Power Tech 15KW Motor & Blower
08-28-2008, 16:05
Has any one replaced their Power Tech 15KW Motor & Blower Assembly and
what Part Numbers and source were your findings. Cost $$..etc...... Would it be suggested to replace the whole assembly with motor or just the motor only. I think I have the motor with a winding to ground and need at least a motor replacement. Is Grainger the place to go? Pro & Cons of complete new assembly vs. just motor replacement from any ones experience in the generator problem department..... Regards Gregg 96 WLSD 42' New Castle, IN |
08-29-2008, 09:02
My squirrel cage fan failed last year. I removed the whole assembly
and took it to an electric motor shop where I asked them to fix or replace the motor and rebalance the fan (look closely and you'll see little bits of metal bent around some of the blades in the squirrel cage). They found a replacement motor (as the OEM unit was long out of existence), installed it, checked the balance of the fan, and painted everything. I reinstalled the assembly in my coach. I don't recall exactly what I paid (I'm on the road) but it was about $500 or so... about double what Tom McCarthy paid in So. CA. (Typical SF Bay Area prices, though...) Since you're in the middle of the country, you'll probably find a more reasonable-priced vendor. Note: keep in mind that the motor is a 220 vac motor.... Also be sure to check the capacitors, if they should fail, it might seem like the motor is dead, when it is not. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Idaho Springs, CO On Aug 28, 2008, at 10:05 PM, Gregg Kizer wrote: > Has any one replaced their Power Tech 15KW Motor & Blower Assembly and > what Part Numbers and source were your findings. Cost $$..etc...... > > Would it be suggested to replace the whole assembly with motor or just > the motor only. I think I have the motor with a winding to ground and > need at least a motor replacement. Is Grainger the place to go? Pro & > Cons of complete new assembly vs. just motor replacement from any ones > experience in the generator problem department..... > > Regards > > Gregg > 96 WLSD 42' > New Castle, IN > <snip> |
08-29-2008, 11:28
08-29-2008, 12:40
Hishan,
We should post this info in the files section for future refrence. Kurt Horvath 95 PT-42 10AC --- In WanderlodgeForum@yahoogroups.com, Hisham Amaral > > Gregg > > I bought my 97 43' from Florida Last year. I found a bill the previous owner paid for the Blower motor and the capacitor from Grainger. > Â > The motor part number is 3M957 1/3 HP 230 VÂ $83.90 > The Capacitor part number (5MFD 370 VAC)Â is 5M003Â $3.70 > Â > Best of luck, Sorry this toke long to get you the information. > Â > Hisham Amaral > 97 WLWB 43' > W. Bloomfield, MI. > Â > --- On Fri, 8/29/08, Pete Masterson > > From: Pete Masterson > Subject: Re: [WanderlodgeForum] Power Tech 15KW Motor & Blower > To: WanderlodgeForum@yahoogroups.com > Date: Friday, August 29, 2008, 5:02 PM > > > > > > > My squirrel cage fan failed last year. I removed the whole assembly > and took it to an electric motor shop where I asked them to fix or > replace the motor and rebalance the fan (look closely and you'll see > little bits of metal bent around some of the blades in the squirrel > cage). They found a replacement motor (as the OEM unit was long out > of existence), installed it, checked the balance of the fan, and > painted everything. I reinstalled the assembly in my coach. I don't > recall exactly what I paid (I'm on the road) but it was about $500 or > so... about double what Tom McCarthy paid in So. CA. (Typical SF Bay > Area prices, though...) > > Since you're in the middle of the country, you'll probably find a > more reasonable-priced vendor. > > Note: keep in mind that the motor is a 220 vac motor.... Also be sure > to check the capacitors, if they should fail, it might seem like the > motor is dead, when it is not. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@mac. com > On the road at Idaho Springs, CO > > On Aug 28, 2008, at 10:05 PM, Gregg Kizer wrote: > > > Has any one replaced their Power Tech 15KW Motor & Blower Assembly and > > what Part Numbers and source were your findings. Cost $$..etc..... . > > > > Would it be suggested to replace the whole assembly with motor or just > > the motor only. I think I have the motor with a winding to ground and > > need at least a motor replacement. Is Grainger the place to go? Pro & > > Cons of complete new assembly vs. just motor replacement from any ones > > experience in the generator problem department.. ... > > > > Regards > > > > Gregg > > 96 WLSD 42' > > New Castle, IN > > <snip> > |
08-29-2008, 12:54
08-29-2008, 13:57
08-29-2008, 14:31
Hisham,
It's easy just click on files on the left side of this page. When the window opens on the right side down a few inches you'll see add file, click on it. That will open to File name. hit the browse button then choose what file you want to upload, for example you could place the info in a word file. You can add a description, and notify the group if you wish. The number from Graingers, "3M957 1/3 HP 230 V" has been discontinued. It has some cross refrenced motors, so I would make a note of that. Kurt Horvath 95 PT-42 10AC --- In WanderlodgeForum@yahoogroups.com, Hisham Amaral > > Kurt > Â > How do put this info into a files section? > Hisham > > --- On Fri, 8/29/08, Kurt Horvath > > From: Kurt Horvath > Subject: [WanderlodgeForum] Re: Power Tech 15KW Motor & Blower > To: WanderlodgeForum@yahoogroups.com > Date: Friday, August 29, 2008, 8:40 PM > > > > > > > Hishan, > > We should post this info in the files section for future refrence. > > Kurt Horvath > 95 PT-42 10AC > > --- In WanderlodgeForum@ yahoogroups. com, Hisham Amaral > > > > > Gregg > > > > I bought my 97 43' from Florida Last year. I found a bill the > previous owner paid for the Blower motor and the capacitor from > Grainger. > > Â > > The motor part number is 3M957 1/3 HP 230 VÂ $83.90 > > The Capacitor part number (5MFD 370 VAC)Â is 5M003Â $3.70 > > Â > > Best of luck, Sorry this toke long to get you the information. > > Â > > Hisham Amaral > > 97 WLWB 43' > > W. Bloomfield, MI. > > Â > > --- On Fri, 8/29/08, Pete Masterson > > > > From: Pete Masterson > > Subject: Re: [WanderlodgeForum] Power Tech 15KW Motor & Blower > > To: WanderlodgeForum@ yahoogroups. com > > Date: Friday, August 29, 2008, 5:02 PM > > > > > > > > > > > > > > My squirrel cage fan failed last year. I removed the whole assembly > > and took it to an electric motor shop where I asked them to fix or > > replace the motor and rebalance the fan (look closely and you'll > see > > little bits of metal bent around some of the blades in the squirrel > > cage). They found a replacement motor (as the OEM unit was long out > > of existence), installed it, checked the balance of the fan, and > > painted everything. I reinstalled the assembly in my coach. I don't > > recall exactly what I paid (I'm on the road) but it was about $500 > or > > so... about double what Tom McCarthy paid in So. CA. (Typical SF > Bay > > Area prices, though...) > > > > Since you're in the middle of the country, you'll probably find a > > more reasonable-priced vendor. > > > > Note: keep in mind that the motor is a 220 vac motor.... Also be > sure > > to check the capacitors, if they should fail, it might seem like > the > > motor is dead, when it is not. > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > aeonix1@mac. com > > On the road at Idaho Springs, CO > > > > On Aug 28, 2008, at 10:05 PM, Gregg Kizer wrote: > > > > > Has any one replaced their Power Tech 15KW Motor & Blower > Assembly and > > > what Part Numbers and source were your findings. Cost > $$..etc..... . > > > > > > Would it be suggested to replace the whole assembly with motor or > just > > > the motor only. I think I have the motor with a winding to ground > and > > > need at least a motor replacement. Is Grainger the place to go? > Pro & > > > Cons of complete new assembly vs. just motor replacement from any > ones > > > experience in the generator problem department.. ... > > > > > > Regards > > > > > > Gregg > > > 96 WLSD 42' > > > New Castle, IN > > > <snip> > > > |
08-29-2008, 15:30
And/Or post it in the Parts Database please.
Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > Hishan, > > We should post this info in the files section for future refrence. > > Kurt Horvath > 95 PT-42 10AC > > > --- In WanderlodgeForum@yahoogroups.com, Hisham Amaral > > > > > Gregg > > > > I bought my 97 43' from Florida Last year. I found a bill the > previous owner paid for the Blower motor and the capacitor from > Grainger. > > Â > > The motor part number is 3M957 1/3 HP 230 VÂ $83.90 > > The Capacitor part number (5MFD 370 VAC)Â is 5M003Â $3.70 > > Â > > Best of luck, Sorry this toke long to get you the information. > > Â > > Hisham Amaral > > 97 WLWB 43' > > W. Bloomfield, MI. > > Â > > --- On Fri, 8/29/08, Pete Masterson > > > > From: Pete Masterson > > Subject: Re: [WanderlodgeForum] Power Tech 15KW Motor & Blower > > To: WanderlodgeForum@yahoogroups.com > > Date: Friday, August 29, 2008, 5:02 PM > > > > > > > > > > > > > > My squirrel cage fan failed last year. I removed the whole assembly > > and took it to an electric motor shop where I asked them to fix or > > replace the motor and rebalance the fan (look closely and you'll > see > > little bits of metal bent around some of the blades in the squirrel > > cage). They found a replacement motor (as the OEM unit was long out > > of existence), installed it, checked the balance of the fan, and > > painted everything. I reinstalled the assembly in my coach. I don't > > recall exactly what I paid (I'm on the road) but it was about $500 > or > > so... about double what Tom McCarthy paid in So. CA. (Typical SF > Bay > > Area prices, though...) > > > > Since you're in the middle of the country, you'll probably find a > > more reasonable-priced vendor. > > > > Note: keep in mind that the motor is a 220 vac motor.... Also be > sure > > to check the capacitors, if they should fail, it might seem like > the > > motor is dead, when it is not. > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > aeonix1@mac. com > > On the road at Idaho Springs, CO > > > > On Aug 28, 2008, at 10:05 PM, Gregg Kizer wrote: > > > > > Has any one replaced their Power Tech 15KW Motor & Blower > Assembly and > > > what Part Numbers and source were your findings. Cost > $$..etc..... . > > > > > > Would it be suggested to replace the whole assembly with motor or > just > > > the motor only. I think I have the motor with a winding to ground > and > > > need at least a motor replacement. Is Grainger the place to go? > Pro & > > > Cons of complete new assembly vs. just motor replacement from any > ones > > > experience in the generator problem department.. ... > > > > > > Regards > > > > > > Gregg > > > 96 WLSD 42' > > > New Castle, IN > > > <snip> > > > |
08-29-2008, 15:33
Hey Leroy,
Whatcha doing in Chatanooga? Nascar is in California this weekend. LOL! Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert wrote: > > I replaced my complete unit, fan motor and housing when I reworked the genset system 3 years ago. That was before I new about a forum or soon after I found it. I purchased the whole thing from BB at about $225 as I recall. Since I have read that Grainger and other places may have the system cheaper. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > On WiFi in Chattanooga, TN > > --- On Fri, 8/29/08, Gregg Kizer > From: Gregg Kizer > Subject: [WanderlodgeForum] Power Tech 15KW Motor & Blower > To: WanderlodgeForum@yahoogroups.com > Date: Friday, August 29, 2008, 12:05 AM > > > > > > > > > > > > Has any one replaced their Power Tech 15KW Motor & Blower Assembly and > > what Part Numbers and source were your findings. Cost $$..etc..... . > > > > Would it be suggested to replace the whole assembly with motor or just > > the motor only. I think I have the motor with a winding to ground and > > need at least a motor replacement. Is Grainger the place to go? Pro & > > Cons of complete new assembly vs. just motor replacement from any ones > > experience in the generator problem department.. ... > > > > Regards > > > > Gregg > > 96 WLSD 42' > > New Castle, IN > |
08-29-2008, 15:47
The "rebalance" of the fan that Pete did sounds like it might be
important to do to keep the motor bearings healthy and reduce vibration??????Unbalanced may have been the cause of the resulting motor failure??? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, Hisham Amaral > > Gregg > > I bought my 97 43' from Florida Last year. I found a bill the previous owner paid for the Blower motor and the capacitor from Grainger. > Â > The motor part number is 3M957 1/3 HP 230 VÂ $83.90 > The Capacitor part number (5MFD 370 VAC)Â is 5M003Â $3.70 > Â > Best of luck, Sorry this toke long to get you the information. > Â > Hisham Amaral > 97 WLWB 43' > W. Bloomfield, MI. > Â > --- On Fri, 8/29/08, Pete Masterson > > From: Pete Masterson > Subject: Re: [WanderlodgeForum] Power Tech 15KW Motor & Blower > To: WanderlodgeForum@yahoogroups.com > Date: Friday, August 29, 2008, 5:02 PM > > > > > > > My squirrel cage fan failed last year. I removed the whole assembly > and took it to an electric motor shop where I asked them to fix or > replace the motor and rebalance the fan (look closely and you'll see > little bits of metal bent around some of the blades in the squirrel > cage). They found a replacement motor (as the OEM unit was long out > of existence), installed it, checked the balance of the fan, and > painted everything. I reinstalled the assembly in my coach. I don't > recall exactly what I paid (I'm on the road) but it was about $500 or > so... about double what Tom McCarthy paid in So. CA. (Typical SF Bay > Area prices, though...) > > Since you're in the middle of the country, you'll probably find a > more reasonable-priced vendor. > > Note: keep in mind that the motor is a 220 vac motor.... Also be sure > to check the capacitors, if they should fail, it might seem like the > motor is dead, when it is not. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@mac. com > On the road at Idaho Springs, CO > > On Aug 28, 2008, at 10:05 PM, Gregg Kizer wrote: > > > Has any one replaced their Power Tech 15KW Motor & Blower Assembly and > > what Part Numbers and source were your findings. Cost $$..etc..... . > > > > Would it be suggested to replace the whole assembly with motor or just > > the motor only. I think I have the motor with a winding to ground and > > need at least a motor replacement. Is Grainger the place to go? Pro & > > Cons of complete new assembly vs. just motor replacement from any ones > > experience in the generator problem department.. ... > > > > Regards > > > > Gregg > > 96 WLSD 42' > > New Castle, IN > > <snip> > |
