Coolant Filters
08-27-2008, 00:50
Coolant Filters
One mod I would like to add is a filter system for the coolant on my
bus. CurtS brought this up one time but now that I have a grand
invested in cleaning out my rad, I have interest (I wasn't political
untill I paid taxes either). I am kinda surprised that there is not
a OEM filter in the design some place. At the same time my Primus
gone Wabasto need a filter system also. A recent flush of that
independent system , register by register proved much crap inbeded
in the path.
I like the idea of running my bus as hot as the engineeres designed
185 to 195 to get all the hp and fluids working but the 10 degree
margine prior to costly damage keeps me concerned. I proved that the
rad will cool things off even compramised 90%(subjective calc by the
shop that did the rodding) so the cooling system optimization is
where I would like to relieve that concern.
Has anyone added a coolant filter mod?
I found this kit but would like a larger inlet outlet to mount it on
the cockpit heater defroster loop.
https://www.dieselsite.com/index.asp?
PageAction=VIEWPROD&ProdID=796&HS=1
GregoryO'Connor
94ptRomolandCa
08-27-2008, 01:25
Coolant Filters
Greg,
I did install a coolant filter. Easy install. Stop by and take a look.
On Wed, Aug 27, 2008 at 5:50 AM, Gregory OConnor <"Gregoryoc@aol.com"> wrote:
in the path.
GregoryO'Connor
94ptRomolandCa
Curt Sprenger
Anaheim Hills, CA
08-27-2008, 05:50
Coolant Filters
Curt,
You obviously have too much time on your hands!! ;^) (I'm envious)
Want to share part numbers, installation pointers, cost, pictures,
etc. on that coolant filter?
Thanks,
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> Greg,
look.
on my
political
not
> > in the path.
designed
on
> > GregoryO'Connor
> > 94ptRomolandCa
> Curt Sprenger
> Anaheim Hills, CA
08-27-2008, 06:51
Coolant Filters
Mike,
I'll getall the information together and publish it.
Curt
On Wed, Aug 27, 2008 at 10:50 AM, mbulriss <"mbulriss@yahoo.com"> wrote:
Curt,
Thanks,
--- In "WanderlodgeForum%40yahoogroups.com", "Curt Sprenger"
> Greg,
look.
on my
political
not
> > in the path.
designed
on
> > GregoryO'Connor
> > 94ptRomolandCa
> Curt Sprenger
> Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
08-27-2008, 09:20
Coolant Filters
Greg,
Here's one with 3/8 NPT inlet/outlet sizes. You should be able to
find it locally. It's what's used in the heavy truck side of
things. Takes standard filters.
https://dynamic.donaldson.com/webc/WebSt...tail.html?
section=10324&item=1857
Hope this helps. I don't believe there is one designed for full flow
coolant, only partial flow. Prevents filter blockage from
interupting engine cooling.
John
my
political
> in the path.
on
> GregoryO'Connor
> 94ptRomolandCa
08-27-2008, 11:32
Coolant Filters
I took pictures of my coolant filter installation and wrote up a document. I just sent that off to Mike and John for Wanderlodge sites publication.
On Wed, Aug 27, 2008 at 2:20 PM, jcmace59 <"jcmace@cox.net"> wrote:
Greg,
John
--- In "WanderlodgeForum%40yahoogroups.com", "Gregory OConnor"
my
political
> in the path.
on
> GregoryO'Connor
> 94ptRomolandCa
Curt Sprenger
Anaheim Hills, CA
08-27-2008, 12:22
Coolant Filters
Thanks Curt. I'm interested in that mod myself.
2008/8/27 Curt Sprenger <"curtsprenger@gmail.com">
Greg,
John
my
political
> in the path.
on
> GregoryO'Connor
> 94ptRomolandCa
Curt Sprenger
Anaheim Hills, CA
Rob, Sue & Merlin Robinson
94 WLWB
08-27-2008, 12:41
Coolant Filters
DITO!
Thanks Curt.
Kurt Horvath
95 PT-42
10AC
a
sites
> > publication.
> > On Wed, Aug 27, 2008 at 2:20 PM, jcmace59 wrote:
> >> Greg,
flow
> >> John
> >> --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> >> "Gregory OConnor"
on
> >> my
> >> political
is not
Primus
inbeded
> >> > in the path.
designed
degree
that
> >> the
by
> >> the
is
it
> >> on
> >> > GregoryO'Connor
> >> > 94ptRomolandCa
> > Curt Sprenger
> > Anaheim Hills, CA
> 94 WLWB
08-27-2008, 13:04
Coolant Filters
I added the pictures in the Photos section in an albumn
named "Coolant Filter Modifcation". The pics are fairly self
explanatory by themselves. The write up is in the Files under Engine
Coolant Filter Installation with a link directly to the pictures or
follow this link to the pics:
http://autos.ph.groups.yahoo.com/group/W...os/browse/
d530?c=
My pdf maker is not working this evening. When I repair it, I will
add the pics to the write up and make a pdf out of it that is small
enough to load as a single complete document. In the meantime, I
wanted to get the info that Curt was so good to submit posted for
folks to see.
Thanks very much to Curt for this information!!
document. I
publication.
> > Greg,
flow
> > John
> > "Gregory OConnor"
on
> > my
> > political
not
Primus
inbeded
> > > in the path.
designed
degree
> > the
> > the
it
> > on
> > > GregoryO'Connor
> > > 94ptRomolandCa
> Curt Sprenger
> Anaheim Hills, CA
08-27-2008, 13:20
Coolant Filters
Prob with the files and pic section is they are not searchable. Is it ok to add the stuff like this: ?
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Coolant Filter Installation -1987 PT38 – 8V92
Contributed by Curt Sprenger August 27.2008
Coolant Filter Base – WIX 24019
Filters – 1st filter NAPA 4074 (WIX 24074). In a year, and each year, change filter to WIX 24701.
Parts – All Brass, all 3/8" - 4 street elbows, 1 close nipple, 1 1-1/2" nipple, 2 NIBCO T585 ball valves. Cost $68.79. You might find the part for less. I shop at a plumbing store that carries more parts than anyone in our area. They are not the least expensive but time is worth something.
Hose – measure generously – I used just under 6' - get good ½" push-on or equivalent. Cost $10.00.
Hose Clamps – 4 each.
Bolts/Nuts – to mount the filter base.
http://us.a2.yahoofs.com/groups/g_14815518/d530/__sr_/127b.jpg?grIZjtIBeKI.TF0J
http://us.a2.yahoofs.com/groups/g_14815518/d530/__sr_/c9a1.jpg?grIZjtIBzcqAcshq
Instructions -
1 I removed the Ether Injector system and installed the coolant filter base in the same location. Or
pick a different location.
2 Loosely attach all the plumbing to the filter base, see picture, and the spin on the filter (not tight), to
get an accurate mounting position that works. Keep the coolant hose clearance/routing in mind.
3 Drill new mounting holes if needed.
4 Install filter base.
5 Install the brass parts. See photos. Shorten the ball valve handles as needed. Use thread
sealant.
6 Tighten the filter.
7 Remove the old hose at the Expansion Tank, save the coolant. Plug the hose for now.
8 Connect new hose from the expansion tank to the filter base center.
9 Connect new hose to the filter base outer connection. Run the hose to the thermostat housing
street elbow to get the length of hose needed, and cut to length.
10 With a knife, slit the old hose at the street elbow on top of the thermostat housing. Quickly
remove that hose and slid on the new hose. A terry towel on top of the thermostat housing will catch the small amount of coolant loss.
