Bay door spring studs & nuts
09-11-2008, 09:12
I broke one of the ball studs that attach the gas spring or strut to the door.
After replacing it ,I discovered that the other studs on some doors had backed off from the attaching nut. This may be some thing all of us should check,one reason being that door hurts when it comes down on your HEAD!!
If you need to take it apart,lube the ball before assembly and get some new 5/16 lock nuts.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
09-11-2008, 09:48
Fred,
Good advice for sure. Something to add to the annual maintenance list.
Fred & Jeanne Hulse
Morristown Arizona
Curt Sprenger
Anaheim Hills, CA
