Broken Cord on Michelin Tire
09-07-2008, 05:05
Hi Everyone,
The left front tire on my coach has a broken cord. The tread is uneven. I am getting the tire replaced next week before I head out on a 1,500 mile trip. The tire only has 27,000 miles on it. Does anyone know if Michelin has a warranty on tires? Has anyone else had a problem with cord breakage on Michelins? Thanks, Randy Merrill 2003 40' Ocala, FL |
09-07-2008, 05:35
Randy,
What is the date of manufacture on your tire? Michelin has a warranty on tires, but has probably expired on yours due to age. If your tires are original on the WL, they probably are around 6 years old. Tires on an RV seldom wear out, but routinely have to be replaced due to age. That could be the case here.
Gary
SOB
09-07-2008, 05:47
Great that you caught this before a major problem. As it its a tire
failure, perhaps you should report it. See the link in this http://www.wanderlodgeownersgroup.com/fo...php?t=1422 Ross 2006 450 LXi > Hi Everyone, > > The left front tire on my coach has a broken cord. The tread is uneven. > I am getting the tire replaced next week before I head out on a 1,500 > mile trip. The tire only has 27,000 miles on it. Does anyone know if > Michelin has a warranty on tires? Has anyone else had a problem with > cord breakage on Michelins? > > Thanks, > > Randy Merrill > 2003 40' > Ocala, FL > |
09-08-2008, 02:35
Hi,
Just a note about reporting the "failure". The request by the NHTSA (national highway traffic safety assoc.) is for all failures, not just blow-outs. In the requested information, there is a line "Nature of the reported failure (slow leak,blow-out, worn etc)" This can be important for the safety of all BlueBirds and all RV's (especially those using 315 tires) Ross 2006 450 LXi Here is the information: http://nhthqnwws112.odi.nhtsa.dot.gov/ac...ts/20\ 08/RQ/INIM-RQ08004-29624.pdf --- In WanderlodgeForum@yahoogroups.com, "Randy Merrill" > > Hi Everyone, > > The left front tire on my coach has a broken cord. The tread is uneven. > I am getting the tire replaced next week before I head out on a 1,500 > mile trip. The tire only has 27,000 miles on it. Does anyone know if > Michelin has a warranty on tires? Has anyone else had a problem with > cord breakage on Michelins? > > Thanks, > > Randy Merrill > 2003 40' > Ocala, FL > |
09-08-2008, 04:21
you guys should find a trucker or trucking company to buy your tires
prior to 3 or 4 years of age. rotating out a set every year or so will put new one on the front of your bus and run the tread off the used tires. its a green thing to do because the tread will be used up and the casing will be good for a retread. Tire Jobbers, can set you up with good credit for rotating out your used tires. I screw cords up jumping curbs and potholes, kinda doubt it is a Mfg prorate thing. GregO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Ross" wrote: > > Hi, > Just a note about reporting the "failure". The request by the NHTSA > (national highway traffic safety assoc.) is for all failures, not just > blow-outs. In the requested information, there is a line > "Nature of the reported failure (slow leak,blow-out, worn etc)" This > can be important for the safety of all BlueBirds and all RV's > (especially those using 315 tires) > Ross > 2006 450 LXi > Here is the information: > http://nhthqnwws112.odi.nhtsa.dot.gov/ac...s/Public/P ursuits/2008/RQ/INIM-RQ08004-29624.pdf > > --- In WanderlodgeForum@yahoogroups.com, "Randy Merrill" > > > > > Hi Everyone, > > > > The left front tire on my coach has a broken cord. The tread is uneven. > > I am getting the tire replaced next week before I head out on a 1,500 > > mile trip. The tire only has 27,000 miles on it. Does anyone know if > > Michelin has a warranty on tires? Has anyone else had a problem with > > cord breakage on Michelins? > > > > Thanks, > > > > Randy Merrill > > 2003 40' > > Ocala, FL > > > |
09-08-2008, 04:40
I agree that the 'broken belt' thing is likely a result of a road
hazard. While I haven't had any problems with my Toyo tires on my coach, over the years, I've had a several tires on my automobile(s) ruined by construction -- Indeed, a few years ago, when BART was being built in the SF Bay Area, I lost several tires due to hitting pavement from a gravel stretch where a subway was being built using the cut-and-cover method. While I certainly tried to drive carefully through the extensive construction zones, at night there were times you just didn't see a transition until you hit it with that sickening thud. Often the tires don't actually display any problems until days (or weeks) after the damaging event. The damage occurs, then the flexing of the tire causes the damage to spread until the tire-cord is compromised. Michelin makes generally good, tough tires. It's always possible that a manufacturing defect was involved, but it's unlikely. More likely there was a road hazard event that let to the failure. In that case, most tire companies don't cover the damage (but some companies may cover road hazard damage), so you'll need to enquire with a Michelin dealer. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Idaho Springs, CO On Sep 8, 2008, at 10:21 AM, Gregory OConnor wrote: > you guys should find a trucker or trucking company to buy your tires > prior to 3 or 4 years of age. rotating out a set every year or so > will put new one on the front of your bus and run the tread off the > used tires. its a green thing to do because the tread will be used up > and the casing will be good for a retread. Tire Jobbers, can set you > up with good credit for rotating out your used tires. I screw cords > up jumping curbs and potholes, kinda doubt it is a Mfg prorate thing. > > GregO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Ross" > wrote: >> >> Hi, >> Just a note about reporting the "failure". The request by the NHTSA >> (national highway traffic safety assoc.) is for all failures, not > just >> blow-outs. In the requested information, there is a line >> "Nature of the reported failure (slow leak,blow-out, worn etc)" > This >> can be important for the safety of all BlueBirds and all RV's >> (especially those using 315 tires) >> Ross >> 2006 450 LXi >> Here is the information: >> > http://nhthqnwws112.odi.nhtsa.dot.gov/ac...s/Public/P > ursuits/2008/RQ/INIM-RQ08004-29624.pdf >> >> --- In WanderlodgeForum@yahoogroups.com, "Randy Merrill" >> >>> >>> Hi Everyone, >>> >>> The left front tire on my coach has a broken cord. The tread is > uneven. >>> I am getting the tire replaced next week before I head out on a > 1,500 >>> mile trip. The tire only has 27,000 miles on it. Does anyone know > if >>> Michelin has a warranty on tires? Has anyone else had a problem > with >>> cord breakage on Michelins? >>> >>> Thanks, >>> >>> Randy Merrill >>> 2003 40' >>> Ocala, FL >>> >> > > |
09-08-2008, 04:57
Question. I know that it is recommended to not run tires older then 8
to 10 years maximum. Approximately how many miles are these tires good for? I haven't heard that mentioned. If a guy runs about 10K per year can he expect to run out of tread long before the years add up? I don't typically get more then 35k on car tires I have no idea what to expect on the MH. I of course understand there are all kinds of variables to consider but as compared to a car what do you figure for tread life on the tires you run on your BB'ds? John Heckman central Pa 1973 FC > > you guys should find a trucker or trucking company to buy your tires > prior to 3 or 4 years of age. rotating out a set every year or so > will put new one on the front of your bus and run the tread off the > used tires. its a green thing to do because the tread will be used up > and the casing will be good for a retread. Tire Jobbers, can set you > up with good credit for rotating out your used tires. I screw cords > up jumping curbs and potholes, kinda doubt it is a Mfg prorate thing. > > GregO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Ross" > wrote: > > > > Hi, > > Just a note about reporting the "failure". The request by the NHTSA > > (national highway traffic safety assoc.) is for all failures, not > just > > blow-outs. In the requested information, there is a line > > "Nature of the reported failure (slow leak,blow-out, worn etc)" > This > > can be important for the safety of all BlueBirds and all RV's > > (especially those using 315 tires) > > Ross > > 2006 450 LXi > > Here is the information: > > > http://nhthqnwws112.odi.nhtsa.dot.gov/ac...s/Public/P > ursuits/2008/RQ/INIM-RQ08004-29624.pdf > > > > --- In WanderlodgeForum@yahoogroups.com, "Randy Merrill" > > > > > > > > Hi Everyone, > > > > > > The left front tire on my coach has a broken cord. The tread is > uneven. > > > I am getting the tire replaced next week before I head out on a > 1,500 > > > mile trip. The tire only has 27,000 miles on it. Does anyone know > if > > > Michelin has a warranty on tires? Has anyone else had a problem > with > > > cord breakage on Michelins? > > > > > > Thanks, > > > > > > Randy Merrill > > > 2003 40' > > > Ocala, FL > > > > > > |
09-08-2008, 05:26
Are highly inflated tires more prone to these failures? The recall
for the 450LXi specifies running tires at 130 psi. If the tire is at max inflation then it is less able to deflect to road discontinuities. Seems like you'll likely have more "broken belt" issues at max inflation??? David Brady '02 LXi, NV Pete Masterson wrote: > > I agree that the 'broken belt' thing is likely a result of a road > hazard. While I haven't had any problems with my Toyo tires on my > coach, over the years, I've had a several tires on my automobile(s) > ruined by construction -- Indeed, a few years ago, when BART was > being built in the SF Bay Area, I lost several tires due to hitting > pavement from a gravel stretch where a subway was being built using > the cut-and-cover method. While I certainly tried to drive carefully > through the extensive construction zones, at night there were times > you just didn't see a transition until you hit it with that sickening > thud. Often the tires don't actually display any problems until days > (or weeks) after the damaging event. The damage occurs, then the > flexing of the tire causes the damage to spread until the tire-cord > is compromised. > > Michelin makes generally good, tough tires. It's always possible that > a manufacturing defect was involved, but it's unlikely. More likely > there was a road hazard event that let to the failure. In that case, > most tire companies don't cover the damage (but some companies may > cover road hazard damage), so you'll need to enquire with a Michelin > dealer. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@mac. com > On the road at Idaho Springs, CO > > On Sep 8, 2008, at 10:21 AM, Gregory OConnor wrote: > > > you guys should find a trucker or trucking company to buy your tires > > prior to 3 or 4 years of age. rotating out a set every year or so > > will put new one on the front of your bus and run the tread off the > > used tires. its a green thing to do because the tread will be used up > > and the casing will be good for a retread. Tire Jobbers, can set you > > up with good credit for rotating out your used tires. I screw cords > > up jumping curbs and potholes, kinda doubt it is a Mfg prorate thing. > > > > GregO'Connor > > 94ptRomolandCa > > > > --- In WanderlodgeForum@ yahoogroups. com > > > wrote: > >> > >> Hi, > >> Just a note about reporting the "failure". The request by the NHTSA > >> (national highway traffic safety assoc.) is for all failures, not > > just > >> blow-outs. In the requested information, there is a line > >> "Nature of the reported failure (slow leak,blow-out, worn etc)" > > This > >> can be important for the safety of all BlueBirds and all RV's > >> (especially those using 315 tires) > >> Ross > >> 2006 450 LXi > >> Here is the information: > >> > > http://nhthqnwws112 .odi.nhtsa. dot.gov/acms/ docservlet/ > Artemis/Public/ P > <http://nhthqnwws112.odi.nhtsa.dot.gov/ac...s/Public/P> > > ursuits/2008/ RQ/INIM-RQ08004- 29624.pdf > >> > >> --- In WanderlodgeForum@ yahoogroups. com > > >> > >>> > >>> Hi Everyone, > >>> > >>> The left front tire on my coach has a broken cord. The tread is > > uneven. > >>> I am getting the tire replaced next week before I head out on a > > 1,500 > >>> mile trip. The tire only has 27,000 miles on it. Does anyone know > > if > >>> Michelin has a warranty on tires? Has anyone else had a problem > > with > >>> cord breakage on Michelins? > >>> > >>> Thanks, > >>> > >>> Randy Merrill > >>> 2003 40' > >>> Ocala, FL > >>> > >> > > > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.17/1655 - Release Date: 9/5/2008 7:05 PM > -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.6.17/1655 - Release Date: 9/5/2008 7:05 PM |
09-08-2008, 05:56
Good question David, I know that blow outs are more likely when the
tire is under inflated because the side walls are flexing and causing heat buildup which weakens the tire. There is some logic however to the thought that a maximally inflated tire might not handle the road hazard because of the inability to flex. On the other hand an under inflated tire might flex too much and result in a stretched or torn belt(right?). The air pressure does afford a cushion. So my suspicion is that a properly inflated tire (even if its maximum inflation) is the way to go. You would hope all this is factored into the tire design by the engineers who build the darned things. Just my logic which could easily be wrong. You would not want to inflate a tire over its max because I think your logic would certainly apply at that point. Another way to think of this is you have pressure pushing out from the inside (inflation pressure) vs forces from the out side which have to be kept in balance. John Heckman central Pa 1973 FC > > Are highly inflated tires more prone to these failures? The recall > for the 450LXi specifies running tires at 130 psi. If the tire is at > max inflation then it is less able to deflect to road discontinuities. > Seems like you'll likely have more "broken belt" issues at max > inflation??? > > David Brady > '02 LXi, NV > > Pete Masterson wrote: > > > > I agree that the 'broken belt' thing is likely a result of a road > > hazard. While I haven't had any problems with my Toyo tires on my > > coach, over the years, I've had a several tires on my automobile (s) > > ruined by construction -- Indeed, a few years ago, when BART was > > being built in the SF Bay Area, I lost several tires due to hitting > > pavement from a gravel stretch where a subway was being built using > > the cut-and-cover method. While I certainly tried to drive carefully > > through the extensive construction zones, at night there were times > > you just didn't see a transition until you hit it with that sickening > > thud. Often the tires don't actually display any problems until days > > (or weeks) after the damaging event. The damage occurs, then the > > flexing of the tire causes the damage to spread until the tire- cord > > is compromised. > > > > Michelin makes generally good, tough tires. It's always possible that > > a manufacturing defect was involved, but it's unlikely. More likely > > there was a road hazard event that let to the failure. In that case, > > most tire companies don't cover the damage (but some companies may > > cover road hazard damage), so you'll need to enquire with a Michelin > > dealer. > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > aeonix1@mac. com > > On the road at Idaho Springs, CO > > > > On Sep 8, 2008, at 10:21 AM, Gregory OConnor wrote: > > > > > you guys should find a trucker or trucking company to buy your tires > > > prior to 3 or 4 years of age. rotating out a set every year or so > > > will put new one on the front of your bus and run the tread off the > > > used tires. its a green thing to do because the tread will be used up > > > and the casing will be good for a retread. Tire Jobbers, can set you > > > up with good credit for rotating out your used tires. I screw cords > > > up jumping curbs and potholes, kinda doubt it is a Mfg prorate thing. > > > > > > GregO'Connor > > > 94ptRomolandCa > > > > > > --- In WanderlodgeForum@ yahoogroups. com > > > > > wrote: > > >> > > >> Hi, > > >> Just a note about reporting the "failure". The request by the NHTSA > > >> (national highway traffic safety assoc.) is for all failures, not > > > just > > >> blow-outs. In the requested information, there is a line > > >> "Nature of the reported failure (slow leak,blow-out, worn etc)" > > > This > > >> can be important for the safety of all BlueBirds and all RV's > > >> (especially those using 315 tires) > > >> Ross > > >> 2006 450 LXi > > >> Here is the information: > > >> > > > http://nhthqnwws112 .odi.nhtsa. dot.gov/acms/ docservlet/ > > Artemis/Public/ P > > <http://nhthqnwws112.odi.nhtsa.dot.gov/ac...is/Public/ P> > > > ursuits/2008/ RQ/INIM-RQ08004- 29624.pdf > > >> > > >> --- In WanderlodgeForum@ yahoogroups. com > > > > >> > > >>> > > >>> Hi Everyone, > > >>> > > >>> The left front tire on my coach has a broken cord. The tread is > > > uneven. > > >>> I am getting the tire replaced next week before I head out on a > > > 1,500 > > >>> mile trip. The tire only has 27,000 miles on it. Does anyone know > > > if > > >>> Michelin has a warranty on tires? Has anyone else had a problem > > > with > > >>> cord breakage on Michelins? > > >>> > > >>> Thanks, > > >>> > > >>> Randy Merrill > > >>> 2003 40' > > >>> Ocala, FL > > >>> > > >> > > > > > > > > > > > > ------------------------------------------------------------------ ------ > > > > No virus found in this incoming message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.6.17/1655 - Release Date: 9/5/2008 7:05 PM > > > > > > -- > No virus found in this outgoing message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.17/1655 - Release Date: 9/5/2008 7:05 PM > |
09-08-2008, 06:07
This is possibly one of the reasons for the mandatory reporting to NHTSA. The newer Wanderlodge has to be inflated to 130 psi for the load. All of them are very close to or over 17,000lbs. Inflating the tire to under 125 leaves it in an overloaded state. Throw in alignment issues-- failure. NHTSA has directed Blue Bird to supply a higher pressure auxillary air pump to allow 130 psi maintanence. Ross ----- Original Message ---- From: David Brady To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 8, 2008 1:26:54 PM Subject: Re: [WanderlodgeForum] Re: Broken Cord on Michelin Tire Are highly inflated tires more prone to these failures? The recall for the 450LXi specifies running tires at 130 psi. If the tire is at max inflation then it is less able to deflect to road discontinuities. Seems like you'll likely have more "broken belt" issues at max inflation??? David Brady '02 LXi, NV Pete Masterson wrote: > > I agree that the 'broken belt' thing is likely a result of a road > hazard. While I haven't had any problems with my Toyo tires on my > coach, over the years, I've had a several tires on my automobile(s) > ruined by construction -- Indeed, a few years ago, when BART was > being built in the SF Bay Area, I lost several tires due to hitting > pavement from a gravel stretch where a subway was being built using > the cut-and-cover method. While I certainly tried to drive carefully > through the extensive construction zones, at night there were times > you just didn't see a transition until you hit it with that sickening > thud. Often the tires don't actually display any problems until days > (or weeks) after the damaging event. The damage occurs, then the > flexing of the tire causes the damage to spread until the tire-cord > is compromised. > > Michelin makes generally good, tough tires. It's always possible that > a manufacturing defect was involved, but it's unlikely. More likely > there was a road hazard event that let to the failure. In that case, > most tire companies don't cover the damage (but some companies may > cover road hazard damage), so you'll need to enquire with a Michelin > dealer. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@mac. com > On the road at Idaho Springs, CO > > On Sep 8, 2008, at 10:21 AM, Gregory OConnor wrote: > > > you guys should find a trucker or trucking company to buy your tires > > prior to 3 or 4 years of age. rotating out a set every year or so > > will put new one on the front of your bus and run the tread off the > > used tires. its a green thing to do because the tread will be used up > > and the casing will be good for a retread. Tire Jobbers, can set you > > up with good credit for rotating out your used tires. I screw cords > > up jumping curbs and potholes, kinda doubt it is a Mfg prorate thing. > > > > GregO'Connor > > 94ptRomolandCa > > > > --- In WanderlodgeForum@ yahoogroups. com > > > wrote: > >> > >> Hi, > >> Just a note about reporting the "failure". The request by the NHTSA > >> (national highway traffic safety assoc.) is for all failures, not > > just > >> blow-outs. In the requested information, there is a line > >> "Nature of the reported failure (slow leak,blow-out, worn etc)" > > This > >> can be important for the safety of all BlueBirds and all RV's > >> (especially those using 315 tires) > >> Ross > >> 2006 450 LXi > >> Here is the information: > >> > > http://nhthqnwws112 .odi.nhtsa. dot.gov/acms/ docservlet/ > Artemis/Public/ P > <http://nhthqnwws112 .odi.nhtsa. dot.gov/acms/ docservlet/ Artemis/Public/ P> > > ursuits/2008/ RQ/INIM-RQ08004- 29624.pdf > >> > >> --- In WanderlodgeForum@ yahoogroups. com > > >> > >>> > >>> Hi Everyone, > >>> > >>> The left front tire on my coach has a broken cord. The tread is > > uneven. > >>> I am getting the tire replaced next week before I head out on a > > 1,500 > >>> mile trip. The tire only has 27,000 miles on it. Does anyone know > > if > >>> Michelin has a warranty on tires? Has anyone else had a problem > > with > >>> cord breakage on Michelins? > >>> > >>> Thanks, > >>> > >>> Randy Merrill > >>> 2003 40' > >>> Ocala, FL > >>> > >> > > > > > > > ------------ --------- --------- --------- --------- --------- - > > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.17/1655 - Release Date: 9/5/2008 7:05 PM > -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.6.17/1655 - Release Date: 9/5/2008 7:05 PM Now with a new friend-happy design! Try the new Yahoo! Canada Messenger |
