Goat rails
09-23-2007, 20:05
Goat rails
wonder what he does with the removed goat rails?
Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
09-23-2007, 22:48
Goat rails
This is somewhat off topic but since the mention of no goat rails I
might mention that I met a gentleman (nice fellow) at the 'birds nest last year who stated that he has owned several 'birds in the past. With each 'bird that he buys the first thing he does is to remove the rails on top. Perhaps one of his victim's??? John Stiles 1980 33FC "My Navion" -- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > 80ish (brown one has no goatrail must be a royal conversion) > GregoryO'Connor > 94ptRomolandca > |
09-24-2007, 00:48
Goat rails
Probably makes a ladder. You then get to look at the a/c systems.
Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 24, 2007 7:05 AM Subject: Re: [WanderlodgeForum] Re: Goat rails wonder what he does with the removed goat rails? Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-24-2007, 01:57
Goat rails
Fabricates "goat stanchions" for his "goat milking parlor" ?
Dick Gideon 1989 35FC Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Probably makes a ladder. You then get to look at the a/c systems. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: erniecarpet@... > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, September 24, 2007 7:05 AM > Subject: Re: [WanderlodgeForum] Re: Goat rails > > > wonder what he does with the removed goat rails? > > Ernie Ekberg > 83PT40 > Weatherford, Tx > > ************************************** See what's new at http://www.aol.com > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
09-24-2007, 05:50
Goat rails
He built a corral for his goats.
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Sep 24, 2007, at 5:05 AM, erniecarpet@... wrote: > wonder what he does with the removed goat rails? > > Ernie Ekberg > 83PT40 > Weatherford, Tx > [Non-text portions of this message have been removed] |
08-28-2008, 09:34
Goat rails
Bob, when I was home this past winter, we have 13 pecan trees around our house. My coach sits under one of those- not only do leaves choke everything, but the pecans made great meals for all the squirrels that ate my wiring to my antenna.
Ernie Ekberg 83PT40 Livingston, Montana |
08-28-2008, 09:42
Goat rails
Hi group,
My rails always seem to catch leaves,etc. because the bottom rail is so close to the roof. It's always a pain to drag the hose up there to clean the roof off. Has anybody cut out the bottom rail between the screws that hold the rails on? My other thought is to just remove the rails altogether. Purist's can holler, but I am more interested in what works to keep the roof clean. Any thoughts? Bob Lawrence 84 PT36 Branson,Mo(Where the leaves are falling) |
08-28-2008, 10:26
Goat rails
I had the same problem with my rails and they where also rusted. I
removed them so I could repaint them and I was suprised how heavy they where.After I had them sand blasted I was going to repair the holes etc. I decided to leave them off.I have also removed the latter and will replace it with a anodized aluminum latter.I think the coach looks better with them off and it also weights less. Lee Condosta 85 PT 40 Holden Beach N.C |
08-28-2008, 11:38
Goat rails
Perhaps I'm a purist, but I can't imagine taking the goat rails off.
It might actually harm the resale value if/when you might decide to sell your coach. Yes, the goat rails are a pain. I live near several 150' tall eucalyptus trees. For those who aren't familiar with them, they drop leaves, acorns, and strips of bark constantly. These are a major pain to clean out of the goat rails and from under the aluminum walks on the roof. About all I could suggest is to perhaps raise the bottom rail a bit to make it easier to push leaf little out from under the rails. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Idaho Springs, CO On Aug 28, 2008, at 3:42 PM, Bob Lawrence wrote: > Hi group, > > My rails always seem to catch leaves,etc. because the bottom rail > is so > close to the roof. > It's always a pain to drag the hose up there to clean the roof off. > Has anybody cut out the bottom rail between the screws that hold the > rails on? > My other thought is to just remove the rails altogether. > Purist's can holler, but I am more interested in what works to keep > the > roof clean. > Any thoughts? > > Bob Lawrence > 84 PT36 > Branson,Mo(Where the leaves are falling) > > > > ------------------------------------ > > Yahoo! Groups Links > > > |
08-28-2008, 15:29
Goat rails
The "Goat Rails" say "Wanderlodge", as does the A/C "Hat" on the FC
models. They certianly make the Coach stand out from the crowd. In a way, it is similar to my Jeep. To date, after I have parked the CJ, no one has ever came over and asked, "Is That a Jeep"? Some desirable items are meant to be unique.. Jack Smith 1973FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Bob, when I was home this past winter, we have 13 pecan trees around our > house. My coach sits under one of those- not only do leaves choke everything, > but the pecans made great meals for all the squirrels that ate my wiring to my > antenna. > > Ernie Ekberg > 83PT40 > Livingston, Montana > > > > > **************It's only a deal if it's where you want to go. Find your travel > deal here. > (http://information.travel.aol.com/deals?...0000000047) > |
