Water Pumps & Holding Tanks
09-10-2008, 17:15
I don't like the sound of blowing air from the coach systems, brakes,
air bags, steps etc. into the fresh water system. Anymore than the
idea of the water system blowing water into the air system.
I think maybe air line fittings with the integral schrader valve, on
each end of the tubing would solve the problem fast, easy and
inexpensive. It would be easy to reattach the tubes in the event you
had to use it.
With the schrader valves you could just air purge the water system
from a cleaner air source than from the coach.
Kurt Horvath
95 PT-42
10AC
> The way the system works is this.
> Air is introduced into the water system to blow out excess water
for winterization. There should be a check valve near the regulator
which prevents water from back flowing into the aux air system. In
most coaches that air system includes the air horns, air step , air
bags, driving lights, aux air pump, bulk oil fill, fresh air vent
system and who knows what else. This check valve is a serious weak
link in BB's. If air can be introduced into the water system to blow
it out, water can be introduced into the aux air system in the event
of a check valve failure. The check valve is the only line of
defense. The air regulator will not prevent water back flow and
neither will the purge air switch.
> There are a couple of choices. Disconnect the air purge system at
the purifier or water filter where ever it is installed and plug it
or install a ball valve above the check valve which separates water
and air and keep it shut off unless used for winterization.
> Everyone who has this system needs to do one or the other. Leaving
it the way it is is not an option in my opinion. I have installed a
ball valve. It is cheap and easy and leaves the original system
intact.
> Leroy Eckert
> 1990 WB-40 Smoke N Mirrors
> Dahlonega, GA
> Royale Conversion
> --- On Wed, 9/10/08, Kurt Horvath wrote:
> From: Kurt Horvath
> Subject: [WanderlodgeForum] Re: Water Pumps & Holding Tanks
> Date: Wednesday, September 10, 2008, 11:48 PM
> Thanks Guys,
> I think your right, It could be a real problem if water flowed into
> the airlines and tanks. I would imagine that a failure in the valve
> would cause an unsafe condition. In my case the pumps are always
on,
> but the air system is not always charged, I see where a back flow
of
> water would mess up the mix.
> Would it be advisable to unhook the air line and plug it?
> I never winterize my coach she's plugged in and heated, we try to
run
> year round.
> Kurt Horvath
> 95 PT-42
> 10AC
> --- In WanderlodgeForum@ yahoogroups. com, Leroy Eckert
> > Where is the picture. My regulator looks like one on a standard
air
> compressor used to adjust the air exiting the hose.
> > I am going to do a post on this issue. The purge air system is a
> weak link in all BB's with winterization blow out systems. Be
> careful, you can create yourself one hell of a problem.
> > Leroy Eckert
> > Dahlonega, GA
> > Royale Conversion
> > From: Kurt Horvath
> > To: WanderlodgeForum@ yahoogroups. com
> > Date: Wednesday, September 10, 2008, 11:11 PM
> > Leroy,
> > I posted a picture of the regulator in question. Let me know what
> you
> > think.
> > Jay Darst, sorry somehow I manged to post my picture in your
album
> > and I couldn't delet it :{
> > kurt Horvath
> > 95 PT-42
> > 10AC
> > wrote:
> > > Your coach is much newer than mine. That said, that little
> > regulator you are talking about on the filter could be the air
> > regulator for the winterizing blow out system. Better check it
out
> > closely. You screw that up, a check valve goes bad and it can
load
> up
> > water in the aux air system. You don't even want that to happen
> I
> > assure you will not like the result.. I am serious. Be careful
with
> > that deal and trace the lines down before doing mods. Mine has an
> > additional ball valve added to prevent the problem.
> > > My Splendide dumps into the black tank. The best thing that
> could
> > ever happen to a black tank.
> > > Leroy Eckert
> > > Danlonega, GA
> > > Royale Conversion
> > > From: Kurt Horvath
> > > Subject: [WanderlodgeForum] Water Pumps & Holding Tanks
> > > Date: Wednesday, September 10, 2008, 10:18 PM
> > > I started the re-build on the water pumps today.
I'm
> > happy one of the
> > > pumps failed. What a mess, I'll post before and after shots
when
> I
> > > get it finished. I have reduced the number on elbows by 80%.
> That
> > > should greatly increase the pumps efficiency.
> > > I took the metal cover off the curb side tank bay just to make
> sure
> > > all the pushing and pulling on the pipes didn't loosen
anything.
> > Well
> > > of course that just presented more opportunities to fix and
> upgrade.
> > > The water filter was the first thing that jumped out at me, I
> will
> > > take it out and backwash the filter. I would like to replace
it.
> > I'm
> > > sure it's original equipment = 13 + years old. The thing I
don't
> > know
> > > anything about is the little pressure regulator or whatever it
> is,
> > > mounted to the top of the filter. Obviously it increases or
> > decrease
> > > pressure but to what end? Also the water pipes are routed to
> > > looped around it, so I'm guessing this filters water to a
> specific
> > > place. Does anyone know to where?
> > > I would like to install a gray water tank over flow pipe. Last
> year
> > I
> > > ran a load of laundry and went to breakfast with some friends,
a
> > > short time latter a call on the cell and my neighbor was
telling
> me
> > > that the coach was leaking. I ask from where and he responded
> with
> > > EVERYWHERE! Well anyway no permanent damage. I thought of
dumping
> > the
> > > Slendide washer/dryer, but I like it. So I never have that
> problem
> > > again a grey water tank over flow pipe is in the future. I'm
sure
> > > someone will chime in with the perils of dumping greywater on
> > > ground. That's not my intention, my intention is to never fill
> the
> > > interior of my coach with gray water again.
> > > Kurt Horvath
> > > 95-PT 42 WLWB
> > > 10AC
09-11-2008, 07:08
Leroy
I have re-plumbed the Air Purge system with 1/4 air lines and routed
them through to the water pump bay, put a Schraeder valve on the
water filter side and closed the regulator in case the air purge
switch gets turned on accidentally. Now it can be purge it from a
clean air source. More importantly there is no chance of water
getting into the air systems.
Just about have the water pump bay finished. It is re-plumbed and the
new accumulator tank is in and charged to 25 psi. Just have to put
the pumps in and hook them up. I mounted them to a separate sheet of
3/4 plywood so they could be easily remove to be serviced. I used
reinforced vinyl tubing 210 psi to hook the pumps up to the rest of
the system using Sea-Tech also known as Watts WaterPEX quick connect
fittings. They can be used with PEX, CPVC, Copper and the dreaded
Polybutalyne, you'll need the plastic insert with the Poly. Man are
these puppies neat they just slip together and they will rotate so if
your like me and once you've glued together the pipes and you miss
calculated an angle, there is no problem. They come apart easily and
will facilitate any future repairs.
The drain pipe for the washer is on the curb side above the rear tank
and crosses over to the front tank, into the top of the tank, but
there is a second drain pipe next to it descending to the top of the
Black tank. I'll have to do some investigating. It would be easier to
put a T in the pipe and plumb from there instead of trying to go
through the top of tank..
Kurt Horvath
95 PT-42 WLWB
10AC
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
brakes,
> idea of the water system pumping water into the air system.
> I think maybe air line fittings with the integral schrader valve on
> each end of the tubing would solve the problem fast,easy and
you
> had to use it.
> Kurt Horvath
> 95 PT-42
> 10AC
blow
event
Leaving
> intact.
> > Leroy Eckert
> > Dahlonega, GA
> > Royale Conversion
> > From: Kurt Horvath
> > Thanks Guys,
into
valve
> on,
> of
> run
> > year round.
> > Kurt Horvath
> > 95 PT-42
> > 10AC
> air
a
> > > Leroy Eckert
> > > Dahlonega, GA
> > > Royale Conversion
> > > From: Kurt Horvath
> > > Leroy,
what
> > you
> > > think.
> album
> > > kurt Horvath
> > > 95 PT-42
> > > 10AC
> out
> load
> > up
> and
> > I
> with
an
> > could
> > > > Leroy Eckert
> > > > Danlonega, GA
> > > > Royale Conversion
> > > > From: Kurt Horvath
> I'm
> > > happy one of the
> when
> > I
> > That
make
> > sure
> anything.
> > > Well
> > upgrade.
> > will
> it.
> > > I'm
> don't
> > > know
it
> > is,
> > > decrease
> and
> > specific
Last
> > year
> > > I
friends,
> a
> telling
> > me
> > with
> dumping
> > > the
> > problem
> sure
> the
fill
> > the
> > > > Kurt Horvath
> > > > 95-PT 42 WLWB
> > > > 10AC
09-11-2008, 07:45
If I understand it correctly all should be well with the possible exception of a failed check valve that should be attached to the air regulator. Theoretically, I guess, with the air regulator closed completely and a failed check valve, water would not get be able to flood the coach. One way to be certain, and it may be overkill, would be to plug both the purge air line from the switch to the regulator and plug the air inlet side of the regulator as it will never be used again due to the installation of the Schraeder valve. I also removed the old nylon air lines and replaced with 1/4" flared copper.
I have found that my washer/dryer (curb side) which is plumbed into the curb side black tank keeps that tank very clean. It is backwards from my prints. Kitchen sink and shower (road side)go into the gray tank, and washer/dryer and bathroom sink and
toilet to the black tank. This configuration also balances out the tank volume and usage. I have never had any real issues with the monitors either apparently because they remain clean.
I will state one more time. For those who have an purge air system it would be prudent to perform a minor change to protect the aux air system from water flooding in the event of a check valve failure. If anyone needs real time info on this subject I am sure I am not out of line saying James Barone still has issues because his aux system flooded due to this very problem. I also think Bill Pape in MI has modified his and when he did found a very iffy check valve.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Date: Thursday, September 11, 2008, 3:08 PM
Leroy
Kurt Horvath
95 PT-42 WLWB
10AC
--- In "WanderlodgeForum%40yahoogroups.com", "Kurt Horvath"
brakes,
you
> had to use it.
> Kurt Horvath
> 95 PT-42
> 10AC
> --- In "WanderlodgeForum%40yahoogroups.com", Leroy Eckert
blow
event
Leaving
> intact.
> > Leroy Eckert
> > Dahlonega, GA
> > Royale Conversion
> > From: Kurt Horvath
> > To: "WanderlodgeForum%40yahoogroups.com"
> > Thanks Guys,
into
valve
> on,
> of
> run
> > year round.
> > Kurt Horvath
> > 95 PT-42
> > 10AC
> air
a
> > > Leroy Eckert
> > > Dahlonega, GA
> > > Royale Conversion
> > > From: Kurt Horvath
> > > Leroy,
what
> > you
> > > think.
> album
> > > kurt Horvath
> > > 95 PT-42
> > > 10AC
> out
> load
> > up
> and
> > I
> with
an
> > could
> > > > Leroy Eckert
> > > > Danlonega, GA
> > > > Royale Conversion
> > > > From: Kurt Horvath
> I'm
> > > happy one of the
> when
> > I
> > That
make
> > sure
> anything.
> > > Well
> > upgrade.
> > will
> it.
> > > I'm
> don't
> > > know
it
> > is,
> > > decrease
> and
> > specific
Last
> > year
> > > I
friends,
> a
> telling
> > me
> > with
> dumping
> > > the
> > problem
> sure
> the
fill
> > the
> > > > Kurt Horvath
> > > > 95-PT 42 WLWB
> > > > 10AC
09-11-2008, 09:09
--Leroy,
I posted two more photos, Home page, click on new photos or in my
album Bumpersbird last two pics. As you can see, I installed a 1/4
air line for each device, one for the water filter and one for the
regulator. I ran them through the tunnel into the pump bay and tied
them up to the pipe with the Spolan Valve. The line with the
schraeder valve is the water filter line and it has to be blocked or
it will dump water once the system is active.. The other line is open
and is cut off by the regulator and the control switch in the dump
bay. The two are no longer connected. If you really needed to you
could simply use a ¼ air line connector and reestablish the Air Purge
capability. I hadn't thought of it before but you would need to
regulate the air pressure if you were to use an outside air source,
you would want to blow the plumbing apart!
Kurt Horvath
95 PT-42
10AC
tank, and washer/dryer and bathroom sink and toilet to the black
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: Kurt Horvath
> Leroy
routed
of
connect
if
tank
to
> Kurt Horvath
> 95 PT-42 WLWB
> 10AC
> --- In WanderlodgeForum@ yahoogroups. com, "Kurt Horvath"
> brakes,
on
> you
> > had to use it.
system
> > Kurt Horvath
> > 95 PT-42
> > 10AC
water
regulator
In
air
weak
> blow
> event
at
it
water
> Leaving
a
> > intact.
> > > Leroy Eckert
> > > Dahlonega, GA
> > > Royale Conversion
> > > From: Kurt Horvath
> > > Thanks Guys,
> into
> valve
always
> > on,
flow
> > of
to
> > run
> > > year round.
> > > Kurt Horvath
> > > 95 PT-42
> > > 10AC
standard
> > air
is
> a
> > > > Leroy Eckert
> > > > Dahlonega, GA
> > > > Royale Conversion
> > > > From: Kurt Horvath
> > > > Leroy,
> what
> > > you
> > > > think.
> > album
> > > > kurt Horvath
> > > > 95 PT-42
> > > > 10AC
air
it
> > out
> > load
> > > up
happen
> > and
> > > I
careful
> > with
has
> an
that
> > > could
> > > > > Leroy Eckert
> > > > > Danlonega, GA
> > > > > Royale Conversion
> > > > > From: Kurt Horvath
today.
> > I'm
> > > > happy one of the
> > when
> > > I
80%.
> > > That
> make
> > > sure
> > anything.
> > > > Well
> > > upgrade.
I
> > > will
replace
> > it.
> > > > I'm
> > don't
> > > > know
> it
> > > is,
> > > > decrease
to
> > and
> > > specific
> Last
> > > year
> > > > I
> friends,
> > a
> > telling
> > > me
responded
> > > with
> > dumping
> > > > the
> > > problem
I'm
> > sure
on
> > the
> fill
> > > the
> > > > > Kurt Horvath
> > > > > 95-PT 42 WLWB
> > > > > 10AC
09-11-2008, 12:03
I see, that should be fine. BB did a fine job thinking through the manufacture of these coaches. Even today they rate far beyond others. Personally, I have some different off the wall theories all of which are based on my personal experience with the coach. So far they have worked. IMO, an air purge system is not required. The low point drain on my coach is in the Propane tank bay. Open that faucet and the two drains in the bedroom, one for the water heater and the other for the pure water tank and there is nothing left. In winter I leave the outside faucet open. Even with residual water in a line there is plenty of room for expansion in the event residual ice forms. With hydronic heat, that has not happened and it's survived 10 degrees.
On another issue. GregO's scoop theory agrees with what I have found.There is a vacuum around the coach at normal
speeds. I didn't use water gauges or ribbons. I used smoke.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Date: Thursday, September 11, 2008, 5:09 PM
--Leroy,
Kurt Horvath
95 PT-42
10AC
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: Kurt Horvath
> Leroy
routed
of
connect
if
tank
to
> Kurt Horvath
> 95 PT-42 WLWB
> 10AC
> brakes,
on
> you
> > had to use it.
system
> > Kurt Horvath
> > 95 PT-42
> > 10AC
water
regulator
In
air
weak
> blow
> event
at
it
water
> Leaving
a
> > intact.
> > > Leroy Eckert
> > > Dahlonega, GA
> > > Royale Conversion
> > > From: Kurt Horvath
> > > Thanks Guys,
> into
> valve
always
> > on,
flow
> > of
to
> > run
> > > year round.
> > > Kurt Horvath
> > > 95 PT-42
> > > 10AC
standard
> > air
is
> a
> > > > Leroy Eckert
> > > > Dahlonega, GA
> > > > Royale Conversion
> > > > From: Kurt Horvath
> > > > Leroy,
> what
> > > you
> > > > think.
> > album
> > > > kurt Horvath
> > > > 95 PT-42
> > > > 10AC
air
it
> > out
> > load
> > > up
happen
> > and
> > > I
careful
> > with
has
> an
that
> > > could
> > > > > Leroy Eckert
> > > > > Danlonega, GA
> > > > > Royale Conversion
> > > > > From: Kurt Horvath
today.
> > I'm
> > > > happy one of the
> > when
> > > I
80%.
> > > That
> make
> > > sure
> > anything.
> > > > Well
> > > upgrade.
I
> > > will
replace
> > it.
> > > > I'm
> > don't
> > > > know
> it
> > > is,
> > > > decrease
to
> > and
> > > specific
> Last
> > > year
> > > > I
> friends,
> > a
> > telling
> > > me
responded
> > > with
> > dumping
> > > > the
> > > problem
I'm
> > sure
on
> > the
> fill
> > > the
> > > > > Kurt Horvath
> > > > > 95-PT 42 WLWB
> > > > > 10AC
