlodgeForum]
Suspension dump
night. This
