Adding Satellite dish
09-11-2008, 16:00
Hi there,
I am going to add a in-motion satellite dish and wonder if there are any special tricks to make it work well. I am looking at King Dome 9762-LP from Kingdom2.com for 995.00 which is for a factory refurbished unit. I talked to Curt and he said that his dome was mounted to a plate and then the plate was bolted to the roof where they had welded some nuts on. When mounting, do you just drill thru roof plate and into bus roof and seal on top and will that also seal the hole in the bus roof under the diamond roof plate? Any help will be greatly appreciated Thanks Paul Potter 1987 PT38 Hesperia CA |
09-11-2008, 23:10
DO NOT drill through the roof
it is only necessary to drill the tread plate laying on the roof\ you can anchor it there Stephen 77fc 35 --- In WanderlodgeForum@yahoogroups.com, "ppotter14950" wrote: > > Hi there, > > I am going to add a in-motion satellite dish and wonder if there are > any special tricks to make it work well. I am looking at King Dome > 9762-LP from Kingdom2.com for 995.00 which is for a factory > refurbished unit. I talked to Curt and he said that his dome was > mounted to a plate and then the plate was bolted to the roof where > they had welded some nuts on. > > When mounting, do you just drill thru roof plate and into bus roof and > seal on top and will that also seal the hole in the bus roof under the > diamond roof plate? > > Any help will be greatly appreciated > > Thanks > > Paul Potter > 1987 PT38 > Hesperia CA > |
09-12-2008, 00:40
Clarification. Our satellite dish is mounted to aluminum plates. Those plates are welded to the roof aluminum tread plate.
On Fri, Sep 12, 2008 at 4:10 AM, Stephen Birtles <"cape0001@hotmail.com"> wrote:
09-13-2008, 01:04
wrote: > > Hi there, Paul I mounted my Motosat behind the forward vent and ran the cables in the same hole the tv cables went through the roof.Lee Condosta 85 PT 40 Holden Beach N.C > I am going to add a in-motion satellite dish and wonder if there are > any special tricks to make it work well. I am looking at King Dome > 9762-LP from Kingdom2.com for 995.00 which is for a factory > refurbished unit. I talked to Curt and he said that his dome was > mounted to a plate and then the plate was bolted to the roof where > they had welded some nuts on. > > When mounting, do you just drill thru roof plate and into bus roof and > seal on top and will that also seal the hole in the bus roof under the > diamond roof plate? > > Any help will be greatly appreciated > > Thanks > > Paul Potter > 1987 PT38 > Hesperia CA > |
09-14-2008, 14:57
don't drill through the roof only the diamond plate!
Curt Sprenger
09-14-2008, 15:16
Will you use an in motion? I have a Motosat that I spent over a
grand repairing. the Factory tech said he can sell me their infalable, top notch unit refurbished for a grand. My question was "if it was infalable why were they returned to be repaired???? We dont use it much while driving. I wouldnt by inmo to start because of need . but your need may differ. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "ppotter14950" > > Hi there, > > I am going to add a in-motion satellite dish and wonder if there are > any special tricks to make it work well. I am looking at King Dome > 9762-LP from Kingdom2.com for 995.00 which is for a factory > refurbished unit. I talked to Curt and he said that his dome was > mounted to a plate and then the plate was bolted to the roof where > they had welded some nuts on. > > When mounting, do you just drill thru roof plate and into bus roof and > seal on top and will that also seal the hole in the bus roof under the > diamond roof plate? > > Any help will be greatly appreciated > > Thanks > > Paul Potter > 1987 PT38 > Hesperia CA > |
09-14-2008, 16:36
I don’t know that we will use it Paul 87pt38 Hesperia ca From: Will you use an in motion? I have a Motosat that I spent over a grand repairing. the Factory tech said he can sell me their infalable, top notch unit refurbished for a grand. My question was "if it was infalable why were they returned to be repaired???? We dont use it much while driving. I wouldnt by inmo to start because of need . but your need may differ. GregoryO'Connor 94ptRomolandCa --- In "WanderlodgeForum%40yahoogroups.com", "ppotter14950" > > Hi there, > > I am going to add a in-motion satellite dish and wonder if there are > any special tricks to make it work well. I am looking at King Dome > 9762-LP from Kingdom2.com for 995.00 which is for a factory > refurbished unit. I talked to Curt and he said that his dome was > mounted to a plate and then the plate was bolted to the roof where > they had welded some nuts on. > > When mounting, do you just drill thru roof plate and into bus roof and > seal on top and will that also seal the hole in the bus roof under the > diamond roof plate? > > Any help will be greatly appreciated > > Thanks > > > 1987 PT38 > Hesperia CA > |
09-14-2008, 22:03
It is a tough decision. The compromises with an in-motion unit are significant -
they always work less-well than an open-face unit. Why? Because with satellite, dish size is important, and in-motion have the smallest dishes of them all. However, if reception while under-way is an important criteria the compromise may be worth it. For me, I decided 3 years ago, which was prior to my BB days, that I would not buy any more TV items for home or coach that was not HD-compatible. For DirecTV that would have ruled out in-motion as well, although it is at least technically possible to do in-motion TV with Dish network. For in-motion listening Sirius or XM does the job nicely. Don Bradner 90 PT40 "Blue Thunder" Motosat SL-5 HD and Sirius radio Posting today by satellite from Lexington, VA On 9/14/2008 at 9:36 PM P & D wrote: >I don't know that we will use it much, but we enjoy listening to cnn and >when we take the grand kids it will be nice, but we figure for 400 more >than >a fixed unit it was worth the extra money. > > > >Paul > >87pt38 > >Hesperia ca > > > > _____ > >From: WanderlodgeForum@yahoogroups.com >[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gregory OConnor >Sent: Sunday, September 14, 2008 8:17 PM >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Adding Satellite dish > > > >Will you use an in motion? I have a Motosat that I spent over a >grand repairing. the Factory tech said he can sell me their >infalable, top notch unit refurbished for a grand. My question >was "if it was infalable why were they returned to be repaired???? >We dont use it much while driving. I wouldnt by inmo to start >because of need . but your need may differ. >GregoryO'Connor >94ptRomolandCa > >--- In WanderlodgeForum@ >yahoogroups.com, "ppotter14950" > >> >> Hi there, >> >> I am going to add a in-motion satellite dish and wonder if there >are >> any special tricks to make it work well. I am looking at King >Dome >> 9762-LP from Kingdom2.com for 995.00 which is for a factory >> refurbished unit. I talked to Curt and he said that his dome was >> mounted to a plate and then the plate was bolted to the roof where >> they had welded some nuts on. >> >> When mounting, do you just drill thru roof plate and into bus roof >and >> seal on top and will that also seal the hole in the bus roof under >the >> diamond roof plate? >> >> Any help will be greatly appreciated >> >> Thanks >> >> Paul Potter >> 1987 PT38 >> Hesperia CA >> |
09-14-2008, 22:54
Install XM radio...can also 'watch' 150 stations along with CNN.
Dick Gideon 89 35FC Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > It is a tough decision. The compromises with an in-motion unit are significant - they always work less-well than an open-face unit. Why? Because with satellite, dish size is important, and in-motion have the smallest dishes of them all. However, if reception while under- way is an important criteria the compromise may be worth it. > > For me, I decided 3 years ago, which was prior to my BB days, that I would not buy any more TV items for home or coach that was not HD- compatible. For DirecTV that would have ruled out in-motion as well, although it is at least technically possible to do in-motion TV with Dish network. > > For in-motion listening Sirius or XM does the job nicely. > > Don Bradner > 90 PT40 "Blue Thunder" > Motosat SL-5 HD and Sirius radio > Posting today by satellite from Lexington, VA > > > On 9/14/2008 at 9:36 PM P & D wrote: > > >I don't know that we will use it much, but we enjoy listening to cnn and > >when we take the grand kids it will be nice, but we figure for 400 more > >than > >a fixed unit it was worth the extra money. > > > > > > > >Paul > > > >87pt38 > > > >Hesperia ca > > > > > > > > _____ > > > >From: WanderlodgeForum@yahoogroups.com > >[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gregory OConnor > >Sent: Sunday, September 14, 2008 8:17 PM > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Re: Adding Satellite dish > > > > > > > >Will you use an in motion? I have a Motosat that I spent over a > >grand repairing. the Factory tech said he can sell me their > >infalable, top notch unit refurbished for a grand. My question > >was "if it was infalable why were they returned to be repaired???? > >We dont use it much while driving. I wouldnt by inmo to start > >because of need . but your need may differ. > >GregoryO'Connor > >94ptRomolandCa > > > >--- In WanderlodgeForum@ > >yahoogroups.com, "ppotter14950" > > > >> > >> Hi there, > >> > >> I am going to add a in-motion satellite dish and wonder if there > >are > >> any special tricks to make it work well. I am looking at King > >Dome > >> 9762-LP from Kingdom2.com for 995.00 which is for a factory > >> refurbished unit. I talked to Curt and he said that his dome was > >> mounted to a plate and then the plate was bolted to the roof where > >> they had welded some nuts on. > >> > >> When mounting, do you just drill thru roof plate and into bus roof > >and > >> seal on top and will that also seal the hole in the bus roof under > >the > >> diamond roof plate? > >> > >> Any help will be greatly appreciated > >> > >> Thanks > >> > >> Paul Potter > >> 1987 PT38 > >> Hesperia CA > >> > |
09-15-2008, 03:39
Don,
I didn't quite understand the part about Direct TV. Was it the part about Hi-Def. or that it wouldn't work with the in motion unit. I had Dish Net in the house and when I tried to get it in the coach they said no way Jose. I asked Direct for in motion service for the coach and they answered no problem, then gave me a better deal than Dish for the house, shop, and coach. $98.00 for 180 channels + 50 movie channels, XM and a bunch of other stuff I never watch or listen to. I can't tell the difference in reception from base station dish, house and shop or in-motion,coach, they both work great. Kurt Horvath 95 PT-42 10AC --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > It is a tough decision. The compromises with an in-motion unit are significant - they always work less-well than an open-face unit. Why? Because with satellite, dish size is important, and in-motion have the smallest dishes of them all. However, if reception while under- way is an important criteria the compromise may be worth it. > > For me, I decided 3 years ago, which was prior to my BB days, that I would not buy any more TV items for home or coach that was not HD- compatible. For DirecTV that would have ruled out in-motion as well, although it is at least technically possible to do in-motion TV with Dish network. > > For in-motion listening Sirius or XM does the job nicely. > > Don Bradner > 90 PT40 "Blue Thunder" > Motosat SL-5 HD and Sirius radio > Posting today by satellite from Lexington, VA > > > On 9/14/2008 at 9:36 PM P & D wrote: > > >I don't know that we will use it much, but we enjoy listening to cnn and > >when we take the grand kids it will be nice, but we figure for 400 more > >than > >a fixed unit it was worth the extra money. > > > > > > > >Paul > > > >87pt38 > > > >Hesperia ca > > > > > > > > _____ > > > >From: WanderlodgeForum@yahoogroups.com > >[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gregory OConnor > >Sent: Sunday, September 14, 2008 8:17 PM > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Re: Adding Satellite dish > > > > > > > >Will you use an in motion? I have a Motosat that I spent over a > >grand repairing. the Factory tech said he can sell me their > >infalable, top notch unit refurbished for a grand. My question > >was "if it was infalable why were they returned to be repaired???? > >We dont use it much while driving. I wouldnt by inmo to start > >because of need . but your need may differ. > >GregoryO'Connor > >94ptRomolandCa > > > >--- In WanderlodgeForum@ > >yahoogroups.com, "ppotter14950" > > > >> > >> Hi there, > >> > >> I am going to add a in-motion satellite dish and wonder if there > >are > >> any special tricks to make it work well. I am looking at King > >Dome > >> 9762-LP from Kingdom2.com for 995.00 which is for a factory > >> refurbished unit. I talked to Curt and he said that his dome was > >> mounted to a plate and then the plate was bolted to the roof where > >> they had welded some nuts on. > >> > >> When mounting, do you just drill thru roof plate and into bus roof > >and > >> seal on top and will that also seal the hole in the bus roof under > >the > >> diamond roof plate? > >> > >> Any help will be greatly appreciated > >> > >> Thanks > >> > >> Paul Potter > >> 1987 PT38 > >> Hesperia CA > >> > |
